Official JVC - 20LTD - RS640 (x990/x9900) - RS540 (X790/x7900) - Owners Thread - Page 350 - AVS Forum | Home Theater Discussions And Reviews
 31171Likes
post #10471 of 12027 Old 01-23-2019, 07:15 AM
DLCPhoto's Avatar
Quoted: 1560 Post(s)
Liked: 693
Originally Posted by Dominic Chan View Post
Yes, I have actually seen the colour shift (white turning yellow) and thought the projector was defective.
Since the shift is quite noticeable, it may affect the whole screen fine adjust as well, not just zone adjust.
EDIT: The yellow tint is visible in the image attached to post 10202 - see the top row of the resolution patterns, where some of the patterns have a yellow (instead of white) background.
Do you mean the little squares (that have either a solid fill, or the horizontal vertical or diagonal lines)? Or am I not looking at the right areas?
If that's what you mean, I do see the yellowish hue, with the boxes with the horizontal lines showing this the most, in multiple areas, with some of the solid ones showing it as well.
I guess the way to prove this is from the zonal adjustments would be to reset these, and repeat the pictures. Do you know if this has been done?
Again, I'm not saying this is not the case, just that I recall someone (can't remember who, couldn't find the post, but my memory was that it was from someone whose knowledge I respected) saying that despite many people saying it was harmful to final picture quality, that in fact it wasn't.
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #10472 of 12027 Old 01-23-2019, 07:38 AM
Quoted: 4507 Post(s)
Liked: 1685
There are no solid fill areas in the actual test patterns. They are vertical lines, horizontal lines and diagonal meshes with one or two pixel-width lines at 4K resolution.
Yes, the issue went away when I reset the pixel adjustments.
I first saw the issue with a static image that contained a white background, which contained yellow botches in areas where I made the fine adjustments.
Dominic Chan is online now
post #10473 of 12027 Old 01-23-2019, 08:14 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6420 Post(s)
Liked: 6407
Originally Posted by Bytehoven View Post
Great day for football. Wow.
Well the big game is coming, imagine how many projectors will be used at all the parties worldwide.
Originally Posted by jwhart View Post
Not if you're a Saints fan.
What a year for bad calls........
Originally Posted by Erod View Post
I have imported curves from Chad B as well. In bright scenes, it looks great. Better, in fact, than my SDR2020. But in dark scenes, the SDR2020 looks better.
Both have advantages, and you have to tweak until you get it right. The white and black tone adjustments help, along with the slider.
Ultimately, it's what we each prefer individually.
It would be great to use just one, but all this different content we have requires different things.
Cleveland Plasma is online now
post #10474 of 12027 Old 01-23-2019, 08:27 AM
Erod's Avatar
Quoted: 1238 Post(s)
Liked: 748
What frustrates me is how it makes the JVC macros somewhat counterproductive. If I switch to HDR from SDR2020, and I have to back out to the top menu or something, when I go back it will switch my profile. In fact, JVC doesn't even list "HDR" under the macro profile options, so you can't switch to it anyway.
Video: JVC RS620/X9500 projector, Stewart ST130 screen, Panasonic ub820 UHD player
Audio: Anthem AVM60 preamp, Anthem MCA525 amp, B&K Reference 125.7 amp
Subs: dual SVS PC-12 cylinders
Speakers: Jamo 626k4 in-wall mains, Jamo 631k4 bi/dipole surrounds, DefTech DI6.5R heights
Erod is online now
post #10475 of 12027 Old 01-23-2019, 08:41 AM
DLCPhoto's Avatar
Liked: 693
Thanks, Dominic. That pretty much answers the question!
post #10476 of 12027 Old 01-23-2019, 08:53 AM
Liked: 1685
To be fair, I can’t say I’ve seen the issue when watching movies.
post #10477 of 12027 Old 01-23-2019, 09:05 AM
DLCPhoto's Avatar
Liked: 693
Good of you to clarify this.
It then makes me wonder: if the initial misalignment (that using zone adjustments is intended to correct) is also not evident when watching actual content (and I understand that isn't what you just said, but might be the case), and the negative effects of zonal adjustments to the misalignment are not apparent, then are we just chasing our tails??
In other words, do these adjustments, whose need is determined by 'pixel-peeping,' have any net positive impact on picture quality when viewing actual content? Or does it just satisfy the OCD that so many of us (myself included!) suffer from?
post #10478 of 12027 Old 01-23-2019, 09:10 AM
Liked: 1685
The colour fringing from misconvergence is visible to me whenever I call up the JVC Menu.
DLCPhoto likes this.
post #10479 of 12027 Old 01-23-2019, 09:53 AM
umjs78's Avatar
Feeding SDR2020 from UB820 but PJ info window says HDR
Originally Posted by rprice54 View Post
And I tried the SDR/2020 option but the PJ still saw a HDR signal. The hdr flag changed from HDR 2084 to HDR. Color space was 2020.
The setting says (auto) next to it so I don’t know if the player auto switches back to hdr or what.
Does anyone know what am I doing wrong?
I have read first post and followed recommend setup,
Gamma set 2.4 and SDR2020 from UB820.
When movie is played, on info window under PJ menu says "HDR: HDR"
Did i do something wrong? as far as i understand, it should say SDR2020 not HDR.
Is this means UB820 still sending hdr meta data to PJ?
Sorry if this question has been addressed already.
umjs78 is online now
post #10480 of 12027 Old 01-23-2019, 12:50 PM
Toknowshita's Avatar
Quoted: 37 Post(s)
Liked: 151
I just picked up a Panasonic UB820. I currently have a UB900 paired with my RS540 which was calibrated by Chad B. Is the HDR Optomizer on the 820 a significant improvement over the 900? Still debating if I need another $500 disc player. Sounds like there is debate on how to setup the 820 with the JVC series.
Toknowshita is offline
post #10481 of 12027 Old 01-23-2019, 12:57 PM - Thread Starter
Quoted: 1243 Post(s)
Liked: 973
Try manually selecting your custom picture mode you set up for sdr2020. Use a sdr title in the 820 then switch back to an hdr title. Does the jvc stay in the custom picture mode or switch back to hdr?
Please confirm where you made the sdr2020 selection on the 820. Was it the menu where it had just the hdr2020 option and the sdr2020 option?
Bytehoven is offline
post #10482 of 12027 Old 01-23-2019, 01:34 PM
mogrub's Avatar
Quoted: 270 Post(s)
Liked: 260
Originally Posted by silver700 View Post
... Just seeing if anyone that owns the 990/790 are happy with it.
No, not happy. Ecstatic. I'm less than a month on a new RS540 and the PQ exceeds my high expectations. Out of the box was very good, but Jeff Meier was in town this week and he absolutely smashed this thing. The calibrated image blows even my wife away. It's exceptional. Plus the price point on this machine makes it a really strong value proposition. IMHO YMMV.
"Get me a scotch. I'm starving." JVC DLA RS-540U, Stewart ST 130 G3, Yamaha RX-A3080, Emotiva XPA-3, Panasonic UB820, Oppo 103D, Xfinity X1, Roku, ATV, Harmony 900.  Atmos 7.2.4 via Martin Logan Stage-X, Martin Logan Theos x2, Martin Logan FX x2, Sonance VP69 x2, Sonance VP66 x4, SVS PC12-NSD x2. Viewer's choice between Palliser recliners x7 or Great Dane beds x2.
mogrub is offline
post #10483 of 12027 Old 01-23-2019, 03:43 PM
jwhart's Avatar
Quoted: 214 Post(s)
Liked: 78
Thanks for your post and for informing me that there's another highly recommended calibrator, who's located closer to me since he's showing April tour in my area and ChadB has nothing scheduled.
jwhart is offline
post #10484 of 12027 Old 01-23-2019, 04:55 PM
Quoted: 579 Post(s)
Liked: 302
Hi Guys.. Can you please tell me if I'm supposed to use the 1200 nit curve for first man or the 4000 nit curve, the movie is from universal.. I went to look on the excel sheet but its not being updated anymore and when i click on info on the jvc is not telling me.. I guess the disc is not reporting..
Newt4431 likes this.
jorgebetancourt is offline
post #10485 of 12027 Old 01-23-2019, 05:26 PM
Javs's Avatar
Quoted: 6791 Post(s)
Liked: 6418
1200nit curve.
Disc is reporting 1000 nits master. 285 nits MaxFALL
Im betting the real nits are well under 1000 though.
jorgebetancourt likes this.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #10486 of 12027 Old 01-23-2019, 06:18 PM
Quoted: 579 Post(s)
Liked: 302
Originally Posted by Javs View Post
1200nit curve.
Thank you.. I saw at the theater loved the space scenes very well done.. But the movie dragged a little in the middle..
The rocket launch was out of this world..
post #10487 of 12027 Old 01-23-2019, 06:58 PM
Javs's Avatar
Liked: 6418
The launches in First Man are awesome.
Totally agree about the rest.
Javs is offline
post #10488 of 12027 Old 01-23-2019, 07:23 PM
thrillcat's Avatar
Quoted: 527 Post(s)
Liked: 493
Originally Posted by sciuttam View Post
Excellent, thank you!
Okay, X790R on a 115" CenterStage UF screen. Throw is about 11'.
We're pulling 17FL in SDR and HDR is at 23.5. We still need to dig into a few more gamma things, but the color balance is spot on and I'm happy with brightness and contrast where we're at.
Bytehoven and Bittermidget like this.
I love my iPhone, but it will never replace my turntable. I've never seen Titanic OR XXXXXXXXX. Alexa is a stripper name.
The Cinema 1858 Remodel Thread
thrillcat is online now
post #10489 of 12027 Old 01-24-2019, 02:14 AM
jj-34's Avatar
Quoted: 134 Post(s)
Liked: 37
I want to relocate my new X7900 into a small attic behind the back wall of our HC room, but before punching the projection opening thru the wall I'd like to know if I am not doing something counter productive putting the projector further away.
My screen is a 4K AT wowen screen with a black baking and a 0.9 gain, it is 8 feet wide and the new throw distance will be 15', isn't that too far away ?
jj-34 is offline
post #10490 of 12027 Old 01-24-2019, 07:27 AM
Quoted: 14 Post(s)
Liked: 2
Those sound like great numbers! Let me know how the rest of it goes.
thrillcat likes this.
sciuttam is offline
post #10491 of 12027 Old 01-24-2019, 07:32 AM
markmon1's Avatar
Quoted: 4661 Post(s)
Liked: 2954
Originally Posted by tswire View Post
I will do some research on my own but a quick search for madvr has some chatter on Netflix working. So I was hoping for someone who is currently using it to confirm before I go deeper.
Dont think so. MadVR is a renderer and requires a player that will use this renderer. The netflix app won't. It probably could, but it doesn't. (The netflix app on pc is terrible, won't even work with simple arrow keys so you are stuck using a mouse. I unsubscribed to netflix because of it).
There may be ways to run blurays off disk through madVR but for the most part, it requires ripped files on disk. ITunes is definitely out.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #10492 of 12027 Old 01-24-2019, 09:25 AM - Thread Starter
Liked: 973
Your peak lumen output will drop, but contrast performance will increase. How is your current setup as far as image brightness for sdr and hdr content?
Given the excellent contrast on these projectors, placing the unit as close as possible gets you max lumens on the screen, while contrast performance is still very good.
Also keep in mind as the lamp ages tge lumen output drops, so if the longer throw is right on the edge for image brightness, it will get worse, needing you to run high lamp sooner or more often.
post #10493 of 12027 Old 01-24-2019, 12:15 PM
Ovunc Erdem Corapci's Avatar
Liked: 0
hey friends . which setup do u prefer on x790 ? on hdr and sdr ? is there any source how to make it??? can u give url?
Ovunc Erdem Corapci is offline
post #10494 of 12027 Old 01-24-2019, 12:18 PM
umjs78's Avatar
I have no non hdr title so I played blu-ray and set picture mode custom then i switch back uhd hdr title, picture mode doesnt switch back to hdr and it stays but it says HDR as i mentioned.
and yes 820 set to sdr2020 and status window says its feeding sdr2020
btw my jvc is x590r, is this a problem?
post #10495 of 12027 Old 01-24-2019, 12:29 PM
Liked: 1685
See the first post.
post #10496 of 12027 Old 01-24-2019, 01:20 PM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
I have my projector mounted to the ceiling with no extension on it - there is a door to the attic behind it, so the 14” extension rod that came with the kit wouldn’t work. The top of the screen is about 1.5 feet down from the projector and I have it angled down with a keystone correction of -5.
Would I gain any benefit from installing a 3” (May have room for a 6”) extension?
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #10497 of 12027 Old 01-24-2019, 01:29 PM
thrillcat's Avatar
Quoted: 527 Post(s)
Liked: 493
I think you'd be better served by leveling out the projector, zeroing out the keystone, and then using the lens shift to get it into the screen. I'm not hip to the specs, but I think you should be able to cover 1.5 feet. I could be wrong.
Bytehoven likes this.
post #10498 of 12027 Old 01-24-2019, 01:34 PM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
It's 1.5' from the top border, then probably another 2' and some inches to the middle and then 2' and some inches to the bottom. You think the lens shift could make it that far down?
post #10499 of 12027 Old 01-24-2019, 01:40 PM
thrillcat's Avatar
Quoted: 527 Post(s)
Liked: 493
It’s easy enough to try.
post #10500 of 12027 Old 01-24-2019, 01:42 PM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
You're right about that - thanks for the help. I will give it a go.
Jvc , xbox one x
