Projector In A Cold Room - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By JeffR1
post #1 of 2 Old 12-06-2016, 11:03 AM - Thread Starter
Cinema Gary's Avatar
Question Projector In A Cold Room
In a cold room 5 degrees at its coldest it is an external room, should a projector be switched on first to warm up first for 10 minutes or should the heateing in the room be turned on first for 10 minutes then switch the projector on
Cinema Gary is offline
post #2 of 2 Old 12-07-2016, 01:06 PM
JeffR1's Avatar
Quoted: 1055 Post(s)
Liked: 510
You're in the UK, so I'm going to assume that's 5 degrees Celsius _ so still above freezing.
Where's your projector, in a fridge ?
Most specs stipulate that any projector should be kept above 15C.
IMO, I would use the projector to warm itself up.
If you use the temp in the room it would take longer then 10 minutes, something like over night before the components would reach room temperature.
Personally I don't think that's good for your machine.
Once the room warms to say 24C, the warm air holds more moisture.
This happens just from you breathing in the room.
Once you let the room cool to only 5 degrees, condensation will occur and you certainly don't want that, especially with a Sony projector.
Cinema Gary likes this.
JeffR1 is online now
