Official JVC - 20LTD - RS640 (x990/x9900) - RS540 (X790/x7900) - Owners Thread - Page 324 - AVS Forum | Home Theater Discussions And Reviews
 31166Likes
post #9691 of 11997 Old 12-08-2018, 08:54 AM
Mike Garrett's Avatar
Quoted: 11808 Post(s)
Liked: 9345
Originally Posted by nonstopdoc1 View Post
I know its a JVC thread but looking for honest advice. Should I buy an openbox Sony 675ES or buy RS540 now, sell it for some loss and buy RS2000 when it comes out?
Both options will cost me roughly the same.
Sent from my SM-G950U using Tapatalk
If going to cost the same, then I would go RS540 and RS2000. The 2000 has too many advantages over the 675.
Mike Garrett is online now
post #9692 of 11997 Old 12-08-2018, 09:22 AM
johng's Avatar
Quoted: 232 Post(s)
Liked: 107
3D Settings??
Hi, Everyone.
We have a family coming over tonight with a 3D copy of Polar Express. We haven't viewed a 3D Blu-Ray since we bought our X790/RS-540. Can someone give me a quick primer on the proper settings?
Good Viewing,John G  JVC DLA-X790 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 region free MOD disc player, Zappiti Mini4K HDR, Synology DS418 NAS, Yamaha RX-A2070 AVR, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,   & Yamaha 6600 External Amp
johng is offline
post #9693 of 11997 Old 12-08-2018, 10:31 AM
Quoted: 579 Post(s)
Liked: 302
Originally Posted by johng View Post
Hi, Everyone.
I'm on the 640 but I had a 520.. just saw the walk last night oh my god what a movie.. for you 3d glasses buy this little rubber strap they make the glasses fit nice a tight around your face much better feeling at least for me and the wife..
Edit: under 3d setting set crosstalk cancel no higher than 4 for more brightness..
Sent from my SM-G930T using Tapatalk
jorgebetancourt is online now
post #9694 of 11997 Old 12-08-2018, 11:05 AM
spinn74's Avatar
Quoted: 77 Post(s)
Liked: 25
Can someone explain the lens aperture setting and how you go about setting it. New to these projectors and have X790 and have on factory settings. Thanks!
spinn74 is offline
post #9695 of 11997 Old 12-08-2018, 11:44 AM
johng's Avatar
Quoted: 232 Post(s)
Liked: 107
Thanks! Good idea with the glasses strap.
jorgebetancourt likes this.
johng is offline
post #9696 of 11997 Old 12-08-2018, 12:06 PM
Quoted: 579 Post(s)
Liked: 302
I bought the strap because when I would walk around the room they always fell like they were going to fall and break.. But the strap have an extra benefit, the glasses now fit snug around the face and so the inmersion goes up way more.. You don't see the frame anymore and not once do u have to adjust them because they feel like they are falling.. My wife loves how they fit now..
giomania likes this.
post #9697 of 11997 Old 12-08-2018, 05:45 PM
Liked: 9345
Originally Posted by DLCPhoto View Post
I have the 'regular' RPA281, not the RPMA281, purchased at the time because I didn't realize there were 2 'flavors' of this mount. Mine does not have the locking mechanism (A, B, or C), and doesn't have the 'geared' mechanism for easy adjustment of roll, pitch, yaw.
Having now become aware of the RMPA281, my plan was to replace my current mount, if I do in fact upgrade to the NX9. My thinking is that it would make adjustments much easier and more precise, as well as make it easier to unmount (should that become necessary), using the locking switch.
Your post seems to indicate the opposite was the case for you, so I'm wondering what I'm missing. Could you explain what you found to be a pain when using the locking mount?
You are correct in your thinking.
DLCPhoto likes this.
post #9698 of 11997 Old 12-08-2018, 05:49 PM
Liked: 9345
Originally Posted by Bytehoven View Post
My experience with the locking mount was with the universal version on my sony 90es. The locking interface was 2 parts. There was a smaller plate with the studs which interface with the ceiling part. Then there was the universal spider legs which mounted to that plate and to the projector.
Problem 1... the ends of the spider which connect to mounting studs installed on the projector were not always easy engage or disengage.
Problem 2 ... getting the spider legs in the exact orientation to preserve original picture alignment was impossible, and the legs had to be removed to access the lamp module.
Your locking version may be easier in both of these areas and allow for repeat accuracy of alignment orientation.
I prefer the way the slb281 mounts to the projector with the machine bolts and then lifted onto the ceiling mount section. This setup is very accurate and repeatable, leaving no hesiation to make you procrastinate taking down the projector as needed.
You are talking about the universal plate. He was not asking about that. The universal plate is not even an option with a JVC. You have to use the custom plate with the Chief mounts.
post #9699 of 11997 Old 12-09-2018, 05:56 AM
coxy2416's Avatar
Quoted: 557 Post(s)
Liked: 327
Check out this write up:
https://www.avsforum.com/forum/24-di...n-writeup.html
coxy2416 is offline
post #9700 of 11997 Old 12-09-2018, 06:32 AM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
@Bytehoven , thank you for all the help with settings for the Oppo. I used your forced settings and they are looking good. I did go ahead and order a Panny 820, which should arrive in the next couple of weeks. I'm going to sell the Oppo 203.
So far we have watched 3 movies in the new room: Gone Girl, The Meg, and Skyscraper! We watched Skyscraper last night; The Rock, a towering inferno of a building and an added bonus, Scream Queen, Neve Campbell!!! It was a blast and the HDR picture was superb. I was curious how well a projector could do HDR in comparison to my Sony XBR75x940C, which is a reference panel, and I'm happy to say, I believe the JVC does it just as well, if not better! I'm really enjoying my time with the new projector!
johng and lucacow like this.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #9701 of 11997 Old 12-09-2018, 09:16 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6390 Post(s)
Liked: 6389
My issues with cable and sports is the quality of the picture is horrible compared to my 65 OLED. The resolution seems to be terrible.
How far away are you from your 65" screen? How far away from your projection screen are you and what size is that screen? Want to see your OLED look bad? Go get a 15" piece of crap LED and watch it from the same distance as the 65", bet the 15" looks real nice.......
Cleveland Plasma is online now
post #9702 of 11997 Old 12-09-2018, 09:27 AM
microwiz's Avatar
Quoted: 282 Post(s)
Liked: 193
Well my transition from Rs400 to 540 is compete, thanks Cleveland plasma! Now how do i explain to my 3 year old that Bubble Guppies can be watched on a regular tv, he insists on watching in my movie room.
Pioneer SC-95, Axiom M80, VP180 Dual EP500 all V4. ISCO III, RS540 + Stewart Cima Neve 133
microwiz is offline
post #9703 of 11997 Old 12-09-2018, 11:43 AM
rhale64L7's Avatar
Quoted: 1085 Post(s)
Liked: 517
This is awesome!!
Ron
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is offline
post #9704 of 11997 Old 12-09-2018, 04:56 PM
Jive Turkey's Avatar
Quoted: 557 Post(s)
Liked: 420
Can you manually move the filter in and out of place in SDR2020 and/or HDR? I don't see a setting for this in the menus.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is offline
post #9705 of 11997 Old 12-09-2018, 05:44 PM
Quoted: 4483 Post(s)
Liked: 1678
There is no direct control for the filter; the projector selects it automatically if the profile requires it. If you do not want the filter for SDR2020, create your own BT2020NF profile or download Manni’s.
jwhart likes this.
Dominic Chan is online now
post #9706 of 11997 Old 12-10-2018, 02:04 PM
doctormyeyes's Avatar
Quoted: 92 Post(s)
Liked: 68
Clearly he has inherited the video gene. You should be proud of fathering the youngest member of AVSForum.
doctormyeyes is offline
post #9707 of 11997 Old 12-10-2018, 04:59 PM
djseto's Avatar
Quoted: 30 Post(s)
I just pulled the trigger on the X790R to replace my 8 year old Epson 9700UB. I almost went with the Sony 285ES for native 4k, but every comparison I've seen says that from viewing distance (11ft for me and 100" screen), the difference is barely noticeable and the JVC absolutely crushes the Sony on blacks. Now that the price has dropped below the Sony, I wasn't sure the Sony was worth the extra money.
I assume the Chief mount that came with my Epson will mount on the JVC?
djseto is offline
post #9708 of 11997 Old 12-10-2018, 05:14 PM - Thread Starter
Quoted: 1243 Post(s)
Liked: 973
Congrats. The chief ceiling mount section will work, but you need vthe slb281 interface for the projector. I got mine from B & H because ut was next day ground from nyc to my location..
Bytehoven is offline
post #9709 of 11997 Old 12-10-2018, 05:18 PM
mzs22's Avatar
Quoted: 225 Post(s)
Liked: 91
Congrats on the new JVC ! I went from the Epson 9700UB also to the JVC X770 . I used the same ceiling plate but had to get a new mount for the JVC.
mzs22 is offline
post #9710 of 11997 Old 12-10-2018, 05:50 PM
djseto's Avatar
Quoted: 30 Post(s)
So which of these two did you need?
https://www.bhphotovideo.com/c/produ...Interface.html
Or
https://www.bhphotovideo.com/c/produ...tor_Mount.html
djseto is offline
post #9711 of 11997 Old 12-10-2018, 06:12 PM - Thread Starter
Liked: 973
The upper parts mounts to the projector.
The bottom part should be what you already have as part of your chief ceiling mount setup.
The 6 posts on the top part, slide into 6 slots of the bottom piece. The bottom piece attaches to a 1.5" diameter threaded pipe which is attached to the ceiling by a flange.
post #9712 of 11997 Old 12-10-2018, 06:21 PM
djseto's Avatar
Quoted: 30 Post(s)
Ah. I gotcha. Thanks for the help. Going to order now so it’s all here when the JVC arrives.
Bytehoven likes this.
djseto is offline
post #9713 of 11997 Old 12-10-2018, 09:23 PM
Quoted: 115 Post(s)
Liked: 47
Question for Mike Garrett
Hi, Mike. Much as I would like to purchase the new N7, I think it is out of my price range. As such I am considering the X9900 or the X9500. Given some of the sharpness issues and light corners, would you agree with Javs that one would be better off getting the older model over this years X-9900 (RS640)? Also, do you have any info as to how the 3D compares between the X-9900 vs. the older X-9500? was there an improvement in crosstalk and ghosting reduction with the newer model? Any opinion you can offer would really help with finalising my decision. Thanks.
ShadowBoy is offline
post #9714 of 11997 Old 12-10-2018, 10:28 PM
Quoted: 227 Post(s)
Liked: 108
I just ordered a x990 from a local dealer for a great price. Upgrading from a 65es. I’m still keeping my rs3000 order. Fingers crossed that i get a good sample.
Colozeus is offline
post #9715 of 11997 Old 12-11-2018, 05:25 AM
ScottAvery's Avatar
Quoted: 630 Post(s)
Liked: 182
The bottom listing you had actually has both parts, the gimble which you may already have, and the same plate as listed in the first listing. In any case, you would not need to order both. Get either just the plate or the full kit, depending on if you have that same gimble as pictured in the *second* link.
If your Epson had the newer cast metal part rather than stamped steel gimble, then you need the 281 SLM plate.
ScottAvery is offline
post #9716 of 11997 Old 12-11-2018, 06:28 AM
microwiz's Avatar
Quoted: 282 Post(s)
Liked: 193
It's like a box of chocolates, your not guaranteed anything regardless of what way you go. My RS540 was comparable to my RS400 which was pretty decent.
microwiz is offline
post #9717 of 11997 Old 12-11-2018, 08:54 AM
djseto's Avatar
Quoted: 30 Post(s)
I think I just need the plate based on the attached image, right?
djseto is offline
post #9718 of 11997 Old 12-11-2018, 09:41 AM
coxy2416's Avatar
Quoted: 557 Post(s)
Liked: 327
Based on your image it looks like you just need the plate.
coxy2416 is offline
post #9719 of 11997 Old 12-11-2018, 10:34 AM
aka jfinnie
Quoted: 2325 Post(s)
Liked: 1464
I think of it this way. The new units are a bit of an unknown quantity still, but have great potential, particularly at sorting a lot of the annoyances with the outgoing DLA-X series; many of which are ever present even at the pinnacle of X95/9900. I think now is a bad time to buy a DLA-X personally; however good the prices being offered on them are, if the N7 turns out to be a great unit the bottom will drop out of the used pricing on DLA-X as there will be a lot on the market; so whatever you'll pay for a DLA-X today is probably too much (even if it seems very good compared to what they were).
The current pricing on DLA-X isn't being put out there to do you (the customer) "a favour". It is for other's benefit, to carry on being able to sell something which has had it's value diminished just by the mere demonstration of the new units. Once there out there for real the values will keep going down. I don't think it will be long until the current DLA-X units are changing hand for the pittances the HD units and X3/X30 series etc all go for.
The smart money (if you don't absolutely have to buy now, this minute) has to be to wait.
bobof is online now
post #9720 of 11997 Old 12-11-2018, 10:34 AM
tjgar's Avatar
rs40
I am considering the switch to the 540 also. In your opinion is the picture quality worth the expenditure? I am using an RS40 now
tjgar is offline
Jvc , xbox one x
