Official JVC RS520/RS620 (X7500/X9500) Owner's Thread - Page 161 - AVS Forum | Home Theater Discussions And Reviews
 10166Likes
post #4801 of 5062 Old 08-08-2018, 08:39 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6679 Post(s)
Liked: 6675
Originally Posted by Erod View Post
Why is this particular JVC thread so dead?
Older model threads seem to die of after there are discontinued and everyone is to busy enjoying there projector
Cleveland Plasma is online now
post #4802 of 5062 Old 08-08-2018, 08:42 AM
Erod's Avatar
Quoted: 1274 Post(s)
Liked: 789
The 600/500 thread is alive and well. The 620/520 are newer models, but this thread isn't.
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: RBH SV-661R and SV-661CR fronts, Jamo 626k4 side/rear surrounds, DefTech DI6.5R heights
Erod is offline
post #4803 of 5062 Old 08-08-2018, 08:48 AM
Quoted: 4884 Post(s)
Liked: 1848
The 520/620 are newer but there’s hardly anything specific to them worth discussing.
Dominic Chan is online now
post #4804 of 5062 Old 08-08-2018, 09:08 AM
Quoted: 235 Post(s)
Liked: 60
They should merge this with the 790/990 thread. Basically the same in most cases.
jorgebetancourt likes this.
tswire is offline
post #4805 of 5062 Old 08-09-2018, 03:27 PM
tsand72's Avatar
Searching for custom gamma settings for various HDR luminance settings (on discs)... RS520... does anyone know of any posts in this thread with that info?
tsand72 is offline
post #4806 of 5062 Old 08-09-2018, 06:40 PM
Mike Garrett's Avatar
Quoted: 12542 Post(s)
Liked: 10154
There are probably four times as many 500/600 owners compared to 520/620 owners. The 500/600 year was a banner year for JVC.
Mike Garrett is offline
post #4807 of 5062 Old 08-12-2018, 07:33 AM
Jive Turkey's Avatar
Quoted: 586 Post(s)
Liked: 467
Does the RS400 and the RS620 use the same lamp? The replacement lamp that came with my RS400 is a PK-L2615UP.
Is the RS620 E-shift 5 or 4?
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #4808 of 5062 Old 08-12-2018, 07:42 AM
Liked: 1848
The RS4x0, 5x0, 6x0 projectors all use the PK-L2615UP lamp, with the 265W Ushio NSHA250JK bulb.
Jive Turkey likes this.
post #4809 of 5062 Old 08-12-2018, 07:55 AM
Quoted: 586 Post(s)
Liked: 467
Does 300 more lumens (620 vs. 400) make a significant difference for HDR?
Is the HDR Picture Mode pretty close till a calibration can be had? Same question for any of the other Picture Modes for 1080P?
See ya. Dave
post #4810 of 5062 Old 08-12-2018, 08:11 AM
Liked: 1848
The picture quality is quite a bit better with the 5x0 and 6x0 projectors, but mainly because of the contrast and the wider colour gamut, not the extra brightness. As a matter of fact, HDR may be dimmer on the higher models, as the colour filter cuts the brightness by more than the 300 lumens difference.
post #4811 of 5062 Old 08-12-2018, 02:20 PM
Liked: 1
x7500 iris noise
Hi All,
Recently I started to hear some dynamic iris noise (set to auto 2) during watching movies which if was not there, or at least as I remember never drew my attention since I have the projector (it's about 1.5 years old with 860 hours or so).
After the movie I checked it in manual mode, swiping through -15 to 0 and to me it sounds not so healthy, here's a
. During the film we heard something like series of those small noise/clicks as with every other step.
Could you take a listen please and compare to your setup? What's your experience on this?
BTW, I also started to notice that in high lamp the fan developed some fixed constant frequency tone (like if bearing wears out or so) beside the usual fan noise. Anybody experienced anything like this?
Thanks in advance,
igy
igy137 is offline
post #4812 of 5062 Old 08-12-2018, 03:07 PM
Javs's Avatar
Quoted: 6925 Post(s)
Liked: 6635
Originally Posted by igy137 View Post
Hi All,
After the movie I checked it in manual mode, swiping through -15 to 0 and to me it sounds not so healthy, here's a link to the recording. During the film we heard something like series of those small noise/clicks as with every other step.
Thanks in advance,
igy
Completely normal.
The louder of the two sounds is the hidden internal iris moving, the quiter one is the external lens iris which you can see.
Dont worry about it, thats how it sounds.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #4813 of 5062 Old 08-12-2018, 08:38 PM
Liked: 10154
Hi All,
Thanks in advance,
igy
As Javs said, that sound is correct. Your unit is operating as it was designed.
post #4814 of 5062 Old 08-12-2018, 11:51 PM
Liked: 1
Thanks for the quick answers! So it's normal that the iris movements are sometimes hearable during movies (I'm relatively close seated, around 2.5m away to the PJ)?
igy137 is offline
post #4815 of 5062 Old 08-13-2018, 01:40 AM
Javs's Avatar
Liked: 6635
Don't sweat it.
Javs is online now
post #4816 of 5062 Old 08-17-2018, 03:09 PM
Erod's Avatar
Liked: 789
Do most of you 520/620 owners use the HDR2020 setting or convert to SDR2020 for HDR material?
Erod is offline
post #4817 of 5062 Old 08-17-2018, 06:02 PM
dmself11's Avatar
Need help. Just set up my RS620 and everything works well except it shows no input when trying to use Oppo 203. My Roku and Directv work fine. Seems like there is a HDMI handshake issue. I get sound coming out of my Denon AVR but no picture. Is there a certain setting i need. I even hooked up my Oppo to another tv and changed the settings but still nothing. I have everthing running through my AVR and then out to the JVC project. Thanks for the help
dmself11 is offline
post #4818 of 5062 Old 08-17-2018, 06:34 PM
Liked: 10154
What AVR and what HDMI cable are you using?
post #4819 of 5062 Old 08-17-2018, 06:39 PM
dmself11's Avatar
Im using a Denon 4200 and just using the HDMI cable that came with the Oppo but tried others as well. Cables work fine on other 4k tv.
dmself11 is offline
post #4820 of 5062 Old 08-17-2018, 06:41 PM
dmself11's Avatar
Also have no problem with 4k on the Roku. Tried my Sony 4k player and same thing. Its not liking the 4k players for some reason.
dmself11 is offline
post #4821 of 5062 Old 08-17-2018, 07:01 PM
Liked: 10154
Okay, you are using the Oppo with the Oppo cable to feed the signal to the AVR, but what HDMI cable are you using to send the signal to the projector?
post #4822 of 5062 Old 08-17-2018, 07:06 PM
dmself11's Avatar
It was professionally installed wires and they said it would work with 4k and it does with the Roku. Isnt their a firmware for this problem. It says its a high speed hdmi with ethernet MHCG
dmself11 is offline
post #4823 of 5062 Old 08-18-2018, 07:06 AM
Liked: 10154
I would give it a 1% chance the problem is the projector. No, there is no firmware update for the projector to solve this problem. As I asked before, what HDMI cable are you using from the AVR to the projector? Is pretty easy to prove it is not the projector, take the HDMI cable that came with the Oppo 203 and connect the Oppo 203 directly to the projector, using the HDMI main out.
Maddog56 likes this.
post #4824 of 5062 Old 08-18-2018, 09:23 AM
Industry Insider
Liked: 6675
How sure are you is the question... You have to eliminate this from the equation as mentioned.
post #4825 of 5062 Old 08-18-2018, 01:02 PM
Roger Dressler's Avatar
Quoted: 2975 Post(s)
Liked: 1736
The Oppo 203 has 2 HDMI outputs. Only Main HDMI carries video (plus audio). The other HDMI carries black video with audio. Which output are you using into the PJ?
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is offline
post #4826 of 5062 Old 08-19-2018, 08:04 PM
chipvideo's Avatar
Quoted: 50 Post(s)
Liked: 24
Can anyone recommend a good AV processor to upgrade too that will pass the correct signal so that I dont need to use the HDLINKER to get the higher contrast in HDR mode? Is the Anthem AVM60 a good choice or is there anything better for under $5000?
chipvideo is offline
post #4827 of 5062 Old 08-19-2018, 10:20 PM
Swatdude1's Avatar
Quoted: 66 Post(s)
Liked: 27
Depending on what displays you are using, the Anthem could be your worst nightmare. The fatal flaw is you can't assign an HDMI output to a specific input. I have been through the ringer and finally have my MRX720 working with an HDFury Vertex.
Swatdude1 is offline
post #4828 of 5062 Old 08-19-2018, 10:22 PM
Swatdude1's Avatar
Quoted: 66 Post(s)
Liked: 27
Thanks in advance,
igy
Is you place dusty? A dirty filter can cause the fan to be louder or develop a pitch.
post #4829 of 5062 Old 08-20-2018, 03:27 PM
chipvideo's Avatar
Quoted: 50 Post(s)
Liked: 24
That sucks. Yah I need to upgrade my Pre Amp as it is not even hdmi and have been using it for 13 years now. Just need a good pre amp with video processing so I can clean up the chain and get rid of my hdmi switcher and multiple hdmi cables going to the projector. Also confused on upgrade paths as far as hdmi versions. Would have to lay down a good amount of coin only to have to upgrade again in a year.
Oh and as far as displays go I have the RS520 and am probably going to upgrade to another JVC in the next year as I just love their black levels.
post #4830 of 5062 Old 08-20-2018, 05:53 PM
mzs22's Avatar
Quoted: 230 Post(s)
Liked: 91
Should the graphics mode setting in the x770 be set to 2k or 4k ?Never was really sure so I just left it in 2k,
mzs22 is offline
