Official JVC - 20LTD - RS640 (x990/x9900) - RS540 (X790/x7900) - Owners Thread - Page 402 - AVS Forum | Home Theater Discussions And Reviews
 31861Likes
post #12031 of 13199 Old 07-28-2019, 02:49 PM
aka jfinnie
Quoted: 2988 Post(s)
Liked: 2091
Originally Posted by Carbo View Post
Thanks, Yup that was what I remember reading. It didn't effect me, that I can tell. I had my projector calibrated by Chadb and it powered back on to a SDR signal from the AppleTV home screen when it came back on. It seems to be working just the way it was before.
If you didn't hear the lamp iris move back to home position when you powered up your lamp iris may well be in the "wrong" position now (think about it, if you didn't hear it - it didn't teleport home!). The lamp iris doesn't actually have a huge impact on light output across its range of travel (by deliberately putting it in the wrong place using this method you can measure the lamp iris's effect, which is usually impossible), but if you have a colorimeter / light meter it is measureable.
The time you'd be most likely to notice would be when you next play HDR. And then you'd only likely see anything problematic if your HDR and SDR modes have very different iris settings. Mine were at -11 and -5 I recall at the time I noticed it. What are your iris settings for each?
bobof is offline
post #12032 of 13199 Old 07-28-2019, 02:55 PM
aka jfinnie
Liked: 2091
Originally Posted by rman222 View Post
Hi all,
I have not found any responses to this question and I have the exact question. Would like to be able to send a "custom mask" command directly to the projector.... Has anyone found a way to do that?
Thanks in advance,
Joe H
Page 26 has the commands you need, though you need to understand how to send them:
http://pro.jvc.com/pro/attributes/PR...lish_Final.pdf
There is an implementation of the bulk of the JVC protocol in ARVE's util in python:
https://github.com/arvehj/jvcprojectortools
Someone just worked on this and made a REST API, don't know if it has enough of the API implemented to do what you want - EDIT: looks like mask is implemented:
https://www.avsforum.com/forum/24-di...l#post58349892
ScottAvery likes this.
bobof is offline
post #12033 of 13199 Old 07-28-2019, 03:06 PM
Carbo's Avatar
Quoted: 354 Post(s)
Liked: 231
I will have to check and see.
1) JVC RS540, Yamaha CX-A5100, Outlaw Audio 7700 & 7140, Wharfedale Jade 7's series speakers, RSL C34e(Atmos)
2) LG OLED65B6, Integra DRC-R1, Emotiva XPA9, Klipsch RP8000F, Klipsch RP404C, Klipsch RP500SA, Klipsch RP140D
Carbo is offline
post #12034 of 13199 Old 07-28-2019, 03:55 PM
rman222's Avatar
Quoted: 14 Post(s)
Bobof
Thank you very much,
Joe H
bobof likes this.
rman222 is offline
post #12035 of 13199 Old 07-28-2019, 09:24 PM
Carbo's Avatar
Quoted: 354 Post(s)
Liked: 231
ChadB had it set up with either Auto 2 for both or Manual 0 for HDR and -10 for SDR. I have been leaving it at Auto 2. So I am guessing it is alright. Nothing funny happens when it activates.
bobof likes this.
Carbo is offline
post #12036 of 13199 Old 07-30-2019, 12:55 PM
Quoted: 31 Post(s)
Anyone know if the RS540 is fussy with the order in which devices are switched when changing sources?
I use a harmony remote in my setup and for some of my sources, I'll just get a black screen or no signal so wondering if that might be a cause for issues. If I mess around and unplug/plug the device it'll work. Case in point is with my Xfinity box - I'll hear audio but no picture. If I power cycle the box sometimes the video will appear.
rinse82 is offline
post #12037 of 13199 Old 07-30-2019, 02:26 PM
Dennis.Mitchell's Avatar
Quoted: 28 Post(s)
Liked: 30
If the different source devices are sending different resolutions or refresh rates, there is a long pause when switching. Try to standard the startup resolution of the different devices. For example, set all of them to 1080p 24fps.
Dennis
Dennis.Mitchell is offline
post #12038 of 13199 Old 08-01-2019, 06:40 PM
Madaeel's Avatar
Quoted: 204 Post(s)
Liked: 177
Just wanted to report back that I played at least 8hrs this past weekend in 4K/60 and had no issues whatsoever with my picture dropping out so I'm 100% convinced now that the cable solved my issue. Now I just gotta run it through the wall.
coxy2416, Tom Riddle and catav like this.
Madaeel is offline
post #12039 of 13199 Old 08-03-2019, 01:00 PM
ddigler's Avatar
Quoted: 1114 Post(s)
Liked: 498
What is the consensus regarding whether or not Dolby Vision and HDR10+ will be added via firmware update to rs640 in future?
Is it even possible?
Thanks for any insight.
ddigler is offline
post #12040 of 13199 Old 08-03-2019, 01:16 PM
aka jfinnie
Liked: 2091
No chance ever.
ddigler likes this.
bobof is offline
post #12041 of 13199 Old 08-03-2019, 01:17 PM
ddigler's Avatar
Liked: 498
Darn. Thought I remember hearing that.
Hardware limitation?
Are the newer model JVC PJs doing it?
Sent from my iPhone using Tapatalk Pro
ddigler is offline
post #12042 of 13199 Old 08-03-2019, 02:28 PM
aka jfinnie
Liked: 2091
a) There is no DV for home projection, Dolby have not created it as yet. No-one has done HDR10+ on projection yet from what I can see, either.
b) JVC don't do retrospective feature updates. A recent exception has been the addition of the auto tone mapping from the N series to the Z1 laser.
ddigler likes this.
bobof is offline
post #12043 of 13199 Old 08-03-2019, 02:32 PM
ddigler's Avatar
Liked: 498
ddigler is offline
post #12044 of 13199 Old 08-04-2019, 12:18 PM
ddigler's Avatar
Liked: 498
I am watching a UHD movie with HDR10. Under the info tab within the menu, HDR is indicating ‘ST.2084’. Can someone tell me what this means? What I’m trying to do is confirm that my player is outputting HDR10 correctly and that my x990 is receding it. Is there a better way for me to verify this?
ddigler is offline
post #12045 of 13199 Old 08-04-2019, 12:37 PM
aka jfinnie
Liked: 2091
ST2084 is the HDR "PQ" gamma curve used for HDR10. If you see this on the info screen it means your player is correctly sending HDR10 to the projector.
ddigler likes this.
bobof is offline
post #12046 of 13199 Old 08-04-2019, 01:25 PM
Quoted: 36 Post(s)
Liked: 30
Bulb Replacement
I would like to purchase some bulb replacements for an X790. What are some of the best places to purchase just the bulb? Also, if I wanted to purchase an extra housing, is there a place to purchase used/discarded housings?
Merlin GS is offline
post #12047 of 13199 Old 08-05-2019, 07:22 AM
Mike Garrett's Avatar
Quoted: 13026 Post(s)
Liked: 10662
Yep and I would say that is a clear indicator that the RS4500/Z1 is carrying through for this fall, no replacement.
Mike Garrett is offline
post #12048 of 13199 Old 08-13-2019, 05:22 PM
Friendly Fire's Avatar
Quoted: 129 Post(s)
Liked: 139
Late to the Game
I'm late to the game, but I just ordered one of the last RS540s -- it will replace an 8 year old Sony HW30 which has been a loyal soldier but it was time to move on. I couldn't justify a native 4K with the current levels of contrast and price points. The 540 looks like a good fit.
Plus I need lens memory. Last year I mounted a 2.40 168" diagonal screen and have loved the results, but displaying 16:9 takes a minute of dinking around with the image size by hand so mostly I just don't watch 16:9 content in the theater room, which is a loss.
Looking ahead it appears that native 4K will be realized with a laser light source. Micro LED panels may eventually win the day, but the timing is uncertain and the concept may never be a real projector replacement.
And I will finally have a JVC projector. This tech moves rapidly enough that I just can justify putting big bucks into the latest and greatest only to be facing gear in a few months that is cheaper a better. The price of fleeting bragging rights is too high for a short buzz.
Friendly Fire is offline
post #12049 of 13199 Old 08-15-2019, 06:38 AM
Jacob22's Avatar
Quoted: 102 Post(s)
Liked: 50
Can anyone help me out with some measurement clarification? I just picked up a RS540U as my first ever projector so I am super stoked as well as I have Chad coming in October to calibrate it plus sound. I am trying to understand the limits of the lens shift capability. Does the lens shift zero-point assume the projector lens is at the top of the screen or the middle of the screen? Again, apologies for such a basic question but just trying to fully understand so I can get the right extension for my mount.
Example:
I have a 44.5 tall screen (2.35:1 screen), would that mean with a +/- 80% offset, I could mound the projector a maximum of 13.35" above the screen? (44.5 * 0.3 = 13.35)?
Jacob22 is offline
post #12050 of 13199 Old 08-15-2019, 06:45 AM
Quoted: 5402 Post(s)
Liked: 2144
Middle. The lens shift can go up as much as it can go down.
Dominic Chan is online now
post #12051 of 13199 Old 08-15-2019, 05:47 PM
coderguy's Avatar
Quoted: 2907 Post(s)
Liked: 1522
Example:
You are about correct, depending on tolerances.
www.webprojectorcalculator.com, pick your projector, select 2.35 lens memory from the Aspect Ratio drop down. Go to the details tab on the bottom left, and it will show you the exact # of inches you have in lens shift available as long as the PJ is horizontally centered.
You have to be careful with lens memory and lens shift, it's restrictive due to switching back and forth between 16:9, unless you want to always watch 2.35 only (and probably few do that unless they have multiple projectors installed).
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is online now
post #12052 of 13199 Old 08-16-2019, 05:09 AM
Jacob22's Avatar
Quoted: 102 Post(s)
Liked: 50
Perfect! What a great website. I ended up moving my screen up a little bit since the way my room is configured it’s the only way without having the projector be below the door frame.
Jacob22 is offline
post #12053 of 13199 Old 08-16-2019, 05:18 AM
Javs's Avatar
Quoted: 6937 Post(s)
Liked: 6654
Hey side question, does your calculator assume a frame size when it lists screen size? Particularly distance from floor and ceiling?
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #12054 of 13199 Old 08-16-2019, 07:16 AM
Liked: 10662
It is mislabeled. It should say top of image and bottom of image, rather than frame.
post #12055 of 13199 Old 08-16-2019, 08:07 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7028 Post(s)
Liked: 7059
<<< Click Here >>>
@Dominic Chan is selling loose bulbs that are the right bulbs and very good. They're cheap. I'd suggest one of those. There are guys just buying the bulb without the whole assembly very cheap, I do not know where that post is though
Originally Posted by dengland View Post
Exchange unit was received today and the failed unit is already in route back to them. I am not the original owner of the projector so it was a tiny hassle. JVC was able to trace that it was bought from an authorized dealer. I had to get the original sales receipt. Earlier in the thread someone mentioned, no original receipt, no sale. Pretty good advice.
Very please with JVC. They could of walked away from this as I was not the original owner.
You have to prove when you bought it Glad you got a new one ......
giomania and Merlin GS like this.
Cleveland Plasma is online now
post #12056 of 13199 Old 08-16-2019, 09:58 AM
coderguy's Avatar
Liked: 1522
That's a good point, it actually says "Top of Screen", but yes, it should say "Top of Image". Not sure why I labeled it that way, must have had an autistic moment.
@Javs
A frame size is assumed at 4" thick, not sure what the average frame size really is, but 4" seemed safe as I think many are 2.5" to 3" thick, and some maybe are up to 4".
If you read the bottom of the Tips section, it tells you this in # 8...
8) The Min Req Ceiling Height is the minimum required ceiling height in your room for the given screen size. It is assumed a screen needs
at least 4 inches (10cm) of clearance for the screen frame's thickness.
Mike Garrett likes this.
post #12057 of 13199 Old 08-16-2019, 03:26 PM
Liked: 0
Do you know if the datacolor spyder X is compatible with the JVC Auto Calibration Software ?
Thank you.
Ender024 is offline
post #12058 of 13199 Old 08-16-2019, 03:42 PM
Javs's Avatar
Liked: 6654
@Javs
Great, so if it says I have 30cm top and bottom spare, that's including the frame?
Fantastic, because I am currently using this to help figure out the max sized screen I should be able to put in my room.
Javs is offline
post #12059 of 13199 Old 08-16-2019, 03:55 PM
Liked: 2144
Thank you.
No, at least with the current versions.
post #12060 of 13199 Old 08-16-2019, 04:13 PM
Liked: 0
Thank you Dominic.
Ender024 is offline
Jvc , xbox one x
