JVC Calibration Software V6 For 2015 Models (X9000,X7000,X5000,RS400,RS500,RS600) - Page 72 - AVS Forum | Home Theater Discussions And Reviews
 1285Likes
post #2131 of 4363 Old 09-02-2017, 06:41 AM
PioManiac's Avatar
Quoted: 3404 Post(s)
Liked: 8703
Originally Posted by chipvideo View Post
Using the newest software for the RS520 and it says to put in ip address and the port number. I just left the port number at the default as i have no idea what port it is and it wont connect. How do I find the port number for my lan on my laptop?
I had issues going direct from my projector to laptop too,
Swapped my LAN cable direct to my wireless router instead,
Switched the JVC network DHCP client to ON and hit set, all the fields auto filled and connected.
Put the new numbers into AutoCal and all was good.
But when I went to repeat that procedure again today to load Manni's DV gamma curve,
I kept getting "Failed to obtain IP address" on my JVC. Tried re-booting everything still no love
Guess for now I'm stuck with Manni's 800-335-4000 Black=77 curve
...at least I got lucky and works great for me.
For now, AutoCal is dead to me
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #2132 of 4363 Old 09-02-2017, 11:54 AM
chipvideo's Avatar
Quoted: 50 Post(s)
Liked: 24
I am sure if I was a computer savvy person I would figure out what to look for and change. Wish we could go back to the easy days of windows XP.
chipvideo is offline
post #2133 of 4363 Old 09-03-2017, 12:56 AM
Bandyka's Avatar
Quoted: 2399 Post(s)
Liked: 1475
I hope someone can shed some light on this.
I am trying to autocal my RS620 using version V1.20 and the problem is the peak white simply displays an error every time hence the calibration results in pink looking gamma. I am only trying to do gamma.
I thought this was fixed in V1.2? Also why would it error out at peak white? It's the Spyder 5 and is within the rectangle as needs to be ,tried placing it further back as far as it goes within the range.
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #2134 of 4363 Old 09-03-2017, 12:44 PM
chipvideo's Avatar
Quoted: 50 Post(s)
Liked: 24
I wonder if mine will work. I have a wireless router upstairs and it feeds directly into a switch in the theater. I should theoretically be able to plug into that switch and should work. I tried that and didnt work either.
post #2135 of 4363 Old 09-04-2017, 01:18 AM
Bandyka's Avatar
Liked: 1475
The PJ for some reason does not like multiple access points,wifi routers, repeaters etc on the system, what usually works if other options fail is to get a cheap router and set up a closed network just for this between the laptop and the PJ that worked for me every time.
Bandyka is offline
post #2136 of 4363 Old 09-04-2017, 07:22 AM
Quoted: 5827 Post(s)
Liked: 2340
A direct connection between the laptop and the PJ, together with manual assignment of the IP addresses, works for me. Some people also had to disable the wi-fi but I haven't found it necessary.
Dominic Chan is offline
post #2137 of 4363 Old 09-04-2017, 08:22 AM
PioManiac's Avatar
Liked: 8703
Angry
THIS makes the most sense to me, Not sure why an internet/network connection should be required
to make autocal settings adjustments between a software program on a laptop and a projector.
But when I enter my IP from the JVC menu, all I get is Connect NG.
Tried with wifi on and off and still no love.
Is there a way to confirm what my port number is on my HP/Windows 10 laptop?
AutoCal seems to automatically insert 20554, is it safe to assume that number is correct?
This is SO frustrating, mostly because it did work for me once already using the network DHCP Client to On.
I've been trying for 3 days now and can't figure out what the heck I did right the first time and can't repeat now.
Freaking HATE computers!
post #2138 of 4363 Old 09-04-2017, 08:49 AM
Liked: 2340
Have you confirmed that on your laptop the ethernet IP address is 192.168.0.1, and default gateway is 192.168.0.254, and on the projector the IP is 192.168.0.2?
The port number on the projector shouldn't change.
post #2139 of 4363 Old 09-04-2017, 09:06 AM
johnson636's Avatar
Quoted: 1538 Post(s)
Liked: 1035
@Dominic Chan +1
Pio, when you connect your laptop directly to the pj, are you able to successfully ping the IP? If your P2P network is set up properly, then you should be able to ping the pj's IP from your laptop.
johnson636 is offline
post #2140 of 4363 Old 09-04-2017, 09:15 AM
PioManiac's Avatar
Liked: 8703
I Got IT! FINALLY
I went back to the screen shot I saved from when it worked the first time through my router, DHCP Client "ON"
Copied the numbers into the required fields, But left DHCP Client "OFF" so I could manually insert the same numbers that worked before, did not hit "Set", just put the same matching IP into AutoCal and it connected.
How it looked the first time
The workaround that just linked up for me now
I just loaded up Manni's DV Curve into Custom slot 3
It's pretty close to the 800-334-4000 (Black-77) curve in my Custom slot 2
For some reason every curve I try loading into my JVC's Custom 1 comes out Green?
I tried 3 different curves, made sure correction value was set to import.
DV Curve
800-334-4000
My JVC's Custom 1 slot looks Matrix Green
...no matter which curve I attempt to load into that slot
Is this a defect in my JVC?
post #2141 of 4363 Old 09-04-2017, 12:18 PM
chipvideo's Avatar
Quoted: 50 Post(s)
Liked: 24
Trying to do a factory reset after loading the init file. How is it done?
post #2142 of 4363 Old 09-04-2017, 01:08 PM
Quoted: 46 Post(s)
Funny, Zombie10K just answered this for me today.
hi, yes it's in the service menu. If you choose to reload the INIT file, do so through the auto cal software then factory reset in service menu, then power cycle.
JVC Projector Service Menu Access Code
Using the remote control:
Press the {UP} {DOWN} {RIGHT} {LEFT} buttons.
Then press the {ENTER} button.
The Service Menu will be displayed.
chipvideo likes this.
RBenavides is offline
post #2143 of 4363 Old 09-04-2017, 01:37 PM
Quoted: 46 Post(s)
I went back to the screen shot I saved from when it worked the first time through my router, DHCP Client "ON" Copied the numbers into the required fields, But left DHCP Client "OFF" so I could manually insert the same numbers that worked before, did not hit "Set", just put the same matching IP into AutoCal and it connected.
This helped answer it I think. DHCP is dynamic ip address allocation, so that IP address you saw changes everytime you power cycle, or sooner depending on your 'lease' settings. So you should have to go to the menu each time to find your new IP address to input into Autocal.
i think settling a fixed IP, like you did, makes sense since you have a one time setting and you're done. that's what I have. Autocal works. I just don't have it plugged into my network to avoid IP address setting issues down the road fixed versus DHCP.
My problem is that my projector can't even resolve DHCP, even though 4 other piece of equipment on the same physical switch do...hmmm. Oh well, for now it all works.
post #2144 of 4363 Old 09-04-2017, 06:09 PM
Sittler27's Avatar
Quoted: 1360 Post(s)
Liked: 122
Had a X750R and now a new X970R. I have a 138" scope screen.
Looking to first do a JVC auto-cal with my Spyder 5.
First off, I do a gamma+color for my HDR mode, which is high lamp, iris 0, CMD off.
I set Color Profile at BT.2020
Color Temp at HDR
Gamma at Normal
Is this correct? I wasn't sure as on my X750R for HDR I selected 2020NF, 6500K and Custom 1 for gamma to run the gamma+color on.
Note: I intend to later create a custom curve for gamma for HDR.
Likewise, I intend to follow Manni's updated instructions and do a gamma+color for my normal Rec709 modes.
For one of these modes, I run low lamp, iris -10, CMD off.
I set Color Profile to Standard (or should I be using an imported Rec709F or Rec709NF?)
Color Temp at 6500K
Gamma at Normal
is this correct to run gamma+color on?
Sittler27 is offline
post #2145 of 4363 Old 09-04-2017, 11:27 PM
Bandyka's Avatar
Liked: 1475
So can anyone confirm the software is still a dud causing red gamma or if not why is it doing it for me and some others causing the peak white error?
Bandyka is offline
post #2146 of 4363 Old 09-05-2017, 06:19 AM
PioManiac's Avatar
Liked: 8703
Thanks Again to Manni!
I've been flipping between your 800-334-4000 (Black-77)
and the Dolby Vision Cinema Emulation and Both look quite good, doesnt matter if they are 4000 or 1000 nit titles.
The DV Emulation adds just the right amount of Pop on colorful titles,
But at the expense of adding a little too much red on skin tones for my preference
(on my un-calibrated JVC) So for most drama type movies I stick to 800-334-4000.
Anyone who wants a real blast of HDR color, load up Lego Batman O-M-G
JVC X750/120" Screen
...and the same shot on my 65" OLED
Dave Vaughn and Manni01 like this.
post #2147 of 4363 Old 09-05-2017, 07:28 AM
Sittler27's Avatar
Liked: 122
Color Temp at HDR
Gamma at Normal
Color Temp at 6500K
Gamma at Normal
Anyone able to answer my questions?
I uploaded the Rec709NF to the projector, and calibrated that for Color Profile setting on my HD modes using autocal instead of using the Standard color profile.
Is that correct?
post #2148 of 4363 Old 09-05-2017, 02:56 PM
Sittler27's Avatar
Liked: 122
For autocal on HDR user modes, what settings should I use for Gamma and Color Profile?
Also, once normal gamma is calibrated with autocal, do we need to bump Dark level up to 2?
post #2149 of 4363 Old 09-06-2017, 07:44 AM
Sittler27's Avatar
Liked: 122
Anyone?
post #2150 of 4363 Old 09-07-2017, 11:21 AM
Lightivity's Avatar
Quoted: 70 Post(s)
So I finally got a hold of Ray's UHD test patterns and made a stab at creating my own gamma curve. Until now I've used Mannis newest 4000 curve for 135 nits, which looks great in my setup: RS400 with 3.6 m throw, 90" 1.0 gain screen, low lamp, all black/velvet and light controlled room, calibrated with Autocal and Spyder5. But I thought I'd try the Arve tool to see if I could get even better results.
I chose the Mad Max scene at appr. 29.05 (recommended by Manni). Structurally it went well in the sense that I got through the whole process (phew) including finding the right bbo number to make bar 77 and above visible (in Rays black clipping pattern).
I found setting the contrast level a bit difficult though, and I actually skipped the Brightness setting altogether.
Contrast: in the Mad Max frame above, I had to turn the contrast down to -30 to reveal all details behind Max's head (the brittle smudges and stains placed to the left and right in the bright window frame). This level rendered a very dim curve, obviously . The curve is much dimmer than Mannis premade one. Question is, is there a better scene or am I doing something wrong ? It seems this one is quite extreme in brightness. Perhaps I should just let some of these details be submerged in bloom, but it's hard to know where to stop the bloom or let it conceal stuff. The details in highlights in this scene are abstract/non-figurative so perhaps that makes it hard.
Brightness: This is just over my head. I tried entering some numbers according to Lovingdvd's speed guide but it seemed to make no difference. Also very hard to know which results to deem as good.
As I mentioned, Mannis premade curve is very nice -- and I think my setup lightning-wise is quite close to his (except the projector) -- but it would be nice to make a wholly custom made curve that is not as dim.
JVC RS400/X5000, Marantz SR5011, Sony UHD X800
"National unity in Europe is still defined in terms of blood and earth. In the USA it's the idea – expressed in the Constitution – that supports the development of the nation. In the matter of integration the difference is profound: everyone can agree on an idea, but no-one can change their ties of blood."
Lightivity is offline
post #2151 of 4363 Old 09-07-2017, 03:22 PM - Thread Starter
Manni01's Avatar
Quoted: 5797 Post(s)
Liked: 6248
We have a very similar setup (Carada BW 88" diag 16/9 with effective gain of 1.1 at most), which explains why my curves work well for you. If I were you, I'd use the parameters I've given for my 4000nits universal curve for low lamp or high lamp at iris open (so that you get the full resolution of Arve's curve, and not the low-res from the JVC Autocal exports), and I'd call it a day after simply adjusting bbi/bbo. You should resolve down to 81. 77 is black in an illegal curve, so should NOT blink.
Both contrast and brightness should be at zero, both in the player and the display.
Ric (LovingDVD) and others will answer regarding the auto process, I never used it myself. You change contrast during the auto process, but contrast and brightness should be at zero at the end of the process.
Side note: I use high lamp most of the time now for HDR (unless I'm watching a super dark picture without much color like Underworld), because the color volume is larger in High Lamp. It's harder to reach DCI-P3 at all levels in low lamp. If you can use high lamp from a fan noise / heat point of view, I highly recommend it (as long as you can enable the dynamic iris with a Linker/Vertex). I only use low lamp when black levels (apart from fade to black) is more important than color saturation, which is not very often. I watched Blade Runner in High Lamp for example.
Lightivity likes this.
Manni01 is offline
post #2152 of 4363 Old 09-07-2017, 03:52 PM
Sittler27's Avatar
Liked: 122
Anyone at all?
Also, came up with another question:
If using HCFR to calibrate HDR using Masciola's HDR greyscale patterns, is it as simple as selecting the HDR gamut in the Preferences/References area of the HCFR app?
post #2153 of 4363 Old 09-07-2017, 05:50 PM
Dave Vaughn's Avatar
Quoted: 1671 Post(s)
Liked: 2597
Side note: I use high lamp most of the time now for HDR (unless I'm watching a super dark picture like Underworld), because the color volume is larger in High Lamp. It's harder to reach DCI-P3 at all levels in low lamp. If you can use high lamp from a fan noise / heat point of view, I highly recommend it (as long as you can enable the dynamic iris with a Linker/Vertex). I only use low lamp when black levels (apart from fade to black) is more important than color saturation, which is not very often. I watched Blade Runner in High Lamp for example.
Manni,
I've been using High lamp as well for HDR and like it better. My screen is a Stewart Firehawk, so I get slightly better black levels due to the screen, which is an added benefit.
Manni01 likes this.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
Dave Vaughn is offline
post #2154 of 4363 Old 09-08-2017, 07:04 AM
Lightivity's Avatar
Quoted: 70 Post(s)
Are these the parameters? Sorry for the basic questions... Should I plug these into your 4000 curve using the Arve's tool? I have only used the Arve tool from the perspective of creating a new curve. So in this case instead of loading a default curve from the Arve toolbox I'll pick yours and then enter your parameters? When you say Autocal exports, what are your referring to? I have never exported anything from Autocal.
EDIT: I'm not sure I'm using the Universal curve. This is the one I have loaded.
post #2155 of 4363 Old 09-08-2017, 07:26 AM - Thread Starter
Manni01's Avatar
Liked: 6248
Yes, these are the parameters for my low lamp calibration at 135nits PeakY. To use one of my curves, you either plug the parameters in Arve's tool and create a high resolution curve that the tool uploads directly to the PJ, or you download the low-res version that I exported with the JVC Autocal. In that case, you have to use the JVC Autocal to upload the curve in a custom slot on the PJ.
If you haven't done either of these things, I don't know how you have tested my curves.
I'm snowed under with work at the moment so won't have the time to answer further questions, but if the explanations in this thread with all the posts linked in the first post are not enough, I'm sure others will help.
Good luck!
Manni01 is offline
post #2156 of 4363 Old 09-08-2017, 09:26 AM
Lightivity's Avatar
Quoted: 70 Post(s)
Good luck!
Thanks Manni! Sorry, I missunderstood what Autocal exports meant. Yes, I have used your exported 4000 curve, I have just never exported something myself. Also didn’t know they were low resolution.
I’m on track I believe...will try testing creating this universal curve soon, and will look for the high lamp settings as well.
Thanks again for the help and for having patience with my scattered questions
Manni01 likes this.
post #2157 of 4363 Old 09-08-2017, 12:31 PM
Sittler27's Avatar
Liked: 122
Anyone at all?
Ok, one more ask....anyone?
post #2158 of 4363 Old 09-08-2017, 11:41 PM
Kazz063's Avatar
Quoted: 107 Post(s)
Liked: 102
I'd like to know too.
I ran the autocal last night on my X5000 but had issues, my non HDR cal seemed to go ok but once I did the BT2020 cal everything had a pink tinge to it.
I ended up reloading the backup and resetting the PJ, anyone got any ideas what might cause this?
Also I was going to download the REC2020NF profile from the beginning of this thread but I get a dropbox message saying this file no longer exists?
Kazz063 is offline
post #2159 of 4363 Old 09-08-2017, 11:47 PM
Bandyka's Avatar
Liked: 1475
So whats going on with the pink tinge etc? Can someone confirm it is still a software issue?
Bandyka is offline
post #2160 of 4363 Old 09-09-2017, 07:01 AM
Sittler27's Avatar
Liked: 122
Speaking of pink tinge, I noticed when I tried to do a greyscale calibration using HDR patterns (Masciola's) using the HDR preset and after running autocal for my user HDR user mode.
I noticed while adjusting the red gain/offset values that I was fine on the calibration software I was using (HCFR) to bump it up but the second I hit a threshold value (forget, but I think red offset at +2) the whole pattern added a huge red push to it, but yet I still needed to bump red up more to align the greyscale.
This was all with BT2020 on in my preset HDR mode as stated calibrated with autodial.
Any ideas? Are you guys just using your 6500K greyscale setting that you derived using a Rec709 calibration and calling it a day? Or are you trying to calibrate greyscale with HDR patterns, etc.?
