JVC Calibration Software V6 For 2015 Models (X9000,X7000,X5000,RS400,RS500,RS600) - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 1256Likes
post #541 of 4238 Old 06-10-2016, 11:41 AM
atabea's Avatar
Quoted: 775 Post(s)
Liked: 668
Quick question: I use my Samsung UHD Player strictly for HDR stuff and I use my Samsung F7500 strictly for blu-ray. My UHD player is hooked up directly to the RS500 via HDMI 1 and the F7500 directly to HDMI 2. When I ran the JVC autocal, I had the JVC on HDMI 1 throughout the whole process. What I was wondering is whether the calibration for the REC709NF, which is on HDMI 2, would still apply. Just want to know if I have to re-run the process on their respective/dedicated inputs.
atabea is offline
post #542 of 4238 Old 06-10-2016, 11:44 AM - Thread Starter
Manni01's Avatar
Quoted: 5653 Post(s)
Liked: 5982
AFAIK the profiles are not input dependent but some settings, like the HDMI settings and possibly others are, so you might want to double check that every setting and user setting uses the correct options.
There shouldn't be any need to re-run the JVC Autocal.
atabea likes this.
Manni01 is online now
post #543 of 4238 Old 06-10-2016, 11:46 AM
Mike Garrett's Avatar
Quoted: 12707 Post(s)
Liked: 10328
You should be calibrated, but like Manni said, setting like MPC and such have to be manually set per input.
atabea likes this.
Mike Garrett is offline
post #544 of 4238 Old 06-10-2016, 12:03 PM
atabea's Avatar
Quoted: 775 Post(s)
Liked: 668
Thanks, Manni and Mike, that's good to know.
atabea is offline
post #545 of 4238 Old 06-10-2016, 04:43 PM
brbecker's Avatar
Quoted: 24 Post(s)
Manni01,
I just completed a new calibration following your updated procedure. The Bluray calibration look great! Could you tell me if the BT2020 attachments show a successful calibration..thanks.
ID:	1490305   Click image for larger version
ID:	1490313   Click image for larger version
ID:	1490321   Click image for larger version
brbecker is offline
post #546 of 4238 Old 06-10-2016, 05:42 PM
Dave Vaughn's Avatar
Quoted: 1485 Post(s)
Liked: 2307
Originally Posted by brbecker View Post
Manni01,
Your gamma is not correct. You need to redo it and make sure the meter is placed on the further most point of the rectangular box during the calibration.
Manni01 likes this.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
Dave Vaughn is offline
post #547 of 4238 Old 06-10-2016, 05:52 PM
brbecker's Avatar
Quoted: 24 Post(s)
Dave it was..?????
brbecker is offline
post #548 of 4238 Old 06-10-2016, 05:54 PM
Liked: 2307
Manni is the expert here, but I know it shouldn't be an S-curve. It should be along that line going up from left to right. You may want to retry and double-check the settings that Manni provides.
mariob33 and Manni01 like this.
post #549 of 4238 Old 06-10-2016, 06:35 PM
mariob33's Avatar
Quoted: 146 Post(s)
Liked: 103
Send a message via Skype™ to mariob33
Manni01,
your gamma is off should be a straight line..two possibilities,
1. perhaps because your trying to calibrate against GAMMA D. I am not sure this is possible.
2. Make sure you didn't leave the dynamic iris on.
In search of video bliss...
mariob33 is offline
post #550 of 4238 Old 06-10-2016, 06:51 PM
brbecker's Avatar
Quoted: 24 Post(s)
Thanks Dave that's what I thought...
brbecker is offline
post #551 of 4238 Old 06-10-2016, 06:52 PM
brbecker's Avatar
Quoted: 24 Post(s)
mariob33 dynamic iris was off I think...will check...
brbecker is offline
post #552 of 4238 Old 06-10-2016, 06:57 PM
atabea's Avatar
Quoted: 775 Post(s)
Liked: 668
That "S" curve happened to me too and it is definitely wrong. I think I got that incorrect result when I selected Gama D while calibrating the BT2020 profile. you have to select something like normal gamma for it to work
atabea is offline
post #553 of 4238 Old 06-10-2016, 07:28 PM
IMDave's Avatar
Quoted: 137 Post(s)
Liked: 158
From Manni a couple of pages back:
" You can't measure gamma D without a pattenrn generator able to switch the PJ in HDR mode and a way to use an EOTF correct for a projector, which calibration software haven't sorted out yet (Calman should hopefully come up with something this month so we can use 5.7 and the Integral with a projector).
I assume atabea has used Chromapure with his i1d3 to read the Gamma D curve in SDR, which isn't relevant.
The Gamma D / PQ gamma curve can't be read without the correct tools. AFAIK, they are not avsilable for projectors yet."
Manni01 likes this.
IMDave is offline
post #554 of 4238 Old 06-11-2016, 02:10 AM - Thread Starter
Manni01's Avatar
Liked: 5982
What's wrong with the Gamma curve is the target (green line) which should also follow an S shape, but the JVC software isn't sophisticated enough to change the shape of the gamma curve when measuring gamma D, so the target always remain a straight line.
The calibration might be fine, but it's hard to say as we can't compare the target (green) to the after calibration measurement (white). Also, I doubt the measurements are correct as I don't think the Autocal is able to switch the PJ to HDR.
For this reason I suggest to use a standard gamma curve when calibrating and measuring. The gamma D curve will be corrected just like the others, but we don't have a way to check it yet as the EOTF for projectors isn't available yet. I understand Calman will have PJ specific EOTF for projectors soon.
In this case before running a new autocal you might just run a log only with a standard gamma selected to see if the white line follows the green line (it should be very close to it). If it is, there is no need to redo the gamma calibration.
post #555 of 4238 Old 06-11-2016, 06:11 AM
brbecker's Avatar
Quoted: 24 Post(s)
Smile
Ok thanks...I'll setup the S5 meter again today and check...thanks.
Dave Vaughn likes this.
brbecker is offline
post #556 of 4238 Old 06-11-2016, 06:12 AM
brbecker's Avatar
Quoted: 24 Post(s)
Thanks..I'll try again today.
brbecker is offline
post #557 of 4238 Old 06-12-2016, 12:53 PM
brbecker's Avatar
Quoted: 24 Post(s)
mariob33 you were correct during the BT2020 calibration Gamma D had been selected instead of standard. I redid the gamma calibration using standard gamma then did a color only calibration of BT2020 and the straight line from lower left to upper right was a straight line with a color temp. of D6500.
IMDave likes this.
brbecker is offline
post #558 of 4238 Old 06-13-2016, 12:10 AM
mpyw's Avatar
Quoted: 99 Post(s)
Liked: 32
Hi,
One question, how do I backup the INIT file before I run the autocal?
I try the export but it shows only 3 types, jpd, prof and gamma for each profile type i.e. cinema, standard & natural
To be or NOT to be......YOU are WHO you ARE
mpyw is offline
post #559 of 4238 Old 06-13-2016, 01:41 AM
IMDave's Avatar
Quoted: 137 Post(s)
Liked: 158
Originally Posted by mpyw View Post
Hi,
The INIT file is created and saved into the same folder as the first Autocal file. You need to run Autocal . There is no option to save INIT until the first Autocal is run.
As Manni has said, just make sure you put it in a safe place, as not to accidentally delete it.
alebonau, mpyw and Manni01 like this.
IMDave is offline
post #560 of 4238 Old 06-14-2016, 07:40 PM
sthompson's Avatar
Quoted: 104 Post(s)
Liked: 39
I saw a few mentions of the Spyder 5 Pro on sale, looks like the deal is over?
Between the express and the pro versions for the JVC, any recommendations on which one to get?
sthompson is offline
post #561 of 4238 Old 06-15-2016, 04:50 AM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 642
Express supposedly works fine.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #562 of 4238 Old 06-16-2016, 11:10 PM
mpyw's Avatar
Quoted: 99 Post(s)
Liked: 32
OK, I've got the Express, run the autocal, the gamma is perfect straight line, and saving the color calibration in a few diff settings.....
Then I check using HCFR software, the RGB graph show blue a little high on low y and red a little low on high y and the DeltaE shows 4.1....how can I improve that?
mpyw is offline
post #563 of 4238 Old 06-17-2016, 07:51 AM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
hi manni
just making sure but this setting is for the blurays like fifth element and other sony releases right?
Min4K in user4 for Mastered in 4K blurays
Colour profile: x.v.color
Color Temp: n/a
Gamma: n/a
Iris: -14
Lamp: Low
My theater build : Roll-In Reels Cinema (7.2.4 atmos theater)
lpnaz480 is offline
post #564 of 4238 Old 06-17-2016, 08:30 AM
nathan_h's Avatar
Quoted: 2733 Post(s)
Liked: 1961
Are you using the same meter for both situations?
nathan_h is offline
post #565 of 4238 Old 06-17-2016, 09:10 AM
mpyw's Avatar
Quoted: 99 Post(s)
Liked: 32
Yes using the same meter spyder 5
mpyw is offline
post #566 of 4238 Old 06-17-2016, 01:48 PM - Thread Starter
Manni01's Avatar
Liked: 5982
You can use HCFR to set 100% white to D65 and work on the gamma and color temp manually, but you will only get it closer to the Spyder5. Unless you notice something off, I would just enjoy the projector. If you want to really improve things, then you need a known accurate meter, at the minimum an i1d3.
Originally Posted by lpnaz480 View Post
hi manni
Color Temp: n/a
Gamma: n/a
Iris: -14
Lamp: Low
Yes, looks good
Just make sure you're in YCC using standard levels not RGB and that all the devices in the chain support xvcolor. The JVC should display x.v.color in the info screen.
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
JVC Macro feature on Vertex/Vertex2/Integral2/Maestro
post #567 of 4238 Old 06-17-2016, 11:02 PM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
Yes, looks good
did you run an autocal w/ in your user4 xvcolor?
lpnaz480 is offline
post #568 of 4238 Old 06-18-2016, 03:06 AM - Thread Starter
Manni01's Avatar
Liked: 5982
Never tried as you can't calibrate any of the presets. Gamma and color temp are not selectable and x.v.color isn't a gamut in itself, it's relative to rec-709. So I assume x.v.color uses the standard colour profile as a reference, but there is no way to check as you can't measure or calibrate to x.v.color. The gamma and colour temp are calibrated with any other user setting using the same lamp/cmd/iris setting, so I just use the same settings as my rec-709 user mode and it looks fine like that.
post #569 of 4238 Old 06-18-2016, 11:54 AM
lpnaz480's Avatar
Quoted: 87 Post(s)
Liked: 54
thanks again!
lpnaz480 is offline
post #570 of 4238 Old 06-19-2016, 10:00 AM
Liked: 0
Guys, just in case...
Suppose someone (me) has lost the pre-calibration backup file of his rs49, cause the HD of his pc was formatted....
Suppose the same someone (me, again...) is having GREAT problems to run the autocal cause nothing works good (my spyder4 has problems with the green... verified it by confronting the measures of my spyder4 with the measures of my xrite... After the autocal, to set the white at 80 IRE, i have to cut off 25 points of green)
... And again suppose that another someone (me, of course) is going to trash the projector through his windows...
Now, the question is:
do you think that a backup init file of another vpr (same model, of course... rs49) could save me?
And, just in case, maybe you know someone that can help me?
Again, just in case...
Thanks from an italian vpr addicted...
jack_pls is offline
