BenQ LK970: 4K DLP, laser, $12,999k MSRP - Page 82 - AVS Forum | Home Theater Discussions And Reviews
 1764Likes
post #2431 of 2446 Old 06-24-2019, 11:55 PM
gadgetfreaky's Avatar
Quoted: 149 Post(s)
Originally Posted by gadgetfreaky View Post
What AppleTV settings do you recommend?
I have
Format 4k SDR
HDMI Output YCbCR (other options are RGB High, RGB low)
Chroma 4:2:0 other option is 4:4:4
Match Dynamic Range On
Match Frame Rate On
This then runs to my HD Fury Vertex which I cant decide between auto EDID or custom, and either passthru scaler or custom scaler? Trying for the best possible pic obviously.
Currently using harpervision settings.
Issue I'm having is when watching a movie on Itunes Movie, every 5 minutes the on screen display of the vertex shows up. This doesn't happen in Netflix, or the same movie on vudu, just itunes movie.
Originally Posted by 12GAGE View Post
Hey gadget, I have one that I can hook up and test with the vertex tonight. I will see if I can help. Thanks.
any chance you were able to check?
gadgetfreaky is offline
post #2432 of 2446 Old 06-25-2019, 06:16 AM
Liked: 0
Is there a lens lock on this? When I turn the vertical/horizontal shift dials nothing happens.
Boo2boy is offline
post #2433 of 2446 Old 06-25-2019, 10:11 AM
Steve Siener's Avatar
Quoted: 59 Post(s)
Liked: 46
Originally Posted by sound2017 View Post
So even though my LK970 cant do HDR the 4k will still look better? How is this possible?
SDR=standard dynamic range - standard color range and image dynamics of Blu-ray
HDR=high dynamic range - wider color range and image dynamics than SDR
HD=high definition - 1080p Blu-ray definition
UHD=ultra high definition - “4k”
You’re not losing picture resolution. When playing UHD content your player sends the UHD content to the projector at its original 4k resolution. However, it must convert the content’s HDR to SDR since the projector does not support HDR color range. Many people actually opt to do HDR->SDR conversion even when the projector supports HDR natively. This is because they may have a superior way of tuning the image parameters such that it ultimately shows better on their projector.
Steve Siener is offline
post #2434 of 2446 Old 06-25-2019, 10:49 AM
Mike Garrett's Avatar
Quoted: 11803 Post(s)
Liked: 9343
That is not what is actually being done. The image is not converted to SDR. All they are really doing is stripping the HDR flag, but still sending the HDR signal. That allows a different device like a Panasonic player to do the HDR tone mapping using a different curve, rather than the projector. The 970 does not do any more than Rec709 color space, which is what a regular BD uses, so the 970 does not really benefit from the wider color space of HDR. It may look different, you may like it, but it is not an improvement in color space size. Often times the color saturation stacks up and the color appears more vivid, due to the poor tracking.
Mike Garrett is online now
post #2435 of 2446 Old 06-25-2019, 03:06 PM
Quoted: 234 Post(s)
Ok i understood some of that... Should I stick with blu rays or UHD 4k movies? I have a Sony X800 right now not the Panny 820. If i had the Panny would i go with UHD 4ks?
sound2017 is offline
post #2436 of 2446 Old 06-25-2019, 09:05 PM
Liked: 9343
UHD will look better than regular BD, due to the higher resolution.
post #2437 of 2446 Old 06-28-2019, 02:03 PM
chirpie's Avatar
Quoted: 391 Post(s)
Liked: 562
Exactly. Color will look better even with a more limited color space due to higher color resolution. Standard blu-rays use 4:2:0 subsampling, which means if you strip away the luma info and look at the chroma info only, it's effectively HALF the resolution of 1080p. Throw up a diagonal red line on a black background and it becomes more obvious. I remember the old dvd menu of Pixar's 'The Incredibles' being a torture test for subsampling limitations due to all of the stark red polygonal shapes. Upsampling of course helps with this, but it's always better to start with the best image possible. ^_^
chirpie is offline
post #2438 of 2446 Old 07-11-2019, 08:33 AM
Quoted: 234 Post(s)
So I got my LK970 calibrated and was wondering why he turned the sharpness all the way from 50 to 0? Is there a reason for this?
post #2439 of 2446 Old 07-11-2019, 08:56 AM
Liked: 0
Who is he? Did you buy it pre-calibrated?
Boo2boy is offline
post #2440 of 2446 Old 07-11-2019, 11:03 AM
Quoted: 234 Post(s)
My bad.. he dropped sharpness from 7 to 0
dropped my contrast from 50 to 34
and dropped my brigthness from 50 to 44
Here is his website: https://www.integratedenver.com/
His name is Sean Hammond
He came to my house and calibrated it. It looks great but was wondering about these settings.
Boo2boy likes this.
post #2441 of 2446 Old 07-11-2019, 11:58 AM
aka jfinnie
Quoted: 2323 Post(s)
Liked: 1464
Sharpness controls are an artificial edge enhancement. Calibration is about reproducing the source accurately, not enhancing edges artificially to give a false impression of sharpness on content that isn't itself sharp.
You can turn it back up if you don't like it, but it should almost always be set at zero or very close to zero.
More info:
https://www.cnet.com/how-to/turn-dow...pness-control/
Craig Peer and Javs like this.
bobof is online now
post #2442 of 2446 Old 07-12-2019, 03:01 PM
Quoted: 234 Post(s)
Cool i set it to 0.
post #2443 of 2446 Old 07-13-2019, 01:55 AM
mikxa's Avatar
Quoted: 18 Post(s)
contrast 34
Very interesting. You can share other settings.
mikxa is offline
post #2444 of 2446 Old 07-13-2019, 02:14 AM
markmon1's Avatar
Quoted: 4627 Post(s)
Liked: 2933
Has anyone noticed the crazy low price on these at benqdirect.com for a refurbished one? I'm tempted to go get one for that price even though I dont need one.
Boo2boy likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #2445 of 2446 Old 07-13-2019, 04:15 AM
latexii's Avatar
Quoted: 56 Post(s)
^ Sucks to live in Fin.. with that price i would grab it.
latexii is online now
post #2446 of 2446 Old 07-13-2019, 08:37 AM
Quoted: 234 Post(s)
markmon1: Thats where i got mine!
