Official JVC DLA-RS400 (X550/X5000) Owner's Thread - Page 194 - AVS Forum | Home Theater Discussions And Reviews
 3547Likes
post #5791 of 5804 Old 11-05-2019, 11:04 AM
livermore larry's Avatar
Originally Posted by xton View Post
Hello!
Has anyone been able to change the original bulb (PK-L2312U) for a Ushio NSHA265JK Bulb? I wanted to know if it was easy to change it and if the new one gives the same result as the original one.
I did mine about a month ago. Picture is great. Like a new projector. When you change bulb I would wear latex gloves and avoid touching the bulb. The screws on my housing were a little hard to loosen. Use the correct screwdriver and be careful not to round off the head of the screws.
mtbdudex, xton and Dominic Chan like this.
livermore larry is offline
post #5792 of 5804 Old 11-05-2019, 02:56 PM
kgveteran's Avatar
Quoted: 795 Post(s)
Liked: 238
Read an article about the panasonic ub420, if i have already loaded my curves and the 60nit curve is the most used, and works well, why would I benefit from tone mapping ??
kgveteran is offline
post #5793 of 5804 Old 11-05-2019, 03:41 PM
Quoted: 5022 Post(s)
Liked: 1934
Your tone mapping curve is fixed, whereas the Panasonic tone mapping is optimized for each movie, assuming the metadata is correct.
Dominic Chan is online now
post #5794 of 5804 Old 11-05-2019, 05:03 PM
kgveteran's Avatar
Quoted: 795 Post(s)
Liked: 238
Hello Dom,
Many thanks for all the curve loading patience.
Is the ub420 plug and play, it will not use my fixed curves ? Can u explain that a little please
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
post #5795 of 5804 Old 11-05-2019, 05:28 PM
Liked: 1934
Hello Dom,
You can set up the UB420 to output HDR, in which case it adjusts its output according to the movie but still uses your fixed curves; or set it up to output “SDR/BT.2020”, in which case it bypasses your curves.
Some people prefer the first approach, others the second.
post #5796 of 5804 Old 11-06-2019, 12:05 AM
xton's Avatar
Many thanks!! Now I just have to find a trusted store to buy it and send to Spain
xton is offline
post #5797 of 5804 Old 11-06-2019, 04:35 AM
xton's Avatar
And if anyone knows where to get it, tell me, because I still can't send pm.
Many thanks
JVC DLA-RS400; Denon AVR-X1500H; RX 1080 ti; Dynavoice fan and MadVR
Hi-Shock "High Diamond" 3d glasses. Elite screen 137", Black Cave.
xton is offline
post #5798 of 5804 Old 11-06-2019, 04:50 AM
kgveteran's Avatar
Quoted: 795 Post(s)
Liked: 238
Thanx again Dom !!
So, any owners of the RS400 using the panasonic UB420 ??
post #5799 of 5804 Old 11-06-2019, 05:39 PM
Dreamliner's Avatar
Quoted: 1446 Post(s)
Liked: 769
From what I understand, for our needs the 420 & 820 are functionally identical. The 420 simply doesn’t have DV. If I was buying today it’d probably be the UB420, now that it is available. I have a UB820 & JVC Optimal Settings Guide. The UB420 should be identical or extremely similar (still waiting on a UB420 owner to confirm this for me).
I wouldn’t think to hard on this. What the RS400 can look like with a 420/820 is pretty outstanding, no hyperbole.
Jive Turkey likes this.
Dreamliner is online now
post #5800 of 5804 Old 11-18-2019, 12:30 PM
atscscm's Avatar
Liked: 0
Hi Guys,
Which 3D glasses are recommended to buy for JVC x5000 (Cheap not original one. ) ?
thanks
JVC x5000 | Screen 100' Magic Screen Future Black | AVR Marantz 8012 | Media Players - Apple TV 4K - Zidoo Box x10 + 24TB server | Monitor Audio RX 7.1.2 | Sub REL 328
atscscm is offline
post #5801 of 5804 Old 11-18-2019, 05:23 PM
Dreamliner's Avatar
Liked: 769
I use some cheap Samsung brand ones, I know there is a guide floating around that has a breakdown of what glasses are best.
There are some polarization differences so some glasses are better than others and let more light through ("brighter"). I do know the JVC ones are the 'brightest' but are ridiculously overpriced.
I read something about rotating the glasses 90° to see the 'potential brightness' or something. I can't find the post but I know there is a post somewhere here that has more details about what I'm trying to say.
post #5802 of 5804 Old 11-18-2019, 09:23 PM
Pip
Pip's Avatar
Quoted: 355 Post(s)
Liked: 161
Hi Guys,
thanks
See this thread: https://www.avsforum.com/forum/24-di...tter-jvcs.html
Pip
Pip is offline
post #5803 of 5804 Old Yesterday, 03:28 AM
xton's Avatar
Hi Guys,
thanks
Hi,
I have this https://www.hi-shock.de/en/rf-pro-hi...-900-polarized and work perfectly with my JVC RS400
The issuer also bought it from them. Very cheap and works perfectly
https://www.hi-shock.de/en/rf-emitte...jvc-projectors
xton is offline
post #5804 of 5804 Old Today, 11:06 AM
Liked: 1
I have the issue that when i start a 3D movie (JVX DLA-X5000) the picture (seen through the official JVC glasses) is much too dark (actually pitch-black!).
It can also be observed on the highlight color of the on-screen-display which normally looks yellow, it turns dark orange.
But i can fix it by pressing the "3D FORMAT" button numerous times so it cycles through all the modes: Auto, Side by Side, Top and Bottom, 2D, until the picture suddenly shifts into correct brightness.
It is totally random which setting gives the correct brightness, sometimes i have to press one time, sometimes 10 times to fix it.
Normally a setting of "Auto" should give the correct brightness, but i have to fix it manually each time.
To rule out any problems with the AVR i have tried to connect the source (a Dune HD media player) directly to the projector, but it made no difference.
Any suggestions to what might be the cause of this?
Domesticus is offline
DLA-RS400 , DLA-RS500U
