JVC DLA-X5900/X7900/X9900 : JVC will introduce 3 new DLA models at IFA BERLIN 2017 - Page 56 - AVS Forum | Home Theater Discussions And Reviews
 2872Likes
post #1651 of 2570 Old 09-14-2017, 08:33 PM
Quoted: 1886 Post(s)
Liked: 1175
Originally Posted by farsider3000 View Post
Okay... big question... Will the new RS640 allow me to turn off e-shift if the projector is receiving a 4k signal? This is going to be a problem for me if it will not allow this.
I have run into an issue where my new Panasonic UHD player looks like hell (super soft) when outputting 1080p signal. I would prefer to output 4k and not use e-shift (the buzzing vibration noise is way too loud for me and the projector is about 4 ft behind and 4 ft above my head).
You can't turn off eshift on a 4K signal. You can on a 1080p signal but not 4K because it would not be able to display the 4k without eshift and it doesn't down convert.
GregCh is offline
post #1652 of 2570 Old 09-14-2017, 08:35 PM
Javs's Avatar
Quoted: 6891 Post(s)
Liked: 6572
Never. That's fundamentally needed to display 4k.
Perhaps your e-shift is faulty? It does not make very much noise on my machine, and mine is 3ft from my head. There is certainly no buzzing on mine. Though have heard of other users reporting loud e-shift. Seems it can vary unit to unit, which makes me think if its too much of an issue you can get yours swapped.
Nick Laslett and OzHDHT like this.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #1653 of 2570 Old 09-14-2017, 08:40 PM
farsider3000's Avatar
Quoted: 1470 Post(s)
Liked: 859
Just to be clear the loud e-shift is on my current 4910.
Well this sucks. Now I have the added variable of whether a new RS640 will have a loud buzzing e-shift or not. I can have a louder fan with the Sony 385 or buzzing e-shift with the RS640.
It seems that most people state that they can hear e-shift but it is not "that" loud. I can't imagine audio/video perfectionists, like myself, in this forum would be okay with the e-shift noise I hear.
I guess e-shift is too loud for me if I can hear it over the low lamp fan noise without e-shift on.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5 for surround & ceiling
Subs: JTR Captivator subs: One S2, Two RS2, One S1, 2 Seaton Submersive (FOR SALE)
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is online now
post #1654 of 2570 Old 09-14-2017, 09:07 PM
Liked: 859
I am getting notified of posts via email and then they are not showing up on the forum. There seems to be a lot of this happening.
Moderators?
post #1655 of 2570 Old 09-14-2017, 09:13 PM
Mike Garrett's Avatar
Quoted: 12279 Post(s)
Liked: 9889
Originally Posted by boothman View Post
JVC had a new mount at CEDIA for their projectors.
Pricing was being discussed and it may end up being more expensive than the Chief mounts.
Mike Garrett is offline
post #1656 of 2570 Old 09-14-2017, 09:15 PM
Liked: 9889
E-shift is on, automaticlly if receiving a 4K input. That is the only way the JVC can display a 4K image. You can turn off E-shift for regular BD. Also the E-shift noise should not be loud.
post #1657 of 2570 Old 09-14-2017, 09:25 PM
Seegs108's Avatar
Quoted: 5167 Post(s)
Liked: 2593
It's not possible for the projector to receive a UHD or 4K image and have eshift disabled. Downscaling is a relatively easy thing for video processors to do. I haven't tried to output 1080p from a UHD Blu-ray disc on my UB900, but I would double check your settings on the player to be sure there isn't something set incorrectly. It's very odd to hear that the image looks soft.
Seegs108 is offline
post #1658 of 2570 Old 09-14-2017, 09:33 PM
Javs's Avatar
Liked: 6572
Ill see if I can record a realistic eshift noise recording for you, and do it in a way where it should simulate the real perceivable volume.
Eshift adds maybe 1db of noise if that. Its more like the db level is the same it just layers in a different frequency.
High lamp would easily sound twice as loud as low lamp+ eshift would.
OzHDHT likes this.
Javs is online now
post #1659 of 2570 Old 09-14-2017, 09:46 PM
Liked: 1175
Why do you think the Sony will have a louder fan? Going just by db readings from the manufacturer can be misleading because you don't know at what distance they measure from and the sound varies depending on which speed it needs for cooling.
I would bet that the fan noise on the Sony is very similar to the JVC.
GregCh is offline
post #1660 of 2570 Old 09-14-2017, 10:17 PM
Liked: 859
You have made some great points. There is no industry spec for measuring projector fan noise that I am aware of .
post #1661 of 2570 Old 09-14-2017, 10:20 PM
Javs's Avatar
Liked: 6572
Here you go.
RS620.
Mic is basically right up against right hand side vent if looking into the lens. This is where most of the mechanical noise comes from on the units.
PJ is in low lamp, so compare it to your low lamp and you get an idea how loud the noise is in real life.
I play around with the iris settings.
At 27 seconds I engage e-shift.
turn on and off etc.
Then I go to high lamp etc.. and repeat.
See how much you may think it bugs you. Sorry its not night time here so there is a bit of a noise floor, but when I say the mic is bumped right up against the right vent im not kidding.
https://www.dropbox.com/s/3l5gekx5gz...Noise.m4a?dl=0
This is what I used to measure if you wanna know.
http://www.daytonaudio.com/index.php...nt-system.html
You're welcome
nathan_h, mwhealton and mutiger like this.
Javs is online now
post #1662 of 2570 Old 09-14-2017, 10:21 PM
Javs's Avatar
Liked: 6572
It is. And there is even a similar noise to e-shift permanently on those units too. Like a high frequency squealing whine if you listen near the lens opening it sounds like a mouse crying... Not as audible as e-shift yet still there.
Javs is online now
post #1663 of 2570 Old 09-14-2017, 10:25 PM
Liked: 859
Originally Posted by Javs View Post
Here you go.
RS620.
You're welcome
Javs,
That is awesome. Thanks for taking the time to measure and post. It does sound like your e-shift is quieter than mine.
post #1664 of 2570 Old 09-14-2017, 10:26 PM
Liked: 859
A mouse crying.. ROFL
post #1665 of 2570 Old 09-15-2017, 01:20 AM
Woof Woof's Avatar
Quoted: 463 Post(s)
Liked: 255
Originally Posted by Mike Garrett View Post
No Dolby support and any projector period.
Didn't a Sony engineer say Dolby Vision was possibly a firmware upgrade away for the 760ES?
Woof Woof is offline
post #1666 of 2570 Old 09-15-2017, 01:44 AM
Liked: 0
I read so too.
Vinilp is offline
post #1667 of 2570 Old 09-15-2017, 03:14 AM
D_B_0673's Avatar
Quoted: 183 Post(s)
Liked: 33
Here you go.
RS620.
You're welcome
what are the noises at 13, 15, 18 20 40, 45 secs. Also at other spots throughout. Sounds like something on and off. I really don't hear much of any thing at 27
Dan
D_B_0673 is offline
post #1668 of 2570 Old 09-15-2017, 03:16 AM
Javs's Avatar
Liked: 6572
I am adjusting iris positions. Those who own JVC are very familiar with that noise so its a bit of a frame of reference really.
Javs is online now
post #1669 of 2570 Old 09-15-2017, 03:19 AM
D_B_0673's Avatar
Quoted: 183 Post(s)
Liked: 33
Thanks, I am excited about getting a 640. I currently use a 10 yr old RS1 that was bought from AVS on the first JVC group buy after Cedia 2007.
dan
Dan
D_B_0673 is offline
post #1670 of 2570 Old 09-15-2017, 04:05 AM
Old A/V Addict's Avatar
Quoted: 35 Post(s)
Liked: 62
Dirty screen effect.....screen door effect....soap opera effect. And now, CME, for crying mouse effect!! Thanks Javs.
Javs likes this.
Oppo 203>Marantz 7704>JVC RS520
Old A/V Addict is online now
post #1671 of 2570 Old 09-15-2017, 04:44 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2388
That would require Dolby to actually develop a version of DV for projectors, and that seems very unlikely for the foreseeable future.
nathan_h likes this.
stanger89 is offline
post #1672 of 2570 Old 09-15-2017, 05:57 AM
Moderator
rboster's Avatar
Quoted: 1610 Post(s)
Liked: 2202
Moderators?
First, moderators can't/don't read each post on AVS....so it was by chance I stumbled across it. Second, the only place to resolve operational issues is by starting a thread in the Forum Operations Center (Forum), the AVS admin. moderates that forum. The admin. is the only paid person on AVS and has access and ability to resolve technical issues and problems.
rboster is online now
post #1673 of 2570 Old 09-15-2017, 06:05 AM
BondDonBond's Avatar
Quoted: 692 Post(s)
Liked: 624
WHAT you don't get paid for babysitting and putting people into time out....I need to help you renegotiate your contract
Home Theater: JVC RS2000, Stewart 120" 2:35 StudioTech 130, Panamorph DCR Lens, B&W 802 Nautilus, HTM1, 4-B&W 805's for surround, 4-Martin Logan 22's ceiling speakers ATMOS, 2- PB-16 Ultra Subs, Marantz 8802A, MacIntosh 8207 AMP and Proceed AMP 5, Panasonic 820, Apple TV, XBox One, HTPC with MadVR, Qnap NAS
BondDonBond is offline
post #1674 of 2570 Old 09-15-2017, 06:15 AM
Moderator
rboster's Avatar
Liked: 2202
Some days, some days......... The stories we could tell
BondDonBond likes this.
post #1675 of 2570 Old 09-15-2017, 06:26 AM
TKNice's Avatar
Quoted: 161 Post(s)
Liked: 118
Originally Posted by Craig Peer View Post
I'd use the Chief JVC specific mount ( RPA 281 or RPMA 281 ) myself. https://www.milestone.com/products/c...g/rpmx/rpma281
Thanks guys, I'll check these out. Do you know if the mounting holes on the JVC take a standard sized screw and thread type? Do most of the projectors?
I would really like to use my existing mount until I can get a new one but is this even possible?
Video: JVC RS540 w/Anamorphic Lens & 122" 2.35:1 CIH
Audio: Marantz SR7010 / XPA-3 / UPA-7 Sources: Nvidia Shield / Xbox One X
7. Ascend Acoustics Sierra-2 EX (L R C), Ascend Acoustics HTM-200SE (side & rear)
2. Subs: SVS PC-2000 & eD A3-300 12" / Sensory: Aura Pro Bass Shakers
4 HTM-200SE for Atmos/DTS:X Theater Pics / Desktop
TKNice is offline
post #1676 of 2570 Old 09-15-2017, 06:29 AM
nathan_h's Avatar
Quoted: 2726 Post(s)
Liked: 1961
I had a universal Chief Mount. It wasn't able to work with the JVC RS500. I had to buy a new mounting plate from Chief specifically designed for the JVC projectors.
TKNice likes this.
nathan_h is offline
post #1677 of 2570 Old 09-15-2017, 07:19 AM
Liked: 9889
I am talking as of right now. Also, I do not know that it would actually be Dolby Vision or some form of it.
post #1678 of 2570 Old 09-15-2017, 07:23 AM
John Ballentine's Avatar
Quoted: 96 Post(s)
Liked: 97
dan
I was part of that group buy too. But I eventually moved on to an RS20 and then RS35. I'm anxiously awaiting the 640 too.
John Ballentine is offline
post #1679 of 2570 Old 09-15-2017, 07:55 AM
Toe
Toe's Avatar
Quoted: 2688 Post(s)
Liked: 3498
I was also part of that AVS group buy. Had the 40, 45 and 520 since then. Hoping to get pricing from my dealer on the new models soon as I'm wanting a 540.
Toe is online now
post #1680 of 2570 Old 09-15-2017, 08:54 AM
millerwill's Avatar
Quoted: 613 Post(s)
Liked: 381
dan
I was also in on the RS1, my first projector. I admire your strength of character in holding out this long before upgrading!
Mike_WI likes this.
millerwill is offline
