Official JVC DLA-RS400 (X550/X5000) Owner's Thread - Page 200 - AVS Forum | Home Theater Discussions And Reviews
 3581Likes
post #5971 of 5997 Old 05-18-2020, 06:48 AM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
Originally Posted by Dominic Chan View Post
Any RS400 owners use a harmony elite remote AND successful added Lens Memory commands for all 5 presets ???
When I added an RS2000 (which has 10 “Installation Modes”) to the Harmony Elite, it was able to control all 5 memory presets of the RS400.
Worked like a charm, between the LensControl presets and the Vertex2, im pretty close to plug-n-play.
**HT Build https://www.avsforum.com/forum/19-ded...-door-0-a.html **
kgveteran is online now
post #5972 of 5997 Old 05-18-2020, 06:50 AM
Quoted: 6134 Post(s)
Liked: 2545
Are you controlling the Vertex using the Harmony?
Dominic Chan is online now
post #5973 of 5997 Old 05-18-2020, 08:01 AM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
No, i only use one input of the vertex (hdmi2)(the only input that would consistency sense output from the AUTO MONITOR OUT of the X4300 Denon) for my JVC to the Vertex using TX1 downscale
I did try quicky to plug all 3 sources into the Vertex, then both monitors connected to the Vertex2, and audio out to the AVR.......Total debacle!!! It was two days from hell :0/ . The input switching was intermittent at best, the next day, nothing would work right. Harmony’ offered 3 different input switching codes that im not really sure if they even worked right, there had to be a bit of USER ERROR to be fair....
This is my final configuration that does 100% of what i need !!!
My system
ShieldTV pro,LG BR UP970,SamsungCablebox (each get their own HDMI)
->6’copperMonoprice18gbps
->DenonX4300
->Monoprice 6’ copper HDMI 18gig->Vertex2 HDMI2/Vertex2 TX1->35’ Monoprice active 18gig->JVC RS400
RS232 works perfect ! No more GammaD. The two most used presets for LensControl 1.85:1 and 2.35:1 and i have an aspect ratio for Ozark, its line a weird 1.85:1 kinda aspect. I did have to ENABLE macros, ive read some people dont have to do that.
And im totally bummed i WONT be seeing FooFighters wednesday in Hamilton On :0(
post #5974 of 5997 Old 05-18-2020, 08:28 AM
Liked: 2545
How do you detect the change in aspect ratio?
post #5975 of 5997 Old 05-18-2020, 08:40 AM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
By eye......
The 185 and 235 are easy, but there is this Ozark series one thats smaller that 185, but im able to resize it zoom/shift with little grey bars on the side. Regardless of zoom and shift, the RS400 looks better than my Optima with an A-lens(CIH)
I would like to change the names of the lens memory on the Harmony app remote for my iphone, but cant figure it out, changing the names on the Elite remote was easy
post #5976 of 5997 Old 05-18-2020, 08:52 AM
Liked: 2545
By eye......
Harmony works well. I thought you were using the Vertex Macros to automatically change the aspect ratio.
post #5977 of 5997 Old 05-18-2020, 10:55 AM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
By eye......
I did a little research on auto aspect ratio, wow big money
post #5978 of 5997 Old 05-18-2020, 11:36 AM
batpig's Avatar
Quoted: 5115 Post(s)
Liked: 5693
Added the RS2000 to my Harmony profile and "Installation Modes" 1-5 work perfectly to recall all 5 Lens Memory slots on the RS400, nice!
For lens memory I have the following presets:
- 2.39:1 mode (basically full width for the screen for widescreen content)
- 2.00:1 mode (Netflix original content is usually 2:1 ratio)
- 1.85:1 mode (for "flat" movies)
- 16:9 mode (for HDTV content)
- small screen mode (for low quality content where I don't want to fill up the giant screen, just a smaller rectangle that's ~100" diagonal)
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
post #5979 of 5997 Old 05-18-2020, 07:43 PM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
What do you use for HDR ?
post #5980 of 5997 Old 05-20-2020, 01:36 PM
batpig's Avatar
Liked: 5693
I'm not following, HDR content comes in all sorts of aspect ratios just like non-HDR content. Are you still talking about lens memory?
Setup Guide and FAQ
batpig is offline
post #5981 of 5997 Old 05-21-2020, 07:49 AM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
Ohhh sorry about being unclear, wondering how ur RS400 handles HDR, did you load curves, are you using a Vertex type product to negate GammaD issues
post #5982 of 5997 Old 05-21-2020, 12:16 PM
batpig's Avatar
Liked: 5693
No, I just use a UB820 to send 4K SDR + Rec.2020 on 4K HDR discs.
Setup Guide and FAQ
batpig is offline
post #5983 of 5997 Old 05-21-2020, 05:34 PM
SirMaster's Avatar
Quoted: 1221 Post(s)
Liked: 842
Yeah Panny tone-mapping is better than even custom Arve curves IMO.
SirMaster is online now
post #5984 of 5997 Old 05-21-2020, 10:28 PM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
Gotcha
Thats what im hearing
post #5985 of 5997 Old 05-23-2020, 07:58 AM
wes nance's Avatar
Any danger in continuing to use a bulb after the RS400 starts to give the “bulb replacement” message on boot up? I just did a thread search for a while and couldn’t come up with an answer. My PJ has upwards of 3400 hours on the original bulb, and on my 138” 2.35:1 CIH setup it still looks very, very bright. I do have a replacement bulb, so will replace when convenient.
Anyone get to the actual end of their bulb life? What happened?
wes nance is offline
post #5986 of 5997 Old 05-23-2020, 05:23 PM
nathan_h's Avatar
Quoted: 2960 Post(s)
Liked: 2082
Urban legend, probably based on something real, warn that the older bulbs get, the more likely they are to implode or burst....and that on some projectors that has resulted in damage to the system other than just to the bulb.
That being said, people with far fewer hours have had a bulb "explode" without permanent damage to the projector.
So, do you feel lucky?
Impressed you got that many hours out of the bulb. When I hit 1000 hours, my system struggles to reach 100 nits in high lamp mode on my 8 foot wide Seymour woven screen.
My current setup.
Recommended podcasts: The Next Picture Show, the /filmcast, AV Rant.
nathan_h is online now
post #5987 of 5997 Old 05-24-2020, 04:44 AM
muzz's Avatar
Quoted: 932 Post(s)
Liked: 647
I had a Sharp DT-500 as my 1st PJ, Bulb blew up with about 100hrs on it, since then I have put massive hrs on 2 other projectors(4 bulbs) without issue.
My 400 has ~2500 on it right now, and it's still bright on low.
I have no intention of replacing it any time soon, although I am getting ready to order a new bulb to have on hand.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #5988 of 5997 Old 05-24-2020, 08:17 PM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
What do you use for your Macro Tab MaxBrightness or MaxCLL
post #5989 of 5997 Old Yesterday, 06:23 AM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
Wait, u mean you send 2K SDR/BT2020, which doesnt flag and bring up the dreaded gammaD, but delivers HDR ???
Or i may be wrong.......
post #5990 of 5997 Old Yesterday, 06:26 AM
nathan_h's Avatar
Liked: 2082
It sounds like it delivers SDR, but an improved SDR since it includes wide color and 4k resolution. This is a common and useful approach to viewing UHD content on a projector.
My current setup.
post #5991 of 5997 Old Yesterday, 11:37 AM
Liked: 2545
SDR/BT2020 is really a misnomer. When you use that option, the player (or HTPC) “handles” the HDR10 ST.2084 EOTF function and the tone mapping associated with it, so the projector does not need to “worry” about it and can use the “SDR gamma” of 2.4. However, the displayed image is the same as when you “output HDR” and have the projector handle the ST.2084 EOTF (other than one may do a better job in tone-mapping than the other).
Thus you’re not “giving up” or compromising HDR when you output SDR/BT2020.
In the case of the RS400, SDR/BT2020 has the further advantage of not triggering Gamma D.
nathan_h likes this.
post #5992 of 5997 Old Yesterday, 12:10 PM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
Thus you’️re not “giving up” or compromising HDR when you output SDR/BT2020.
What in the Hell does this forum do to what we type :0/
post #5993 of 5997 Old Yesterday, 12:29 PM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
Which allows you to eshift or not, and engage DI or not.......
post #5994 of 5997 Old Yesterday, 01:16 PM
Liked: 2545
Are you using an Android phone? I have problems seeing the original message on a computer or on an iPad. Your posted replies turned some punctuation marks into strange character strings.
post #5995 of 5997 Old Yesterday, 07:02 PM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
Its an iphone....
Do you use MaxBrightness or MaxCLL
post #5996 of 5997 Old Yesterday, 07:44 PM
Liked: 2545
I’m not sure what you’re asking. The CUSTOM HDR10 PROFILES check both Max Brightness and MaxCLL.
post #5997 of 5997 Old Today, 03:34 AM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
I’️m not sure what you’️re asking. The CUSTOM HDR10 PROFILES check both Max Brightness and MaxCLL.
Did you setup all six of your custom HDR10 profiles, thats my last step, i just used my 60nit curve for all six just to have something there, and get to it later
I notice BR discs never look dull, i was streaming Netflix (Fleabag) and the HDR was a bit dim. Theres alot of info on the screen but i need to move the txt cause i watch alot of 2.35:1 and 200:1 the txt is off the screen
Setting the vertex to 19seconds works real nice on the macro tab
DLA-RS400 , DLA-RS500U
