Official JVC DLA-RS400 (X550/X5000) Owner's Thread - Page 171 - AVS Forum | Home Theater Discussions And Reviews
 3571Likes
post #5101 of 5913 Old 04-06-2018, 11:26 PM
Quoted: 146 Post(s)
Liked: 54
Originally Posted by Bahn Yuki View Post
Originally Posted by Dreamliner View Post
It's up to you. If you are happy with the exact way your player is right now then you could keep it. I have serious doubts about any future updates or support from Oppo.
The only other solution is a Panasonic UB900 and a HD Fury Vertex (this is what I have). There is a Panasonic coming this year with Tone Mapping but it's not known if the Vertex will still be required or not. One advantage this setup will have over the Oppo is it will remember the Gamma setting and you won't need to select it each time.
After much research I think I'd be better off returning the OPPO and picking up a Panasonic UB420 which should do tone mapping also
Sent from my SAMSUNG-SM-G891A using Tapatalk
This may not apply to you but one thing to consider is that the Panny will not have an HDMI input like the Oppo so you will not be able to tone map anything from an external source. That is if you are currently using the HDMI input.
Hawks07 is offline
post #5102 of 5913 Old 04-18-2018, 12:51 PM
KevinH's Avatar
Quoted: 262 Post(s)
Liked: 117
Hi guys. My X550 has been in storage while our house was being built. We're now moved in and I'm in the process of putting together my HT. I currently have a 110" 16:9 and am contemplating the move to a 2.35 screen. At a 15' throw and max 2.0 zoom, I'd get a 138" 2.35, which is the same height as my current screen thus would give me the same 16:9 size image I'm used to. Is anybody using theirs at max zoom with a similar throw with good picture brightness and no complaints? I'm sure I'll back it up a bit so I'm not at absolute max zoom but am curious as to what your throw distances and approx. zoom ranges are for a particular AR and diag screen size?
JVC X550R /Panny UB820/GIK treatments
Elunevision 140" 2.35
Marantz AV8802a/Wyred4Sound 7-channel amp
Outlaw 5000/ 4 JBL 328Cs in ceiling/ 7.2.4 Atmos
JTR 3TX LCRs/Single8 HT-LP surrounds(4)/Dual PSA TV36 iPals
KevinH is online now
post #5103 of 5913 Old 04-18-2018, 04:06 PM
Dreamliner's Avatar
Quoted: 1519 Post(s)
Liked: 810
You’ll have no problems with that. My screen is 136” and my throw is 18’ and the picture looks great. Nobody ever wished they had a smaller screen (except for a few bad curve HDR apologists).
As long as you’ve got your projector setup right, it will look great. Check out my JVC 4K QuickStart Guide for a quick refresher.
Dreamliner is offline
post #5104 of 5913 Old 04-18-2018, 05:30 PM
Quoted: 146 Post(s)
Liked: 54
I have a 14' throw to a 132" diagonal 16:9 screen which is probably close to what you are looking at. Looks like you would be right at the minimum which is where I am at and my brightness is great with an excellent picture. No complaints, you should be fine.
Hawks07 is offline
post #5105 of 5913 Old 04-19-2018, 09:22 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7159 Post(s)
Liked: 7198
With OPPO going out of business, would it be best to return the 203 and go for another option for this projector?
I am sure many are asking that same question.....An extended warranty is cheap, might want to add that in case you need parts one day, as I bet those are hard to get to.
I would be concerned about the updates myself. Panasonic makes a great unit, that's for sure....
Cleveland Plasma is offline
post #5106 of 5913 Old 04-26-2018, 02:36 PM
radchad3's Avatar
Quoted: 26 Post(s)
Hello everyone. I have been out of the PJ game for awhile and am looking to pick one of these up. I am coming from an RS-2. Have there been any major issues from a reliability standpoint with this PJ? Any bulb issues etc?
My RS-2 has been rock solid and looking to get the same life out of this one if I go with it. Thank you!
Chad
radchad3 is online now
post #5107 of 5913 Old 04-26-2018, 02:43 PM
Quoted: 5571 Post(s)
Liked: 2250
Unless the price difference is large, I would suggest a newer model (RS420 or RS440). It’s much easier watch HDR on the newer models.
Dominic Chan is online now
post #5108 of 5913 Old 04-26-2018, 02:51 PM
radchad3's Avatar
Quoted: 26 Post(s)
I have heard that HDR with the 400 is less than optimal but that JVC had instruction for the fix. Even with the fix, are the newer models a big step up?
post #5109 of 5913 Old 04-26-2018, 03:24 PM
Liked: 2250
There is no fix. JVC simply posted some settings that make Gamma D look less bad.
What they should have done is to add the ST2084 curve like on the newer models.
Dreamliner likes this.
post #5110 of 5913 Old 04-26-2018, 04:46 PM
DLCPhoto's Avatar
Quoted: 1775 Post(s)
Liked: 860
Chad
Dominic is correct in that getting good HDR performance with either the 420 or 440 is much easier.
But I do want to add though, that if you're technically oriented, and don't mind investing some time in learning how to do it properly with Custom Gamma Curves, the performance you can get with the 400 is just as good as that of the 420/440. You might also need to buy a second device to enable the Auto Iris for use with HDR, and to prevent the Projector from auto-switching to Gamma D (such as the HDFury Linker, which I picked up used for $100). I believe the Linker would still be needed for Auto Iris function in the 420, but not with the 440, but I'd have to double-check on that.
I bought the 400 coming up on 2 years ago, and have gone through that process, and I am extremely pleased with what I'm seeing with mine.
But if you're looking for a more 'plug-and-play' then Dominic is correct, that this will be much easier with one of the newer models, but obviously at some added cost.
Jive Turkey likes this.
JVC NX7, DCR Lens, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #5111 of 5913 Old 04-26-2018, 05:05 PM
radchad3's Avatar
Quoted: 26 Post(s)
Thank you both for the comments! They are much appreciated. I am a DIYer so I don't mind playing with the 400. Has it been a reliable unit otherwise? Any other major known problems?
post #5112 of 5913 Old 04-26-2018, 05:58 PM
Liked: 2250
The only issue I experienced (and read about) is that very occasionally the screen can go totally crazy and requires a reboot. That’s with both the RS400 and RS420.
post #5113 of 5913 Old 04-26-2018, 05:58 PM
mtbdudex's Avatar
Quoted: 85 Post(s)
Liked: 1582
Ok, I’ve posted here about my frustration the RS400 won’t anamorphic stretch 4k 4:4:4 60 ( my Xbox1x feed), nor will my X8500H.
If I get the Oppo 203 , and feed my AVR into it, the oppo 203 then is my video processor for HDR tonning and anamorphic stretch , right?
mtbdudex is offline
post #5114 of 5913 Old 04-26-2018, 06:08 PM
Liked: 2250
I would feed the OPPO into the AVR, not the other way round.
muzz likes this.
post #5115 of 5913 Old 04-26-2018, 06:58 PM
mtbdudex's Avatar
Quoted: 85 Post(s)
Liked: 1582
I’d feed the hdmi audio out to the AVR , the video to PJ
mtbdudex is offline
post #5116 of 5913 Old 04-26-2018, 08:30 PM
DLCPhoto's Avatar
Liked: 860
It seems that relatively few problems are reported on the forums. I did have my aperture stop working, though, which apparently is a relatively rare occurrence. But I sent it in for repair, under warranty, and it has been fine since then.
post #5117 of 5913 Old 04-27-2018, 05:04 AM
radchad3's Avatar
Quoted: 26 Post(s)
Ok, thanks for the reply!
post #5118 of 5913 Old 04-27-2018, 06:23 AM
Mike Garrett's Avatar
Quoted: 13205 Post(s)
Liked: 10830
Correct. I only have one other source, a Roku, so I feed that into the Oppo 203 and the Oppo 203 feeds into the prepro. But it will also work the way you want to do it, if you have multiple sources.
Mike Garrett is offline
post #5119 of 5913 Old 04-27-2018, 10:27 AM
Dreamliner's Avatar
Liked: 810
I pretty much agree with what has been said. I own a RS400 and have probably (certainly) been the most vocal in my frustration with getting "HDR" to look right. JVC really shafted the RSx00 owners by not including a HDR gamma curve and immediately releasing the RSx20 models only one year later that does. It is very obvious from any objective perspective this was a very poor decision by JVC. The RSx20 should have simply been a RSx00 firmware update. Period.
I made a JVC 4K QuickStart Guide that will answer all 4K questions for a new RSx00 owner.
For HD & 3D, it really doesn't make a difference which projector you get. For 4K & HDR, that's where there is a bit of differentiation:
If you want the least amount of hassle, I do suggest the RSx20 or above. It has a built in HDR curve and will automatically switch over when you put in a 4K disc and you really don't need to worry about anything else, unless you want to start tinkering around (which you can still do).
If you are okay with a bit of hassle, you can get a RSx00 model and follow my guide which outlines the steps to get the most out of your projector.
mtbdudex and Hawks07 like this.
post #5120 of 5913 Old 04-27-2018, 10:54 AM
Liked: 2250
Some additional details:
The RSx20 has an additional HDR mode (not just the ST2084 HDR curve). The distinction is important, as if you create a custom HDR gamma curve and select it in the HDR mode, whenever the projector detectors HDR source it will use your custom curve and not the built-in ST2084 curve.
In comparison, the RSx00 only has a “Gamma D” curve, which the projector will use even when you prefer the custom curve.
post #5121 of 5913 Old 04-27-2018, 11:05 AM
Dreamliner's Avatar
Liked: 810
The RSx20 has an additional HDR mode (not just the ST2084 HDR curve). The distinction is important, as if you create a custom HDR gamma curve and select it in the HDR mode, that custom curve will be used automatically whenever an HDR source is detected.
Right exactly. Which is why the RSx20 models are recommended if someone wants the simplest solution possible.
post #5122 of 5913 Old 04-27-2018, 12:26 PM
mtbdudex's Avatar
Quoted: 85 Post(s)
Liked: 1582
I truly enjoy my RS400 PJ, but now it’s another $550 for a oppo 203 to give same usability as it should have itself , I feel cheated .
Does anyone know if JVC will do a software fix for the RSX00 models??
Have they been asked about it?
mtbdudex is offline
post #5123 of 5913 Old 04-27-2018, 01:05 PM
Quoted: 146 Post(s)
Liked: 54
Zero chance of a software update for these models for HDR. There should have been an update when the RSx20 models came out with updated HDR modes but JVC opted not to. It stinks but it's a fact we have to live with.
Depending on your setup you may be able to just download some pre made curves and get outstanding results without buying the Oppo.
I tried the Oppo for a couple of months and liked it but now I have custom curves installed by Chad B and it looks great so the Oppo is going back.
You may also want to hang tight and wait for the Panasonic players next month. They will be a little cheaper than the Oppo and might have better results with tone mapping right away.
Jive Turkey and mtbdudex like this.
Hawks07 is offline
post #5124 of 5913 Old 04-27-2018, 01:14 PM
mtbdudex's Avatar
Quoted: 85 Post(s)
Liked: 1582
Thx, will the panny have hdmi input and dual hdmi outputs like the 203?
mtbdudex is offline
post #5125 of 5913 Old 04-27-2018, 01:20 PM
Liked: 10830
Dual output, most likely. HDMI input, very doubtful.
post #5126 of 5913 Old 04-27-2018, 01:37 PM
Quoted: 146 Post(s)
Liked: 54
Yeah, here are the specs listed on their site for the 420 model.
https://www.panasonic.com/uk/consume...0eb.specs.html
Hawks07 is offline
post #5127 of 5913 Old 04-27-2018, 06:51 PM
radchad3's Avatar
Quoted: 26 Post(s)
Thank you all for the input on the HDR and reliability!
Chad
post #5128 of 5913 Old 04-28-2018, 07:09 AM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 644
My RS400 has been great, no issues with 1700+hrs on it.
Other than the Gamma D nonsense on a $4k PJ.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #5129 of 5913 Old 04-29-2018, 10:01 AM
Moebius's Avatar
Quoted: 233 Post(s)
Liked: 148
I haven't had to think about my projector for the last 18 months or so (just been using it), but as I finally decided to get a 4k player, it brought a couple things to mind. First of course is getting the color profiles and curves loaded. That's easy enough to do. The second is a problem it seemed a handful of folks witnessed on the JVCs and I'm curious if any firmware updates ever corrected it.
We all know the JVC takes a while to pair to the given input mode, but the problem is when switching back and forth on a semi-frequent basis, every once in a while the projector goes ballistic and starts through random color lines all over the screen (no image, just the lines). The only way to correct is to power cycle the projector, which of course means waiting for the bulb cool down time and all, plus it can't be great for the bulb. I can't remember which owners thread I saw some other folks talking about it, but does anyone know if there have been any firmware updates that might have addressed it?
Remember, no matter where you go... You're not where you were anymore.
HJ Movie House Build Thread
Moebius is offline
post #5130 of 5913 Old 04-29-2018, 12:30 PM
Quoted: 146 Post(s)
Liked: 54
Yes this is a really annoying issue that still pops up occasionally for me as well. For me it seems to happen when I add a new device to the chain or when I upgrade firmware on a device like a blu ray player.
I just recently added the Oppo and had this problem when I upgraded the Oppo's firmware.
As far as I know there is no firmware fix for this. Some people say that turning off CMD fixes it but it is off in my unit and I still have the problem.
Hawks07 is offline
DLA-RS400 , DLA-RS500U
