Official JVC RS520/RS620 (X7500/X9500) Owner's Thread - Page 133 - AVS Forum | Home Theater Discussions And Reviews
 10166Likes
post #3961 of 5062 Old 12-12-2017, 04:54 PM
Roger Dressler's Avatar
Quoted: 2972 Post(s)
Liked: 1729
Originally Posted by Roger Dressler View Post
I cannot figure out where this problem originates. Content? Projector? (I have another UHD disc that does the same.)
On specific scenes, I see a red alignment offset, the red is shifted down. I'm confident it is not a convergence error.
I'm playing discs in an Oppo UDP-203 with Main HDMI direct to RS-520 via a 10' high speed HDMI cable, no symptoms of bandwidth limitations.
I'm using Hacksaw Ridge, comparing the UHD disc with the HD Blu-ray. In both cases the player is outputting 4k24, the PJ has e-shift turned on.
The HD disc looks perfect; the UHD disc presents the color shift. The attached pictures aren't great but you can most easily see the red misalignment on the "+" in the opening title of Hacksaw Ridge. In the others there's red smearing below the mouths. If anyone has this UHD and a UDP-203, could you please check what you see? Anyone heard of such a thing?
The second image occurs at 21:03 minutes, and the third one is from chapter 9 after the navy shells the ridge: "Nobody can survive that sh*t." The frame grab at *. In all cases the UHD is on the right.
The problem is caused by the Oppo UDP-203 player. It is not the PJ. These images were taken of 4k HDR 2:40 content fit to the screen using Oppo's 21:9 zoom mode, when the Video Output TV Aspect Ratio was set to 21:9 Fixed. But when I changed Oppo's TV ratio to 16:9 wide, the problem goes away.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #3962 of 5062 Old 12-13-2017, 05:48 AM
Tom Bley's Avatar
Quoted: 916 Post(s)
Liked: 893
I have the same issue with my Oppo 203 and RS-500. I'm glad someone else noticed this because I have not been following the Oppo 203 thread. This is not ready for prime time, though I wish it would work properly.
Tom Bley is online now
post #3963 of 5062 Old 12-13-2017, 07:57 AM
FGEvans's Avatar
Quoted: 82 Post(s)
I have finally got my x7500 installed on my ceiling and hope to get my screen up on the weekend.
does anyone have any set up tips to start out with at this point
i know that settings are environment specific but any advice would be appreciated on what to change to get the best settings.
FGEvans is offline
post #3964 of 5062 Old 12-13-2017, 09:11 AM
jeahrens's Avatar
Quoted: 2067 Post(s)
Liked: 1365
I used this for a 1080p baseline:
- Select a user setting to change (User 1)
- Set the lens aperture to -7 to -10 depending on screen size and desired brightness, then change to Auto 2 (this enables the Dynamic Iris and sets the max brightness)
- Set the color space to Standard, temp to 6500K
- Set the advanced picture settings to Clear Black Low, Enhance 2, Smooth 0, NR 0. Motion Enhance OFF, CMD OFF, Graphic Mode 2K, eShift on or off (I prefer on)
- Set the Gamma to Custom and select 2.4 or 2.5
- Set the brightness to eliminate any crush (+1 - +3)
- Set color to desired saturation (mine was about -8 before calibration yours may vary)
HDR you would use the normal HDR preset, high lamp, e-shift on, graphic mode 4K, and experiment with Picture Tone and Dark Level. The last 2 will introduce some gamma error and clipping, but for out of the box I found they worked very well. I think I used +3 and +2 respectively.
Obviously calibrating will give you the best results, but for just setting it up and enjoying you'll find something like this to be pretty pleasing.
FGEvans likes this.
jeahrens is offline
post #3965 of 5062 Old 12-13-2017, 09:21 AM
ack_bk's Avatar
Quoted: 1343 Post(s)
Liked: 1501
My basment build is moving along faster than I hoped
I need to start thinking about a projecor mount for my 520 but I want to keep it as flush to the ceiling as possible since I have a 2nd row riser and 8' ceilings. I see the Chief RPMA218 and CMA101 often mentioned but wouldn't I need a drop tube of some kind with that style mount? I really don't want to drop the projector any lower than I have to. Any other flushmount options? I am also considering building a custom hush box that will be open to the back/front and I could have some vents on the side. With the amount of lens shift with this projector I don't suspect I would need to adjust much if I build a nice level box.
ack_bk is offline
post #3966 of 5062 Old 12-13-2017, 01:52 PM
Mike_WI's Avatar
Quoted: 442 Post(s)
Liked: 326
You can look at my HT thread (link in sig) with pics at beginning (JVC RS20) and end (JVC RS520 with new adapter plate).
I you can build a hush box that has adequate air circulation that also sounds good and is projector type independent for future upgrades.
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & 18 GHz output x1 cards} - "new (112818 FW)" 18 GHz microcode - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is offline
post #3967 of 5062 Old 12-13-2017, 05:49 PM
Liked: 1729
Oppo is aware of the problem, and I presume that means it will be investigated and if possible, fixed. In the meantime, I'll be using settings that avoid the problem.
Ok=Ok
X=no good
Tom Bley likes this.
post #3968 of 5062 Old 12-13-2017, 06:05 PM
Liked: 1729
I need to start thinking about a projector mount for my 520 but I want to keep it as flush to the ceiling as possible since I have a 2nd row riser and 8' ceilings.
I had to put my PJ under a soffit, so just built a simple rack. Worked great. As tight to ceiling as you like.
Name:	PJ rack2.jpg
post #3969 of 5062 Old 12-13-2017, 08:53 PM
ack_bk's Avatar
Liked: 1501
I hat to put my PJ under a soffit, so just built a simple rack. Worked great. As tight to ceiling as you like.
That is perfect, thank you. They say imitation is the sincerest form of flattery....
ack_bk is offline
post #3970 of 5062 Old 12-14-2017, 10:45 AM
beastaudio's Avatar
Quoted: 5621 Post(s)
Liked: 5458
Is there a master thread for different hushbox designs? I might consider one just for fun...
Mike_WI likes this.
beastaudio is offline
post #3971 of 5062 Old 12-14-2017, 09:00 PM
WereWolf84's Avatar
Quoted: 413 Post(s)
Liked: 175
you can consider to build something like this
WereWolf84 is online now
post #3972 of 5062 Old 12-15-2017, 08:46 AM
beastaudio's Avatar
Liked: 5458
That looks gorgeous, and not functional.
post #3973 of 5062 Old 12-15-2017, 11:47 AM
EllisGJ's Avatar
Quoted: 417 Post(s)
Liked: 189
Because it can't be adjusted?
EllisGJ is offline
post #3974 of 5062 Old 12-15-2017, 11:52 AM
Liked: 1729
I guess because it will not block the fan noise. Those slats are open, right?
post #3975 of 5062 Old 12-15-2017, 11:58 AM
beastaudio's Avatar
Liked: 5458
Yes exactly. You can clearly see the corner of the PJ through the slats. I guess it might help a little, but it's certainly form over function.
post #3976 of 5062 Old 12-15-2017, 01:27 PM
farsider3000's Avatar
Quoted: 1564 Post(s)
Liked: 947
Control4 and JVC projectors
My Control4 dealer is trying to get my projector to work with serial cable and we are having issues with the projector accepting a simple "On" command. "Off" command works as do the lens memory commands. I have a JVC RS4910 and they are using the driver from the X500 which is the same unit so I don't think that is the issue.
Any one have Control4 set up in their theater controlling their JVC through serial or IR? If you are using IR does anyone know where I can find the IR Pronto commands for lens memory 1, 2, 3? I found a JVC document that has the Hex codes but I need the Pronto codes. I am currently researching the Hex conversion to Pronto as there are various conversion programs but so far my dealer can't get them to work.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5 for surround & ceiling
Subs: JTR Captivator subs: One S2, Two RS2, One S1, 2 Seaton Submersive (FOR SALE)
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is online now
post #3977 of 5062 Old 12-15-2017, 10:20 PM
Bandyka's Avatar
Quoted: 2327 Post(s)
Liked: 1422
OK so just autocal-ed my X9500 and suddenly lost about 5ftl of brightness, why would that be and and how to get it back?
Gamma is spot on but gray scale is way out, in RGB blue being about 10% below baseline. I know something similar has been discussed but I can't find it.
Any suggestions? Thanks.
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #3978 of 5062 Old 12-15-2017, 10:34 PM
woofer's Avatar
Quoted: 1422 Post(s)
Liked: 2222
@Bandyka
PM Matthew, same thing happened to him at one stage ...though i cant remember if it was the X9500 or the X9900 ?
woofer is offline
post #3979 of 5062 Old 12-15-2017, 11:04 PM
Bandyka's Avatar
Liked: 1422
Originally Posted by woofer View Post
@Bandyka
I know I already did but he is busy It's in this thread or the other somewhere.
Bandyka is offline
post #3980 of 5062 Old 12-15-2017, 11:14 PM
woofer's Avatar
Liked: 2222
Somewhere here..
https://www.avsforum.com/forum/24-dig...l#post55150332
woofer is offline
post #3981 of 5062 Old 12-15-2017, 11:39 PM
Bandyka's Avatar
Liked: 1422
Thanks I can see where it all started I just don't see the solution yet, I guess I will have to keep reading...
Bandyka is offline
post #3982 of 5062 Old 12-16-2017, 12:15 AM
woofer's Avatar
Liked: 2222
woofer is offline
post #3983 of 5062 Old 12-16-2017, 12:33 AM
Bandyka's Avatar
Liked: 1422
Thanks heaps!
Bandyka is offline
post #3984 of 5062 Old 12-16-2017, 12:49 AM
Soccerdude's Avatar
Quoted: 375 Post(s)
Liked: 130
Is the 4k native or lens shift ?..
LG OLED C8 65 2018 BR . HT: JVC RS2000, S Studio Tek 130 1.3 Gain screen, Apple TV4k, Def Tech 9080/C 9080/9040 Dolby Atmos Speakers, Denon X6500H , Panasonic UB820 and a nagging wife.
Soccerdude is offline
post #3985 of 5062 Old 12-16-2017, 05:41 PM
Javs's Avatar
Quoted: 6917 Post(s)
Liked: 6620
I emailed you...
As to where it started, well two issues one, was a bloody bum light meter for measuring lumens! Thats all fixed now.
The autocal thing was real though, just yesterday I got all my brightness back after I had switched lamps. 9900 didnt have the issue.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #3986 of 5062 Old 12-16-2017, 05:47 PM
Javs's Avatar
Liked: 6620
E-Shift
Javs is online now
post #3987 of 5062 Old 12-17-2017, 06:39 AM
Dimitri_ISF's Avatar
Quoted: 43 Post(s)
Hey all,
Quick question...
Can the x7500 do 2D to 3D conversion?.
I do not have the emitter nor the glasses yet, but I cannot see this option in the 3D section.
Dimitri_ISF is offline
post #3988 of 5062 Old 12-17-2017, 03:48 PM
Javs's Avatar
Liked: 6620
Originally Posted by Dimitri_ISF View Post
Hey all,
Quick question...
No.
Javs is online now
post #3989 of 5062 Old 12-19-2017, 12:28 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
Are there any proven HDMI cables garaunteed to work with the X5900 at 12.5M - 15M length?, I'm in the UK and it seems the 15m ruipro works with one issue but it's £200 here
JVC DLA-X7900 3D Projector, Sapphire 106" Electric screen, Sony KDL-55W905 3D TV, Pana TX-L37LZD80, Panasonic UB820, UB700, BDT-380 MZ, Panasonic DMP-BD60, Sky Q 2TB, Fire TV 4K, Marantz SR7012, 7.1.2, SVS PC2000 Sub, Kef Q600C Centre, Q300 fronts, Ci160QR Ceilings, CA SX60 Surrounds, Harmony 950+hub.
panman40 is offline
post #3990 of 5062 Old 12-19-2017, 01:03 PM
juras's Avatar
Quoted: 12 Post(s)
this a well known one that work perfect
https://www.amazon.com/Monoprice-Sli...oprice+slimrun
or direct from monoprice (they also have regularly coupons) right now 20% off
https://www.monoprice.com/product?p_id=21568
panman40 likes this.
- juras -
juras is offline
