Official JVC RS520/RS620 (X7500/X9500) Owner's Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 10176Likes
post #61 of 5130 Old 02-01-2017, 07:06 AM
Mike Garrett's Avatar
Quoted: 13792 Post(s)
Liked: 11435
Originally Posted by jedimastergrant View Post
So I will say something negative about this projector. I was really annoyed at the super long sync times with my RS 400. They may be somewhat improved with the RS 520 but I am still counting upwards of 10 seconds when changing resolutions etc! That is just unacceptable if you ask me. It is a constant annoyance. I hope this is something they can fix with a firmware update but I'm not holding my breath since it was not addressed with my RS 400. I guess I will continue to curse this time suck for years to come.
What I have gotten in the habit of doing is pausing the movie or stream or whatever after I hit play. Then wait for the picture to finally appear before hitting play again. Otherwise the content is totally playing and you can hear the sound and everything but you end up missing the first 10 seconds! If anyone has a better solution for this I am all ears.
If you have low latency mode on, I believe it decreases the sync time slightly.
Mike Garrett is online now
post #62 of 5130 Old 02-01-2017, 07:09 AM
Liked: 11435
Originally Posted by mintakaX View Post
When will the RS620 be available from AVS ? I was considering a Sony 675ES, but am leaning towards the RS620 at the moment. I have always had Sony's and currently have a VW95ES.
They have been shipping them already.
post #63 of 5130 Old 02-01-2017, 07:34 AM
Liked: 11435
Originally Posted by egrady View Post
I've been waiting for a PJ that has black levels good enough to moot screen masking. I'm thrilled to see your comments and will forward to seeing what the RS620 can do.
An RS600/620 has very good black floor and in darker scenes, you might not see the black bars, if your room is a black pit, but as soon as you have a bright scene, you can see the black bars.
post #64 of 5130 Old 02-01-2017, 10:08 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7497 Post(s)
Liked: 7534
I am sure it will be nothing but excellent. Seems to be the JVC trend.
Cleveland Plasma is offline
post #65 of 5130 Old 02-01-2017, 11:01 AM
Buddylee123's Avatar
Quoted: 926 Post(s)
Liked: 630
Originally Posted by Bandyka View Post
Well I am afraid there are some glitches and you just confirmed that. I first tested with Resident evil on PC and that looked absolutely horrible, white text looked like red as if the panel alignment went horribly wrong so first I thought I had a faulty filter as with the filter off it looked normal but then I turned on the PS4Pro and all games were flawless with the filter on, I also tried changing resolutions and bit depth on the PC which managed to crash the projector yes the projector not the PC so I had to shut down the PJ and reboot. After this I did not test the PC again shortly I will be looking into this. There seem to be some glitches.
The PC game also detected the PJ as native 4K so it set the resolution to 4096x2160 so the PJ seems to be reporting some things incorrectly from what I gather. So mine was pushing red yours pushing purple, interesting.
This doesn't give me much confidence that my RS420 will be plug and play with my Xbox One S.
Buddylee123 is offline
post #66 of 5130 Old 02-01-2017, 01:15 PM
Bandyka's Avatar
Quoted: 2449 Post(s)
Liked: 1535
Mine is probably DOA will be talking to support shortly.
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #67 of 5130 Old 02-01-2017, 01:17 PM
Bandyka's Avatar
Liked: 1535
I knew this upfront so I prepared myself for it and accepted it as a fact of life. It still bothers me but nothing I can do.
Bandyka is offline
post #68 of 5130 Old 02-01-2017, 01:23 PM
Craig Peer's Avatar
Quoted: 7957 Post(s)
Liked: 10338
It's like being married to a rich supermodel that snores. It's a minor inconvenience.
DERG, jedimastergrant and Ronman79 like this.
Craig Peer is online now
post #69 of 5130 Old 02-01-2017, 01:26 PM - Thread Starter
desertdome's Avatar
Quoted: 1581 Post(s)
Liked: 1923
Ok I could use some help here. I was eager to try out the HDR gaming feature that is available on some games through my PS4.
The PS4 detected that I had an HDR capable display and prompted me to turn on HDR if I so desired like so . . . Everything is........well purple. Now I am a KSU Wildcat fan but this is ridiculous.
Go the the JVC menu and change the Input Signal > Color Space to a manual setting. Since the JVC info is showing RGB and 12-bit, it looks like these settings are on Automatic on the PS4. I don't expect changing the Color Space to help, but weird things sometimes happen.
I recently had a Panasonic PJ that would go into YCbCr mode even though the laptop was set to RGB. The image would go pink. If I connected another laptop, the PJ would go back into RGB mode and then the 1st laptop would work again up reconnection. Wait a few days and the laptop would again put the PJ into YCbCr mode.
cemo62 likes this.
Ponderosa Theater
High Impact AV
- JTR Speakers Customer Appreciation Sale
- ISF Level III Video Calibrator, THX-HAA HT3 Audio Designer/Calibrator
desertdome is offline
post #70 of 5130 Old 02-01-2017, 01:33 PM
Bandyka's Avatar
Liked: 1535
Except earplugs can be a bliss in that situation ...but there is no workaround here.
On a serious note if they've fixed that would have been almost too good to be true along with all the other improvements.
Dandlj likes this.
Bandyka is offline
post #71 of 5130 Old 02-01-2017, 01:34 PM
Bandyka's Avatar
Liked: 1535
good call.. or simply press the HDR button on the remote before turning on the PS4 which means the PJ is forced into the correct mode even before the the auto detection kicks in.
Bandyka is offline
post #72 of 5130 Old 02-01-2017, 02:05 PM
Javs's Avatar
Quoted: 7110 Post(s)
Liked: 6841
Correct, its a bug that very rarely pops up... rebooting the AVR always fixed it in seconds.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #73 of 5130 Old 02-01-2017, 02:34 PM
Kris Deering's Avatar
Quoted: 4370 Post(s)
Liked: 7955
I guess I was fortunate in some ways. My X750's zoom kicked the bucket a few weeks back. It obviously worked fine on my screen size but if I tried to go for a longer throw it wouldn't budge. I told JVC about it to get it into service while I had the 4500 in for review. Sure enough, zoom ring completely busted. Since it is part of the lens assembly which is fused to the optical block, can't be repaired so now being replaced with a X7500. Should be here in a week or so (they are backordered). Hopefully I will still have the 4500 here to do comparisons. Anxious to see if the HDR settings work the same on the 7500 as they do on the 4500.
My Home Theater UPDATED NOV 2019
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is offline
post #74 of 5130 Old 02-01-2017, 03:28 PM
egrady's Avatar
Quoted: 411 Post(s)
Liked: 183
I'm aware that the ANSI contrast of any projector won't come close to OLED. But in a black pit I don't want to see bars that aren't very, very close to the black velvet framing material of my screen in a very low light scene. If the RS 620 can do that...
egrady is online now
post #75 of 5130 Old 02-01-2017, 07:20 PM
Liked: 11435
No, the RS600/620 can't do that. Close, but not quite. The bars will show up with bright content. In darker scenes, you will not be able to tell the black bars from the black velvet of the frame.
post #76 of 5130 Old 02-01-2017, 07:27 PM
Highjinx's Avatar
Quoted: 1323 Post(s)
Liked: 538
No black pit is ever totally non reflective. Project some light and dark video, stand at the screen and look at the back, ceiling and side walls. If you see any reflections, that light is finding it's way to the screen and will light up the black bar area.
Masking is definitely beneficial.
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is offline
post #77 of 5130 Old 02-01-2017, 07:34 PM
Bandyka's Avatar
Liked: 1535
I have velvety stuff all around and I am having a hard time finding any notable reflections.
Bandyka is offline
post #78 of 5130 Old 02-01-2017, 07:42 PM
Highjinx's Avatar
Liked: 538
Seems like you have a great room!
I have flat slate grey paint on the back wall and ceiling, but project a bright scene, if I stand at the screen and look toward the rear wall and I sure can see the wall. That light of course is finding it's way back to the screen.
Highjinx is offline
post #79 of 5130 Old 02-01-2017, 08:29 PM
Bandyka's Avatar
Liked: 1535
Well I built a frame and hung fabric all around including the ceiling, guess that made a difference, when the PJ is on and paused at a mid bright scene I can just make out some creases on the back wall fabric. It is very hard to make a room totally dark I agree.
BTW I am watching Sully on UHD on the 7500 and it's incredibly sharp and detailed and HDR is great, been swapping between SDR WCG and HDR and I think am happy to stay HDR.
Bandyka is offline
post #80 of 5130 Old 02-01-2017, 08:47 PM
2 Stangs's Avatar
Quoted: 35 Post(s)
Liked: 24
Well, I decided to go with the RS520 which arrived this afternoon. Won't have a chance to try it until the weekend as my room is being redone from scratch but I'm excited!
Thanks Craig!!!
Bandyka likes this.
2 Stangs is offline
post #81 of 5130 Old 02-01-2017, 09:14 PM
Bandyka's Avatar
Liked: 1535
Thanks Craig!!!
I wish I had your patience.
Bandyka is offline
post #82 of 5130 Old 02-01-2017, 09:34 PM
2 Stangs's Avatar
Quoted: 35 Post(s)
Liked: 24
I've taught first and currently teach sixth grade. I have infinite patience!
Bandyka likes this.
2 Stangs is offline
post #83 of 5130 Old 02-02-2017, 03:49 AM
jedimastergrant's Avatar
Quoted: 913 Post(s)
Liked: 745
It was worth a try. But, did not do the trick.
I also made an attempt at a different game with HDR. The Last of Us Remastered but was met with the same Jimi Hendrix Purple Haze.....
jedimastergrant is offline
post #84 of 5130 Old 02-02-2017, 03:51 AM
Quoted: 913 Post(s)
Liked: 745
That's a good tip. May work out for the best if I just plan to leave it on at all times then. I will do some experimenting.
post #85 of 5130 Old 02-02-2017, 03:52 AM
Quoted: 913 Post(s)
Liked: 745
Hmm, ok will try that tonight and report back. Why didn't I think of that!!!
post #86 of 5130 Old 02-02-2017, 04:20 AM
Quoted: 913 Post(s)
Liked: 745
Ok, that is promising news. I was hoping I could stick with HDR vs just WCG.
Are you using the HDR stripping feature on your Oppo 203? That is one of the reasons I bought the unit myself. And then here I am trying out all of this content last night to see what I want to use for the Kansas City Theater Crawl next month and I run into Mad Max. Now I know there have been numerous problems with this disc in most of the players. It was my first time trying it but I got the red push and it was way too dark. I have the blu ray of this film as well so I popped it in for comparison and everything was as it should be. Now like some kind of idiot I totally forgot about the HDR stripping feature of my 203! I will try that and see how I like it. I hope I do not run into many of these problems though.
So do you have Mad Max too? What does it look like through your 203 and JVC (since you have the same play back devices)?
I still have my Samsung 8500 so I will give it a chance to spin Mad Max just to rule that out.
post #87 of 5130 Old 02-02-2017, 08:41 AM
Industry Insider
Liked: 7534
All we need is that 105" OLED at $10K...... Problem solved.
Mike_WI likes this.
post #88 of 5130 Old 02-02-2017, 09:15 AM
Toe
Toe's Avatar
Quoted: 2819 Post(s)
Liked: 3773
Hey guys, thanks for all the reports so far and this sounds like a hell of a projector! Couple questions. ...
1. Low lag mode work with 4k games?
2. HDR games on PS4 Pro/XB1 work on the JVCs? If not, is HDR easy enough to turn off on the consoles so there is no issue with the JVCs (I don't have either of these consoles yet, so not sure what the options are)?
Toe is offline
post #89 of 5130 Old 02-02-2017, 09:29 AM
Quoted: 145 Post(s)
Liked: 39
Your experience is holding me back from pulling the trigger on a JVC x20. It's important the my next projector works with HDR on the PS4 Pro and Xbox One S. Until this if figured out, I guess I will keep waiting. I was really hoping to upgrade from my Sony HW30ES... but I don't want to drop the $$$ just to have issues.
CollectedDust is offline
post #90 of 5130 Old 02-02-2017, 09:39 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2390
That's still way too small, especially for scope movies. Wake me up when there's a 110" wide, direct view scope solution, that's not "cost impossible".
rak306 likes this.
stanger89 is offline
