Lumens (Brightness) for New JVC's (RS440/540/640) - AVS Forum | Home Theater Discussions And Reviews
 49Likes
post #1 of 261 Old 11-17-2017, 10:15 AM - Thread Starter
coderguy's Avatar
Quoted: 2457 Post(s)
Liked: 1325
Several people had posted much lower numbers than the previous year (as low as 300 lumens less, but averaging say 100-200)...
I was thinking we should have a separate thread for this to keep track of it to see if this is really an issue or just something of an anomaly (bad lamp run?).
If anyone has measurement data, it may help to just post here so we do not end up reading through hundreds of pages of past posts to try to dig the data up.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #2 of 261 Old 11-17-2017, 11:45 AM
Craig Peer's Avatar
Quoted: 7114 Post(s)
Liked: 8466
Also, they should post -
1 - hours on lamp.
2- light meter used.
3 - screen size they are shooting the 100 IRE test pattern on.
4 - throw distance used for said screen.
5 - lux reading.
ARROW-AV likes this.
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is offline
post #3 of 261 Old 11-17-2017, 12:29 PM
zombie10k's Avatar
Quoted: 5422 Post(s)
Liked: 5785
Originally Posted by woofer View Post
Sorry to clutter the Sony thread BUT the X9500 AND X7500 i have here are brighter than the X9900 i also have here???
Even swapped the bulb from the X7500 ( it had zero hours on it) to the X9900 and the X9900 was still dimmer......sort of takes the bulb out of the equation???
re-posting this here, it would be interesting to hear additional info on this test.
zombie10k is online now
post #4 of 261 Old 11-17-2017, 03:00 PM
We're Nuts About AV
ARROW-AV's Avatar
Quoted: 4117 Post(s)
Liked: 6655
Please kindly list the "several people"?
Are you referring to anyone further to:
(1) ARROW-AV
(2) Javs
(3) Woofer?
Just so you know I have further information regarding this matter including information provided to us directly by JVC...
But first of all I need to know is there anyone else in addition to this?
ARROW-AV is offline
post #5 of 261 Old 11-17-2017, 03:09 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
Here's some additional info... According to @woofer , whom I am sure that he won't mind my saying so, the projected video image did not in fact actually look any dimmer.
Also, I think that it is important to note that he had changed the projector's input setting to SUPERWHITE which reduces peak luminance with 100 IRE by circa 20%
With respect to the units which we measured, these are both nicely run in now and we factory reset both projectors, then recalibrated them both and we now measure only a circa 8% difference in peak luminance. Something which is certainly not outside of tolerance.
Craig Peer likes this.
ARROW-AV is offline
post #6 of 261 Old 11-17-2017, 03:10 PM
zombie10k's Avatar
Liked: 5785
what is the info from JVC?
post #7 of 261 Old 11-17-2017, 03:18 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
I had a very interesting 30 minute telephone conversation with one of the senior guys within the technical division of JVC who basically explained that it's quite simply not possible for there to be a difference between the two models with respect to peak luminance outside of inter-unit variance.
I am awaiting an email confirming matters in writing and as soon as I receive it I will post it on here. JVC knows that I will be publishing it and have authorized me to do so.
Let's wait and see what they say...
What I can say right now is that JVC said that if someone correctly/accurately measures more than 20% lower peak luminance, without any influencing factors skewing the results, then that unit is defective and should be returned for evaluation.
ARROW-AV is offline
post #8 of 261 Old 11-17-2017, 03:22 PM
zombie10k's Avatar
Liked: 5785
I had a very interesting 30 minute telephone conversation with one of the senior guys within the technical division of JVC who basically explained that it's quite simply not possible for there to be a difference between the two models.
what was the lumen output of the new JVC's you have been testing?
This member is seeing ~ 1100 lumens in high lamp
https://www.avsforum.com/forum/24-dig...l#post55140260
post #9 of 261 Old 11-17-2017, 03:37 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
JVC DLA-X9500/RS620 = 1,469 Lumens
JVC DLA-X9900/RS640 = 1,353 Lumens
Calibrated. High Lamp. Iris Wide Open.
ARROW-AV is offline
post #10 of 261 Old 11-17-2017, 03:41 PM
Quoted: 572 Post(s)
Liked: 574
Ok this is different now, I have seen people post that the JVC is 1200 in low calibrated and 1600 in high, in fact I believe when someone was asking about the Sony vs the JVC one of the comments was that the JVC is as bright in low and the Sony is in high.
kaotikr1 is offline
post #11 of 261 Old 11-17-2017, 03:43 PM
Quoted: 572 Post(s)
Liked: 574
kaotikr1 is offline
post #12 of 261 Old 11-17-2017, 03:46 PM
zombie10k's Avatar
Liked: 5785
over 20% difference from a 4th reporter.
hopefully just some bad lamps out there. folks should continue to report in as more units are delivered.
post #13 of 261 Old 11-17-2017, 03:49 PM
Javs's Avatar
Quoted: 6933 Post(s)
Liked: 6642
(1) ARROW-AV
(2) Javs
(3) Woofer?
kaotikr1 posted LUX readings in the Sony 385 thread, hes part of this thread now too ^. He is well short of where his 9900 should be OOTB.
OOTB JVC 9900.
110" Screen 14.5ft throw (This equates to 6-7% less possible peak light output vs min throw according to Coderguys awesome new PJ Calculator)
The JVC in the Natural mode was 1058 Lumens
The JVC in torch high bright mode was 1439 Lumens
By comparison, his Sony 385 at 13.5ft throw was doing 1245 Lumens.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is offline
post #14 of 261 Old 11-17-2017, 03:50 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
One thing JVC did tell me is that there are a load of generic lamps that have been and are being used with JVC projectors which produce different light output.
Said generic lamps were/are being used with the JVC projectors... NOT by JVC themselves, so JVC are NOT shipping the projectors with generic lamps, they are being fitted afterwards by people.
It could simply be this...
ARROW-AV is offline
post #15 of 261 Old 11-17-2017, 03:51 PM
Quoted: 572 Post(s)
Liked: 574
One thing JVC did tell me is that there are a load of generic lamps that have been and are being used which produce different light output.
Wait, so JVC has a batch of generic lamps going out in there hand picked RS640s?
kaotikr1 is offline
post #16 of 261 Old 11-17-2017, 03:53 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
OOTB JVC 9900.
As I mentioned ^^^ JVC have said that if someone correctly and accurately measures more than 20% lower peak luminance, with respect to a brand new X9900/RS640 unit as compared with an X9500/RS620 without any influencing factors skewing the results, then that unit is defective and should be returned for evaluation.
Dandlj likes this.
ARROW-AV is offline
post #17 of 261 Old 11-17-2017, 03:53 PM
Javs's Avatar
Liked: 6642
My X9900, absolute min throw. 120" screen area. less than 15 hours on the lamp at time of measurement.
High Bright Mode / SDR No filter / High Lamp / Iris Open - 355 LUX - 1398lm
D6500 calibrated mode - 302 LUX - 1193lm
Oh, and my 9500, with 800 hours on it...
High Bright Mode / SDR No filter / High Lamp / Iris Open - 377 LUX - 1484lm
Javs is offline
post #18 of 261 Old 11-17-2017, 03:54 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
No, I did not say that...
I said that generic lamps were/are being used with the JVC projectors...
Not by JVC themselves...
ARROW-AV is offline
post #19 of 261 Old 11-17-2017, 03:54 PM
Frohlich's Avatar
Quoted: 2061 Post(s)
Liked: 2275
Oh boy..please tell clarify ARROW-AV. That could totally be taken the wrong way as it sounds like you are saying JVC factory installed generic lamps. I know that can't be right????
Frohlich is online now
post #20 of 261 Old 11-17-2017, 03:55 PM
zombie10k's Avatar
Liked: 5785
2 generations ago this was common 1100 low / 1600+ high. My RS600 was 1700+ D65 @ mid throw with new lamp measured with a calibrated Minolta T10.
post #21 of 261 Old 11-17-2017, 03:55 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
Already beat you to it
ARROW-AV is offline
post #22 of 261 Old 11-17-2017, 03:56 PM
Quoted: 572 Post(s)
Liked: 574
Well that makes zero sense, are you implying that WE are taking brand new projectors, taking out the bulb so we can put a new generic one in just so it will report lower?
kaotikr1 is offline
post #23 of 261 Old 11-17-2017, 03:58 PM
Frohlich's Avatar
Liked: 2275
Thank you Sir. However, we are talking about a brand new model just put into people's hands in the last few weeks. These folks aren't going to be using anything but the factory lamp they received it with. I have no doubt this could be the case with previous generation models as people naturally replace their bulbs.
post #24 of 261 Old 11-17-2017, 03:59 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
No I did not say that either...
What happens when a lamp needs replacing?
ARROW-AV is offline
post #25 of 261 Old 11-17-2017, 04:01 PM
Quoted: 572 Post(s)
Liked: 574
I guess I am just confused why you would even bring up that scenario. I could see if we are talking about projectors from 2 generations ago. This thread is about low possible brightness on new just released projectors and you bring up something about generic bulbs being used and that could cause it.
While I get what you are saying, it does seem like your implying that the generic bulbs could be why the lower numbers are reporting....
kaotikr1 is offline
post #26 of 261 Old 11-17-2017, 04:02 PM
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6655
To clarify, the generic bulbs are initially BRIGHTER... However, their lifespan is much reduced.
So if someone was to have installed one into an X9500/RS620 because the lamp needed replacing and then compared this with a brand new X9900/RS640 then this would create the illusion that the X9900/RS640 is dimmer, when in fact it is not; it's because of the difference with respect to the lamp performance.
Case in point, we directly compared brand new X9900/RS640 with brand new X9500/RS620 and did not have a statistically significant difference in peak luminence performance, in that the respective measurements are within normal tolerance.
ARROW-AV is offline
post #27 of 261 Old 11-17-2017, 04:03 PM
Craig Peer's Avatar
Liked: 8466
OOTB JVC 9900.
That's not the same as moving it up to 11' and measuring it. Also, was Superwhite on ?
post #28 of 261 Old 11-17-2017, 04:50 PM
Javs's Avatar
Liked: 6642
Kaotik, did you have superwhite on mate when you took those measurements? Or was everything on Auto on the 2nd Settings screen?
superwhite will kill alot of peak output if you manually switch it on. If you didnt touch anything there it should be on Auto and thus the proper range.
I agree, I dont know why we are now suggesting users are putting generic light bulbs on zero hour JVC's.
In fact, I dont even know anyone on the forum using generic bulbs period. Certainly none who are reporting these light issues.
Javs is offline
post #29 of 261 Old 11-17-2017, 04:51 PM
Javs's Avatar
Liked: 6642
Nigel, you have said a few times now that you have installed and measured a handful of these units and calibrated them, that means you would have peak light readings on each one right? Can you share some more data?
Javs is offline
post #30 of 261 Old 11-17-2017, 04:56 PM
Craig Peer's Avatar
Liked: 8466
I think he's going to try and pull together a report over the weekend.
