Official JVC DLA-RS420 (DLA-X570R) Owners Thread - Page 83 - AVS Forum | Home Theater Discussions And Reviews
 3516Likes
post #2461 of 3017 Old 10-18-2018, 07:45 AM
munnlete's Avatar
Quoted: 26 Post(s)
I received a x570 yesterday, and when running the xbox one s in 4k hdr, I am 70% of the time getting pure static snow, and 30% of the time getting a working screen but filled with speckles all over the screen.
Receiver: yamaha rx-a1070
HDMI cable receiver to projector: C&E High-Speed HDMI Cable - 25 Feet, Supports Ethernet, 3D and Audio Return, UltraHD 4K Ready
HDMI cable xbox to receiver: Tried 2. The first was the cable that came with the Xbox One S. The second was 4K HDMI Cable/HDMI Cord (6 feet / 6 ft, HDMI to HDMI, TOP Series) by KabelDirekt
I read about other people having success going with the Monoprice Certified cables, so I will lean towards ordering 2 of them. Any other thoughts or help?
edit: forgot to test the direct connection from xbox to pj. it works fine that way, but still would like it to work through the receiver.
munnlete is offline
post #2462 of 3017 Old 10-18-2018, 12:41 PM
lizrussspike's Avatar
Quoted: 1507 Post(s)
Liked: 2288
So @ munnlete , it sounds like you have an issue with the cable from the receiver to the projector, is that correct? Since you hooked the XBOX directly to projector, and had no issues.
I do not see anything that it is premium certified:
https://www.amazon.com/Monoprice-115...4k%2B60hz&th=1
I had issue as well at first, but once I got a certified premium cable, no problems since.
lizrussspike is offline
post #2463 of 3017 Old 10-18-2018, 05:09 PM
munnlete's Avatar
Quoted: 26 Post(s)
Thanks, I ordered a couple.
munnlete is offline
post #2464 of 3017 Old 10-18-2018, 06:03 PM
Viper359's Avatar
Quoted: 70 Post(s)
Liked: 59
Glad to hear @Viper359 , and agree that @Javs curves made a big difference in my viewing once I downloaded them. I was overwhelmed as I had a few errors(operator errors) but once I got them loaded from the laptop, and then cycle between the 1200 and 4000 nits, I could really see the difference. So worth the effort with Javs curves!
I agree, what a night and day difference. I was actually kind of surprised by such a difference. Low lamp mode, and it looks fantastic. Mind you, My beamer is only 13.5-14 feet from my 120" screen, but wow
Beamer: JVC RS420 || Screen: 120" SilverTicket 16:9 Frame || Fronts: Paradigm Monitor 7 || Center: Paradigm Monitor CC390 || Sub: Polk HTS 12 || Surrounds: Paradigm Monitor Bookshelf || Atmos Rear: Polk || AVR: Denon AVR S710 || Streamer: Nvidia Shield ||Control: Harmony Hub Ultimate ||Console: Xbox One X
Viper359 is offline
post #2465 of 3017 Old 10-19-2018, 03:56 AM
Liked: 2288
Yea buddy @Viper359 , now it is time to sit back and enjoy some flicks. I sit about 13.5 on a 113" screen as well. Got the first purge coming to day, so hoping for a good movie night.
post #2466 of 3017 Old 10-19-2018, 10:43 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7474 Post(s)
Liked: 7513
Cleveland Plasma is offline
post #2467 of 3017 Old 10-19-2018, 09:20 PM
Viper359's Avatar
Quoted: 70 Post(s)
Liked: 59
I purchased this cable, and works fine for me so far. It's from Amazon Canada, but figured it may help someone.
Monoprice Certified Premium High Speed HDMI Cable, HDR, 25ft Black https://www.amazon.ca/dp/B06X3QDY4M/
Viper359 is offline
post #2468 of 3017 Old 10-19-2018, 09:27 PM
rukus29's Avatar
Quoted: 287 Post(s)
Liked: 147
What are these javs curves? I’m sub 100 hours on my pj so haven’t gotten back into diy calibration yet... another rabbit hole I’ve managed to avoid for the last 4-5years since I started learning it for my last JVC pj.
rukus29 is offline
post #2469 of 3017 Old 10-19-2018, 10:17 PM
Viper359's Avatar
Quoted: 70 Post(s)
Liked: 59
Click on @Javs and see his signature for a direct link to his curves, install instructions et. I am running v3 1000 and 4000 nits
Viper359 is offline
post #2470 of 3017 Old 10-20-2018, 05:00 AM
Rdawg16's Avatar
Quoted: 29 Post(s)
Any recommendations on calibration settings for this projector? I am helping my brother with his new x570 but we don't have any fancy calibration equipment. Any help on settings would be greatly appreciated! Thanks!
Rdawg16 is offline
post #2471 of 3017 Old 10-20-2018, 08:36 AM
Quoted: 6121 Post(s)
Liked: 2539
Recommended HDR settings for RS420
Note: For models with Gamma D (RS400/500/600; x550/x750/x950) see the recommended settings here:
https://www.avsforum.com/forum/24-di...l#post56987686
The RS420 added HDR Picture Mode with ST2084 gamma, which is much better than Gamma D on the RS400. However, depending on your screen size, the default settings may not be optimal. Custom curves can provide a big improvement, but if you’re not ready to get into that, here are some suggested settings grouped by screen size and mastering nits.
These are based on my own measurements done on the RS420 (x570), trying to match custom curves as closely as achievable using the 3 controls. They should work equally well on the RS520/620, and even the RSx40 assuming JVC did not change the ST.2084 implementation in the newer projectors. Feedbacks are welcome.
Different settings are recommended for the mastering nits; you can use the 2000-nit settting if you don’t want to be bothered with switching. Note: only change the White settings, not the individual R/G/B settings.
Note: if you’ve never run autocal, the projector most likely will have developed some “gamma droop”, in which case you may want to reduce Picture Tone and Dark Level by one click.
The three numbers listed are for Picture Tone, Dark Level, Bright Level respectively.
Small screens (90” or less). You can get around 140 nits peak using a new bulb.
4000: 1, 5, -1
2000: 1, 5, 0
1000: 1, 5, 1
Average screens (100-120”), 100 nits peak
4000: 3, 7, -3
2000: 3, 7, -2
1000: 3, 7, 1
Large screens (>120”), 70 nits peak
4000: N/A (cannot avoid clipping while producing good brightness; just use the 2000 nit settings.).
2000: 10, 4, -7
1000: 10, 4, -5
noah katz, johng, Schwa and 9 others like this.
Dominic Chan is online now
post #2472 of 3017 Old 10-21-2018, 05:56 AM
munnlete's Avatar
Quoted: 26 Post(s)
I received them and the Monoprice cables solved the flickering/snow problem. Another probably unrelated note is that when trying to launch games with HDR enabled on my (non Pro model) PS4, I get the "Green or purple saturated screen". I could've sworn though that this was not a problem when I got the PJ a couple days ago, but only started when I updated ps4 software last night. Perhaps it tweaked some sort of HDR setting. It's also possible that the software update was the first time there'd been a "hard close" on my ps4 system since the new PJ, therefore HDR was never enabled up until that point. Either way, HDR is being screwy. Thoughts?
munnlete is offline
post #2473 of 3017 Old 10-21-2018, 10:34 AM
jwhart's Avatar
Quoted: 215 Post(s)
Liked: 78
Refer to the 1st page of this thread which has the recommended settings.
jwhart is offline
post #2474 of 3017 Old 10-21-2018, 10:41 AM
Rdawg16's Avatar
Quoted: 29 Post(s)
Where at? I've looked and nobody posts their settings.
Rdawg16 is offline
post #2475 of 3017 Old 10-21-2018, 10:51 AM
jwhart's Avatar
Quoted: 215 Post(s)
Liked: 78
Sorry, wrong thread.
https://www.avsforum.com/forum/24-di...rs-thread.html
jwhart is offline
post #2476 of 3017 Old 10-21-2018, 11:39 AM
Liked: 2539
You can try the HDR settings in Post 2471 above.
post #2477 of 3017 Old 10-21-2018, 06:02 PM
NetViper's Avatar
Quoted: 80 Post(s)
Liked: 31
These are based on my own measurements, trying to match custom curves as closely as achievable using the 3 controls. Feedbacks are welcome.
4000: 1, 5, -1
2000: 1, 5, 0
1000: 1, 5, 1
4000: 3, 7, -3
2000: 3, 7, -2
1000: 3, 7, 1
2000: 10, 4, -7
1000: 10, 4, -5
I’m new to Jvc, where do you go to change this?
NetViper is offline
post #2478 of 3017 Old 10-23-2018, 10:24 PM
Nutdotnet's Avatar
Quoted: 181 Post(s)
Liked: 53
Somewhat of a silly question.
I have a RS420 and would like to try out MadVRs SDR2020 capabilities. Does anyone know of a how-to guide (or similar) on how to set MadVR up for our projectors?
I have it configured correctly to play using MPC-HC, there’s just so many image quality options to choose from that it’s a bit overwhelming.
Sorry if this has been covered.
Nutdotnet is offline
post #2479 of 3017 Old 10-24-2018, 09:06 AM
Viper359's Avatar
Quoted: 70 Post(s)
Liked: 59
What is the best way to ensure USER2 is always selected for HDR 4K content. Sometimes, with my Nvidia Shield, it defaults the just HDR, instead of the customer USER2 input with the custom curves.
Viper359 is offline
post #2480 of 3017 Old 10-24-2018, 09:42 AM
Liked: 2539
The projector always switches to the HDR Picture mode when detecting HDR metadata. Just set up you HDR Mode the same way as your User2.
post #2481 of 3017 Old 10-24-2018, 10:46 AM
Viper359's Avatar
Quoted: 70 Post(s)
Liked: 59
Thank You, that worked
Viper359 is offline
post #2482 of 3017 Old 10-25-2018, 04:30 PM
luzovich's Avatar
Quoted: 33 Post(s)
Liked: 25
What is the benefit when using an HDFury with the RS420 (if any)? I've seen many references to the HDFury converting HDR to SDR and such and I'm wondering how that affects the image of the RS420. I'm not terribly happy with the image when watching UHD disks on the Sony X800 and was wondering if an HDFury would help. If so, would any HDFury box work and if not, which one would be a good match. Thanks.
luzovich is offline
post #2483 of 3017 Old 10-25-2018, 04:34 PM
farsider3000's Avatar
Quoted: 1692 Post(s)
Liked: 1082
If your picture does not look amazing with the 420 then something is wrong. What is it about the picture that you don’t like?
Sent from my iPhone using Tapatalk Pro
luzovich likes this.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5/P5 in-wall
Subs: JTR Captivator subs: One S2, Two RS2, One S1
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is online now
post #2484 of 3017 Old 10-25-2018, 04:45 PM
Liked: 2539
The HDFury does not convert HDR to SDR; it just strips the HDR metadata so that the RS400 doesn’t switch to Gamma D. It doesn’t do anything for the RS420.
If you have different custom curves, the HDFury Vertex will automatically switch to the optimum one.
If you’re not ready to get into custom curves, you can try my recommended settings in Post 2471 above.
post #2485 of 3017 Old 10-25-2018, 11:43 PM
luzovich's Avatar
Quoted: 33 Post(s)
Liked: 25
I haven't watched very many 4K discs but it seems like the colors appear muted. I was expecting something better than standard blu-ray but they seem worse not better. 4K streaming content looks fine. I'll have to double check my settings.
What's a really good 4K disc that should look amazing on the RS420 if I have everything set right? I can rent it and see how it looks.
luzovich is offline
post #2486 of 3017 Old 10-26-2018, 04:40 AM
Liked: 2539
Planet Earth 2 is my favorite.
post #2487 of 3017 Old 11-06-2018, 11:18 AM
Viper359's Avatar
Quoted: 70 Post(s)
Liked: 59
I have been watching this projector like crazy, and wow. Just destroys my old Benq W1070, in all aspects.
Viper359 is offline
post #2488 of 3017 Old 11-06-2018, 06:24 PM
limbery's Avatar
Quoted: 78 Post(s)
Who else here uses their Oppo UDP-203 to manage their HDR? (info is on the Oppo forum)
The idea is that the Oppo gets to manage the colour palate rather than the projector...I'm running mine that way and the meta data must not be passed through since the projector doesn't kick into the bright bulb mode. I'm told that this is normal and I figure that it probably will extend my bulb life running in normal all the time....but to tell the truth, I'm not blown away with any kind of HDR programming vs. regular 4K or HD but at least my colours look better than the overblown ones that I was getting when I had the JVC running in HDR mode
limbery is offline
post #2489 of 3017 Old 11-08-2018, 01:56 AM
Quoted: 75 Post(s)
Liked: 4
Are there any fellow Panasonic UB420/820 users around here? If so, what settings are we thinking are best? I'm currently using the standard HDR settings on the JVC and SDR/BT2020 on the Panasonic.
SeargentPeppers is offline
post #2490 of 3017 Old 11-27-2018, 02:10 AM
Liked: 0
Hey. PS4 non pro will not work with HDR on RS420. RS420 does not support HDR in 1080p (4k only).
Teodor248 is offline
jvc rs420 420
