JVC DLA-RS46 :: Any way to view a 3D only Blu-ray in 2D ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-04-2016, 08:11 PM - Thread Starter
ahmadka's Avatar
Quoted: 23 Post(s)
Hi guys .. I've owned a JVC DLA-RS46 for about 2 years but have been too lazy to formally post this question, even though it's been bugging me for a while ... Is there any way I can view a 3D only Blu-ray in 2D using this projector ? Many budget 3D projectors have this option so I would be surprised if the JVC RS46 doesn't.
ahmadka is offline
post #2 of 9 Old 01-04-2016, 08:17 PM
kwk2293's Avatar
Quoted: 87 Post(s)
Liked: 35
Panasonic bluray player have this option
kwk2293 is online now
post #3 of 9 Old 01-04-2016, 08:39 PM - Thread Starter
ahmadka's Avatar
Quoted: 23 Post(s)
That may be true but I already have two blu-ray players in my HT room and don't want to buy a third
I just want to know if the RS46 can do this or not ? I once had a budget Optoma HD131Xe which did have this option (3D >> 2D) and so I'm wondering if the RS46 can also do that.
ahmadka is offline
post #4 of 9 Old 01-06-2016, 04:56 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2384
I'm pretty sure on my RS4910 under the 3D settings, one of the options is 2D.
stanger89 is offline
post #5 of 9 Old 01-14-2016, 04:57 AM - Thread Starter
ahmadka's Avatar
Quoted: 23 Post(s)
I looked at the settings on my RS-46, and the closest setting I found was this: Menu >> Input Signal >> 3D Setting >> 3D Format >> [Available Options here: Auto, Side by Side, Top and Bottom, 2D] ... By default it was on Auto. I thought changing it to 2D might help but it didn't do anything :/
Anything else I can try ?
ahmadka is offline
post #6 of 9 Old 01-14-2016, 06:56 AM
stanger89's Avatar
Liked: 2384
On my RS49 it displays in 2D if you set it thus.
post #7 of 9 Old 01-14-2016, 07:15 AM - Thread Starter
ahmadka's Avatar
Quoted: 23 Post(s)
What's your setup exactly (AVR, player, etc.) and what media are you using when testing this out ?
ahmadka is offline
post #8 of 9 Old 01-14-2016, 07:26 AM
stanger89's Avatar
Liked: 2384
I think the last time I tried it, it was some SBS videos through my Lumagen, which was outputting 1080p SBS.
post #9 of 9 Old 01-14-2016, 09:28 AM
kwk2293's Avatar
Quoted: 87 Post(s)
Liked: 35
It wouldnt work with bluray or media player on my rs4910 may not work with fp 3d
