Official JVC - 20LTD - RS640 (x990/x9900) - RS540 (X790/x7900) - Owners Thread - Page 379 - AVS Forum | Home Theater Discussions And Reviews
 32133Likes
post #11341 of 14019 Old 03-23-2019, 04:01 PM
Quoted: 6285 Post(s)
Liked: 2644
Originally Posted by jpiddy View Post
Does anyone know a way to create a SDR2020 and HDR2020 calibration using JVC AutoCal with different color profiles? My understanding is the calibration for the BT2020 is shared across all User Profiles and I can’t find a way to engage the color filter on any other color profiles during calibration.
If you want SDR2020 you should use the BT.2020 colour profile, with an SDR gamma (2.2 or 2.4).
JVC DLA-X550R; Denon AVR-X3400H; HD Fury Linker / Vertex 2; ATV4K; Sony UBP-X700
JVC Curves; Optimizing HDR;
Creating a basic HDR curve using Arve’s Tool;
Replacing JVC Bare Bulbs
Dominic Chan is online now
post #11342 of 14019 Old 03-23-2019, 04:07 PM
jpiddy's Avatar
Liked: 3
If I do that, what can I do to create a different color Profile for HDR utilizing the color filter?
jpiddy is offline
post #11343 of 14019 Old 03-23-2019, 04:19 PM
Liked: 2644
You use two Picture Modes, one for SDR and one for HDR. Both use the same BT.2020 colour profile but with different gamma settings.
post #11344 of 14019 Old 03-23-2019, 05:03 PM
jpiddy's Avatar
Liked: 3
That makes sense. Does sharing the color profile have any impacts on the gamma since it was Calibrated with a different color profile? I guess I was thinking it would. If not I guess problem solved.
jpiddy is offline
post #11345 of 14019 Old 03-23-2019, 05:20 PM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Ah, so with the Oppo you already have the tone-mapping capability. I believe the settings on the first post of this thread are what have been found to be optimal with Oppo/RS540.
For 4K HDR sources not coming from Panasonic 820/Oppo, I've found the settings by Dominic and JAVS via ARVE tool work best... e.g. Roku/Apple 4K
Oh.. one other thing... I don't know how well this works (I dont have oppo)... but you may be able to have your Roku HDMI out feed into the Oppo and use tone-mapping that way... that's a unique feature that Oppo 203 has.
Originally Posted by Reddig View Post
Im using an Oppo 203 for UHD discs. I have a Roku Ultra but have not streamed anything in UHD yet. Don't wanna buy anymore players although Im aware of whats out there for tone mapping.
I have about 10 UHD BD movies so far. Put in a few last night and was pleasantly surprised on the HDR pop im getting. I don't plan to start buying everything on UHD yet but im having fun playing around with them on the 540.
Reddig likes this.
stumlad is offline
post #11346 of 14019 Old 03-23-2019, 05:34 PM
Reddig's Avatar
Quoted: 610 Post(s)
Liked: 1249
Thanks stumlad.
Im not exactly sure what all the 203 is doing with an UHD HDR signal. It has some luminance settings that you can adjust. I put it down from 1,000 down to 500 and then down again to 300 and Im liking that a lot. Then theres the gamma adjustments on the JVC that Ive been playing around with and it really made a huge diference as before I had them all at 0. Im almost positive that the Panasonic players you mention have better tone-mapping. If they were $199 or even $299 i might try one but Im actually tapped out from buying the RS540.
Im gunna try some of Dominics settings and also look around more at olds posts.
JTR/JBL/JVC/Denon/Oppo/Monolith/Silver Ticket/Furman/Seatcraft/Acoustimac/AudioQuest/Harrison Labs/Roku
Reddig is offline
post #11347 of 14019 Old 03-23-2019, 05:47 PM
Liked: 2644
Each gamma calibration is shared by all profiles and picture modes that have the same lamp power, CMD and colour filter setting.
giomania likes this.
post #11348 of 14019 Old 03-23-2019, 06:08 PM
jpiddy's Avatar
Liked: 3
Thanks for the help!
jpiddy is offline
post #11349 of 14019 Old 03-23-2019, 10:42 PM
Cleveland Plasma's Avatar
Quoted: 7645 Post(s)
Liked: 7709
Originally Posted by rbouch8828 View Post
Anyone know of someone that I can get to do a calibration on my 790, being fed by an Oppo 203, from Denon 6500, with Xfinity XG1v4 and Apple 4K feeds? I am in Framingham, MA. West of Boston. Everything is wired and operating. Just looking for Calibration.
Chad B : [email protected]
Cleveland Plasma is offline
post #11350 of 14019 Old 03-24-2019, 05:53 AM
Tom Riddle's Avatar
Quoted: 1103 Post(s)
Liked: 1359
Originally Posted by markmon1 View Post
After spending time on the RS3000, it's my opinion that the new line of JVC has better motion than the Sony's. A huge upgrade over the current line.
What about the 1000 and 2000?
For 18k, the 3000 better be flawless. I would love to own one!
Routh Family Theater - My Dedicated Home Theater Build - 7.2.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I & TV3612 Subwoofers
Marantz AV7705 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #11351 of 14019 Old 03-24-2019, 06:02 AM
Tom Riddle's Avatar
Liked: 1359
Originally Posted by jj-34 View Post
I know this has probably been said before, but what Picture Quality does one loose if any with Low Latency ON ?
Said another way, what exactly is gained by leaving Low Latency OFF ?
There aren’t any picture compromises by turning on Low Latency. It’s especially helpful if you are a gamer, as it reduces input lag. For me, I had a slight lip sync issue and turning on low latency fixed it.
Reddig and jj-34 like this.
post #11352 of 14019 Old 03-24-2019, 12:17 PM
rbouch8828's Avatar
Quoted: 57 Post(s)
Liked: 54
Ok, thanks.
I have sent an email.
rbouch8828 is offline
post #11353 of 14019 Old 03-26-2019, 12:37 AM
pippo53's Avatar
Quoted: 47 Post(s)
Liked: 3
Hi, after an X5000 (RS 400) I bought an X7900 (RS 540). Could any of the most expert explain, step by step, a correct and complete Autocal procedure for this pj?
Both for sdr and for hdr
thanks, thanks very much
pippo53 is offline
post #11354 of 14019 Old 03-26-2019, 02:58 AM
Quoted: 79 Post(s)
Liked: 4
How's the upgrade pippo53?
SeargentPeppers is offline
post #11355 of 14019 Old 03-26-2019, 04:02 AM
pippo53's Avatar
Quoted: 47 Post(s)
Liked: 3
Remarkable. It is worthwhile, especially with the current cost of the RS 540
pippo53 is offline
post #11356 of 14019 Old 03-26-2019, 08:20 AM
woodhead2's Avatar
Quoted: 97 Post(s)
Did you find out how to do the autocal? I am interested, also. I have the 540
woodhead2 is offline
post #11357 of 14019 Old 03-26-2019, 09:03 AM
fr8flyr's Avatar
Quoted: 35 Post(s)
Liked: 56
I just acquired an RS540 from another member and would also be interested in the autocal.
Earl
fr8flyr is offline
post #11358 of 14019 Old 03-26-2019, 09:24 AM
Liked: 2644
There’s a dedicated thread on JVC Autocal. It was created originally for the RSx00 (2015) models but 95% of the info applies equally well for the RSx20 and RSx40 models.
https://www.avsforum.com/forum/24-di...500-rs600.html
fr8flyr, neo_2009 and TriniTa like this.
post #11359 of 14019 Old 03-26-2019, 01:31 PM
pippo53's Avatar
Quoted: 47 Post(s)
Liked: 3
And for HDR?
pippo53 is offline
post #11360 of 14019 Old 03-26-2019, 02:27 PM
Liked: 2644
And for HDR?
For gamma, Autocal calibrates the “base gamma”, not specifically SDR or HDR.
The thread does cover BT2020 but Autocal doesn’t do that good a job for BT.2020, as the projector’s gamut is approx. DCI-P3 with the filter.
EDIT: Some Spyders may also result in a yellowish white when used for colour calibration.
post #11361 of 14019 Old 03-27-2019, 05:16 AM
pippo53's Avatar
Quoted: 47 Post(s)
Liked: 3
pippo53 is offline
post #11362 of 14019 Old 03-27-2019, 06:10 PM
ddigler's Avatar
Quoted: 1165 Post(s)
Liked: 517
Originally Posted by ddigler View Post
Booted up my RS640 to an error state for the first time that I am aware of. Standby and warning lights were solid with the orange lamp light blinking. Pushed the power button again, projector booted up and seems to be working fine. A little concerning as I’ve had the projector for about one year and don’t ever recall this happening before.
Recently I changed out the HDMI cable that connects my projector to my AVR. I am now using a Ruipro optical HDMI which seems to function perfectly during viewing.
Additionally, I recently cut speaker holes in my double drywall ceiling for Atmos speakers. I covered the projector up during the dusty process but it’s possible that it may have taken some dust. I cleaned it off from the outside afterward but maybe I’ve got to get out and clean the filter?
Thoughts on why this may have happened, suggestions on how to rectify? Thanks in advance for any help!
Does anyone have any ideas on above? Just happened for a second time. I’ve used the projector for many hours since the first time it happened until the second time tonight with no issues whatsoever. Anybody experiencing this issue or can tell me what the error codes mean?
ddigler is offline
post #11363 of 14019 Old 03-27-2019, 06:16 PM
Liked: 2644
The error code indicates “Lamp does not light up and unit is unable to project”.
ddigler likes this.
post #11364 of 14019 Old 03-27-2019, 06:19 PM
ddigler's Avatar
Liked: 517
Ohhhhh kay thanks Dominic. Can you tell me where you found this information? Could this indicate a failing lamp? this is a very ambiguous error description …
ddigler is offline
post #11365 of 14019 Old 03-27-2019, 06:23 PM
Liked: 2644
It’s the last error code described in the manual (P.78).
The lamp may not be “failing”. You can continue to use it.
ddigler likes this.
post #11366 of 14019 Old 03-27-2019, 06:46 PM
ddigler's Avatar
Liked: 517
This is going to sound ridiculous but is it normal to get a PJ error from time to time? Why should I assume the lamp is not failing when I get this error every now and then? Bought the projector brand new; lamp time is sitting at 850 hours.
Thank you for directing me to the owners manual page. The description of the error code I am receiving suggest to check the lamp and lamp cover are installed correctly and then restart. Maybe some vibrations from the floor above have knocked the lamp loose?
Sorry for so many questions; I love this projector and just trying to determine what I’m up against…
ddigler is offline
post #11367 of 14019 Old 03-27-2019, 06:58 PM
Liked: 2644
I didn’t say it’s “normal”, but the only other option is to replace the lamp. If the projector is still under warranty you can contact JVC.
X1, X2, X3 are different error codes with different causes. Remove the lamp and re-inserting it may not solve the problem, but is easy enough to try.
ddigler likes this.
post #11368 of 14019 Old 03-27-2019, 07:23 PM
ddigler's Avatar
Liked: 517
Fair enough thank you for the input Dominic.
How often should one be cleaning the air filter? Can a dirty air filter cause oddball error codes? Thought I read somewhere something about that...
ddigler is offline
post #11369 of 14019 Old 03-27-2019, 09:48 PM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Question about 3D glasses for these projectors. I currently have an IR sensor but have the older JVC/xpand 103. They work well, but they are heavy. If I went with an RF emitter, what are the best 3rd party light-weight glasses that work with this? I have a Stewart ST130 G3 screen. I do not believe it holds any polarization. I have seen some info on the Xpand 105, but is there a specific model number i need? (I know they have IR and RF glasses, but I remember reading somewhere that some are horizontal and some are vertical).
stumlad is offline
post #11370 of 14019 Old 03-28-2019, 02:26 AM
coxy2416's Avatar
Quoted: 774 Post(s)
Liked: 457
I had a lamp error with my X790 at around 200 hrs and it wouldn't even start up. I ended up taking the bulb out and putting it back in and that seem to correct the error and everything worked fine after that.
johng and ddigler like this.
coxy2416 is offline
Jvc , xbox one x
