Official JVC RS520/RS620 (X7500/X9500) Owner's Thread - Page 135 - AVS Forum | Home Theater Discussions And Reviews
 10166Likes
post #4021 of 5062 Old 12-26-2017, 09:58 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
Originally Posted by Dimitri_ISF View Post
Should the projector switch into a 3D mode when it receives a 3D signal?, because mine just stays in the same picture mode.
Yes, as already said it should detect a 3D blu Ray and then you can adjust settings accordingly which it will store for the next 3D watch.
JVC DLA-X7900 3D Projector, Sapphire 106" Electric screen, Sony KDL-55W905 3D TV, Pana TX-L37LZD80, Panasonic UB820, UB700, BDT-380 MZ, Panasonic DMP-BD60, Sky Q 2TB, Fire TV 4K, Marantz SR7012, 7.1.2, SVS PC2000 Sub, Kef Q600C Centre, Q300 fronts, Ci160QR Ceilings, CA SX60 Surrounds, Harmony 950+hub.
panman40 is offline
post #4022 of 5062 Old 12-26-2017, 07:11 PM
docajay's Avatar
Originally Posted by Applemike68 View Post
Just curious.. Has anyone upgraded from the 620 to the 640? Any benefit?
Also, when watching 1:85 on a 2:35 screen, how do i align it properly? Do i use the Shift/zoom method until i get an image then save it ?
Thank you...
From looking in the owners thread for the RS640/540 it seems like the main advantage would be functioning CMD with Low Latency. Right now the CMD fix on the RSx20 lineup introduces issues with Low Latency mode. So if you like CMD and are bothered by the banding that shows up in some scenes with the original software, the fix will make low latency mode unusable. However if you don't use CMD and do not have the fix performed low latency mode works fine. JVC is supposed to be working on a fix for this, but right now that's where we're at. Other differences e-shift 4 vs. e-shift 5 and a functioning DI with 4K material. The differences in e-shift are subtle and I wouldn't say it's worth taking the hit to trade up for it. The DI not working in 4K on the RSx20 lineup can be fixed with a HDFury Linker (~$200). If I was buying new and the price differential was small, the RS640 would be an easy pick. But since you're likely to take a decent hit on resale, I'd just stick with the RS620.
Yup you do exactly that with the 1.85:1 picture. You can either measure the distance from the alignment grid to the screen border or use a centralized point (I use the tweeter on the center) to center it. And then just save the memory position.
Hi jeahrens,
Thanks for your answers again.
One more question, it seems jvc 640 has good hdr "out of the box". Does the 620 have equal hdr as well. Do you need to put in custom gamma curves? Or other calibration.
I guess bottom line, is it HDR capable AND equivalent to a 640.
Ajay
docajay is offline
post #4023 of 5062 Old 12-26-2017, 07:43 PM
tygraham1's Avatar
Liked: 2
Selecting User Picture Mode via Automation?
Hey guys,
Does anyone have a slick solution for selecting User Picture Modes via automation? I'm currently using a Harmony Elite/Hub to control my theater room, and I'd like to default the JVC into a specific picture mode based on my activity. I can't use the picture modes like Natural or Cinema that are available directly on the remote (and in the Harmony remote codes) because they don't allow user color profiles.
Things I've tried:
I can use custom activity steps in the harmony to select a standard mode (e.g. Natural), send the picture mode popup, arrow up/down the correct number of times, send OK, then send BACK to close the popup at the end. This is a pretty ugly workaround, and due to the long sync times with the JVC I have to insert 10-15 sec delays after both mode switches, plus 1 sec delays after the picture mode popup and direction keys. I've already decided I'd rather just use the remote to select the mode manually than go this route.
I've looked into RS232 commands and found the command to set the projector to a user picture mode, but I haven't yet looked into how to integrate my Harmony hub with an RS232 controller (but I'm sure that's been done).
Any help or direction is much appreciated, and sorry if this has already been discussed. A few searches in this thread didn't turn anything up.
Tyler
Anthem AVM-60 | JVC DLA-RS620
OPPO UDP-203 | DirecTV | Nvida ShieldTV
XBox360 | XBoxONE | PS3 | PS4
Custom Gaming PC | GTX970 x 2
tygraham1 is offline
post #4024 of 5062 Old 12-26-2017, 10:24 PM
KarlKlammer's Avatar
Quoted: 263 Post(s)
Liked: 257
Hi,
I currently use the Harmony device profile for the DLA-X55 (I don't know the corresponding RS-Model). With this I have three direct accessible user presets for my X9500 or X5000.
You could even use the device profile for the DLA-X30 to have five user presets accessible with your Harmony.
Projection: JVC DLA-NX9
VP/Calibration: Lumagen Radiance Pro, LightSpace CMS, x-rite i1 Pro 2, x-rite i1 Display 3
KarlKlammer is offline
post #4025 of 5062 Old 12-27-2017, 12:59 AM
Dimitri_ISF's Avatar
Quoted: 43 Post(s)
When I send it a 3d(FP) signal from my murideo, the info window on the JVC does show 1080(FP). But it doesn't "go" into a special 3D mode, like it does when I send it HDR from the murideo.
Should it go into high lamp automaticly?. The manual says it should.
I have bypassed my receiver(denon avr4311) which is a 3D receiver. But connecting directly to the projector yielded the same results.
Dimitri_ISF is offline
post #4026 of 5062 Old 12-27-2017, 03:10 AM
Bytehoven's Avatar
Quoted: 1374 Post(s)
Liked: 1086
Thank you...
Hi jeahrens,
Ajay
There has been mention of a patch in the works to address the cmd low latency thing.
When trying to sort out upgrading from a 620, you might have to reflect on the quality of the 620 as far as convergence, lens clarity and stuck pixels. If you have a very good 620 sample, while the 640 does offer significant improvements, there are far to many quality control issues being reported with the 640/990/9900, such that you might not want to take the risk. Or at least don't sell the 620 until you can confirm what kind of 640 you receive.
That may sound harsh, but in light i f what is being reported, it is justified.
JVC DLA-X990 (RS640) - 128" 2.35 1.3 Gain Screen - Panasonic UB820 - ROKU Ultra - PS4 - XBone
7.1.4 Atmos - Denon X4300H + Denon 3806(LCR) - JBL Control 5 - BIC Sub - Dayton
Bytehoven is offline
post #4027 of 5062 Old 12-27-2017, 12:25 PM
Quoted: 411 Post(s)
Liked: 242
Hi guys , i m planning on upgrading my Optoma UHD60 to the RS440, i never owned a jvc before so this will be my first.
My question is if both can be had at the same price do u think its better to get the RS520? My room is 60-70% treated with black velvet but not a complete bat cave. I keep reading about some issues with the 520, i game a lot using my pc ar 4k 60 andps4 pro, i watch 4k blurays with my sony x800d and i like FI with movies.
Based on my situation, which one would be a better buy for me.
Thanks a lot.
JVC DLA X590/RS440
BenQ LK970
tnaik4 is offline
post #4028 of 5062 Old 12-27-2017, 01:10 PM
Toe
Toe's Avatar
Quoted: 2721 Post(s)
Liked: 3571
Thanks a lot.
The CMD fix broke 4k gaming on the X20 models. I wouldn't count on a fix until it's actually fixed. If you have to buy now, I'd go with a new X40 model.
Toe is online now
post #4029 of 5062 Old 12-27-2017, 01:18 PM
beastaudio's Avatar
Quoted: 5621 Post(s)
Liked: 5458
Originally Posted by 703 View Post
I'd avoid fine adjustments. Full pixel yes.
What is your reasoning behind not using the fine adjustments? They do a pretty good job and zoning in on smaller problem areas.
Thanks a lot.
Until the CMD/eshift/low latency thing is worked out, I would just hold my breath if you are contemplating any of the x20's machines and wait to see how it all shakes out. Gaming as you do currently, and liking FI, it absolutely will not be the machine for you at the current time. Hopefully a patch will fix the problem.
beastaudio is offline
post #4030 of 5062 Old 12-27-2017, 01:31 PM
Quoted: 411 Post(s)
Liked: 242
What it actually broke ? What is the issue that was introduced with the cmd fix.
Yeah that would be a deal breaker for me and i would definitely go for rs440.
Thankss
tnaik4 is offline
post #4031 of 5062 Old 12-27-2017, 01:34 PM
Quoted: 411 Post(s)
Liked: 242
Actually latest reply kind of answered my question, thanks guys for ur help, it looks like the rs440 is the one for me then.
Much appreciate the help.
JVC DLA X590/RS440
BenQ LK970
tnaik4 is offline
post #4032 of 5062 Old 12-28-2017, 10:24 AM
PHINSON's Avatar
Pretty excited....Have a 520 coming tomorrow from AV Science. I've been largely out of the hobby for about 12 years. My last projector was a JVC G11 with a huge whisperquiet hushbox. Since there are over 4000 posts in this topic, anybody know of a post or post(s) that provides some helpful startup information re initial settings, quirks, calibration, (autocalibration?) etc.? I hope to have it mounted by the end of the day tomorrow. ANY info you could provide would be helpful.
Paul W. Hinson
PHINSON is offline
post #4033 of 5062 Old 12-28-2017, 04:36 PM
jbn008's Avatar
Quoted: 267 Post(s)
Liked: 131
Unless you find a used x20 model that never got the new cmd fix. I believe the fix (or lack there of) came out around the end of Sept
jbn008 is offline
post #4034 of 5062 Old 12-28-2017, 04:39 PM
Toe
Toe's Avatar
Liked: 3571
True, but then you have a broken CMD. If you don't care about CMD though and can find a pre fix X20, that would be a good option.
Toe is online now
post #4035 of 5062 Old 12-28-2017, 04:56 PM
jbn008's Avatar
Quoted: 267 Post(s)
Liked: 131
I don't use CMD so I didn't even think about that. Good point
jbn008 is offline
post #4036 of 5062 Old 12-29-2017, 09:09 AM
Applemike68's Avatar
Quoted: 251 Post(s)
Liked: 57
Hi All,
I'm looking for someone to calibrate my RS620. Anyone know of a good person around the Houston/Spring/conroe/woodlands area? I live in the woodlands.
Thank you,
JVC RS2000 : Panamorph DCR Lens : Screen Innovations 125" Slate 1.2 2.40.1
Anthem MRX 1120 : Kaleidescape Strato :Kaleidescape 24TB Server :Apple TV 4K
Oppo 203 : Xbox One X
Paradigm 95f , 55c, Paradigm Elite in wall surround and atmos speakers
SVS sb16 ultra x 3 : Emotiva XPA 3 DR 3 for LCR : Current Setup 7.3.4 Atmos : Control 4
Applemike68 is online now
post #4037 of 5062 Old 12-29-2017, 09:26 AM
Mike_WI's Avatar
Quoted: 442 Post(s)
Liked: 326
Calibrators
Hi All,
Thank you,
I'm not sure about Houston area specifically, but these calibrators have gear, will travel:
Chadb - http://www.hdtvbychadb.com/
Craig Rounds - http://www.cir-engineering.com/calibration-equipment/
Jeff (Accupal)
Mike
HT: Oppo UDP-203 -> Lumagen RadiancePro 4446 {18 GHz input x2 & 18 GHz output x1 cards} - "new (112818 FW)" 18 GHz microcode - parallel outs to --> [Audio: Denon 5308CI] --> [Video: JVC RS520 FW v30.1]
HT Details: link
Mike_WI is online now
post #4038 of 5062 Old 12-30-2017, 02:31 AM
jowicrt's Avatar
Quoted: 704 Post(s)
Liked: 208
Does this series of projectors have a warmup time that is needed for doing the (mechanical) and optical setup?
I noticed a few times that after setting it up properly, i had to do it again the next day... If you guys set it up, how often do you need to re-adjust shift/zoom/focus?
Arcam AVR850 • Pioneer KURO KRP-600M • KEF Reference Model 4/2/200c •• Velodyne DD15 •• HDI Dune 4K Solo • Logitech Squeezebox Radio/Duet • Wyrewizard Dreamcaster & Spellbinder (by Nordost) • JVC D-ILA-X7500 • HDFury Vertex
jowicrt is offline
post #4039 of 5062 Old 12-30-2017, 04:37 AM
Quoted: 251 Post(s)
Liked: 57
Jeff (Accupal)
Mike
Thank you Mike
post #4040 of 5062 Old 12-30-2017, 08:37 AM
Toe
Toe's Avatar
Liked: 3571
Wait until the unit is on at least 45 min or so to dial in a final sharpness. I rarely have to refocus my JVCs. I do have to tweak shift slightly on most power ups, but that's because my subs knock the lens out of alignment slightly.
jowicrt likes this.
Toe is online now
post #4041 of 5062 Old 12-30-2017, 09:25 AM
Naylorman32's Avatar
Quoted: 494 Post(s)
Liked: 219
maybe its the content ive been watching but ive noticed more "motion judder" recently. i know its usually best to keep all motion options turned off because it can cause the soap opera effect, but what do you guys typically set your projectors at? CMD or motion enhance? right now i have CMD off and motion enhance at Low but i still seem to be struggling with more judder. any suggestions?
JTR Speakers, RSL Atmos, Kaleidescape, Lumagen Radiance Pro, Marantz Processor, Emotiva Amps, JVC RS540
Naylorman32 is offline
post #4042 of 5062 Old 12-30-2017, 07:54 PM
KASOFO's Avatar
Quoted: 72 Post(s)
Help Needed!
HELP!!! Hello and happy holidays all. I am struggling mightily with trying to get my RS-620 software updated. I am getting a constant "communication error". I have spent two hours attempting and want to jump of a ledge. I am using the recommended Triplight RS232 Adapter with no other interconnects other than the female adapter at the projector. I have set the communication rate at the com port at 57600 and have tried 3 different laptops using Windows-7.8, and 10. Still nothing. I have searched the forum and web multiple times and I know this is an issue but could really use an assist. All cables other than power are unplugged including my 3-d emitter. Unit light is in standby. I have unplugged the power, plugged in the RS232 and powered on, and nothing. Plugged in the RS232 with power on (standby) and nothing. Just communication errors. The Triplight is working fine. Would love some solid input!! Thanks in advance!
Keith
Marantz 8802A Processor, Wyred4Sound SX-1000R Monoblocks X 3, Emotiva XPA-7 Gen3 Amp, Oppo 205 Ultra HD/Blu-Ray Player, JVC-DLA RS620U Projector, Dark Energy 127-Inch ALR Screen, Tekton Ulfberht’s Mains, Tekton Ulberht Center, Def-Tech SR8080-BP Surrounds (4), Seaton Submersive F2+ and F2 Slave Subs, Two Seaton F18+'s subs, Power Sound Audio S3010 sub, 4 ADX Maximus Bass Shakers
KASOFO is offline
post #4043 of 5062 Old 12-31-2017, 12:35 AM
Roger Dressler's Avatar
Quoted: 2973 Post(s)
Liked: 1733
Keith
I did not have the Tripp Lite adapter, but an off-brand one, and could not get it to work via USB, so I dug out an old laptop that has an RS232 serial port. Used a DB9 null modem "crossover" cable and it all worked fine.
Is your DB9 female to female adapter a null-modem type? Maybe it should be?? They come both ways, and they look alike. When the RX and TX are reversed, you will get the communication error. I know -- I tried it both ways.
Notice the picture on page 3 of the instructions shows a USB adapter connected to a crossover cable. Worth a try.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #4044 of 5062 Old 12-31-2017, 02:54 AM
Quoted: 43 Post(s)
Keith
I have tried to use a keyspan USB-serial adapter for calibration purposes.
Could not connect to the projector also....
post #4045 of 5062 Old 12-31-2017, 07:47 AM
KASOFO's Avatar
Quoted: 72 Post(s)
Thank you for the input. Not sure I can find a laptop with the RS232 port but will try. Obviously it REALLY should not be this difficult but it is what it is I guess. Thanks again for the tip and Happy New Year to all!
Keith
KASOFO is offline
post #4046 of 5062 Old 12-31-2017, 10:09 AM
Quoted: 43 Post(s)
Keith
I have used the adapter to calibrate pioneer CCC plasma's in the past.
It always worked back then.
Happy newyear!.
post #4047 of 5062 Old 12-31-2017, 11:20 AM
Liked: 1733
I agree it is an antiquated method. I guess JVC agrees as the newest models have finally dropped it for USB IIRC.
It was impossible to find a DB9 crossover cable in my little town, so I used some RJ45 - DB9 adapters I had on hand and made my own. But crossover cables and adapters are cheap and readily available online. It's worth a try.
post #4048 of 5062 Old 12-31-2017, 01:57 PM
EllisGJ's Avatar
Quoted: 418 Post(s)
Liked: 189
...I am using the recommended Triplight RS232 Adapter...
I used this one with no problem: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
DTECH 10 ft USB to RS232 DB9 Female Serial Port Adapter Cable with FTDI Chipset Supports Windows 10, 8, 7 and Mac Linux
EllisGJ is offline
post #4049 of 5062 Old 01-01-2018, 03:17 AM
Quoted: 43 Post(s)
Ok, just placed an order for the Dtech. See what happens.
post #4050 of 5062 Old 01-03-2018, 11:20 AM
Masterkale's Avatar
Quoted: 79 Post(s)
Liked: 33
Anybody noticed difference in audio quality while using his/her jvc projector? I get a huge peformance drops. Just unplug the projector and start a movie. Plug the jvc in and listnen again.
Masterkale is offline
