Official JVC RS520/RS620 (X7500/X9500) Owner's Thread - Page 97 - AVS Forum | Home Theater Discussions And Reviews
 10176Likes
post #2881 of 5131 Old 08-09-2017, 11:38 AM
Toe
Toe's Avatar
Quoted: 2832 Post(s)
Liked: 3788
Originally Posted by D_B_0673 View Post
Can I force the 620 to stay on low lamp when viewing HDR 4k?
I feel I would have a enough brightness (only 106" DaLite high Powerscreen )
I am hoping to not have the fans ramp up, although I don' know how much louder it would be.
thanks
dan
Yes. I used my 520 in low lamp for 4k with my HP screen.
chipvideo likes this.
Toe is offline
post #2882 of 5131 Old 08-09-2017, 01:23 PM
D_B_0673's Avatar
Quoted: 183 Post(s)
Liked: 33
what settings did you use, i.e to keep the pj from forcing the lamp to high. I thought the pj automatically went to high lamp mode with HDR
Dan
D_B_0673 is offline
post #2883 of 5131 Old 08-09-2017, 02:29 PM
Toe
Toe's Avatar
Liked: 3788
Unless I'm remembering it wrong (someone correct me if I am), once I switched it over to low lamp for the HDR preset it stayed there.
Toe is offline
post #2884 of 5131 Old 08-10-2017, 04:53 AM
D_B_0673's Avatar
Quoted: 183 Post(s)
Liked: 33
thanks
dan
Dan
D_B_0673 is offline
post #2885 of 5131 Old 08-10-2017, 08:49 AM
Cleveland Plasma's Avatar
Quoted: 7621 Post(s)
Liked: 7693
Originally Posted by Javs View Post
Same physical projector save for the gold trim ring on the RS.
I have an X9500 which is identical to an X970 which is identical to an RS620.
Some may wonder why there are two different model numbers and similar projector's, one unit is meant for custom installer types and the other is meant for retails stores like Best Buy.
Cleveland Plasma is offline
post #2886 of 5131 Old 08-10-2017, 03:33 PM
Erod's Avatar
Quoted: 1437 Post(s)
Liked: 938
Which makes no damn sense whatsoever. Lol
It's the only thing that I don't like about JVC. Not a big deal.
Erod is offline
post #2887 of 5131 Old 08-10-2017, 04:16 PM
Quoted: 156 Post(s)
Liked: 107
Hi Everyone,
I have a newish RS620. I experienced the colored bars and lock up when switching between HDR and non-HDR sources, so I successfully applied the firmware upgrade to 30.1 two nights ago.
I was just watching an HDR show on Amazon Video on Roku and at the end the projector went to switch back to SDR and it locked up again. See attached pic.
Anyone have any thoughts? The 30.1 upgrade was definitely successful ...
David
dgkula is offline
post #2888 of 5131 Old 08-10-2017, 06:22 PM
DLCPhoto's Avatar
Quoted: 1842 Post(s)
Liked: 944
Originally Posted by dgkula View Post
Hi Everyone,
David
Many of us have encountered a bug that sounds like this, specifically with the Roku, and it seems to occur only when CMD is turned On. So, is your CMD On? If it is, turn it Off when using the Roku, and theoretically the problem shouldn't occur, if it's the same one many of us have run into.
Don
JVC NX7, DCR Lens, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is offline
post #2889 of 5131 Old 08-11-2017, 05:12 AM
lunnar's Avatar
Quoted: 59 Post(s)
Liked: 42
Don
Yea I also got this problem form time to time when switching output to my Roku or resolution/refresh rate on my HTPC. And I also concur that it only seem to happend when CMD is on.
The firmware update did not hel for this.
EllisGJ, a member here got an open ticket with JVC on this matter.
-Lunnar
"Tempo is everything, perfection unattainable..."
lunnar is offline
post #2890 of 5131 Old 08-11-2017, 08:58 AM
EllisGJ's Avatar
Quoted: 420 Post(s)
Liked: 189
If anyone can reproduce this problem on demand - a set of steps that causes the failure - it would help JVC with the diagnosis.
EllisGJ is offline
post #2891 of 5131 Old 08-11-2017, 06:57 PM
starshipvelcro's Avatar
Quoted: 45 Post(s)
Does anyone have any experience programming the harmony hub to work with the RS520?
Which the power on setting is sent I see the projector led blink green as if it received the signal but doesn't switch on. The original remote works fine.
starshipvelcro is offline
post #2892 of 5131 Old 08-11-2017, 07:09 PM
mzs22's Avatar
Quoted: 261 Post(s)
Liked: 97
Hi, I had that same issue while programming my Harmony 650. I used the projector remote and put it next to the 650 remote and manually programmed the power on command.
mzs22 is offline
post #2893 of 5131 Old 08-12-2017, 06:02 AM
jowicrt's Avatar
Quoted: 707 Post(s)
Liked: 209
I'm thinking about buying an X7500. My screen will be a 16:9 110" diagonal Elite Saker tab tensioned (view width about 240cm / 96").
According to the viewing distance table from the manual, the projector can be placed anywhere from 3.31m / 130.3" (wide) tot 6.75m / 265.7" (tele) away from the screen, is that correct? Is there an optimal distance? I mean, if i'm using a 110" screen and i move the projector 6.75 meters away, isn't that asking a lot of the optics and light output?
In my case, the projector can be placed at any distance i want, so i guess that 3.31m is the one to go for?
jowicrt is offline
post #2894 of 5131 Old 08-12-2017, 07:02 AM
thetman's Avatar
Quoted: 544 Post(s)
Liked: 306
Hi Everyone,
David
Have the 570R ( 420) but this happens to me too when watching HDR on Amazon and then switching back to menu or SDR with Roku. except my screen goes all to black. everything is running through yamaha 3060. I switch inputs back and forth on the receiver and then the Roku menu comes back up. I haven't done the latest firmware update yet ( no PC or cable at the moment). Sorry to hear it still does it even with the latest firmware. I have CMD off.
thetman is offline
post #2895 of 5131 Old 08-12-2017, 07:09 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2390
It depends on what you want/need in your setup. Shorter throw results in more brightness but lower contrast, where as long throw is the reverse. Previously I would have said put it at long throw since these projectors are quite bright and you've got a modest/average screen size, so there's plenty of brightness on tap, we can afford to focus on maximizing contrast.
However the wrench in that plan is HDR, for that we tend to want as much brightness as possible, so you might want to put it at short throw for that.
stanger89 is offline
post #2896 of 5131 Old 08-12-2017, 07:59 AM
jowicrt's Avatar
Quoted: 707 Post(s)
Liked: 209
I wasn't aware of the relationship between throw distance and contrast... i'm having trouble explaining this to myself; contrast is the difference between the brightest and blackest a projector can generate; but if you move the projector away from the screen, the brightness will reduce, but also the blackness will improve... in an ideal, black room, if i move my projector away to an infinite distance, my blacks will be perfect, but my brightness will be gone
I mean, the ideal projector, like a crt for example, will have a superior blacklevel at any distance, since it just doesn't emit any light at a 0 ire signal. So i can imagine moving a crt away from the screen will decreas brightness, and since the black stays the same, the contrast will get lower... not higher? Am i missing something?
jowicrt is offline
post #2897 of 5131 Old 08-12-2017, 10:15 AM
stanger89's Avatar
Liked: 2390
It's due to how the lenses work. Projectors don't have constant aperture lenses, as you zoom out (farther throw) the f-stop decreases, which means it it blocks more light, but it also blocks more stray (reflected) light than it does desired light. So that means the contrast increases. It's the same way that contrast increases when you reduce the iris/aperture setting in the projector.
jowicrt likes this.
post #2898 of 5131 Old 08-12-2017, 12:47 PM
Roger Dressler's Avatar
Quoted: 3463 Post(s)
Liked: 2195
I'm new around here, but have had the lock-up occur a couple times prior to 30.1 install (too recent to say whether it has helped or not). And I can tell you that if switching inputs on the Yamaha fixes the problem, that is not the same lock-up problem we are lamenting. The one and only remedy to that is to pull the power cord on the PJ.
Deadwood II Theater (Previous Deadwood Theater HTOM)
Anthem AVM 60 7.4.4; Classé SSP-800 PLIIx 7.4; MiniDSP OpenDRC-AN
Oppo UDP-203; Oppo BDP-93; Win10 media PC w/Roon+Kodi; Roku Ultra; DirecTV Genie
Adam Audio S3V/S3H LCR, KEF Ci200QS 4 srrnd, Tannoy Di6 DC 4 hts, Hsu ULS-15 4 subs
JVC RS520; Stewart Cima Neve screen 125" diag 2.35:1, MLP at 115"
Roger Dressler is online now
post #2899 of 5131 Old 08-13-2017, 06:40 AM
mzs22's Avatar
Quoted: 261 Post(s)
Liked: 97
I was thinking of getting a new screen to go with my 770R . I have a Screen Innovations 106" 1.1 or 1.0 not sure, matte white fixed screen 16x9 I was using with my old epson projector. Since we watch 90% Blu-ray movies I am really getting tired of the black bars and was thinking of going with a 2.35:1 screen. Was wondering what would be a good match with this projector and would there be a noticeable jump in PQ to justify spending the money on a new screen? Also when watching a 16x9 program will it be distorted when you stretch it to fill the screen?
mzs22 is offline
post #2900 of 5131 Old 08-13-2017, 10:10 AM
Liked: 2195
Assuming you want to have the same picture size for 16x9 images, your 2.35 screen will be wider. That might be a noticeable improvement if the image width is more suitable for you.
I made such a transition as my original theater was too narrow for a 2.35 screen, so I went from a 42 deg angle of view to 53 deg with the new screen (so-called 1:1 distance to width ratio) which for me was a big improvement for widescreen presentations -- I leave 16x9 and 1.85 images alone (CIH mode). The wider screen means zooming the image larger, so there's technically a drop in resolution and brightness that occurs. Not a problem for me, and I don't use 4k or e-Shift.
Aside from size, unless you are not happy with the texture of the screen, I do not see how a new material will improve things noticeably.
If you stretch 16x9 images to fill the 2.35 screen, by definition you will see distortion. That's what stretch does -- non-linear or otherwise. I do not bother with that. The non-illuminated side bars are of no consequence to my eyes. But my room is on the dark side.
post #2901 of 5131 Old 08-13-2017, 12:19 PM
mzs22's Avatar
Quoted: 261 Post(s)
Liked: 97
I was just thinking the wider screen would be nice because that is the majority of what I watch, my room is only 14ft wide and I still need to leave room for my front towers. I thought if I could get a substantial bump in pq it might be worth it . I will have to take some measurements and see if it would work. I would like to get a little larger screen now that I have a projector that can light it up. Going to get it calibrated so I would like to get a new screen if I am going to before that. Thanks!
mzs22 is offline
post #2902 of 5131 Old 08-13-2017, 12:46 PM
Mike Garrett's Avatar
Quoted: 14009 Post(s)
Liked: 11682
If the majority of what you watch is scope and you have the space to go wider, then I would definitely consider going with a scope screen. What throw distance do you have to work with? If you could fit a 133" diagonal 2.35 screen in your room, you would get the same size 16:9 that you currently get, but a huge step up in scope image. With the 133" 2.35, your scope image would be 44.13SF, compared to your current scope image size of 25.01SF. We are talking a 76.45% increase in size.
Mike Garrett is offline
post #2903 of 5131 Old 08-13-2017, 12:50 PM
mzs22's Avatar
Quoted: 261 Post(s)
Liked: 97
My throw distance is 14ft. What would the dimensions of the 133" be?
mzs22 is offline
post #2904 of 5131 Old 08-13-2017, 01:03 PM
Liked: 11682
You would need 14'-4" to be able to fill the 133" diagonal 2.35. Size would be 52-1/8" x 122-3/8".
post #2905 of 5131 Old 08-13-2017, 01:36 PM
mzs22's Avatar
Quoted: 261 Post(s)
Liked: 97
My exact measurement is lens to wall 14.3 and at 52 1/8 tall I could fit my towers under the screen if I have the top of the screen 5 inches from my ceiling. not suer if this would work or if I would have to go a little smaller.
mzs22 is offline
post #2906 of 5131 Old 08-13-2017, 02:26 PM
mzs22's Avatar
Quoted: 261 Post(s)
Liked: 97
I would like a 133" but might have to settle with 120
mzs22 is offline
post #2907 of 5131 Old 08-14-2017, 07:27 AM
Liked: 11682
Or go somewhere inbetween.
mzs22 likes this.
post #2908 of 5131 Old 08-14-2017, 10:42 AM
Quoted: 17 Post(s)
Liked: 0
So, I'm still chasing the HDR dragon, and am wondering if dropping from a 120' 1.0 gain to 100' higher gain (exact number TBD) screen would be a significant improvement. As I understand it there is a brightness increase from shrinking the screen, and higher gain seems like an easy brightness win (below whatever point makes the screen start to sparkle).
Thoughts?
blackgold9 is offline
post #2909 of 5131 Old 08-14-2017, 10:44 AM
Bandyka's Avatar
Quoted: 2523 Post(s)
Liked: 1628
DO NOT pull the power cord you will damage the PJ. hold down the power switch on the back of the PJ until shuts off gracefully.
EPSON TW-9300 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, DIY Subs 18" 24hz tune and 12" 17hz tune Panasonic UB900, HTPC, etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-di...l#post50298297
Bandyka is online now
post #2910 of 5131 Old 08-14-2017, 10:46 AM
Bandyka's Avatar
Liked: 1628
Thoughts?
Do a simple test, shrink your screen via zoom. do you see a difference?
