point projector down or keep level?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-11-2016, 12:18 PM - Thread Starter
smiddleton5401's Avatar
Quoted: 50 Post(s)
Liked: 25
I have a JVC X550R mounted in a bulkhead up approx. 88" that is shifting down with the lens. My question is, should I elevate the rear feet about 10-15 degrees (pointing the lens down) and shift the rest or should I keep it 100% level and just use the shift?
Specs:
Projector height 88"
Distance from screen 16'
screen size 130" wide 2.35 screen
smiddleton5401 is offline
post #2 of 3 Old 09-11-2016, 12:20 PM
Scott 44's Avatar
Quoted: 57 Post(s)
Liked: 43
LEVEL!
Scott 44 is offline
post #3 of 3 Old 09-11-2016, 01:05 PM
Michael9009's Avatar
Quoted: 342 Post(s)
Liked: 87
Keep the projector always level and use lens shift for vertical image adjustment. Never use keystone correction.
Michael9009 is offline
