Official JVC DLA-RS440 (DLA-X5900) - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 405Likes
post #631 of 940 Old 09-24-2018, 07:44 AM
Quoted: 4863 Post(s)
Liked: 1836
Originally Posted by vaskokvas View Post
Hi everyone,
Is there anybody using JVC 5900 (440) with apple TV 4? Is frame rate match on ATV works with JVC? Does it really switches the projector's frame rate to match the source?
I use an ATV4K with RS420. Frame rate match simply means the ATV doesn’t change the source frame rate; it’s not matching anything with the projector as such. The projector will sync to it, if compatible.
Dominic Chan is online now
post #632 of 940 Old 09-24-2018, 08:13 AM
Quoted: 44 Post(s)
Hi everyone,
Yes I’m using it. It does change frame rate however it takes 6-10 sec to change frame rate back and forth which is really distracting so I ended up only using Match range setting
sam143569 is offline
post #633 of 940 Old 09-24-2018, 08:39 AM
vaskokvas's Avatar
OK, :-) than the question will be - if JVC is compatible and will it sync with ATV?
vaskokvas is offline
post #634 of 940 Old 09-24-2018, 08:39 AM
Quoted: 44 Post(s)
Yes. Just curious why it is important for you? I don’t see much difference or may be I haven’t observed closely with that setting on or off
post #635 of 940 Old 09-24-2018, 08:42 AM
vaskokvas's Avatar
So it takes some time, but it really syncs frame rate with the movie from ATV.
Thanks a lot
sam143569 likes this.
post #636 of 940 Old 09-24-2018, 09:06 AM
vaskokvas's Avatar
Always considered as a rule to avoid any frame rate conversion. May be rules had changed...
post #637 of 940 Old 09-24-2018, 02:18 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6662 Post(s)
Liked: 6645
Originally Posted by nastyboy View Post
I have dedicated home theater room that I built around my DLA-RS40U which just died / not worth fixing, looking to replace with the X590BR. I assume my ceiling mount won't change. Little bit disappointed with JVC with my recently passed projector
Electronics will fail at some point no matter what the build quality, even when you first get them. Sometimes they just get retired as well, bet even these retirement units that are put on the shelf somewhere, they can not last forever either if they where continued to be used. Not much on this planet lasts forever.......
Cleveland Plasma is online now
post #638 of 940 Old 09-29-2018, 06:32 PM
Skylinestar's Avatar
Quoted: 1311 Post(s)
Liked: 268
How will the RS440 look on a diy spandex 120" 16:9 screen ? Too dim for 0.8 gain screen?
Skylinestar is offline
post #639 of 940 Old 09-29-2018, 06:39 PM
Liked: 268
Originally Posted by Duddits View Post
I know that lensreflection is a thing with Jvc, but just how much can you accept.
That looks pretty bad.
https://www.avsforum.com/forum/24-di...flections.html
post #640 of 940 Old 09-29-2018, 11:38 PM
Pyronaut's Avatar
Quoted: 89 Post(s)
Liked: 35
Does anyone know if you can replace just the bulb itself when it reaches the end of its life, rather than the whole housing?
My currently projector's manufacturer recommends replacing the whole housing since you can just pop out the old one and plug in a new one that way, but it's a big waste and more costly. I was able to just pay 1/3 the price by opening up the housing and replacing just the bulb itself.
With this projector having such a high bulb replacement cost (with the housing), anything to bring the price down would be helpful.
Pyronaut is offline
post #641 of 940 Old 09-30-2018, 01:28 AM
Liked: 1836
You can replace the bulb itself. Just make sure it’s an Ushio NSHA250JK, which is the same type used in the JVC PK-L2615U. Do not use the NSHA230JK even though some claim it’s “compatible”.
Pyronaut likes this.
post #642 of 940 Old 09-30-2018, 11:06 AM
Quoted: 299 Post(s)
Liked: 75
Hi, Dominic Chan
Is this bulb the same as the RS540? I'm looking at upgrading to either RS440 or RS540 and just was wondering if the bulbs are the same.
jsil is offline
post #643 of 940 Old 09-30-2018, 11:40 AM
Philnick's Avatar
Quoted: 393 Post(s)
Liked: 184
Are instructions for swapping in a new bulb for the old one (using the old housing) available anywhere online?
Philnick is offline
post #644 of 940 Old 09-30-2018, 11:48 AM
Liked: 1836
Originally Posted by jsil View Post
Hi, Dominic Chan
The lamp is the same for all RSx00 through RSx40 models. Even the new (NX) models use the same bulb, but in different housing.
post #645 of 940 Old 09-30-2018, 11:59 AM
Liked: 1836
I haven’t seen any YouTube videos for this particular lamp, but the process is very similar to the older lamps (PK-L2210u, PK-L2312u). I have outlined the steps here:
https://www.avsforum.com/forum/252-f...l#post55303260
post #646 of 940 Old 09-30-2018, 02:32 PM
Quoted: 299 Post(s)
Liked: 75
Thanks Dominic Chan.
jsil is offline
post #647 of 940 Old 10-02-2018, 06:03 AM
Quoted: 394 Post(s)
Liked: 113
Hi, I just got the RS440, please can some advise what resolution i should set my Nvidia shield to? it looked a bit funny when it was on default (4k @59hz) and better on 1080p but i assume i wont be able to stream any 4k material.
I also noticed that it took a while for the projector to sync; is there anything i can do to reduce the sync time?
apologies for my ignorance and thanks in advance.
Theater:JVC RS440, Elite 120". 7.1.4:RTi8, CSi5, FXiA4, RTiA3, 620-RT(4) & SVS PB12-NSD. Denon X4300H, UPA-700, Crown XLS1502 & XLS1000(2). Sony UBP-X800, Panasonic DP-UB424, Shield & ATV 4K. Lounge:Vizio M70-D3, Benq HT1075, & Elite 106". 7.1.4:RTi12, CSi5, RTiA1, TSx110, MC60(4), & RBH I-12. Marantz AV7702, Crown XLS1500, XLS1000(2) & Amp 100v2(2). Samsung UBD-K8500, LG BP440, Shield & ATV
shyyour is offline
post #648 of 940 Old 10-04-2018, 10:40 AM
Daniel Chaves's Avatar
Quoted: 620 Post(s)
Liked: 487
the DLA-RS440U and the DLA-RS540U are around the same price point but when i search for reviews on the 540, I dont come up with any? specs wise the 540U looks to be a better projector but I can find the 440U used for a good price so what are peoples thoughts on this? has anyone come across a comparison review between the two?
Projector: BenQ w1500 + ES Sable 135" 16:9 Screen AVR: Marantz SR6011 ATMOS/DTSX + Unity 2ch Amp + Darbee 5000s Speakers: Polk Audio TSX550t (FL/FR), CS2 Series II (C), FXiA6 (SL/SR), Monitor40 Series II (RL/RR), TSx110B (Ceiling FL/FR RL/RR) LFE: (2) JL Audio 12" Subs + (2) Dayton 15" Subs + (2) ButtKicker LFE Arrangement: 7.1.4 Source: OPPO UDP-203 4k Bluray Player, Roku 4, HTPC, 2017 nVidia Shield, Hauppauge OTA DVR
Daniel Chaves is offline
post #649 of 940 Old 10-04-2018, 11:36 AM
Liked: 1836
Those two projectors are also known as the DLA-x590 and x790 respectively.
https://www.soundandvision.com/conte...ojector-review
The differences between them have remained the same for the last 3 generations (x550 vs x750, x570 vs x770 etc).
Daniel Chaves likes this.
post #650 of 940 Old 10-04-2018, 01:22 PM
Quoted: 620 Post(s)
Liked: 487
Thank you.
post #651 of 940 Old 10-12-2018, 07:48 AM
NoThru22's Avatar
Quoted: 379 Post(s)
Liked: 169
I am on JVCs site to check for a firmware update on the 440U and it's not even listed. Where can I check?
Your mom is a classy lady!
Tom's Book Blog
PSN: Macello / Xbox: Macello
NoThru22 is offline
post #652 of 940 Old 10-12-2018, 09:53 AM
ed3120's Avatar
Quoted: 203 Post(s)
Liked: 24
I searched the other day too and also couldn’t find it.
ed3120 is offline
post #653 of 940 Old 10-12-2018, 09:52 PM
golden78's Avatar
Quoted: 406 Post(s)
Liked: 134
Any current owners of the rs440 had a sony hw45es prior ? I'm trying to decide if it's enough of picture upgrade to be worth the money
golden78 is offline
post #654 of 940 Old 10-12-2018, 09:59 PM
markmon1's Avatar
Quoted: 5216 Post(s)
Liked: 3388
The sony motion will be a little better. The JVC will be sharper, handle 4K content, and have far better blacks. The sony iris doesn't do as much to help either. But the artifacts from JVC's iris is more noticeable. The 45es and 440 have same lumen ratings, but the JVC will be about 300 lumens brighter on low lamp than the sony due to the way that JVC and Sony run their low lamp bulbs. I consider the 440 a sizeable upgrade over a 45es.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #655 of 940 Old 10-12-2018, 10:05 PM
golden78's Avatar
Quoted: 406 Post(s)
Liked: 134
what kind of artifacts and is it very noticeable and happen alot and/ or only noticeable in very dark scenes
golden78 is offline
post #656 of 940 Old 10-12-2018, 10:08 PM
golden78's Avatar
Quoted: 406 Post(s)
Liked: 134
I'm debating on waiting saving for a rs540 although I have no idea the difference between the 540 and 440 I assume mainly black levels is difference and little wider color gamut. Not sure if that's worth it as i have an opportunity get a 440 for around 2k
golden78 is offline
post #657 of 940 Old 10-12-2018, 10:10 PM
markmon1's Avatar
Liked: 3388
There can be scenes where you see the iris clamp down a level when it doesn't really need to. It doesn't happen very often. The contrast on the RS440 is still a lot better than the Sony though, and because it's brighter on low lamp, you could clamp the iris down to say -8 and disable the dynamic iris entirely and probably be close to brightness matched to the sony on low lamp and still have better blacks than the sony.
markmon1 is offline
post #658 of 940 Old 10-13-2018, 05:48 AM
brian6751's Avatar
Quoted: 1705 Post(s)
Liked: 1701
I used to have a 45es. The Sony is a great 1080p projector but the 440 is absolutely worth the extra cost if its within your budget. Its brighter, much better contrast, 4k resolution and it can actually do HDR. Call Mike at AV Science and see what deals he has. @Mike Garrett
FOR SALE:
Lots of stuff. Check the Audio Gear Classifieds
brian6751 is online now
post #659 of 940 Old 10-13-2018, 05:50 AM
markmon1's Avatar
Liked: 3388
The RS500 here on AVS for sale for $2250 is going to perform better than the new RS440 in my opinion.
markmon1 is offline
post #660 of 940 Old 10-13-2018, 06:17 AM
Liked: 1836
The RS500 will perform better than the RS440, but is harder to set up for HDR as it will constantly switch to the built-in Gamma D when detecting HDR.
You will need an HD Fury Linker or similar, to disable the HDR metadata.
jvc projector , projector , projector help , projector screen advice , room correction
