JVC 4k Native Laser projector (confirm) - Page 134 - AVS Forum | Home Theater Discussions And Reviews
 3995Likes
post #3991 of 5254 Old 02-16-2017, 03:54 AM
Dave Harper's Avatar
Quoted: 3159 Post(s)
Liked: 1723
Originally Posted by OzHDHT View Post
Dave think you're misinterpreting me again mate. I'm far from worried about doing it. ......
You're totally confusing me then, sorry. When people say they don't want to be a "guinea pig", at least to me, it means they're a little worried about being one of the first to be doing what someone's asking.
Let's just leave it here then. Enjoy your 4500/Z1 while I continue to sit here being jealous!
Dave Harper is offline
post #3992 of 5254 Old 02-16-2017, 09:06 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2384
Thanks Craig, that's good to know. Does sound kind of surprising it would be that easy to plug in the custom gamma curves from the lamp based 5/6xxx series into the 4500. Maybe I'll be patient and wait for one of the other guys to give that ago. I may not be home tonight to try it anyway.
I don't see why it wouldn't work, assuming JVC hasn't changed the file format for the new calibration software. There's nothing specific to the projectors being lamp based. It's just an gamma curve that's been calibrated to approximately match the ST.2084 EOTF. What they are, is setup specific. In other words the curve I made is specific to my setup, my measured peak luminance, and possibly any anomilies in my projector's native gamma (though I believe the autocal should take that out).
On the RSx00's the built in Gamma D curve is very bad, and these custom curves are much, much better. The remaining question is, what's different about the new "HDR" curve in the RS4500 (and RSx20s), hopefully they're fixed and there's no benefits to running a custom curve.
Dave Harper likes this.
stanger89 is offline
post #3993 of 5254 Old 02-16-2017, 09:10 AM
Mike Garrett's Avatar
Quoted: 11816 Post(s)
Liked: 9351
The gamma curve in the RS4500 is not bad now.
OzHDHT likes this.
Mike Garrett is offline
post #3994 of 5254 Old 02-16-2017, 09:30 AM
stanger89's Avatar
Liked: 2384
Sorry, didn't mean to imply that it was, but I guess we don't know if it's just an improved version of Gamma D (with enough fiddling you could get that looking decent on the RSx00's), or if it's entirely new and based of ST2084. If it's the later, I don't expect there'd be much benefit with a custom gamma.
post #3995 of 5254 Old 02-16-2017, 01:41 PM
Bandyka's Avatar
Quoted: 2327 Post(s)
Liked: 1422
Does anyone know where/if this PJ can be demoed in the Sydney area AUS?
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #3996 of 5254 Old 02-16-2017, 01:46 PM
Kris Deering's Avatar
Quoted: 3750 Post(s)
Liked: 6399
Correct, it is a better plug and play than the other line (though I'm still looking at the RS620 in this regard). BUT, the approach Manni is taking should benefit 4500 owners just as much, if not more, than the other JVC owners. They all still have to try and conform somehow to the standards and since the 4500 can do laser dimming, it would make it better for blacks on top of it. No doubt in my mind, I'd be all over this with the 4500 if I still had it here.
Dave Harper and OzHDHT like this.
My Home Theater UPDATED DEC 2017
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is offline
post #3997 of 5254 Old 02-16-2017, 05:27 PM
Craig Peer's Avatar
Quoted: 6612 Post(s)
Liked: 7684
I downloaded and tried the 1100 - 800 - 4000 gamma. Interesting, but I think I like either the HDR preset, or strangely enough, that new gamma looks closer to SDR Rec. 709 to me. At least on my RS4500. No time to experiment more right now.
Craig Peer is online now
post #3998 of 5254 Old 02-16-2017, 05:40 PM
OzHDHT's Avatar
Quoted: 1216 Post(s)
Liked: 732
I definitely never said I didn't think it would work. My only comments were based around the curve being suitable across both the 5/6xx series and 4500. Listening to Kris it seems to be very likely there is a significant benefit to be had.
You'd have to speak to JVC as the 2 units they have, as I indicated in my recent posts both being tested and calibrated at Sydney production houses in last week (the second still at one this week). From what I know one unit would be back with JVC, not sure if they've loaned it out again since last week. Again I'd call them directly and inquire, that would be your best bet.
You've inspired me to take action Kris! Sounds like my Friday night project if I get left alone to do it for few minutes after work . If I can persuade the Mrs to want to watch a 4K movie with me I'll get a decent opportunity to evaluate it as well.
Missed your post while I was replying to others. There you go, I knew someone would probably get to it before me. Interesting stuff Craig. I was testing my Panny and Oppo yesterday briefly and redid the Panny pic settings back to base and looked at a couple of scenes in The Shallows. The chapter I had pre-cued was going into the shadowy night scene. I was pretty happy with results in HDR mid or high. Did see mode 2 dimming jump a couple of times noticeably.
OzHDHT is offline
post #3999 of 5254 Old 02-17-2017, 06:13 AM
Kevin 3000's Avatar
Quoted: 141 Post(s)
Liked: 39
Still looking to upgrade my X90.
Shot at 18mm 1/5sec f3.5 standard kit vr lens handheld - Gamma 2.2 - 3m screen
Kevin 3000 is offline
post #4000 of 5254 Old 02-17-2017, 08:36 AM
Craig Peer's Avatar
Liked: 7684
At this point I'm just going to get Jeff in here to calibrate it.
OzHDHT likes this.
post #4001 of 5254 Old 02-17-2017, 09:00 AM
stanger89's Avatar
Liked: 2384
Come on, where's your sense of adventure?
post #4002 of 5254 Old 02-17-2017, 10:37 AM
Gary Lightfoot's Avatar
Quoted: 1302 Post(s)
Liked: 1053
And his brown trousers?
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #4003 of 5254 Old 02-17-2017, 11:38 AM
Liked: 1723
They were left on the cutting room floor!
post #4004 of 5254 Old 02-17-2017, 11:56 AM
Craig Peer's Avatar
Liked: 7684
I loaded it, I tried it, it looked poor. What more do you want ? It actually looked closer to SDR Rec.709 than HDR. The thing is, I know Rec. 709 is good out of the box. So, I have better options right now. But I gave it a shot !
OzHDHT likes this.
post #4005 of 5254 Old 02-17-2017, 11:58 AM
Craig Peer's Avatar
Liked: 7684
I'm guessing it works better on JVC projectors other than the RS4500. But if I had unlimited time, maybe I could get better results.
OzHDHT likes this.
post #4006 of 5254 Old 02-17-2017, 12:01 PM
stanger89's Avatar
Liked: 2384
Woops, thought you hadn't tried it
post #4007 of 5254 Old 02-17-2017, 12:13 PM
Craig Peer's Avatar
Liked: 7684
See post # 4010 !
post #4008 of 5254 Old 02-17-2017, 01:31 PM
Javs's Avatar
Quoted: 6791 Post(s)
Liked: 6418
Go and demo real projectors instead or comparing images in a forum then
SJHT, OzHDHT, Craig Peer and 1 others like this.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #4009 of 5254 Old 02-20-2017, 04:22 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 509 Post(s)
Liked: 598
It's grown rather quiet here.
Cam Man is offline
post #4010 of 5254 Old 02-20-2017, 04:25 PM
Craig Peer's Avatar
Liked: 7684
Shhh, we're busy watching movies.
cardoski and Bandyka like this.
post #4011 of 5254 Old 02-20-2017, 04:30 PM
Craig Peer's Avatar
Liked: 7684
I used my new Sper Scientific light meter to re - measure my RS4500. Mind you that these numbers only apply to my setup and should be taken with a grain of salt. If I moved 8" closer to the projector, the numbers jump and I would have much higher numbers. This is mostly so I'll have an idea how bright I'm watching in MY room on MY screen with MY setup. Taken at the screen ( 122" 16:9 Stewart Cima Neve - 1.1 gain ), facing the projector from 14' , Natural mode, manual iris open, auto iris off -
Low laser - 615.64 lumens. That would give me 15 + foot lamberts.
Mid Laser - 1516.69 lumens. That would give me 38 foot lamberts !
High Laser - 2242.42 lumens. That would give me 56.22 foot lamberts - ha !
The way I've been watching it - Natural mode, Mid Laser, manual iris at -7, laser dimming mode 2 - 1104.90 lumens, 27.70 foot lamberts ! No wonder I thought it was bright ! I'm going to close down the iris and re - measure tonight - 18 or 20 foot lamberts is probably going to be better.
post #4012 of 5254 Old 02-20-2017, 05:00 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 225 Post(s)
Liked: 167
So you are reading fc, converting to ftL using the assumed gain, right? And calculating lumens form the fc reading. The way your post read it sounded like you were doing something different.
GetGray is offline
post #4013 of 5254 Old 02-20-2017, 06:36 PM
Craig Peer's Avatar
Liked: 7684
Correct - and assuming that my Stewart Cima Neve is 1.1 gain, although Jeff at Accucal measured it a bit higher. It just good to try and get things in the ballpark, without too much guess work. I'll see what Jeff measures with his much better ( and more expensive ) equipment when he calibrates it in a few weeks.
post #4014 of 5254 Old 02-20-2017, 07:33 PM
OzHDHT's Avatar
Liked: 732
Craig, out of curiosity, how do you add in the gain to calculate the lumens from fc? I had enough trouble working out the fc to Lumens formula correctly . I might pull out my old meter again and do some fresh measurements and try to calc my set up adjusted for the screen gain.
OzHDHT is offline
post #4015 of 5254 Old 02-20-2017, 08:29 PM
Craig Peer's Avatar
Liked: 7684
Once you know how many lumens are hitting your screen, you multiply by the gain ( x 1.1 in my case ) and divide by the square footage of your screen.
https://www.avsforum.com/forum/24-dig...ojector-5.html
See post 121, but Stanger89 has a simpler method in the following post.
post #4016 of 5254 Old 02-20-2017, 08:35 PM
OzHDHT's Avatar
Liked: 732
Great, thanks Craig. I'll definitely utilise that info! Cheers
OzHDHT is offline
post #4017 of 5254 Old 02-20-2017, 08:41 PM
Craig Peer's Avatar
Liked: 7684
I found an old note from 2 -22- 2007, when I first got my light meter. I had thought my Optoma H79 was a bit dim at the time. 244 lumens, 6.13 foot lamberts. It was then and there I swore to - A: never guess how bright my projector was, to actually measure it, and B: never watch a dim picture again ( I sold the Optoma and got a DPI dVision 1080p projector with twin 300 watt lamps )!
OzHDHT likes this.
post #4018 of 5254 Old 02-21-2017, 02:27 PM
Stereodude's Avatar
Quoted: 4233 Post(s)
Liked: 2988
Great! I will take a look and see if it makes a difference!
So what did you find out? Was the contrast performance affected by the location of the bright white boxes?
Stereodude is online now
post #4019 of 5254 Old 02-21-2017, 03:51 PM
R Harkness's Avatar
Quoted: 2755 Post(s)
Liked: 2659
I wouldn't be surprised, upon meeting Kevin 3000, to find him wearing a T-shirt bearing one of his screen shots.
Javs likes this.
R Harkness is offline
post #4020 of 5254 Old 02-21-2017, 10:45 PM
OzHDHT's Avatar
Liked: 732
Finally received a set of vents for the Z1. I've only switched the unit on for a few mins and not sat down for any actual viewing. As suggested by other owners and Kris, I do think they've helped change the pitch of the fan noise in good way. But I'll reserve judgement till I've spent real time with them fitted.
In more interesting news. I was informed by JVC, that the factory are about to make an official announcement about several issues. I was passed on the actual communication about this announcement which suffers from bad 'Engrish', however I got the gist. Without cut and pasting word for word here, these are the main takeaways from the initial statement : "official statement for DLA-Z1's several issues", which was due for release last Friday, but was unable to done within that dead line (insert very bad Engrish version of that explanation here), is the following line : "the root cause is rather deep and difficult to expain clearly sooner actually."
It seems they want to get the information across as clearly as possible as they are concerned about website forum feedback and rumors, which is fair enough. So I imagine we'll hear something in the next week. I have to say I'm more than a bit interested in what they have to say when they do. It sounds very much like they have taken on board the feedback from @ARROW-AV and quite possibly some of mine along with no doubt a few others around the globe.
OzHDHT is offline
