Sony VW365ES Owner's Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 129Likes
post #361 of 372 Old 02-18-2019, 05:19 AM
rwestley's Avatar
Quoted: 502 Post(s)
Liked: 327
Originally Posted by SKYRANCH View Post
I’ve been building a home theater for a year now and this weekend the projector was switched on for the first time. I selected the Sony VPLVW365ES and purchased one with very little use on EBay. The Blu-ray’s look beautiful but when we put a 4K disc in the picture is completely distorted (color bursting) in the HDR mode... when that is off the image is flat and colorless. The technician is a bit stumped and wants to do more tests before I give up and send the projector back. I was wondering if anyone on here has any ideas or suggestions. Thanks in advance from a very frustrated home theater fan.
I would suggest that you read the regular 285/385 threads. You might want to consider loading the German Curves and settings. You also give very little information on what settings you are using. It is obvious that the technician you had to install the unit has very little knowledge about the settings on this projector.
rwestley is online now
post #362 of 372 Old 02-18-2019, 07:28 AM
Archibald1's Avatar
Quoted: 2398 Post(s)
Liked: 1298
Hi.
You need to make sure that the HDMI ports on the projector are set to enhanced format and limited dynamic range.
Then you need to make sure the source is set to output full 4k resolution and 10/12 bit colour depth.
What disc player are you using?
Then when you are watching a 4k disc, you need to make sure that HDR (in the picture menu under expert settings) is set to 'auto'.
It might simply be that the previous user has set the contrast/brightness and colour wrong too.
Do a full reset on the unit if all else fails and try again, but if everything in the chain is set to full bandwidth and deep colour etc then the results should be very pleasing when adjusted correctly.
You will be better off asking your question in the 365 owners thread too.
I would also forget about loading gamma curves etc, until you have more of a handle on the machines settings.
rwestley likes this.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is offline
post #363 of 372 Old 02-22-2019, 09:52 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7134 Post(s)
Liked: 7175
Originally Posted by rsaunders37 View Post
How heavy is that projector? Wondering if that kind of set up could hold an NX7. Tnx
3/4 ply would hold a grown man if you lagged 2" screws into the ceiling joists properly.
I hung from mine I do have an awesome set of tools though lol
Cleveland Plasma is online now
post #364 of 372 Old 02-22-2019, 11:35 AM
cdnscg's Avatar
Quoted: 645 Post(s)
Liked: 130
Could be the 4k player and/or its setting. Have had 2, and find that they can be very different in the final results.
cdnscg is online now
post #365 of 372 Old 02-23-2019, 10:34 PM
Dave Harper's Avatar
Quoted: 3159 Post(s)
Liked: 1723
Dave Harper is offline
post #366 of 372 Old 03-09-2019, 04:41 PM
Quoted: 26 Post(s)
Liked: 4
You want to never buy a mount again? Build a box out of 3/4" plywood, I used cabinet grade Oak Plywood sold at Home Depot or Lowe's. Mine is 15" X 24" X 24". Used 3 --- 2" wood screws at each joint, I did not 45 Degree the joints by the way, just a standard butt joint. Used the exact same paint that I used for the wall's and ceiling.
---Sounds like with the fan you have in the way you might need to build a shelf as you noted and could use 3/4" plywood with 2x4 supports under it......
Would it be possible to use a DCR lens with this setup?
Steezo Jay is offline
post #367 of 372 Old 02-05-2020, 08:27 PM
Liked: 0
I'm having issues updating the software on my vplvw37665es. I've followed the instructions on the Sony website. Downloaded the update to a thumb drive, input the thumb drive into the USB port while the projector was turned off, turned it on, and...nothing. It's supposed to auto update at that point but it never does. Can anyone provide any assistance here?
JCD80 is offline
post #368 of 372 Old 02-06-2020, 04:07 AM
Archibald1's Avatar
Liked: 1298
Make sure you prepare the USB device on a PC not a Mac.
FAT32 also is the format needed.
There should only be the folder unzipped on the drive NOTHING else or it won't work.
If it fails again after trying it over, then try a different USB stick.
I use an old 1GB stick for my updates and it works great.
Stephen Hawking.
post #369 of 372 Old 02-06-2020, 01:35 PM
Liked: 0
Do I need to unzip the file before I update the projector?
JCD80 is offline
post #370 of 372 Old 02-06-2020, 01:36 PM
Liked: 0
Do I need to unzip the update before I install in projector?
JCD80 is offline
post #371 of 372 Old 02-10-2020, 01:06 PM
Tom in OH's Avatar
Yes.
Archibald1 likes this.
"4k UHD makes today a great time to be alive"
Tom in OH is offline
post #372 of 372 Old 02-11-2020, 03:21 AM
Archibald1's Avatar
Liked: 1298
Originally Posted by Tom in OH View Post
Yes.
As already said, Yes.
Unzip the download and copy the resultant folder (in it's entirety) into the root of the USB stick. Nothing else should be present.
Then read the updating instructions through twice before proceeding.
Stephen Hawking.
hdcp 2.2 , ps4pro , sony vpl-vw365es , VW365ES
