Sony VPL-VW385ES Owners Thread - Page 70 - AVS Forum | Home Theater Discussions And Reviews
 1439Likes
post #2071 of 3660 Old 11-07-2017, 06:53 AM
jbrinegar's Avatar
Quoted: 339 Post(s)
Liked: 252
Originally Posted by justinhow View Post
Now that a few people have had this projector for a little while, is there any consensus from existing owners whether the 4K HDR is bright enough to make it work well, bearing in mind that the lamp will dim as time goes on?
My screen is 108" with a gain of 1.2 approx. I currently have an HW40ES which had a spec of 1700 lumens so that will be my reference point. It is plenty bright enough on low power.
IMO yes, plenty bright. My screen is bigger than yours and I never feel like I need more brightness. Im extremely happy with 4k HDR. Just this weekend I watched Spiderman Homecoming, Pirates 5 and Fantastic Beasts all on 4k UHD bluray and was blown away at the pq.
The settings I like for 4k HDR (until I get a pro calibration) are cinema 2 with lamp on high, iris fully open, dynamic iris on, contrast enhancer on med or low depending on the movie. I think it looks fantastic
billqs, Mike Garrett and justinhow like this.
JVC RS2000
Anthem mrx1120//Lumagen Radiance Pro
Klipsch Ref series 7.2.4 setup
Panasonic UB820 //Xbox one X //PS4 Pro // Apple 4k TV
Stewart Filmscreen 135" Cima Neve
jbrinegar is offline
post #2072 of 3660 Old 11-07-2017, 07:53 AM
Frohlich's Avatar
Quoted: 1960 Post(s)
Liked: 2129
The eagle has landed. GIDDY UP!!!!
Frohlich is online now
post #2073 of 3660 Old 11-07-2017, 08:00 AM
scoochie's Avatar
Quoted: 77 Post(s)
Liked: 48
Originally Posted by DERG View Post
I'm late joining the 21st Century as I've only experienced 3d movies twice & that was at a local theater (John Carter & Gravity). So, now with the 385 I can & have actually purchased a few 3D movies already. But, I need glasses. Amazon has these (SONY-Compatible 3ACTIVE 3D Glasses. Rechargeable. FOUR-PACK) for about 175.
Are these good? Any suggestions?
And Sony Support recommends these suggestions for viewing. Good advice?
Sony Support:
Follow these steps to set up the projector for 3D viewing:
Turn off the projector.
Connect the 3D Sync Transmitter to the 3D Sync input on the back of projector.
IMPORTANT:
Not all 3D Projectors have the ability to connect a 3D Sync Transmitter. Refer to the instructions manual to check if a 3D Sync Transmitter can be connected to your projector. Go to Manuals, Specifications & Warranty.
If your projector does not have the ability to connect a 3D Sync Transmitter, skip steps 2 and 3.
Set the 3D Sync Transmitter in a place where it is free from obstruction.
Connect the 3D source device to the projector using a High-Speed HDMI® cable.
NOTE: For more information regarding the HDMI cable required for 3D viewing visit http://www.hdmi.org.
If using a 3D capable Blu-ray Disc® player or PlayStation® 3 (PS3) console, insert a 3D movie or game title. If you have subscribed to 3D programming through your cable or satellite provider, tune the receiver or set-top box to the station with 3D programming.
NOTE: Confirm that your player does not need a software update to be capable of playing 3D Blu-ray Disc discs. You can determine if your Blu-ray Disc player needs a software update by accessing the customer support website for your particular model.
Using the supplied remote, turn on the projector and press the INPUT button to select the appropriate HDMI input.
NOTES:
Normally your 3D projector should automatically detect a 3D signal and display the image in 3D mode. If this does not happen, select 3D and the proper 3D format (Side-by-Side or Over-Under) from the menu.
At this point the image on the screen may appear blurry or out of focus. Put on the 3D glasses and synchronize them with the transmitter.
NOTE: For model-specific steps regarding any of the information provided in this solution, refer to the supplied operations manual. Go to Manuals, Specifications & Warranty.
I would recommend the "XPAND X105-RF-X1 Rechargeable 3D RF/Bluetooth Glasses" on amazon.
I didn't have a transmitter to attach or anything. All you do is display a 3D image, put on the glasses and follow the instructions that come with the glasses to register them with the projector. This only has to be done once. After that all you do is hit the little button to turn 3D on/off. You can also play with the 3D settings on the projector to adjust brightness as well as I use High lamp for 3D viewing.
DERG, MOberhardt and WildBoar like this.
scoochie is offline
post #2074 of 3660 Old 11-07-2017, 08:12 AM
jbrinegar's Avatar
Quoted: 339 Post(s)
Liked: 252
Awesome, looks like a fun day for you. Please let us know what the options are for 4k display. Can you set it to run in 4k 60 without HDR to get rid of banding? Or can you force 4k 24 or 30 HDR to get rid of banding? Thanks! Have fun!
JVC RS2000
post #2075 of 3660 Old 11-07-2017, 08:14 AM
zax123's Avatar
Quoted: 156 Post(s)
Liked: 49
I'm trying to order the 385 from a dealer up in Canada, and I'm being told there's a 4 to 5-week wait. Is that the case in the US now as well?
zax123 is offline
post #2076 of 3660 Old 11-07-2017, 08:18 AM
DreamWarrior's Avatar
Quoted: 940 Post(s)
Liked: 539
Originally Posted by Norixone View Post
I agree that banding is a personal issue and may be regarded by some as not being a deal breaker. However, if I am investing as much as 7000USD ore even 5000USD for the 285, I would like the pj to be future proof as Hollywood is going to produce more 60 fps films in HDR. So games will not be the only products suffering from banding once UHD films go towards higher frame rates. Of course, I do not think we will see many films out in 60 fps in a very short time so the investjment may be viable for 4 to 5 years. Personally, I am looking at a longer time span.
I am evaluating the 285, but I also have my eyes on the UHZ65 from Optoma. Two entirely different projectors each with their weack and strong points. Sincerely, if I could I would buy the 760 and be done with it, but then others factors could become an issue
Not to push you in one way or the other, but in addition to what @MOberhardt said, I'd also contend that in most 60fps movie content you'll have to go looking for banding. Scenes that provoke it aren't going to be as common in movies as they are in games where the rendering engine can create smooth gradients for everything. And, in movie content, sometimes banding is in the source because of a variety of reasons (compression being one).
That said, I'm still on the fence, but leaning towards waiting another year to see what shakes out.
MOberhardt likes this.
DreamWarrior is offline
post #2077 of 3660 Old 11-07-2017, 08:19 AM
Frohlich's Avatar
Liked: 2129
Its going to probably take a while to download my first game (COD WWII) since most these 4k games are 100gig. So I probably can't start playing it for a little while...though I did take vacation days rest of the week so I will have plenty of time to play and provide feedback.
Here is a picture of the 4k menu...you can definitely turn HDR off manually for the whole console. Not sure how individual games will work, they might have a similar option at the game level. I will experiment with HDR on and off this week.
post #2078 of 3660 Old 11-07-2017, 08:38 AM
jbrinegar's Avatar
Quoted: 339 Post(s)
Liked: 252
[QUOTE=Frohlich;55083316]Its going to probably take a while to download my first game (COD WWII) since most these 4k games are 100gig. So I probably can't start playing it for a little while...though I did take vacation days rest of the week so I will have plenty of time to play and provide feedback.
Thank you! Is the way you have the boxes checked the best way to run it on our projectors? i.e. leave the 4:2:2 box unchecked
JVC RS2000
post #2079 of 3660 Old 11-07-2017, 09:07 AM
Frohlich's Avatar
Liked: 2129
[quote=jbrinegar;55083434]
I have no idea yet (I suspect it is) , that was the default configuration for 4K and I have not adjusted any settings yet. Still downloading my first game
jbrinegar likes this.
post #2080 of 3660 Old 11-07-2017, 10:52 AM
Craig Peer's Avatar
Quoted: 6566 Post(s)
Liked: 7593
The supply is tight for the next few weeks as far as I know.
Craig Peer is online now
post #2081 of 3660 Old 11-07-2017, 10:59 AM
zax123's Avatar
Quoted: 156 Post(s)
Liked: 49
OK, thanks Craig!
zax123 is offline
post #2082 of 3660 Old 11-07-2017, 11:02 AM
Craig Peer's Avatar
Liked: 7593
OK, thanks Craig!
Plenty of VW285's available though. Maybe Sony concentrated on building those first.
post #2083 of 3660 Old 11-07-2017, 11:03 AM
zax123's Avatar
Quoted: 156 Post(s)
Liked: 49
I'd love to be able to do the VW285 and save all that money, but I have a CIH 2.35:1 setup, so I really need lens memory...
zax123 is offline
post #2084 of 3660 Old 11-07-2017, 12:06 PM
MOberhardt's Avatar
Quoted: 653 Post(s)
Liked: 242
I'm still on the fence as well. My heart says Sony due to a life long appreciation of all their equipment I own, back to my first gen Playstation. But so many are trying to make me think the JVC is a better option.
I do have to make a call in a few months though. I'm building my movie room finally and have the rest of my gear, just waiting on a projector. I would like to see how the 885 shapes up, but it really is more than I want to spend.
MOberhardt is offline
post #2085 of 3660 Old 11-07-2017, 12:41 PM
No Fun's Avatar
I'm in the same boat, but for the 285. My dealer called today and was told maybe the end of the month.
No Fun is offline
post #2086 of 3660 Old 11-07-2017, 01:42 PM
Quoted: 940 Post(s)
Liked: 539
I'm in a similar boat. Moving into a new house in December, finally have some space in the basement to build an HT, and trying to decide what to do. I may just use my 75" Sony flat screen for a while. Fortunately, I'm in no rush. I've been without a projector for my whole life, so...I can wait a bit longer, lol.
post #2087 of 3660 Old 11-07-2017, 01:44 PM
Mike Garrett's Avatar
Quoted: 11671 Post(s)
Liked: 9230
Well, you could pair a 285 with an Oppo 203, then you have one button push aspect ratio change between scope and 16:9 going through the Oppo. If you have a second source, you could use the Oppo 203 HDMI input.
Mike Garrett is online now
post #2088 of 3660 Old 11-07-2017, 01:58 PM
TheBrandon's Avatar
Quoted: 555 Post(s)
Liked: 220
Yours landed early congrats! Mine should be here any second. My guess is Live is going to be hammered. I have 1gbps fiber connection but I’ll try the network transfer. I grabbed 4K content on my One S so hopefully it’s quick! I’ll throw pics up soon as I can.
TheBrandon is offline
post #2089 of 3660 Old 11-07-2017, 02:01 PM
zax123's Avatar
Quoted: 156 Post(s)
Liked: 49
But doing this means not using the full width of the projector's pixels to display 16:9 content right?
zax123 is offline
post #2090 of 3660 Old 11-07-2017, 02:10 PM
Craig Peer's Avatar
Liked: 7593
With power zoom and focus - even though it doesn't have lens memory, you could manually zoom between 2.35:1 and 16:9 using the powered lens and remote. I did that for 7 1/2 years with a Sim Lumis Host. It's not that hard, and I wound up not having to do it all that often. Just FYI.
post #2091 of 3660 Old 11-07-2017, 02:15 PM
DERG's Avatar
Quoted: 183 Post(s)
Liked: 89
Glad you isolated the issue.
I have a 40 foot run of this cable and it works for 4K 60HZ HDR (no guarantees of course in your set-up):
https://www.monoprice.com/product?p_id=12735
Got the Monoprice 25' cable today & they work perfectly. The key word is "Active" for longer cables. The others were not.
Thanks Frohlich!
Frohlich, cemo62 and Archibald1 like this.
Man-Cave Home Theater: Sony VPL-VW385ES 4k Projector, CIH, 130" Stewart ScreenWall 2.35:1 1.3 gain, Denon AVR-X4400H, nVidia Shield TV (2017), Oppo BDP-203 Blu-ray Player, 6 - HSU HB-1 MK2 Front & Surrounds, 1 - HSU HC-1 MK2 Center, 4 - HIW-1 Horn In-Wall Speakers (ceiling mount), 2 - HSU VTF-15H Subwoofers.
DERG is offline
post #2092 of 3660 Old 11-07-2017, 04:27 PM
CLEMSON1881's Avatar
Liked: 3
OK, so I order a 385 in early October for November 1st delivery. Dang thing gets stolen at UPS hub! Replacement coming on the 19th.
CLEMSON1881 is offline
post #2093 of 3660 Old 11-07-2017, 04:36 PM
farsider3000's Avatar
Quoted: 1405 Post(s)
Liked: 792
FedEx has until 8:00 here in the Houston area to deliver tonight... I am starting to doubt they will make it.
I am relying on you guys to show me some images of 4k 60Hz HDR to see where we have to deal with banding but which games support this? I am still considering purchasing a 385 if the banding is not too distracting.
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5 for surround & ceiling
Subs: JTR Captivator S2, JTR Captivator S1, 2 Seaton Submersive (dual 15")
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #2094 of 3660 Old 11-07-2017, 04:38 PM
Liked: 3
Installed 30 foot Monoprice Slimrun active fiber optic. Now if the projector hadn't got ripped off!
post #2095 of 3660 Old 11-07-2017, 04:40 PM
Liked: 792
That is terrible. I wonder if it was not double boxed when shipped so that it was easy to identify as a high dollar item?
post #2096 of 3660 Old 11-07-2017, 05:05 PM
Liked: 3
I don't know. The thief is an idiot because UPS has cameras all over that place. They have him on video. They won't provide any additional details.
post #2097 of 3660 Old 11-07-2017, 05:17 PM
TheBrandon's Avatar
Quoted: 555 Post(s)
Liked: 220
Transferring @ a painful 159mbps. Taking forever!!!!
post #2098 of 3660 Old 11-07-2017, 05:18 PM
Liked: 792
Quit complaining . I don’t have fiber. My connection is about 230Mbps max.
I assume you are connecting via Ethernet ?
Sent from my iPhone using Tapatalk Pro
post #2099 of 3660 Old 11-07-2017, 06:12 PM
sass8181's Avatar
Quoted: 20 Post(s)
Liked: 24
The banding is not bad on assassins creed. If you stare at the sky it is noticeable more if you stare at the sky. The 4K hdr stuff I?ve played is stunning still.
Question for those that have had a projector or this projector with a dynamic iris. What is the difference with the full, limited and off setting. Along with the brightness slider. I?ve had mine on full and max brightness. Not sure if that?s the best setting. Any advice would be appreciated.
sass8181 is offline
post #2100 of 3660 Old 11-07-2017, 07:12 PM
TheBrandon's Avatar
Quoted: 555 Post(s)
Liked: 220
Quit complaining [IMG class=inlineimg]https://www.avsforum.com//forum/images/smilies/smile.gif[/IMG]. I don?t have fiber. My connection is about 230Mbps max.
transferring and man brutal waiting lol. Spun up Gears. Not 60hz I don?t think but it looks incredible.
ID:	2311798   Click image for larger version
ID:	2311800   Click image for larger version
ID:	2311802   Click image for larger version
ID:	2311804   Click image for larger version
