The Official Sony VPL-VW550ES/ VPL-VW675ES Owners Thread - Page 68 - AVS Forum | Home Theater Discussions And Reviews
 1113Likes
post #2011 of 2036 Old 12-06-2018, 02:37 AM
forsaken13's Avatar
Quoted: 26 Post(s)
Liked: 8
People! I have finally completed my HT! Details as follows:
Home Theatre:
Projector: Sony Vpl-vw550es
LCR: 3 x JBL Synthesis SAM2LF + SAM1HF + SAM12X
Surrounds: 4 x Revel w283
Atmos: 2 x Revel C763L
Subs: 2 x SVS PB-2000
Receiver: Arcam AVR390
Atmos Amplifier: Rontek XD-100(x2)
Cables: Accell for HDMI and ICE for speaker cables.
Bluray player: Sony UBP-x700
Screen Size: 165"
HTPC spec:
OS: Windows 10 Home 64bit
Processor: Intel core i7-8700k
Motherboard: Asus Rog strix 370e gaming
Ram: Corsair 16gb x 2 (32gb) 3000mhz
SSD: Samsung 860 evo 500gb m.2 internal
HDD: 2TB Seagate Barracuda 7200rpm
GPU: Zotac Nvidia Geforce RTX 2080ti 11gb Amp
Cooler: Corsair h115i 280mm liquid CPU cooler
Smps: Corsair Vengance 750m
Case: Cooler Master Mastercase h500p Mesh White Edition
My projector is already outdated lol!!! Had initial hiccups with the projector while setting up the PC set to 4k, but once did its all great! 4k Gaming is unbelievable especially on a 165" screen
Thanks to all those who helped me with the choices!
Pras
ID:	2492442   Click image for larger version
MOberhardt likes this.
Projector: Sony Vpl-vw550es, Screen Size: 165"
Surrounds: 4 x Revel w283, Atmos: 2 x Revel C763L
Subs: 2 x SVS PB-2000, Receiver: Arcam AVR390
HTPC: I7-8700k, 32gb ram, RTX 2080ti
forsaken13 is offline
post #2012 of 2036 Old 12-06-2018, 04:36 PM
MOberhardt's Avatar
Quoted: 652 Post(s)
Liked: 239
Originally Posted by forsaken13 View Post
I just bought the projector last month and the exact same thing happened. Power went off but my HT was connected to an online UPS with twice the power factor capacity so the power to the units was there but the projector gave out a bursting sound and some sparks came out. The Hdmi Cable, Projector Inputs and Source input in the Receiver were all out. Contacted Sony and they replaced the board with warranty but still now haven't found the reason behind it. They requested me to use the "HDMI 2" port cos if it fails "HDMI 1" port will work but the vice versa is not possible. Also check whether the cable you use is capable of 18gbps, I have a suspicion that my previous HDMI cable which was 10.2 gbps (My bad I didn't check it and neither did my HT vendor) somehow overloaded and caused this issue.
Pras
I guess this is also another good reason to use fiber optic HDMI. You can't get surges through it I believe.
forsaken13 likes this.
MOberhardt is offline
post #2013 of 2036 Old 12-07-2018, 07:14 PM
sbquart's Avatar
Quoted: 162 Post(s)
Liked: 34
Guys, I've read the stories of Sony panels degrading. I've owned the 675 since it was released. While I was watching the bathroom fight scene in MI Fallout I noticed the lower bottom center of the screen was noticably purple when the entire scene takes place in a white bathroom. Does this sound like degradation to you? I've never noticed this purple hue before. I have about 1075 hours on the bulb too.
sbquart is online now
post #2014 of 2036 Old 12-17-2018, 09:51 AM
Archibald1's Avatar
Quoted: 1827 Post(s)
Liked: 1006
Could just be due to bulb aging. Maybe buy a new bulb and check? Also see if you can find some full screen 100%, 80% etc IRE images and display them and see what the uniformity is like. Try on low ands high bulb. Also change the gamma and colour temp settings and see if it changes anything.
It is possible it may have been like it from the start, but if it is developing an issue, then document it and gather evidence and get in touch with your dealer and/or Sony as you should still be under Prime Support warranty.
Any pics you can post up of what you are seeing?
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is online now
post #2015 of 2036 Old 12-19-2018, 11:17 AM
dsschaefer's Avatar
Need your advice
I understand that when viewing a 2.39 movie there will be black bars above and below the image.
However when I expand the image to fill my 2.39 screen I get a black bar above but I see a whitish bar below which is very annoying. Is this normal?
Any comments would very much be appropriated
Dave
dsschaefer is offline
post #2016 of 2036 Old 12-19-2018, 12:50 PM
aguy's Avatar
Quoted: 85 Post(s)
Liked: 75
Originally Posted by dsschaefer View Post
Need your advice
Dave
If I understand correctly that is the “black” bars being projected onto the area above and below your screen.
There is a setting for blanking in the menus that I use to fix that.
Living Room NAD M17 / NAD M27 / Martin Logan 60XT (LR) 50XT (C) / Def Tech LCR 6.5 (Surrounds) / SVS SBUltra 13+ / Sony A1 OLED
aguy is offline
post #2017 of 2036 Old 12-20-2018, 08:53 AM
dsschaefer's Avatar
Thanks Aguy,
Ill give that a try!
post #2018 of 2036 Old 02-19-2019, 09:23 AM
normandia's Avatar
Quoted: 338 Post(s)
Liked: 136
Over it the ATV4k forums, an HDR update for ATV4k compatibility (5.004) has been released...finally!
Downloaded it, but it failed on my Mac...had this problem before...something with hidden files needing to be deleted...so I'll search through this thread (although it might be on other Sony PJ threads).
Anyone recalling that procedure, please adivise.
Theater: Lyngdorf MP-50 7.3.4, Sony VW675ES, Revel Ultima Salon2/Voice2/Gem2(4)/Paradigm Be Atmos (4), Mark Levinson amps (53 L/R, 532 Center biamped, 531H side/surrounds), Atmos amp: Sherbourn, Oppo 203, Roku Ultra Premier+, DTV 4k, Velodyne 1812 Signature (LFE), Velodyne DD-15.
FR: Marantz 8802A (and/or 7703), Sony XBR 4k TV, Meridian A350 LCR onwall, Dali in-wall surrounds, Atmos Martin Logan in-ceiling, REL sub, Oppo 105 (and/or 103), DTV, AppleTV, Sony 4k Media Server.
normandia is offline
post #2019 of 2036 Old 02-19-2019, 10:50 AM
dminches's Avatar
Quoted: 229 Post(s)
Liked: 92
I just applied the update and the picture with HDR on is still somewhat dark. If I keep HDR on I will have to recalibrate my projector and get the brightness right.
David M.
dminches is offline
post #2020 of 2036 Old 02-19-2019, 10:54 AM
Brian Hampton's Avatar
Quoted: 1290 Post(s)
Liked: 755
Sounds like you should try the German Curves.
Brian Hampton is offline
post #2021 of 2036 Old 02-19-2019, 02:42 PM
normandia's Avatar
Quoted: 338 Post(s)
Liked: 136
How does one obtain German curves (for 675) and how does one install them? USB?
Will do a search. I now have 200h so am ready for a professional calibration, but could try this first.
Mike
Brian Hampton likes this.
post #2022 of 2036 Old 02-19-2019, 02:49 PM
Liked: 755
Mike
Well,... I maybe spoke without really looking all that into it. I have the 285 and I know the "German Curves" can be used with multiple models but I don't know the ins and outs of the 675.
I may review this thread to see if anyone mentions them. Basically, if they are applicable then you down load the curves themselves (free) and the software to install them (also free) and they over write some of the built in Gamma curves.
You can back up the built in curves before over writing them. I think that with my PJ (again the 285) doing a full reset restores the original curves also.
I don't know much about the 675 but if you have dull HDR and the German Curves are used by other 675 users they should help.
=Brian
post #2023 of 2036 Old 02-20-2019, 06:54 AM
dminches's Avatar
Quoted: 229 Post(s)
Liked: 92
I am trying to find a download link for these curves. If anyone has it can they post it here?
David M.
dminches is offline
post #2024 of 2036 Old 02-20-2019, 06:05 PM
MOberhardt's Avatar
Quoted: 652 Post(s)
Liked: 239
So there is new firmware for the projector? Oh nice. That is unexpected! It'd be great if after this I get less handshaking issues. I'm so sick of toggling inputs to force handshaking again and again.
I take it this should work on the 550, not just the 675?
post #2025 of 2036 Old 02-21-2019, 12:08 AM
aguy's Avatar
Quoted: 85 Post(s)
Liked: 75
I’m wondering the same. I am in Australia and when I checked yesterday the Sony Australia website still had 5.003 as the current firmware for download.
aguy is offline
post #2026 of 2036 Old 02-21-2019, 12:54 PM
MOberhardt's Avatar
Quoted: 652 Post(s)
Liked: 239
I loaded it last night. No issues. I did get a scare as I saw it go solid red after the Amber flashing stopped, and I pulled out the USB stick, so I pulled it out and it started flashing Amber again maybe after I hit the power button on the remote, so I put it back in. It all went red again, and all Dame up ok. So maybe when it goes red after the Amber flashing, just wait a minute.
post #2027 of 2036 Old 02-21-2019, 01:55 PM
aguy's Avatar
Quoted: 85 Post(s)
Liked: 75
What region is your 550?
aguy is offline
post #2028 of 2036 Old 02-21-2019, 02:06 PM
MOberhardt's Avatar
Quoted: 652 Post(s)
Liked: 239
Aussie. Same as me
aguy likes this.
post #2029 of 2036 Old 02-26-2019, 02:17 PM
Liked: 0
I have the 675ES and its shut off after being on for few minutes. This just started to happen to the projector a couple days ago. I noticed that it happen when I switched from Reference to another video setting but now its happening after being on for a few minutes. Anyone else have this issue?
Franky66 is offline
post #2030 of 2036 Old 02-26-2019, 03:01 PM
MOberhardt's Avatar
Quoted: 652 Post(s)
Liked: 239
Might be a physical issue, like overheating? Is it possible vents might need vacuuming or something? I have seen it mentioned on other threads and quickly googling it could be a faulty lamp needing replacement.
post #2031 of 2036 Old 03-09-2019, 02:20 PM
MOberhardt's Avatar
Quoted: 652 Post(s)
Liked: 239
BTW, I think that firmware upgrade fixed up some general handshaking issues. Since I've done it, I've not ended up in the situation where my av chain for a UHD has incorrectly put it in bt709 mode rather than 2020. I used to have it quite a lot, but not since.
post #2032 of 2036 Old 06-12-2019, 02:21 PM
RDalton's Avatar
Quoted: 102 Post(s)
Liked: 117
I can see muted lighted edges extending outside of my screen border edges when viewing a movie, but the movie is being projected within my screen borders. Is there any way to fix that with a setting adjustment? I'm on the Normal screen size on my projector. Thanks.
Media Room: Sony VPL-VW675ES, Anthem MRX-1120, Oppo UDP-205, Atlantic Technology THX Ultra2 371LR, 373C, 374LRSSR, 454LRBSR, Dual SVS PB-4000 Subs, (4) AT IC-6-OBA Atmos Ceiling Speakers, DirecTV c61K, Roku Ultra, Sony PS4, Sonos Connect | Living Room: LG OLED65C8PUA, Oppo UDP-203, DirecTV c61K, Sonos Playbar & Wireless Sub, Sonos PLAY:1 Surrounds, Sonos Connect | Patio: Onkyo TX-DS989v2, PSB CS1000 Outdoor Speakers, Sonos Connect | Control4 Home Automation
RDalton is offline
post #2033 of 2036 Old 06-13-2019, 07:33 AM
Archibald1's Avatar
Liked: 1006
Blanking may be your friend here, but if viewing on a 16:9 screen zoomed to where indicated on the following picture and you have black borders, there should be no real issue.
Name:	picture alignment pattern 16_9.jpg
RDalton likes this.
Stephen Hawking.
post #2034 of 2036 Old 06-15-2019, 02:56 PM
RDalton's Avatar
Quoted: 102 Post(s)
Liked: 117
Thanks for your response. I’ll take a look at blanking. Did you post a helpful pic? If so, I can’t see it.
RDalton is offline
post #2035 of 2036 Old 06-15-2019, 03:44 PM
Archibald1's Avatar
Liked: 1006
No probs. I did and I can see it in your quote now. Can you not see it?
Edit:
I have added the thumbnail if it helps.
RDalton likes this.
Stephen Hawking.
post #2036 of 2036 Old 06-17-2019, 03:04 PM
RDalton's Avatar
Quoted: 102 Post(s)
Liked: 117
Edit: I have added the thumbnail if it helps.
I could not see the pic until you added the thumbnail.
It did help, I appreciate it
Archibald1 likes this.
RDalton is offline
