BenQ HT8050 DLP 4K UHD THX Certified Projector Unveiled - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 57Likes
post #181 of 229 Old 07-03-2017, 02:41 PM
Ruined's Avatar
Quoted: 2643 Post(s)
Liked: 1273
Originally Posted by JonasHansen View Post
http://www.projectorreviews.com/the-...ter-projector/
Review is coming. They seem very positive so far!
Will be interesting to read, though it is worth keeping in mind that the European version (BenQ W11000) was hit pretty hard for its dynamic iris implementation - Art mentions it in this first look (audible noise when moving); was hit hard enough that BenQ stated that one of the major improvements in the next iteration due in November 2017 (BenQ W11500) is an improved dynamic iris, plus HDR. Which is probably worth waiting for as just around the corner.
Still, man the chassis of the HT8050 is sexy!
Ruined is offline
post #182 of 229 Old 07-20-2017, 12:04 PM
JonasHansen's Avatar
Quoted: 425 Post(s)
Liked: 179
Just read a review of the new cheap BenQ (Successor of HT3040): http://www.projection-homecinema.fr/...t-benq-w2000-2
They measure the contrast to ~2000:1 which is double the HT8050.. I don't get it! (Use Google Translate for the review).
Home Theater: JBL M2 & SUB18 powered by Crown and BSS.
HAA HT1, HT2 & HT3 certified
JonasHansen is offline
post #183 of 229 Old 07-20-2017, 01:10 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2595
It looks like 2500:1 actually. I wonder if the "smarteco mode" helps contrast even more. And is it fairly invisible in it's action?
Seegs108 is offline
post #184 of 229 Old 07-20-2017, 01:52 PM
Seegs108's Avatar
Liked: 2595
Just got a response back from TI about this .67' XPR DMD and associated controller:
The DLP660TE [.67" XPR DMD] is intended for use in a 4K UHD system and supports UHD displays. Furthermore, these displays must run at 50Hz or 60Hz. The front end processor will convert any input frame rate to either 50Hz or 60Hz.If the input is an integer multiple of 50Hz or 60 Hz, the front end will use 2:2 pulldown, otherwise it will use 3:2 pulldown. These configurations are not currently programmable. Any source with a resolution lower than UHD will be upscaled by the front end processor to UHD. The DLPC4422 controller does allow different levels of control to drive the DMD, but it’s the decision of the system integrator on how to configure the final system.
So it looks like 3:2 pulldown is the only way to do 24p with this current controller and DMD. That's another knock against DLP as we move forward.
Seegs108 is offline
post #185 of 229 Old 07-20-2017, 11:11 PM
Quoted: 485 Post(s)
Liked: 125
I can't believe they offer projectors without 24p support.
Will they even be able to do proper DFI without 24p support for people who like DFI?
TheronB is offline
post #186 of 229 Old 07-20-2017, 11:32 PM
darinp's Avatar
Quoted: 543 Post(s)
Liked: 749
I admit that I haven't given this a lot of thought, but I'm not sure that Dark Frame Insertion would work very well with eShift/XPR. It wouldn't give a whole lot of time to create each sub-frame. In the case of DLPs, the mirrors can only move so fast and they would probably need to do more dithering if they were doing DFI.
--Darin
darinp is offline
post #187 of 229 Old 08-17-2017, 01:49 PM
Cine4Home's Avatar
Quoted: 540 Post(s)
Liked: 846
Is you TI source reliable?
Because so far the DMD does not work with 50Hz either, only(!) 60Hz.
Cine4Home is offline
post #188 of 229 Old 08-17-2017, 03:12 PM
Seegs108's Avatar
Liked: 2595
https://e2e.ti.com/support/dlp__mems...f/947/t/610610
TheBrandon likes this.
Seegs108 is offline
post #189 of 229 Old 08-21-2017, 01:56 PM
Quoted: 315 Post(s)
Liked: 255
does anyone own the ht8050? impressions? I thought about it but went with optoma uhd60 instead.
am2model3 is offline
post #190 of 229 Old 08-28-2017, 01:46 AM
Liked: 0
@Seegs108
The programmer's guide is online:
http://www.ti.com/lit/ug/dlpu060/dlpu060.pdf
SiggiUA is offline
post #191 of 229 Old 08-28-2017, 07:31 AM
Seegs108's Avatar
Liked: 2595
Originally Posted by SiggiUA View Post
@Seegs108
The only mention I see regarding frame rate control or manipulation in that guide is for the internal test patterns. Please correct me if I've missed something.
Seegs108 is offline
post #192 of 229 Old 08-28-2017, 07:55 AM
Kris Deering's Avatar
Quoted: 4412 Post(s)
Liked: 8056
TI told me the same thing when I was doing the 9050 review. 60 Hz refresh rate visually (120 Hz in projector, since it is two subframes). I measured this with my meter and got the exact same thing for refresh.
My Home Theater UPDATED JUNE 2020
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is online now
post #193 of 229 Old 08-28-2017, 08:12 AM
Seegs108's Avatar
Liked: 2595
I've asked TI again to further clarify if this new programmers guide has any new control over on screen refresh rate based upon the input source.
Seegs108 is offline
post #194 of 229 Old 08-28-2017, 04:34 PM
Seegs108's Avatar
Liked: 2595
TI claims it's now possible to do 24p at 48hz with this latest software release for the control board. That's good news. Now TI is back to supporting a feature that's been supported for over a decade on all other platforms. It also isn't clear on whether or not BenQ, Optoma and others who have a DLP projector based on this DMD will issue a firmware update to add proper 24p support. It would be terrible for those who've spent thousands on these faux-K DLP units if they didn't receive an update to support something it should have had out of the box. It feels this DMD and controller was rushed out the door before a polished software platform was created for it.
Seegs108 is offline
post #195 of 229 Old 08-29-2017, 08:02 AM
Ruined's Avatar
Liked: 1273
Considering a BenQ representative informed Kraine they were adding HDR and 3D to the HT9050 via firmware by end of year, I don't think its far fetched to assume that it may include native 24p as well.
As I stated before numerous times, every single DLP 4K projector has a USB port designed for firmware updates. It is clear that the platform wasn't 100% finished when it was released. But the DLP manufacturers needed something 4K to sell, and some have done incredibly well with their products such as the Optoma UHD60/UHD65 despite the lack of this feature (and 3D) - UHD65 continues to outsell the 5040UB on projectorpeople, for instance, since launch. But, since all these projectors are FW updatable, those projectors can now also get this feature in the future.
Tempest in a teapot, once again.
am2model3 likes this.
Ruined is offline
post #196 of 229 Old 09-12-2017, 06:17 AM
Frank714's Avatar
Quoted: 974 Post(s)
Liked: 429
Okay, that could explain why we are currently still stuck with only two previews of the HT9050.
http://hometheaterhifi.com/news/prod...ector-preview/
http://www.projectorreviews.com/the-...er-projectors/
Is there any indication it will feature Frame Interpolation for 4K UHD program content?
"It is only about things that do not interest one that one can give a really unbiased opinion, which is no doubt the reason why an unbiased opinion is always absolutely valueless." Oscar Wilde
Frank714 is offline
post #197 of 229 Old 09-12-2017, 06:23 AM
Ruined's Avatar
Liked: 1273
No I don't believe it will include FI.
But there is a good chance it could include native 24p unlike the current firmware.
Ruined is offline
post #198 of 229 Old 09-12-2017, 06:34 AM
Frank714's Avatar
Quoted: 974 Post(s)
Liked: 429
Now that would be rather disappointing, IMHO, for a front projector scheduled to cost 9,000 $.
Hopefully Acer reconsiders that, should they plan a sucessor for their V9800 that shares the same projector housing as the HT9050.
Frank714 is offline
post #199 of 229 Old 09-12-2017, 06:37 AM
Liked: 8056
I think for a projector that costs $9K you're in for A LOT of disappointment when it comes to features. Even without getting into the abysmal contrast performance, this thing is an absolute dud when it comes to features in comparison to anything at or near its price point.
post #200 of 229 Old 09-12-2017, 06:42 AM
Ruined's Avatar
Liked: 1273
In all fairness the HT8050/HT9050 were the very first DLP 4k projectors released on the biggest DLP platform change in over a decade. So I'm not surprised they arent fully featured.
I do agree their MSRP is overpriced, though the HT8050 I knows sells for a lot lower than msrp.
The ht9050 has a lot of potential for next years model, but this year's model just isn't a good value in its current form and pricepoint. If they added HDR, 3D, dynamic led dimming, native 24p, and dropped price to $7500 then it would be a good value IMO.
Ruined is offline
post #201 of 229 Old 09-12-2017, 06:52 AM
Liked: 8056
Considering what Optoma was able to do at half the price, I don't find the "we're first" argument a good excuse. BenQ should have looked at the market for $9K and known what they were up against. I just had a meeting at CEDIA with TI and they were of similar opinion.
HDR is going to be a task for a projector with a contrast of less than 1K:1. Not only are they going to have to figure out how to get their dynamic system to work, they are going to have to completely rework their WCG support (it does not support 2020 currently) and fix their massive RBE issues (probably the worst DLP I've seen in over a decade in this respect). Kudos to them if they can get it all right with a firmware update, but call me skeptical at the moment.
Mikenificent1 and DavidHir like this.
post #202 of 229 Old 09-12-2017, 07:12 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2390
Yeah, like the Sony VW385
Seriously, at $8000 you can have Native 4K, 15,000-20,000:1 native contrast (plus DI), ~90% of DCI P3 coverage (I think that's what we're expecting), 3D, powered lens, lens memory
or
Wobulated 4K, <1000:1 native contrast, ~75% of DCI P3 coverage, no 3D, no power lens, no lens memory
Granted the 385 wasn't announced when BenQ announced these, but still, that's the reality their facing.
TheBrandon and Frank714 like this.
stanger89 is offline
post #203 of 229 Old 09-12-2017, 07:12 AM
Ruined's Avatar
Liked: 1273
Yeh I think all of the issues overall with the ht9050 are too much to fix with firmware (especially RBE, perhaps dynamic dimming might be hard to address since these could be tied to hardware limitations) - or, if fixable, would probably be worth relaunching as a new model due to bad press from first model.
The platform has a lot of potential, it just hasn't been realized for 5k+ range yet. Optoma did a great job in the under 5k bracket though IMO. The UHD65/UHD60 were homeruns given their price point.
I was also disappointed with BenQ's boring ck917 5000 lumen laser for $12k. Nearly 6k more for the same thing as the Optoma 4k500. Casio released basically the same projector 6 months and for less money. Some company needs to step up and contrast optimize these high lumen DLP projectors. Hopefully we will see that with the sequel to the ht9050.
Would also love to see the 5000 lumen variant of the colorspark platform with rapid cycling Leds but that is looking less likely sadly. Maybe Delta will step up to the plate given their history with LED projector design.
Ruined is offline
post #204 of 229 Old 09-13-2017, 02:21 AM
Frank714's Avatar
Quoted: 974 Post(s)
Liked: 429
You didn't just go to the Texas Instruments booth to talk about the HT9050, right?
Would you be willing to share with us what you learned? Do they acknowledge the contrast deficiency of current DMDs and do they have any plans for the future to solve the issue? Do they now only focus the low-end home theater segment or are high-end solutions still on their radar? I still haven't read any CEDIA report of TI's plans for the future, it would be nice to learn where they are heading.
Found this official Optoma statement at Amazon.com, following this question:
Optoma; does this dlp projector feature DarkChip 2,3 or 4 for contrast?
The UHD60 uses “Single 0.66” TRP S610 4K UHD DMD DLP chip by Texas Instruments. It is a new line from TI and is not part of their Dark Chip lineup.
So the question apparently remains whether TI will feature a corresponding DMD in their "Dark Chip lineup".
Frank714 is offline
post #205 of 229 Old 09-13-2017, 02:35 AM
Quoted: 425 Post(s)
Liked: 179
I bought the Acer V9800 (equivalent to the BenQ HT8050) as I have always been a fan of DLP and their colors, sharpness and bright scenes.
Disclaimer: The test was in a room with white walls and projected the image on a wall as my home theater is still being built.
My findings:
- Sharpness is the best I have ever seen. Single-chip and "almost" 4k is a combination which just looks fantastic. Subtitles look so sharp and I have not seen this matched even by a true 4K non-DLP projector.
- Bright images were really good - had the DLP look I like and colors pop.
- Low APL scenes: Much worse than I feared. I knew blacks were not going to be the best, but I expected that this is something I could live with - but I must admit, that the performance ruins the experience completely. By activating the iris it becomes acceptable but the implementation is useless. If the scene contains subtitles or small bright objects the image flickers and pumps. It is a shame as the blacks and contrast is actually okay when the iris is at max.
So conclusion: I will send the unit back and will look at alternatives. It's a shame as I really like the sharpness and the brighter scenes very much. I will try and upload some images.
EDIT: See attaches image. This is a "black scene".
post #206 of 229 Old 09-13-2017, 02:57 AM
Frank714's Avatar
Quoted: 974 Post(s)
Liked: 429
Ouch...yes, the good old shadow show utilizing your own hand can be a devastating test for contrast and black level performance. Heck, even my old Optoma HD83 does a better job, there's definitely the need for considerable improvement.
Frank714 is offline
post #207 of 229 Old 09-13-2017, 04:30 AM
Ruined's Avatar
Liked: 1273
I don't think there is anything that can actually be done of note on the DMD level. Pretty sure Texas Instruments went down this road before and found that DarkChip4 was essentially the best they could get in black levels without unaffordable chip prices; and even these DC4 chips are used in more expensive projectors, with virtually all under $10,000 using the less expensive DarkChip3 DMD. 4K complicates things further as the smaller mirrors leads to lower contrast, and this is one reason why XPR was created to allow for larger mirror size.
The path to blacker blacks on DLP leads to the lightpath implementation, not further refinements of the DMD. You can optimize the lightpath at expense of lumens for higher contrast. Or, you can use multiple DMDs in series in combination with light source dimming for a better dynamic contrast solution. The former is much less expensive than the latter, and hopefully with the excess of lumens laser brings DLP manufacturers will start introducing some of these contrast optimizations in the lightpath.
So it really boils down to whether one can deal with not having entirely black blacks in exchange for DLP's other strengths.
Ruined is offline
post #208 of 229 Old 09-13-2017, 07:48 AM
Liked: 8056
I had a pretty long meeting with TI about their chip. They downplayed the contrast issue saying they didn't think sequential contrast numbers were a good indicator of performance, which we agreed to disagree on. They think ANSI contrast is a better indicator (because of course they would) despite ALL evidence and science showing ANSI has VERY little to do with onscreen dynamic range. It didn't sound like they were going to do anything to try and increase CR performance and left the onus on manufacturers with light path design and dynamic systems. They did show their prototype for the next XPR evolution, which uses an even smaller DMD that is only 1080p and instead of flashing it twice for 8 million plus pixels, they flash it four times. Of course they had it in their heads that this too should be considered 4K because each frame is handled on its own but didn't even think to mention that these pixels would HAVE to overlap so despite any individual addressing, they would inevitably be on top of each other. But I guess that doesn't matter with these BS rules for what qualifies as true 4K and those that are willing to lap it up.
Frank714 and am2model3 like this.
post #209 of 229 Old 09-13-2017, 08:07 AM
Frank714's Avatar
Quoted: 974 Post(s)
Liked: 429
Thanks, at least we now have an idea where TI is heading and what to expect (or better not to expect) in the foreseeable future.
Frank714 is offline
post #210 of 229 Old 09-13-2017, 09:15 AM
stanger89's Avatar
Liked: 2390
Guess I can write DLP off my list going forward (unless stacked/sequential DMD machines are ever allowed), that's a shame, it's still my favorite projection technology.
That's funny, Darin was postulating exactly that idea in some of the XPR threads.
Benq , ht8050
