Additional SDR Gamma Curves for Sony Projectors - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By OMARDRIS
post #1 of 10 Old 12-07-2017, 02:16 AM - Thread Starter
OMARDRIS's Avatar
Quoted: 76 Post(s)
Liked: 128
Hello @All ,
the selection of SDR gamma curves on the Sony projectors is very modest just around the Gamma 2.2. In addition, sometimes the Sonys have to fight with a light Gammadrift.
Since not everyone wants to do manual gamma curves with Projector Calibration Pro or the ImageDirector, I'll just make some curves available, which might help in some cases.
The "Custom SDR Forums Edition" includes 6 new gamma presets and complements the standard gamma curves (1.8 / 2.0 / 2.1 / 2.2 / 2.4 / 2.6) of Sony projectors to case by case to choose a better fitting gamma curve. Especially in connection with a slight gamma drift, it may be useful to use a modified gamma curve. In this case, it makes sense to measure the grayscale before using a correction curve.
But even without Gammadrift it may be that, for example, gamma 2.30 likes better than 2.20 or 2.40.
The package contains the following gamma curves, each in the file format for the Sony ImageDirector:
SDR Gamma 2.25
SDR Gamma 2.30
SDR Gamma 2.35
SDR Gamma 2.45
SDR Gamma 2.50
SDR Gamma 2.55
The curves were calculated with an application by me to create gamma curves in 10-bit resolution.
Here is the link to the package and instructions:
https://www.magentacloud.de/lnk/wNvPN4qZ
In the bottom line of the mask you can switch from German to English language.
Please click on the arrow under the word "Herunterladen/ Download" in the mask.
Maybe one or the other can use something like that.
Peter
BakeApples and WildBoar like this.
S/W: LightSpace CMS, Calman 5, HCFR, Colorfacts
V/P: Lumagen Radiance Pro, DVDO AVlab TPG
Meters: JETI Spectraval 1501, Klein K-10A, I1Pro2, I1D3
OMARDRIS is offline
post #2 of 10 Old 12-07-2017, 03:25 AM
rwestley's Avatar
Quoted: 459 Post(s)
Liked: 297
Thanks for the hard work. It will be really appreciated. Wondering if there is any plan to do curves for 3D?
rwestley is offline
post #3 of 10 Old 12-07-2017, 06:40 AM
jqmn's Avatar
Quoted: 428 Post(s)
Liked: 155
Originally Posted by OMARDRIS View Post
Hello @All ,
Peter
Peter, thanks for making this available. Do you know whether Calibration Pro can read Image Director Files? If not, is there an issue with uploading one of these files and then pulling it down in Calibration Pro? Thanks.
jqmn is offline
post #4 of 10 Old 12-07-2017, 10:21 AM - Thread Starter
OMARDRIS's Avatar
Quoted: 76 Post(s)
Liked: 128
Hi,
Calibration Pro can not process files from ImageDirector.
Calibration Pro has only 64 points for the gamma curve. The ImageDirector has 1024, so it's much more accurate.
You can see clearly in the ImageDirector when a curve has been loaded by Calibration Pro. This is then edged. That's why I use the ImageDirector, even though it's the older program.
Peter
OMARDRIS is offline
post #5 of 10 Old 12-07-2017, 10:51 AM
jqmn's Avatar
Quoted: 428 Post(s)
Liked: 155
Thanks for this info. I had been using Calibration Pro so I will take a look at ID. I have both but for some reason used CP out of the chute (maybe because all the other tools in CP are so easy to use).
jqmn is offline
post #6 of 10 Old 12-07-2017, 08:27 PM
tangcoma's Avatar
Quoted: 65 Post(s)
Liked: 33
Yup , a additional gamma curves for 3D is appreciated! Thx
tangcoma is offline
post #7 of 10 Old 12-09-2017, 01:15 PM
Quoted: 21 Post(s)
Liked: 3
But are they good to test with the hw55es?
lucama is offline
post #8 of 10 Old 12-09-2017, 01:20 PM
TheBrandon's Avatar
Quoted: 555 Post(s)
Liked: 220
Hello @All ,
SDR Gamma 2.25
SDR Gamma 2.30
SDR Gamma 2.35
SDR Gamma 2.45
SDR Gamma 2.50
SDR Gamma 2.55
Peter
Is it possible to use a custom gamma curve for the Game Mode? Mainly I would like something like Gamma 10 brightness I am seeing for user but to automatically turn on or off depending on HDR signal on Game Mode.
TheBrandon is offline
post #9 of 10 Old 09-12-2019, 01:08 AM
tangcoma's Avatar
Quoted: 65 Post(s)
Liked: 33
Can u share the Projector Calibration Pro Software to me ? Really appreciated if u can do the help !
tangcoma is offline
post #10 of 10 Old 09-12-2019, 06:07 AM
rwestley's Avatar
Quoted: 459 Post(s)
Liked: 297
The original versions of the curves had additional settings that had to be set first per instructions.
Should one use those same settings with these curves?
rwestley is offline
