Official JVC DLA-RS400 (X550/X5000) Owner's Thread - Page 198 - AVS Forum | Home Theater Discussions And Reviews
 3574Likes
post #5911 of 5931 Old 02-21-2020, 12:48 PM
kgveteran's Avatar
Quoted: 883 Post(s)
Liked: 255
After about 2hrs in Hi Lamp mode i lose my image, do you think it could be a heat issue.
Is there a tab with temperature reading ?
If i pause the movie, image comes back in about 8seconds.
If i put on my ceiling fan to mix up the room ceiling air, image stabilizes......
I have cleaned out the filter in the pj
kgveteran is online now
post #5912 of 5931 Old 02-21-2020, 01:06 PM
Quoted: 5791 Post(s)
Liked: 2319
If the problem only occurs with High Lamp it could be a heat issue. You can try turning on the High Altitude mode but combined with High Lamp it is quite loud.
Dominic Chan is online now
post #5913 of 5931 Old 02-21-2020, 04:59 PM
kgveteran's Avatar
Quoted: 883 Post(s)
Liked: 255
I guess the ceiling fan’s gotta be on for HDR
Has there been any interest in the
Vertex2 for the 400 ? Makes the HDR more plug/play
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
post #5914 of 5931 Old 02-28-2020, 03:15 PM
descalabro's Avatar
Quoted: 514 Post(s)
Liked: 201
I just saw an X550 go on eBay for around six hundred bucks. Sometimes I wished I lived in the US.
4,3 x 2,8m semi-blacked out media room | 2010 MacMini > Pioneer VSX-520-K > JVC RS50 (X7) > 107", 1.1 gain, white screen | JVC X30 (RS45)
descalabro is offline
post #5915 of 5931 Old 02-28-2020, 03:32 PM
Liked: 2319
Do you have the link? That sounds way too low.
post #5916 of 5931 Old 02-28-2020, 06:31 PM
descalabro's Avatar
Quoted: 514 Post(s)
Liked: 201
https://rover.ebay.com/rover/0/0/0?m...2F193358503943
post #5917 of 5931 Old 02-29-2020, 08:09 AM
jake51's Avatar
Quoted: 329 Post(s)
Liked: 76
4K HDR on JVC X5000 vs X5500?
I have a X5000 (calibrated only for SDR)
I can buy an ISF calibrated X5500 with a new bulb
Is this a bad idea, as in will I be able to see a real difference with 4K HDR?
jake51 is offline
post #5918 of 5931 Old 02-29-2020, 10:26 AM
kgveteran's Avatar
Quoted: 883 Post(s)
Liked: 255
Now it is happening either Hi or Low lamp after about 1.5hrs :0/
I pause the movie, image appears after a few seconds and sometimes just stays on til the end of the movie
Im gonna watch some cable tv HBO movies to rule out the shieldTV as a problem maker
post #5919 of 5931 Old 03-03-2020, 05:46 AM
Liked: 2
Hey guys.
Scored a wicked deal on an rs400. I am getting ready to dive head first into using the oppo or Panasonic work around for HDR. I just want to clarify - will my amazon basics HDMI cables (I’ve used them throughout my entire system) work for 4k HDMI? They are rated for 4k HDR @ 60. But we know ratings, any first hand experience with them? Any other recommendations on how to go about this and not make mistakes someone else has made is appreciated !!!
Love the picture so far
Hbs187 is offline
post #5920 of 5931 Old 03-03-2020, 05:54 AM
Liked: 3
If they are rated for 4K/60 (18Gbps) they should work just fine.
If not you will notice yourself as you are not able to send 4K/60 signals, projector blacks out, player falls back to 8 bit etc. stuff like that
SimpleTheater likes this.
Peule_P is offline
post #5921 of 5931 Old 03-04-2020, 11:32 AM
batpig's Avatar
Quoted: 5039 Post(s)
Liked: 5513
Originally Posted by Hbs187 View Post
Hey guys.
Unfortunately, you won't know until you try. HDMI cables SHOULD work but they can be flaky. But if you're not going to send HDR to the PJ and let the Panasonic convert to 4K/SDR/BT2020 that should lower the bandwidth of the signal and make it less likely the HDMI cable will barf.
The big problems happen when you are pushing the 18gbps limits of HDMI 2.0, like a 4K/60 HDR signal at 4:2:2 with 10/12 bit color.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5922 of 5931 Old 03-05-2020, 10:36 AM
kgveteran's Avatar
Quoted: 883 Post(s)
Liked: 255
Anyone using a HD Fury Vertex2 with their RS400
post #5923 of 5931 Old 03-22-2020, 11:12 PM
Quoted: 103 Post(s)
Liked: 7
I’m Using original vertex with my x5000(rs400) and is a great addition. It provides the same if not more features than the recent rs440 I think the model is, here in OZ it’s the x5900. Vertex2 will add more features so go ahead and purchase, you will not regret it
johnnyboy632 is offline
post #5924 of 5931 Old 03-23-2020, 04:01 AM
Quoted: 103 Post(s)
Liked: 7
Just a little peculiar thing that happens with my projector is that I set my lense shift but over time it will slightly shift, it’s no big deal but constantly have to shift it a couple of notches, anyone have similar issue
post #5925 of 5931 Old 03-23-2020, 05:04 AM
Adamd's Avatar
Quoted: 1258 Post(s)
Liked: 715
Originally Posted by johnnyboy632 View Post
Just a little peculiar thing that happens with my projector is that I set my lense shift but over time it will slightly shift, it’️s no big deal but constantly have to shift it a couple of notches, anyone have similar issue
Most projectors will shift a bit when they go from cold to warmed up. My x790r shifts to the left and moves down a small amount while warming up. Best thing to do I’ve found it wait till it’s been on for a hour or 1.5 hours then set it. It will shift a bit when it cools down but when it warms up it should go back to the way you set it.
Adamd is online now
post #5926 of 5931 Old 03-23-2020, 06:46 AM
Quoted: 103 Post(s)
Liked: 7
Ok makes sense thanks for the quick reply, cheers
post #5927 of 5931 Old 03-23-2020, 03:58 PM
Pip
Pip's Avatar
Quoted: 382 Post(s)
Liked: 187
Mine does that too. Every three months or so I need to reset.
Pip
Pip is offline
post #5928 of 5931 Old 03-24-2020, 12:42 AM
Quoted: 103 Post(s)
Liked: 7
Pip
Previous explains why it does which makes sense, once projector warms up after an hour adjust then leave it. When you power on another time it will be slightly out but once warmed up it will return to normal
post #5929 of 5931 Old 03-25-2020, 08:25 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7269 Post(s)
Liked: 7296
Someone snagged a great deal, as long as it does not have nay issues.....
Cleveland Plasma is online now
post #5930 of 5931 Old 03-26-2020, 10:25 AM
kgveteran's Avatar
Quoted: 883 Post(s)
Liked: 255
“i cannot tell you exactly for your JVC PJ, you can ask in avsforum JVC thread to get input from same PJ owners. but basically you just have to enable macro and set sync time to match your PJ sync time.”
That message is from HD Fury concerning setting macros to control my user settings (loaded curves) when viewing HDR/UHD in 1080p.
Any help with this would be great, thank you
post #5931 of 5931 Old 03-26-2020, 04:38 PM
descalabro's Avatar
Quoted: 514 Post(s)
Liked: 201
Indeed.
DLA-RS400 , DLA-RS500U
