Epson LS10500 4K (enhance) laser projector - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 472Likes
post #1351 of 1356 Old 11-27-2019, 11:16 AM
5x10's Avatar
Quoted: 923 Post(s)
Liked: 626
Originally Posted by btran33 View Post
I think there is a bug with the Epson, that sometimes it got the wrong color space, you just need to check if thing doesn't look right...
Go to Epson's menu:
Signal--->Advanced--->Color Space--->choose REC760
Exit menu
Done!
Thank you sir! It’s weird the Epson is switching even though my atv is set to 1080
Only happens on Netflix too, Amazon. Att tv, youtube are all looking normal
Originally Posted by bobpaule View Post
To overcome the green tint push on my replacement LS10500 (had all the labels on, did not look like a refurb, 15hours) I had to set:
Skin Tone to +6
Green Offset to -28
All else failed to kill the green push on the welcome screen (EPSON logo greenish hue) and with Apple TV.
Otherwise satisfied.
Dont have this issue, knock on wood
Lg 65 C7
Lg 9800 1080 Oled
Epson LS10500
Panasonic UB820 uhd player
5x10 is offline
post #1352 of 1356 Old 11-27-2019, 03:33 PM
btran33's Avatar
Quoted: 232 Post(s)
Liked: 51
Skin Tone to +6
Green Offset to -28
I still think something is not right with your LS as without doing any adjustment or calibration, I just use the Cinema picture mode with all the default setting and I don't have any green push. I'll try to take a picture of the logo tonight and post here for you to compare.
btran33 is offline
post #1353 of 1356 Old 11-30-2019, 11:34 AM
5x10's Avatar
Quoted: 923 Post(s)
Liked: 626
Does changing it to rec 790 do anything to the picture that my ub820 4K player is feeding it?
It was on auto and I switched it to the rec option
Lg 65 C7
Lg 9800 1080 Oled
Epson LS10500
5x10 is offline
post #1354 of 1356 Old 11-30-2019, 07:15 PM
btran33's Avatar
Quoted: 232 Post(s)
Liked: 51
if you are watching 4K HDR then the LS needs to be in BT2020, otherwise your picture will be very washed-out; REC790 is for SDR. Like I said, there is a bug with the LS10.5K caused it to not switch profile correctly on auto; sometime you have to switch it manually on some programs. Most of the time it is switching correctly.
5x10 likes this.
btran33 is offline
post #1355 of 1356 Old 11-30-2019, 11:28 PM
5x10's Avatar
Quoted: 923 Post(s)
Liked: 626
No doubt
Netflix app via a Apple TV feeding it 1080 is the only app that’s effected
Lg 65 C7
Lg 9800 1080 Oled
Epson LS10500
5x10 is offline
post #1356 of 1356 Old 12-01-2019, 11:50 AM
magicj1's Avatar
Quoted: 208 Post(s)
Liked: 150
Anyone successfully controlling the Epson using either iRule or Demopad? I can control mine via the 'web control' but I cant for the life of me using iRule
magicj1 is online now
ls10500
