Epson LS10500 4K (enhance) laser projector - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 451Likes
post #61 of 1280 Old 10-02-2016, 11:19 AM
DavidHir's Avatar
Quoted: 2532 Post(s)
Liked: 2198
Originally Posted by Mike Garrett View Post
My wish list for this projector was the following:
1. More calibrated lumens.
2. HDR
3. Full 18Gbps HDMI chip.
4. BT2020 compatibility.
If they had done these things, they would have been flying off the shelf.
More contrast too.
DavidHir is offline
post #62 of 1280 Old 10-02-2016, 11:57 AM
Mike Garrett's Avatar
Quoted: 11816 Post(s)
Liked: 9351
Originally Posted by Woof Woof View Post
Odd considering the LCD UHP models get the 18Gbps didnt they?
No, the 5040 is not 18Gbps. It is 10.2Gbps.
Mike Garrett is offline
post #63 of 1280 Old 10-02-2016, 12:31 PM
rak306's Avatar
Quoted: 616 Post(s)
Liked: 252
Originally Posted by LumenChip View Post
That is a possibility, but why stick to your guns with a formula that doesn't work. With most reverting to a WCG & SDR soup, this projector with around 2000 calibrated & stable lumens (and a $500 token price reduction) would be a very convincing buy. The LS10000 was Epson's first Laser attempt and reliability/longevity was a concern, but is no longer a concern for this round.
Check out at the 4 min mark of this interview with an Epson rep.
I doesn't sound like the LS line is much of a priority to Epson.
rak306 is offline
post #64 of 1280 Old 10-02-2016, 04:29 PM
Bandyka's Avatar
Quoted: 2327 Post(s)
Liked: 1422
Funny I've been thinking just the same, I can get and LS10K for crazy good price I could just use the fury and get SDR WCG.
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #65 of 1280 Old 10-02-2016, 07:20 PM
Woof Woof's Avatar
Quoted: 460 Post(s)
Liked: 253
not 18Gbps. It is 10.2Gbs
Wow. That being the case, it's basically the LS10000 with a firmware update.
Which begs the question: who's isn't the LS10000 getting a firmware update.
Woof Woof is offline
post #66 of 1280 Old 10-03-2016, 11:18 AM
Ruined's Avatar
Quoted: 2597 Post(s)
Liked: 1240
Or save a bunch of money and just play upscaled 2k blu-rays on it?
Is price of uhd player + fury + uhd discs worth it for wcg only? And further is it worth dropping from 1050 calibrated lumens to 800 calibrated lumens for P3 only? That reduction could prevent use of eco mode.
Seems like a stretch to justify using uhdbd vs. real world gain in doing so.
Ruined is offline
post #67 of 1280 Old 10-03-2016, 12:17 PM
DavidHir's Avatar
Liked: 2198
In that case, why not just get the 9600e? It has the same contrast although a little shy of the light output, but notably cheaper and seems like the better option of the two for someone just interested in BD for a while.
DavidHir is offline
post #68 of 1280 Old 10-03-2016, 04:46 PM
Ruined's Avatar
Liked: 1240
Few reasons:
- Light output is significantly less to the point where 3D and eco mode could be dark or even unusable. Ls10k has just enough for both.
- Still expensive at 5999, but won't hold value as well due to lacking the UHD checkboxes
- Lacks e-shift to eliminate SDE if an issue
Ruined is offline
post #69 of 1280 Old 10-03-2016, 04:50 PM
darrellh44's Avatar
Quoted: 1033 Post(s)
Liked: 499
IMHO, WCG is the only UHD feature worth pursuing with the LS10000. Even if it supported HDR (like the LS10500 supposedly will), they don't have the lumens to do it justice.
But having said that, no one has come up with a way to accurately display BT2020 on the LS10000 without an expensive 3DLUT box. The LS10000 can display an SDR/ BT2020 image, but its internal EOTF is not correct, and according to Epson, can only be corrected with a hardware change. Another UHD limitation as the LS10000 currently stands is it cannot accept a 4K signal and 10/12 bit color at the same time. Therefore your only two UHD operational modes (even with an expensive 3DLUT box) are 4K/SDR/BT709, or 1080p/SDR/BT2020.
Here's a review by Anna and Flo (@Soulnight) at ProjectionDreams that talks about this a little more in the comments section at the bottom.
http://projectiondream.com/en/epson-...jector-review/
As far as UHD support in the LS10500, I would wait before jumping in until some solid reviews are out. Since their new 6040/5040 PJs are based on new hardware platforms, they probably have a much better chance of working correctly.
DavidHir likes this.
darrellh44 is offline
post #70 of 1280 Old 10-03-2016, 04:53 PM
Bandyka's Avatar
Liked: 1422
Thanks that rules out the LS10K for me. Let's see what the new one is capable of.
Bandyka is offline
post #71 of 1280 Old 10-04-2016, 08:19 AM
DavidHir's Avatar
Liked: 2198
Pure speculation on my part, but it seems to me Epson focused on the 5040/6040. Maybe next year the LS10000/10500 will get a real upgrade especially with JVC presumably refreshing their RS line at that point.
DavidHir is offline
post #72 of 1280 Old 10-05-2016, 11:50 AM
jjcook's Avatar
Quoted: 463 Post(s)
Liked: 188
Where is the reference that the LS10000 cannot accept a 4K/24Hz/10-bit signal with filter engaged for P3 (with signal corrected with e.g. a Lumagen or hacked with a HDfury Linker)?
jjcook is offline
post #73 of 1280 Old 10-05-2016, 12:56 PM
darrellh44's Avatar
Liked: 499
I've had an incident ticket open with Epson for several months concerning this issue. There have been many back and forths as they research what they can/will do, and as I have asked new questions as I learn more details. Here is a direct quote from one of their more recent responses I received in mid-June. I assume SEC is their engineering department.
When the 4K signal is inputting to the LS10000, the projection image will be displayed as 8 bits color image regardless the bit number of the input signal.
Because the LS10000 will downscale the wide color gamut signal to 8 bits image.
Even if the UHD BD player can send the SDR+BT2020 or 10 bits image signal to the LS10000 by using the HDFury, the actual projection image from LS10000 is 8 bits image.
We guess the color bit depth of info menu is displayed as “---”, even in above method.
And SEC cannot guarantee the image quality which is realized by this method since the input signal is not supported in the first place.
In SEC’s basic opinion, SEC does not intend to update the firmware of the LS10000 to support the wide color gamut signal.
So it appears they can accept a 10/12 bit signal with 4K/BT2020, but it will be truncated to 8 bits before it reaches the display.
post #74 of 1280 Old 11-11-2016, 01:09 PM
Liked: 5
So I've read through this some and tried looking around a bit, but I'm struggling to find a good answer. Has anyone seen the LS10000 and the 6040 side by side for a comparison? I've got both of them available to me in roughly the same price range (the LS10000 is a display model) and I'm wondering which would truly be best for me. I'm upgrading my 3010, if that makes any difference.
scottsanz is offline
post #75 of 1280 Old 11-11-2016, 03:17 PM
Bandyka's Avatar
Liked: 1422
I was in the same dilemma and yes have seen them multiple times, the 6040 cannot hold a candle IMO so it was no brainer for me to go with the LS10K and never looked back.
Bandyka is offline
post #76 of 1280 Old 11-11-2016, 03:20 PM
Bandyka's Avatar
Liked: 1422
I came across this when someone was explaining how an older JVC PJ was actually displaying correct WCG with the Fury I was scratching my head at first but then I realized it must be the same trickery with the LS, so the fury compresses the signal to 8bit then the projector displays it in 10bit as it processes in 10bit internally and I have to say the end result is just the same as I've seen on my ex Sony 4K except the colors a deeper. So whatever the actual process is, using the Fury results in the same end result as JVC or Sony and actually better as the LS can display a wider gamut, I've verified this via different color meters and software. This has also been verified in the UK it's on an official site.
With those replies I think Epson are just playing safe.
Here is the official specs:
http://www.epson.com.au/products/pro...0000_Specs.asp
It says: "Colour Processing 10 bit (Partial 12bit)" Its processing internally.
Bandyka is offline
post #77 of 1280 Old 11-11-2016, 07:35 PM
Liked: 5
Thanks for the help there! I'm really looking forward to this one, but I wanted to make sure this decision made sense.
Bandyka likes this.
post #78 of 1280 Old 11-11-2016, 07:45 PM
Bandyka's Avatar
Liked: 1422
If you can get a 10K for the same price as a 6040 it's a real bargain.
kohe321 and scottsanz like this.
Bandyka is offline
post #79 of 1280 Old 11-12-2016, 07:33 AM
darrellh44's Avatar
Liked: 499
Did you ever get a response from Epson on what updates are in your v1.31 FW? Have you noticed anything different?
post #80 of 1280 Old 11-12-2016, 05:38 PM
Bandyka's Avatar
Liked: 1422
Not yet, I was about to follow up on this next Monday, I really want to know! I did notice a brighter image yes and seemingly more accurate WCG after calibration but this could be a placebo effect after having the loan unit for two weeks just not sure but I think it is brighter and more accurate. Let me do some testing to see if it is brighter if I can dig up the measurements of the old unit. Just for a test I was thinking we all complain that projectors don't enough brightness for HDR but I thought what if we shrunk the image to the size of a 65" TV so I did that and the peak brightness went from 120" 27ftL to 65" 48ftL
Bandyka is offline
post #81 of 1280 Old 11-12-2016, 06:23 PM
Javs's Avatar
Quoted: 6791 Post(s)
Liked: 6418
Get a 1.3 gain screen... 30% more brightness for free... I really like my screen from OZ Theatre Screens.
LumenChip likes this.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #82 of 1280 Old 11-12-2016, 07:49 PM
Bandyka's Avatar
Liked: 1422
I have no problems with mine 1.1.
Bandyka is offline
post #83 of 1280 Old 11-12-2016, 08:23 PM
Javs's Avatar
Liked: 6418
Not saying you do, just sayin you can get more brightness that way and keep the screen size big
Javs is offline
post #84 of 1280 Old 11-13-2016, 02:09 AM
Bandyka's Avatar
Liked: 1422
I get you Only did it as an experiment that's all, if I needed to run HDR that may be the way to go.
Javs and scottsanz like this.
Bandyka is offline
post #85 of 1280 Old 11-13-2016, 02:10 AM
Javs's Avatar
Liked: 6418
Oh course though with added gain comes increased black floor level...
Bandyka likes this.
Javs is offline
post #86 of 1280 Old 11-13-2016, 02:14 AM
Bandyka's Avatar
Liked: 1422
I am quite pleased as is for now.
Bandyka is offline
post #87 of 1280 Old 11-13-2016, 03:17 AM
Andreas21's Avatar
Quoted: 1133 Post(s)
Liked: 729
30% more brightness, but a lot of artifacts in most cases even the Studiotek 130 has artifacts like sparkle.
Andreas21 is offline
post #88 of 1280 Old 11-13-2016, 03:24 AM
Javs's Avatar
Liked: 6418
My screen has no sparkle. So, not all cases
None that I can see anyway. Sitting 1.1 screen width from 120 inch diag screen. 2700 hours worth of watching... perfect image.
scottsanz likes this.
Javs is offline
post #89 of 1280 Old 11-13-2016, 08:29 AM
Liked: 5
Thanks again for your input, Bandyka! I'm really looking forward to this projector, but I'm so impatient to get it. They'd already agreed to loan out the display unit on a new build until the customer can get their LS10500, so I have to wait for that to ship before I can get my LS10000. Oh, the waiting! How will I survive it???
post #90 of 1280 Old 11-13-2016, 10:56 AM
LumenChip's Avatar
Quoted: 222 Post(s)
Liked: 123
If only Epson will surprise us with 1500 Calibrated lumens. The JVC updates are a long way out and some of us are projectorless while we wait. A brighter Epson can steal some sales.
LumenChip is offline
ls10500
