Official JVC DLA-RS440 (DLA-X5900) - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 403Likes
post #601 of 928 Old 08-27-2018, 02:24 PM
Liked: 0
I am looking at purchasing the X590 to replace my existing Panasonic AE3000 on which the bulb is now dying
My issue is that we will probably be moving the next year, and expect to build a new home theater room, and am trying to minimize buying much more equipment for now.
I currently have an Onkyo TX-727 receiver, which while it has 4K pass-through only has HDMI 1.4 ports
Thus if I have read everything else correctly I could use the Monoprice HDMI switch linked below to run one output of my Oppo203 to the switch and the other to the TX-727 for sound.
In addition probably need a new HDMI cable and looking at the attached Monoprice cable
If anybody has, any thoughts on this would appreciate the feedback before I buy the projector
taxman2015 is online now
post #602 of 928 Old 08-27-2018, 04:40 PM
Philnick's Avatar
Quoted: 354 Post(s)
Liked: 174
All Oppo players, including the UDP-203 and going back at least to the BDP-93, have dual HDMI outputs precisely to deal with AVRs that cannot pass through the latest video standard. HDMI 1 has the best video processing and can be run either through a current AVR as the only cable, or directly to the display or projector, with HDMI 2 going to the AVR for sound. No switch needed.
Philnick is offline
post #603 of 928 Old 08-28-2018, 05:53 AM
Liked: 0
Thanks . The switch is needed for non HDR content that will still be going through the receiver such as TV from my cable box, X Box one (with HD DVD drive) etc
post #604 of 928 Old 08-28-2018, 10:14 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6394 Post(s)
Liked: 6393
Originally Posted by lizrussspike View Post
@enricoclaudio , I just got my RS420 calibrated, and I came from a Sony 40 ES. The Sony is a great projector, and does 1080P well, but these JVC's are awesome, even as E-shift.
Yes they are Who did you calibration? What do you think about the before and after difference?
Cleveland Plasma is offline
post #605 of 928 Old 08-28-2018, 10:33 AM
lizrussspike's Avatar
Quoted: 1105 Post(s)
Liked: 1636
Doug Weil
Clearly Resolved Image & Sound
I thought Doug did a great job. He explained what he was doing while calibrating, as much as my feeble mind could withstand. The before and after calibration reports open my eyes as well. I think that the blacks look better, contrast seems better, and maybe a tad brighter for 4K UHD viewing. I was looking up Chad B, but he was not coming this way until fall, and I had an opportunity that enabled me to have the house to myself most of the weekend. Really happy with the results. Now to maybe get a Panny UB820 and see what else I can see with the JVC.
lizrussspike is offline
post #606 of 928 Old 08-30-2018, 07:20 AM
Philnick's Avatar
Quoted: 354 Post(s)
Liked: 174
A question I posted here three days ago has gotten no response:
For the past three or so years I've had a Darbee Darblet on the path from my AVR to my Panasonic PT-AE2000 1080p projector so it can enhance all sources.
Since the Darbee can't pass 4K signals, I may have to set up two connections from the AVR to the JVC DLA-RS440 - one direct and one through the Darbee - so I can have the Darbee enhancement on 1080 and 480 signals - unless the RS440's own upscaling does a good job itself. In reading through the manual, I saw that it has what appears to be its own approach to enhancing non-4K images.
Anyone here familiar with Darbee who can chime in on how JVC's enhancement of 1080 (and below) signals compares to Darbee's?
I've been told in the Oppo 203 thread that its upscaling of sub-4K material is so good that the Darbee would go unused most of the time, but I would love to hear about how good the JVC's enhancement is, and whether it could work in tandem with a 1080 Darbee'd signal. Does anyone here have anything to contribute?
Philnick is offline
post #607 of 928 Old 08-30-2018, 09:08 AM
Quoted: 392 Post(s)
Liked: 112
Please pardon my ignorance and stupid question.
Will the vertical lens shift on a JVC X590 be able to avoid/shift the image if there is a vertical obstruction (a dropped ceiling)?
I just realized a made a very big mistake putting a dropped ceiling in my projector path hence the question?
thanks
Theater:JVC RS440, Elite 120". 7.1.4:RTi8, CSi5, FXiA4, RTiA3, 620-RT(4) & SVS PB12-NSD. Denon X4300H, UPA-700, Crown XLS1502 & XLS1000(2). Sony UBP-X800, Panasonic DP-UB424, Shield & ATV 4K. Lounge:Vizio M70-D3, Benq HT1075, & Elite 106". 7.1.4:RTi12, CSi5, RTiA1, TSx110, MC60(4), & RBH I-12. Marantz AV7702, Crown XLS1500, XLS1000(2) & Amp 100v2(2). Samsung UBD-K8500, LG BP440, Shield & ATV
shyyour is offline
post #608 of 928 Old 08-30-2018, 09:24 AM
Philnick's Avatar
Quoted: 354 Post(s)
Liked: 174
thanks
I've got a similar situation. I have a 9.5" tall support beam running across the ceiling halfway to the screen.
Shift can't avoid the obstruction, so the projector has to shoot up from under the obstruction.
My solution - still theoretical as the room is under construction - has been to draw an imaginary line from the top of my intended screen area - the ceiling line - under the front of the support beam back to the projector location, and use that point - about twice as far down from the ceiling as the bottom of the support beam - as the height limit for the top of the projector's lens. To be safe, I'll put it a little lower than that and use shift to fine-tune the image's position.
Anyone here agree or disagree with this?
Philnick is offline
post #609 of 928 Old 08-30-2018, 09:25 AM
Quoted: 4492 Post(s)
Liked: 1680
thanks
Even with lens shift, you still need a clear line of sight between the project and the screen. If you have an obstruction you may need to install the projector lower.
EDIT: Philnick beat me to it and provided a more detailed reply.
Dominic Chan is online now
post #610 of 928 Old 08-30-2018, 11:20 AM
Quoted: 392 Post(s)
Liked: 112
Thank you, my room is still under construction but my options to correct are very expensive. break the wall and go lower or remove the newly installed dropped ceiling.
i just might be able to get away with it based on @Philnick 's explanation i have about 6-7 cm unobstructed from the ceiling to the lens. Its also theoretical at this point as i wont have the projector in hand until about 3 weeks time.
thanks again guys for your help.
shyyour is offline
post #611 of 928 Old 08-30-2018, 02:01 PM
Liked: 1680
Even without the projector, you can position yourself such that your eyes are where you plan to place the projector, and confirm from that position you can see the top of the screen unobstructed by the drop ceiling.
post #612 of 928 Old 08-30-2018, 02:38 PM
Quoted: 392 Post(s)
Liked: 112
Even without the projector, you can position yourself such that your eyes are where you plan to place the projector, and confirm that from that position you can see the top of the screen unobstructed by the drop ceiling.
i plan to test that this weekend, thanks again
shyyour is offline
post #613 of 928 Old 09-10-2018, 06:30 AM
Quoted: 12 Post(s)
Liked: 0
I just got a jvc dla-590r and have a question about sources and HDR.
My first 4k source is an Apple TV 4k. When I hooked it up, the screen was blank but I was finally able to get it outputting 4k/60Hz. I could not however output 4K HDR. The ATV 4K supports Dolby Vision and HDR-10. The JVC doesn't support DV. When i tried to manually select 4k HDR, the ATV reported a cable problem. This would not be surprising as I installed the in-wall cabling 3 years ago using cables I'd bought 8 years ago for my 1080p projector. I'm happy to at least be able to make 4k work. At some point I'll have to open the walls/ceiling a bit to push new cable through but not for now...
Does the ATV 4K normally choose the best version of HDR your display can support? What about source media like Blu-Ray UHD disks? Are they either HDR-10 or DV? Is there any conversion possible between them? Also, what are the chances JVC provides a DV firmware upgrade?
thx
js91 is offline
post #614 of 928 Old 09-11-2018, 11:24 AM
Quoted: 44 Post(s)
Just ordered RS440 for 2600$. Got an amazing deal I think. Really excited to join club
sam143569 is offline
post #615 of 928 Old 09-11-2018, 04:04 PM
Quoted: 12 Post(s)
Liked: 0
Is anyone aware of a good source if I want to attempt calibrating myself? I'm projecting on a gray wall right now (it actually looks pretty good to my eyes). That said, I'm trying to convince my wife to allow me to get a screen. The projector is in the living room so its been a tough sell...
Also any tips in relation to using the x590r in conjunction with the panasonic ub820 in terms of specific settings? I read as much of this thread as I have time for right now...
js91 is offline
post #616 of 928 Old 09-12-2018, 11:20 PM
Quoted: 44 Post(s)
Anyone who has calibrated mind sharing details of settings? I understand settings vary from unit to unit n room scenarios but want to have ball park settings for dark room.
post #617 of 928 Old 09-13-2018, 01:47 PM
Quoted: 44 Post(s)
What’s typical price for calibration? Looking to get ballpark number
post #618 of 928 Old 09-13-2018, 02:46 PM
tico1970's Avatar
Quoted: 47 Post(s)
this is the only post i have seen with recommendations.
https://www.avsforum.com/forum/24-di...l#post56247778
tico1970 is offline
post #619 of 928 Old 09-13-2018, 03:41 PM
Liked: 1680
Can also take a look at this:
https://www.avsforum.com/forum/24-di...rs-thread.html
post #620 of 928 Old 09-13-2018, 05:35 PM
Jive Turkey's Avatar
Quoted: 557 Post(s)
Liked: 420
Depends....but $500 would not be out of line for an excellent job by an excellent Calibrator.
See ya. Dave
"High Fidelity audio has been like a dog chasing his tail. High Fidelity in my marriage has been much more rewarding because she knows where I sleep."
Jive Turkey is online now
post #621 of 928 Old 09-13-2018, 06:38 PM
tico1970's Avatar
Quoted: 47 Post(s)
and this too 790 settings
tico1970 is offline
post #622 of 928 Old 09-14-2018, 05:59 AM
nastyboy's Avatar
I have dedicated home theater room that I built around my DLA-RS40U which just died / not worth fixing, looking to replace with the X590BR. I assume my ceiling mount won't change. Little bit disappointed with JVC with my recently passed projector ( bulb issues ir/led board/ ballast / scaler cpu board. Is this model type solid? Any issues or concerns one should think about prior to the big buy. Thank you.
nastyboy is offline
post #623 of 928 Old 09-14-2018, 02:12 PM
Industry Insider
Liked: 6393
Yep, thats about the price.
Chad B : [email protected]
D-Nice : [email protected]
If all else fails master list :
<<< Click Here >>>
DLA-RS440U/DLA-X590R are officially discontinued, whats out there is out there........ What a great machine......
brian6751 likes this.
post #624 of 928 Old 09-15-2018, 01:38 PM
Quoted: 44 Post(s)
Does anyone know if projectorpeople are authorized jvc dealer. Their website claims it but cant find anything on JVC and called JVC told me same
post #625 of 928 Old 09-23-2018, 08:32 AM
Liked: 0
Roku and Projector
I just got a JVC RS440 recently but unfortunately I have a Pioneer VSX80 receiver that "is 4K" ready but doesn't have HDCP 2.2. I would like to stream 4K content from my Roku Stick+. I understand that I cannot get UHD content with I use the Roku with the receiver and run the signal to the projector. However, can I use the Roku stick directly with the projector and run audio down to the receiver? If this works, would I miss out on anything? I will need a new receiver if I add a Bluray player to this but was hoping to postpone that for a little longer. If I do need a new receiver - any recommendations? I have a 5.1 setup now but may want to add Atmos enabled speakers to my normal speakers. Room has 8ft ceilings, 14 feet from projector to screen but open to the hall and stairs going up.
argorius is offline
post #626 of 928 Old 09-23-2018, 08:55 AM
DavidHir's Avatar
Quoted: 2532 Post(s)
Liked: 2198
Not sure, but I would reach out to Mike Garrett of AVScience....they are definitely authorized.
DavidHir is offline
post #627 of 928 Old 09-23-2018, 09:23 AM
nastyboy's Avatar
Just got the X590BR replacing my RS40U. Wow just amazed so nice straight out of the box. Forgot how easy it was to setup / dial the picture in. Thank you powered shift, focus and zoom!
Mike Garrett likes this.
nastyboy is offline
post #628 of 928 Old 09-23-2018, 04:22 PM
Duddits's Avatar
Quoted: 14 Post(s)
I know that lensreflection is a thing with Jvc, but just how much can you accept.
ID:	2459306   Click image for larger version
ID:	2459308   Click image for larger version
Duddits is offline
post #629 of 928 Old 09-24-2018, 06:23 AM
vaskokvas's Avatar
Hi everyone,
Is there anybody using JVC 5900 (440) with apple TV 4? Is frame rate match on ATV works with JVC? Does it really switches the projector's frame rate to match the source?
vaskokvas is offline
post #630 of 928 Old 09-24-2018, 06:37 AM
Mike Garrett's Avatar
Quoted: 11815 Post(s)
Liked: 9350
The RS440 has been a pretty solid projector. I would not be worried about buying one.
Mike Garrett is online now
jvc projector , projector , projector help , projector screen advice , room correction
