Official JVC - 20LTD - RS640 (x990/x9900) - RS540 (X790/x7900) - Owners Thread - Page 375 - AVS Forum | Home Theater Discussions And Reviews
 31540Likes
post #11221 of 12541 Old 03-10-2019, 10:30 PM
Madaeel's Avatar
Quoted: 201 Post(s)
Liked: 176
Originally Posted by Madaeel View Post
I was wondering if anyone here that runs a HTPC could help me out. I had an Epson 3700 before I bought the 540 and 3D worked fine on it. I encoded movies using the top-and-bottom format and I never had a problem with it. I can't seem to get the JVC to work with it though. Oddly enough it seems to "engage" the 3D when I select side-by-side on the JVC. I have JRiver and no matter if I use that or MPC it does the exact same thing. Thought maybe it was settings in one or the other but like I said the Epson worked fine. Any ideas?
Anyone?? 3D is enabled in JRiver and the JVC is set to auto but still can't get any of my rips to work?
Any help or suggestions would be appreciated.
Madaeel is offline
post #11222 of 12541 Old 03-11-2019, 12:07 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
Originally Posted by Javs View Post
Link in my signature.
Thanks I’m blind!. I will just be using the JVC software to upload them. I was going to try the 1200 curves but which one do you recommend, V1 2 or 3 ?, I have the X7900 in a non dedicated room with a plain white 1.0 gain screen.
Thank you.
JVC DLA-X7900 3D Projector, Sapphire 106" Electric screen, Sony KDL-55W905 3D TV, Pana TX-L37LZD80, Panasonic UB820, UB700, BDT-380 MZ, Panasonic DMP-BD60, Sky Q 2TB, Fire TV 4K, Marantz SR7012, 7.1.2, SVS PC2000 Sub, Kef Q600C Centre, Q300 fronts, Ci160QR Ceilings, CA SX60 Surrounds, Harmony 950+hub.
panman40 is offline
post #11223 of 12541 Old 03-11-2019, 02:28 AM
coxy2416's Avatar
Quoted: 571 Post(s)
Liked: 341
Thank you.
You will want to use V3
coxy2416 is offline
post #11224 of 12541 Old 03-11-2019, 02:32 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
Thank you.
Great thanks for that.
coxy2416 likes this.
panman40 is offline
post #11225 of 12541 Old 03-11-2019, 02:38 AM
Javs's Avatar
Quoted: 6921 Post(s)
Liked: 6629
Yeah not to sound smart, but if v1 or 2 was the one to use there would be no v3
johng, markmon1 and panman40 like this.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #11226 of 12541 Old 03-11-2019, 06:19 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
Yeah not to sound smart, but if v1 or 2 was the one to use there would be no v3 [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
I thought you may have deleted the others if they were old or not as good V3.
panman40 is offline
post #11227 of 12541 Old 03-11-2019, 07:12 AM
rlarsen462's Avatar
Quoted: 236 Post(s)
Liked: 78
Originally Posted by stumlad View Post
Javs,
I installed your curves. Instructions were fairly easy to follow. Thanks! As far as actually using them, I'm guessing you choose between Custom gamma 1 and 2 within the user setting. Do we base it off of the reported MaxCLL... i.e. if it reports 4000, choose custom 2 (assuming that's where it was installed). Which do we select if MaxCLL is 500 nits, or 2000 nits, etc? Is there a low enough rating where we would opt for a pre-defined gamma (A, B, etc)?
Basically I would just use the 1200 curve until you see a maxcll way above that which will be pretty rare. You can probably still do it with 2000nit titles too. I wager you won't even be able to spot where it's clipping.
It's super annoying how many titles and HDR content don't report a MaxFALL & MaxCLL...when they do I get weird ones where the MaxCLL is like 10,000 but the MaxFALL is <500...so I use the 1200 nit curve knowing it will likely be appropriate for the majority of the content if the average is <500, and will clip on those random super bright pixels.
I typically don't use the 4000nit curve until the MaxCLL itself is at least 1000 with the MaxFALL being 3000 or greater. Obviously there is some content (I think Altered Carbon on Netflix is one that springs to mind) that actually has a MaxCLL above 2000-3000 which makes it a no brainer to use the 4000nit curve.
Ultimately I guess you just have to play around with it and find what works for you. When no MaxCLL or MaxFALL is reported I just go ahead and use the 1200nit curve.
rlarsen462 is offline
post #11228 of 12541 Old 03-11-2019, 08:59 AM
bytebuster's Avatar
Quoted: 130 Post(s)
Liked: 36
Folks, ran into a very strange issue last night. When I powered on my projector, it started up with these streaks of green lines. Powered off and on again and thankfully it came up fine.
Has anyone seen this before?
bytebuster is offline
post #11229 of 12541 Old 03-11-2019, 12:17 PM
mogrub's Avatar
Quoted: 270 Post(s)
Liked: 260
Originally Posted by bytebuster View Post
Folks, ran into a very strange issue last night. When I powered on my projector, it started up with these streaks of green lines. Powered off and on again and thankfully it came up fine. Has anyone seen this before?
The color shift to green suggests a handshake issue, as does the fact that a power cycle corrected it. (The other way a handshake induced color shift can be seen is pink.)
bytebuster likes this.
"Get me a scotch. I'm starving." JVC DLA RS-540U, Stewart ST 130 G3, Yamaha RX-A3080, Emotiva XPA-3, Panasonic UB820, Oppo 103D, Xfinity X1, Roku, ATV, Harmony 900.  Atmos 7.2.4 via Martin Logan Stage-X, Martin Logan Theos x2, Martin Logan FX x2, Sonance VP69 x2, Sonance VP66 x4, SVS PC12-NSD x2. Viewer's choice between Palliser recliners x7 or Great Dane beds x2.
mogrub is offline
post #11230 of 12541 Old 03-11-2019, 12:26 PM
mogrub's Avatar
Quoted: 270 Post(s)
Liked: 260
Owners on this thread are lucky in a bunch of ways, including that they aren't experiencing all the problems being reported by early adopters of the next generation JVC projectors. Feel bad for every one of those guys. Lots of us thought about it. Glad we stayed put. ✌️
JJ7 and Reddig like this.
mogrub is offline
post #11231 of 12541 Old 03-11-2019, 12:30 PM
Archaea's Avatar
Quoted: 3888 Post(s)
Liked: 3689
I've seen a JVC RS600 in my room and was blown away by it. Is it fair to say a RS540 would look as good as RS600? I'm tottering between upgrading now, or waiting for HDMI 2.1 and true 4K in a quality projector like one of these JVCs coming down to about $3K pricepoint. I'm guessing that's about 2 years out.
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is offline
post #11232 of 12541 Old 03-11-2019, 12:38 PM
thrillcat's Avatar
Quoted: 533 Post(s)
Liked: 508
I've seen a JVC RS600 in my room and was blown away by it. Is it fair to say a RS540 would look as good as RS600? I'm tottering between upgrading now, or waiting for HDMI 2.1 and true 4K coming down to about $3k - which seems to be maybe 2 years away?
If you ask @dlbeck to compare his 500 to my X790R, he should give you a pretty good take, as he's seen them both.
EDIT: Wait, never mind, he didn't make the 2001 screening, so he hasn't seen mine yet. oop:
I love my iPhone, but it will never replace my turntable. I've never seen Titanic OR XXXXXXXXX. Alexa is a stripper name.
The Cinema 1858 Remodel Thread
thrillcat is offline
post #11233 of 12541 Old 03-11-2019, 01:56 PM
pippo53's Avatar
Quoted: 44 Post(s)
Liked: 3
After 30 hours of operation on my X7900 appeared lines that you can see in the picture. I contacted the assistance and they replaced the optical group
pippo53 is offline
post #11234 of 12541 Old 03-11-2019, 09:09 PM
Reddig's Avatar
Quoted: 533 Post(s)
Liked: 1050
Originally Posted by bobof View Post
Form, fit and function are identical, it is just brightness you might notice some difference in - how noticeable depends on screen. If you already think it is bright I'm guessing your screen doesn't maintain much polarisation. You can work out how much already just by putting the xpands on and rotating your head 90 degrees while looking at the screen.
I tried flipping the glasses 90* on a bright 3D image I just could not see any difference in brightness. I was up till 4 am watching 3D movies last night lol. The Boss Baby 3D and Prometheus 3D both were absolutely incredible and had some high contrast scenes that had me floored. Ive never experienced super high contrast 3D before.
JBL Pro/JTR/JVC/Denon/Oppo/Monoprice/Elite Screens/Furman/Seatcraft/Acoustimac/AudioQuest/Roku
Reddig is offline
post #11235 of 12541 Old 03-11-2019, 09:10 PM
Reddig's Avatar
Quoted: 533 Post(s)
Liked: 1050
Originally Posted by Cleveland Plasma View Post
I hope JVC produces these for a long, long time
I see so many people weighing the pros and cons of different projectors and Im thinking, "just get an RS540 and don't look back!"
Reddig is offline
post #11236 of 12541 Old 03-12-2019, 12:17 AM
aka jfinnie
Quoted: 2641 Post(s)
Liked: 1739
I doubt you'll see any difference with the JVC glasses then as that is effectively all that is different (and the silk screen printing on the legs).
If you measured it I guess you'd probably find a slight increase in brightness with the correct orientation (on something that didn't maintain significant polarisation I still saw 10% difference). 10% is pretty hard to notice with the naked eye though.
bobof is online now
post #11237 of 12541 Old 03-12-2019, 12:18 AM
aka jfinnie
Liked: 1739
Doubtful isn't it? I mean, these are pretty much on closeout sale I thought...
bobof is online now
post #11238 of 12541 Old 03-12-2019, 01:26 AM
Quoted: 61 Post(s)
Liked: 3
Hi All,
Bit late to the party, picked up my X9900 recently.
I have uploaded Javs V3 1200 and 4000nit curves via Arve, Download R masciolas Patterns, Just a few things i am unsure off.
When setting targeted luminence, i used the 100% white pattern of AvsHD709. I also used it to set luminence in HDR mode. i was able to obtain 36ftl with low lamp iris wide open. Did i use the wrong pattern for setting it in HDR? i could not find a 100% white pattern with the Masciola Suite.
When adjusting BBO levels and aiming for black at bar 64, do i leave the IRIS in manuel mode? and after completion do i set it back to Auto Di 1 or 2 or leave in manuel?
Cheers
shazza6887 is offline
post #11239 of 12541 Old 03-12-2019, 02:29 AM
coxy2416's Avatar
Quoted: 571 Post(s)
Liked: 341
Originally Posted by shazza6887 View Post
Hi All,
Cheers
Iris should be in manual mode and I would also turn off clear black while setting the black level. When you are finished you can then leave the Iris in Manual or set it to one of the Auto modes.
coxy2416 is offline
post #11240 of 12541 Old 03-12-2019, 04:44 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
I’m trying to import Javs 1200 nit gamma using the JVC software but it won’t recognise it, I just clicked on the V3 cures and put them onto my desktop the same as I did for mannis and Dominic’s, I’m not very good in this area with laptops, I guess I’m doing something dumb ?.
panman40 is offline
post #11241 of 12541 Old 03-12-2019, 06:42 AM
Quoted: 4883 Post(s)
Liked: 1847
Javs curves are available in both .conf format and .jgd format. You have to use Arves Tool and JVC Autocal for them, respectively.
panman40 likes this.
Dominic Chan is online now
post #11242 of 12541 Old 03-12-2019, 06:53 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
Thanks Dominic, I see on my desktop they are in .conf format so that's the reason why then, I can't seem to find them in the .jgd format ?. I use the JVC autocal.
panman40 is offline
post #11243 of 12541 Old 03-12-2019, 07:20 AM
Liked: 1847
They are under his v3 85 nits curves
post #11244 of 12541 Old 03-12-2019, 07:24 AM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
Ahh thanks very much for that
panman40 is offline
post #11245 of 12541 Old 03-12-2019, 11:41 AM
johng's Avatar
Quoted: 244 Post(s)
Liked: 113
I've seen that artifact on my system. It was an HDMI handshake problem. After tightening the cable at both ends the problem has not appeared again.
Good Viewing,John G  JVC DLA-X790 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 region free MOD disc player, Zappiti Mini4K HDR, Synology DS418 NAS, Yamaha RX-A2070 AVR, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,   & Yamaha 6600 External Amp
johng is offline
post #11246 of 12541 Old 03-12-2019, 11:45 AM
Reddig's Avatar
Quoted: 533 Post(s)
Liked: 1050
Thanks. Ya if there is a change going on I can't perceive it.
They certainly do look IDENTICAL. Like you said the screen printing is probably all.
Reddig is offline
post #11247 of 12541 Old 03-12-2019, 02:21 PM
panman40's Avatar
Quoted: 336 Post(s)
Liked: 144
I have a pair of Sim branded glasses which are identical to, I can’t remember if I mentioned it but 3 out of my 5 pairs now have a split in the nose bridge on the inside. Also 2 pairs have broken plastic where the pins go into the legs. They still work ok though, it’s a shame as I’m the only one who handles them and I’m extremely careful so just something to watch out for.
Reddig likes this.
panman40 is offline
post #11248 of 12541 Old 03-12-2019, 02:25 PM
Reddig's Avatar
Quoted: 533 Post(s)
Liked: 1050
Yes you did mention that and after wearing them I can totally see that happening. It seems to have a weak point right between the lens on the frame. If someone was to take them off real quick and a leg catches I could easily see it snap. I too will usually be the only one handiling them and Im going to be very carful. Thanks alot.
Reddig is offline
post #11249 of 12541 Old 03-13-2019, 05:46 AM
Archaea's Avatar
Liked: 3689
I take it you’ve seen both. What are your thoughts. (Recognizing different rooms, screen sizes, conditions etc)
Archaea is offline
post #11250 of 12541 Old 03-13-2019, 06:16 AM
coxy2416's Avatar
Quoted: 571 Post(s)
Liked: 341
I have the X790 and it is a great projector however I am not sure you are going to see a night and day difference between your RS600 and the RS540. Are they not both eShift projectors?
I personally would love to see a $3000 native 4K JVC projector but I don't think that will happen. Mostly the prices stay the same on each model, year in and out, as each model is upgraded.
coxy2416 is offline
Jvc , xbox one x
