Official JVC - 20LTD - RS640 (x990/x9900) - RS540 (X790/x7900) - Owners Thread - Page 386 - AVS Forum | Home Theater Discussions And Reviews
 31171Likes
post #11551 of 12026 Old 04-23-2019, 08:04 PM
jwhart's Avatar
Quoted: 214 Post(s)
Liked: 78
Originally Posted by suffolk112000 View Post
What projector mounts are available for the JVC RS540?
I've used the Chief mounts with all 3 of my projectors and cannot reccommend them more highly. The links are included on the 1st page of this thread.
suffolk112000 and Tom Riddle like this.
jwhart is offline
post #11552 of 12026 Old 04-24-2019, 03:41 AM
JonnyVee's Avatar
Quoted: 274 Post(s)
Liked: 163
Originally Posted by JonnyVee View Post
Any recommendations for screen adjustment mode for Silver Ticket’s white 1.1 matte screen?
https://www3.jvckenwood.com/english/...creen/#x9900be
Anyone?
Rec Room: JVC x790 w/120" Silver Ticket screen, Denon x4400H 5.1.4 with Kef Q100 L/R, Q200 centre, T101 surrounds, Ci160er rear atmos, Energy Rc-Mini - front atmos, SVS PC-2000. Family Room: LG 65B7P OLED, Denon s730H 5.1 - Kef Q500, Q200c, Energy v-mini - surrounds. Calibration Gear: X-Rite i1Display Pro, Calman Home Enthusiast, trial & error, and a patient wife.
JonnyVee is offline
post #11553 of 12026 Old 04-24-2019, 06:49 AM
jwhart's Avatar
Quoted: 214 Post(s)
Liked: 78
Anyone?
Maybe you should contact JVC's customer support.
jwhart is offline
post #11554 of 12026 Old 04-24-2019, 06:56 AM
microwiz's Avatar
Quoted: 282 Post(s)
Liked: 193
Originally Posted by joepaiii View Post
I wonder why reviewers don't measure the motion resolution of various projectors or even TVs? I came from a DLP to a JVC and it does noticeably blur when things start moving. I think some people notice this more than others and would like to see some actual tests which reliably measure it.
JVC does advertise lines of resolution with FI turned on, I think it's about 900 lines vs 300 something when turned off so it's pretty good in my opinion when watching sports, I also use it for movies for that same reason.
DLP would be better but the JVC is every bit as good as all my LCD flat screens in the house for watching sports.
Pioneer SC-95, Axiom M80, VP180 Dual EP500 all V4. ISCO III, RS540 + Stewart Cima Neve 133
microwiz is offline
post #11555 of 12026 Old 04-24-2019, 07:23 AM
Quoted: 4507 Post(s)
Liked: 1685
Each screen is different. I would not use settings meant for another screen.
The ST matte white screen is fairly neutral and you should be OK without setting the screen type. If you’re doing an actual calibration the screen material is accounted for when you take readings off the screen.
giomania, Mike_WI and JonnyVee like this.
Dominic Chan is offline
post #11556 of 12026 Old 04-24-2019, 08:06 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6416 Post(s)
Liked: 6406
RPA + SLB281 combo
RPMA + SLM281 combo >>> This has gear adjustment.
__________________________________________________ ____________________________________________
Projector box
Could also build a box, never have to buy a mount ever again. <<< Click Here >>> to be linked to pics and details.
suffolk112000 likes this.
Cleveland Plasma is offline
post #11557 of 12026 Old 04-24-2019, 09:09 AM
JonnyVee's Avatar
Quoted: 274 Post(s)
Liked: 163
Thank you. If there are no known matches on JVC's list that correspond to the Silver Ticket, I'll just leave it as is and not set screen type. I'll also be doing a followup calibration with Calman afterwards.
JonnyVee is offline
post #11558 of 12026 Old 04-25-2019, 04:20 PM
mogrub's Avatar
Quoted: 270 Post(s)
Liked: 260
Originally Posted by jwhart View Post
And Saints!
Saints were fantastic last year. It was only the Rams 12th man that beat them.
jwhart likes this.
"Get me a scotch. I'm starving." JVC DLA RS-540U, Stewart ST 130 G3, Yamaha RX-A3080, Emotiva XPA-3, Panasonic UB820, Oppo 103D, Xfinity X1, Roku, ATV, Harmony 900.  Atmos 7.2.4 via Martin Logan Stage-X, Martin Logan Theos x2, Martin Logan FX x2, Sonance VP69 x2, Sonance VP66 x4, SVS PC12-NSD x2. Viewer's choice between Palliser recliners x7 or Great Dane beds x2.
mogrub is offline
post #11559 of 12026 Old 04-26-2019, 04:32 AM
Quoted: 25 Post(s)
Liked: 2
Still making my way through the forum and enjoying my projector.
Question regarding sharpness and e-shift.
When 4k e-shift is “off’, images are crystal clear and sharp. This includes Windows 10 text in 1080p, Quick Brown Fox chroma test image, and the JVC Focus grid (grid has nice definition - similar to JAVS’ images on page 1.
However, when when 4k e-shift is “On”, test images are soft ... Windows 10 text (3840x2160) is not as sharp and the JVC focus grid is blurry... unable to see the two rows of green horizontal pixels.
Is this normal? Seems odd that 1080p is sharper than 4k.
I’ve noticed this too. The menus look like SD DVD quality to me
Terminate is offline
post #11560 of 12026 Old 04-26-2019, 04:54 AM
Liked: 1685
Test images like QBF should be displayed in native resolution. e-shifted (non-native) 4K will look less sharp, but “smoother” (less blocker) than 1080p. That’s why usually one should adjust focus with 1080p source and e-shift turned off.
post #11561 of 12026 Old 04-26-2019, 06:05 AM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
JonnyVee- Try this:
1) Look at Windows at 1920x1080 with e-shift off.
2) Look at Windows at 3840x2160 with e-shift on, but set DPI scaling to 200%
Look at the text and overall image. Which looks better ?
I believe Javs has comparison shots of JVC 1080p versus e-shift in which shows that e-shift does in fact give you more resolution than native 1080p. If anyone has that link, please post as I do not remember what thread it was in. The problem with text on 3840x2160 is that the JVC e-shift isn't true 3840x2160p so it won't look as good as a native projector.
Terminate- Can you post a pic of your SD looking menu? When you do so, do it with the info that shows your incoming resolution/bit-depth/etc. Maybe take a 2nd with menu showing e-shift on, and then a 3rd showing e-shift off. Perhaps you have a panel alignment issue?
stumlad is offline
post #11562 of 12026 Old 04-26-2019, 07:06 AM
Tom Riddle's Avatar
Quoted: 682 Post(s)
Liked: 548
Originally Posted by stumlad View Post
JonnyVee- Try this:
I've played around extensively on 1080p discs, toggling between 4k and 2k to see which provides the sharper picture. I can say with certainty that 4k looks much better than the 2k profile.
Routh Family Theater - My Dedicated Home Theater Build - 7.1.4 Atmos Setup
Seymour AV 100" Electronic Masking Screen - Klipsch RF-7 II's, RC-64 II, RS-62 II's, RS-52 II's, CDT-5650 II-C x 4 - PSA V3600I Sub
Marantz AV7704 with TK421 Modification - Panasonic UBD 820
Emotiva XPA -7 & XPA-5 - Sony XBR-75x940c with Ideal-Lume Panelight (Living Room)
Tom Riddle is offline
post #11563 of 12026 Old 04-26-2019, 10:40 AM
Industry Insider
Liked: 6406
We asked JVC if the RS540U was still being produced, this is what was said:
Maybe one more shipment. Not sure.
Nothing more in May. Possibly June.
Schwa and giomania like this.
post #11564 of 12026 Old 04-26-2019, 11:30 AM
Cinema Six's Avatar
Quoted: 39 Post(s)
Liked: 29
Originally Posted by coxy2416 View Post
I own this projector and would not recommend it if you are going to be watching a lot of sports. It’s fantastic for movies, tv and gaming but if I watched a lot of sports I would check out something different such as a DLP.
Originally Posted by Tom Riddle View Post
I find it to be just fine for sports. I mostly watch on my tv in the living room, but the Super Bowl and The Masters looked great on my unit. It’s not as bright as the Epson would be, but I’ve tweaked the settings for TV to my liking.
With that said, I mostly use my 540 for HT, so that was I purchased the JVC.
My sincere apologies for the late response. Thank you for your replies. I’m going to look at the NX5 and Epson 6050. Movies and sports are my viewing habits. Hopefully, one of these projectors provide a bright, color picture with POP.
Klipsch: RF-7III, RC64III, R-115SW(2)
Sony VPL HW40es....Coming Soon....JVC DLA RS540/X790👍
Marantz AV8805, Emotiva XPA-11
Panasonic UB820
PS4 and Xbox One X
Cinema Six is offline
post #11565 of 12026 Old 04-26-2019, 11:49 AM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
I found the link that shows eShift vs pure 1080p from Javs:
https://www.avsforum.com/forum/24-di...l#post50711409
post #16091
giomania, Kadath and JonnyVee like this.
stumlad is offline
post #11566 of 12026 Old 04-26-2019, 03:48 PM
Reddig's Avatar
Quoted: 497 Post(s)
Liked: 984
I had ordered a big lot of Blu-rays that showed up a bit before my RS540 did and Ive been having sooooo much fun every evening watching a new movie! Never has my theater felt more like a fantastic private cinema then it has now. Im able to truly be swept away in my movies without poor black levels taking me out of the scene, which was my big complaint with my last projector. Every day I literally count down the hours until i get to go back down into the theater! Ive always had some little performance detail keeping me from truly getting engulfed into each moive, but I got my audio down pat and now my image is too! Need to quit waking up my wife with the bass tho lol.
JBL Pro Cinema/JTR/JVC/Denon/Oppo/Roku Ultra/Elite Screens/Furman/Seatcraft/Acoustimac/AudioQuest
Reddig is offline
post #11567 of 12026 Old 04-26-2019, 03:50 PM
Reddig's Avatar
Quoted: 497 Post(s)
Liked: 984
Originally Posted by mogrub View Post
Chris makes it hard not to.
That he does!!
Reddig is offline
post #11568 of 12026 Old 04-27-2019, 03:54 AM
JonnyVee's Avatar
Quoted: 274 Post(s)
Liked: 163
post #16091
JonnyVee- Try this:
Thank you gentlemen, appreciate the insight. I’m a newbie with JVC and it’s helpful when learning the ropes.
I also talked to JVC Canada and they confirmed what I was seeing was normal. Today I’ll be running autocal with my new Spyder and then fine-tuning with Calman.
I will say this. I’m really glad BenQ’s release of the HT3550 was delayed. Made me think outside the box (installed a porthole to get a longer throw and move the projector out of my 11’ deep theatre room) and I got a much better projector because of it.
stumlad likes this.
JonnyVee is offline
post #11569 of 12026 Old 04-28-2019, 02:25 AM
Quoted: 20 Post(s)
Liked: 0
New RS540 on the way...most likely going with 135 inch screen. Which screen would you recommend?
Room is light controlled (black out curtains make it pitch black), dark grey walls and black ceiling with black velvet on projector wall and first 6 feet of ceiling. Overkill...maybe.
But as for the screen...once and a while we might have low ambient light when company is over and we are watching sports or something. Otherwise it’ll be completely black.
I’d like to keep the budget under $1k.
I will be watching both 3D and 4K movies.
Darthprater is offline
post #11570 of 12026 Old 04-28-2019, 01:50 PM
pwong888's Avatar
Quoted: 61 Post(s)
Just got a panasonic ub9000 bluray player, should I set it sdr2020 or using the hdr2020 have better picture quality?
Denon 8500,
Martin Logan Descent i subwoofer
JVC RS 540 projector, 120 acoustic transparent fixed screen
Energy Veritas V-6.3 Speaker x 3
pwong888 is offline
post #11571 of 12026 Old 04-28-2019, 02:08 PM
Liked: 1685
“Better” is in the eye of the beholder, but most people seem to prefer SDR2020 for projectors.
Jive Turkey likes this.
post #11572 of 12026 Old 04-29-2019, 08:10 AM
johng's Avatar
Quoted: 239 Post(s)
Liked: 107
Congratulations. If you like the 540 as much as we like ours you'll have many hours of pleasurable viewing. As far as screen's are concerned, how far from the screen is your primary viewing position? We're throwing the image on a 110" (16x9) screen and we sit about 8 feet from the screen. How close you sit is a big factor in screen size and brightness. Have you looked as the "used" market for a screen? Often people move and are forced to replace their screen. Start by checking the "for sale" section of this forum. Unless you move often, your screen will likely stay with you much longer than your projector. We're on our 3rd projector with this screen. It sounds like you've got a very nice room.
Good Viewing,John G  JVC DLA-X790 Projector, Vutec 110" (16x9) Bright White Screen, Oppo UDP-203 region free MOD disc player, Zappiti Mini4K HDR, Synology DS418 NAS, Yamaha RX-A2070 AVR, Toshiba 1250 NTSC-PAL Region Free BR Player, 7 Paradigm Reference spkrs w Dual Subs,   & Yamaha 6600 External Amp
johng is offline
post #11573 of 12026 Old 04-29-2019, 10:47 PM
cinebuff's Avatar
HIGH ALTITUDE MODE VS. FAN NOISE
I know JVC projectors have lower thresholds for heat build-up than most other brands (JVC recommends utilizing High Altitude mode at elevations above 3,000 feet). Unfortunately, they're also nosier than most other brands when this mode is activated. I would like to hear the experiences and suggestions of projector-owners in High Altitude regions, to see if they have found a way to compensate for this situation (or whether they simply chose to disregard it, without repercussions).
For instance, would using the JVC projector for nighttime viewing possibly eliminate the need for High Altitude mode, or perhaps during cooler months of the year? What about the idea of hanging a USB fan next to one of the exhaust ports as an alternative to High Altitude mode, to either blow or draw air (and if so, which particular port of the RS540-style projector)? Or could this possibly cause issues with dust build-up or dust blobs? Can High Altitude mode be deactivated occasionally in order to enjoy programming that is equatable with, in Elaine Benes' words, being "sponge-worthy" of the privilege? After all, what's the good of watching "A Quiet Place" when your projector environment is anything but?
I live in the Southwest, at 4,000-feet elevation. I had to remove both my PS3 and Dish Network receiver from my A/V cabinet in order to get them to stop periodically shutting down, presumably due to low air density. I used to keep High Altitude activated on my Sony projector as a precaution (even though its threshold was 5,000 feet), without having significant issues with its fan noise (but its panels failed nevertheless). But the JVC is a whopper; its loud High Altitude fan drowning out a lot of the benefits of having a well- calibrated audio system.
My projector hangs about 6 1/2 inches from my eight-foot ceiling, about two feet behind my seating.
Thank you very much.
cinebuff is offline
post #11574 of 12026 Old 04-30-2019, 03:21 AM
MX48's Avatar
Quoted: 92 Post(s)
Liked: 52
Originally Posted by petexian View Post
Here's bulb I used... just got and installed it this afternoon. $135USD
It was easy to replace after taking the lamp assembly out of the projector. I only needed a phillips screwdriver to remove and replace the bulb in the assembly.. I also used non-latex gloves to keep the oils from my hands off the new bulb.
Original Ushio Projector Lamp Replacement for JVC PK-L2615UP (Bulb Only)
https://smile.amazon.com/dp/B07KTL7R..._WIMVCbYGGGMTM
Has anyone that has received one of the Amazon lamps checked it with a light meter to see if it is putting out as many lumens as an original?
woodhead2 and jorgebetancourt like this.
MX48 is offline
post #11575 of 12026 Old 04-30-2019, 05:10 PM
petexian's Avatar
Quoted: 33 Post(s)
I live at 7200ft my settings are high altitude mode OFF because of the noise. My lamp is on high for 4K (HDR) and low for cinema mode. My projector is in a well ventilated area. I just replaced my bulb after 2800 hrs. JVC advertises 4500 hour bulb life, probably on Low lamp, ECO mode.
petexian is offline
post #11576 of 12026 Old 05-01-2019, 10:48 PM
the_jaguar's Avatar
Quoted: 160 Post(s)
Liked: 50
When I connect my HTPC to JVC RS540 via my receiver (X4300H), I do not get a signal if I set the output of my video card (1070Ti) to Full RGB, 8 bit and 60hz, but if I set it to Full RGB, 8 bit (or 12 bit) and 30hz, I get a signal. My Projector is connected to the receiver via a 25 foot Amazon Basics cable. The obvious thing that comes to mind is that this is a HDMI cable issue - just wanted to confirm from the collective wisdom here that this is case before I replace my cable. Please suggest.
the_jaguar is offline
post #11577 of 12026 Old 05-02-2019, 07:33 AM
fredxr2d2's Avatar
Quoted: 352 Post(s)
Liked: 233
Sounds like a cable issue to me. I'd get one of the monoprice premium certified ones - they come in 25 ft and even 30 ft.
jwhart and the_jaguar like this.
Tim S.
Former 35mm and Digital Projectionist @ Regal Cinemas (circa 2012)
Currently watching on: JVC X790, 106" 0.8 Gain Screen, FireTV Stick 4K, PS4, Oppo 203, w/Marantz SR6011, 2 Outlaw M2200, Outlaw Model 5000, SVS Subs, Def Tech Speakers
fredxr2d2 is offline
post #11578 of 12026 Old 05-02-2019, 07:43 AM
jwhart's Avatar
Quoted: 214 Post(s)
Liked: 78
Ditto! The Monoprice certified cables are outstanding and have a lifetime guarantee. They also have fiber optics for longer runs.
jwhart is offline
post #11579 of 12026 Old 05-02-2019, 03:45 PM
trpltongue's Avatar
Quoted: 93 Post(s)
Liked: 25
Hey all just finished reading this whole thread in anticipation of receiving my 540. I was hoping you could check my logic on HDR tone mapping?
I’ll be using madVR as my primary source is an HTPC with Kodi (buying an RTX2060).
If I understand correctly, most people running MadVR map the hdr content to SDR/2020 color profile. And then select the SDR mode on the JVC with their own preferred iris/lamp/color filter/ etc settings.
However, this means that both SDR and HDR content would get the exact same image settings in terms of lamp/iris/filter/etc. I was under the impression we would want different lamp/iris settings for HDR and SDR content, even when using MadVR, so how do we go about changing these settings easily between SDR and HDR content?
Or is it as simple as saving an SD color profile with relevant settings for HDR content and then using Rec709 for SD content?
Russell
trpltongue is offline
post #11580 of 12026 Old 05-02-2019, 07:28 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 601 Post(s)
Liked: 417
Russell
Congratulations on your new PJ.
I had posted the below Excel spreadsheet with a settings matrix that has various recommendations and tips I have collected that you may find useful.
https://docs.google.com/file/d/1E2jN...letype=msexcel
Sent from my iPhone using Tapatalk Pro
giomania is offline
Jvc , xbox one x
