Improving Madvr HDR to SDR mapping for projector - Page 156 - AVS Forum | Home Theater Discussions And Reviews
 7359Likes
post #4651 of 7922 Old 12-27-2018, 10:26 AM
Quoted: 29 Post(s)
I also get incomplete files always since beta32.
tried with this beta37 with "The Predator2018", got an incomplete file also.
Do we have to rename the incomplete files in order to madvr use them? I don't manage to get them used with this last beta.
What application do you use to open them in order to insert the target nits?
Regards!
Axelpowa is offline
post #4652 of 7922 Old 12-27-2018, 10:33 AM
Sittler27's Avatar
Quoted: 1355 Post(s)
Liked: 122
Originally Posted by Dexter Kane View Post
Basically if the target nits is too low then there isn't enough contrast in the highlights which gives you a flat and bright image, you'll also lose too much highlight detail because of the compression. If the target nits is too high then the normal 0-100 nits range of the movie will appear too dim. So you're looking for a balance between having the movie bright enough while giving you enough contrast to get that HDR pop. I'd start at your measured nits and work up, try a bunch of different movies with a range of brightness until you find something that works well with all movies.
This is really great advice and well worded on what to look for. I've settled on a setting of 240 or now.
I see in here lots of reference to madmeasure app and I think that most madvr users are creating profiles per type of movie format (1080p, 4K, etc.).
Are there instructions for how to best approach this from where I am right now (i.e. set target nits to 240 and used initial settings provided by markmon1 to approach Sony processing on a JVC projector)?
Sittler27 is offline
post #4653 of 7922 Old 12-27-2018, 10:44 AM
Neo-XP's Avatar
Quoted: 860 Post(s)
Liked: 1188
Originally Posted by madshi View Post
JFMI, how exactly is "avg avg highlights" defined?
Soulnight will explain this better
18) Black bars are now excluded from Avg/MaxFALL measurements
Nice! Are they also excluded from the luminance change calculation (to make the scene detection more reliable)?
Neo-XP is offline
post #4654 of 7922 Old 12-27-2018, 11:05 AM
madshi's Avatar
Quoted: 2744 Post(s)
Liked: 3846
Originally Posted by Manni01 View Post
Regarding our discussion re the MakeMKV bug, have you found a way to implement Mike's suggestion to use the video track duration vs the file duration in order to avoid the error with some MKV files when the audio track is longer? Apart from this, it seems to be ready for release, unless our tests reveal some kind of bugs.
I don't have access to that kind of information, only nevcairiel has.
Looking at the measurements file, thanks again for adding a few metadata fields. Any chance to add the complete metadata, including gamut coordinates and white point?
Why didn't you ask for this right away, instead of asking for the black level first, and then this now? Changing this kind of stuff multiple times costs me much more time than changing it once.
Originally Posted by FidelioX View Post
I've tried 3 times to create the measurament file of my MKV file of Pacific Rim UHD HDR.
Every time I get incomplete.
The process arrives at 100% but the final file is incomplete.
Did you run this with the original m2ts files from the Blu-Ray, or using a remuxed MKV? MakeMKV is known to have a bug which can cause this problem.
No, not at this point.
Sorry guys, found a couple small bugs, one of which affected measurements once more.
So please trash all the measurements you made with build 37 once more, and re-measure with this new test build:
http://madshi.net/madVRhdrMeasure38.zip
SamuriHL, Mevlock, AmigoHD and 7 others like this.
madshi is offline
post #4655 of 7922 Old 12-27-2018, 11:39 AM
Manni01's Avatar
Quoted: 5618 Post(s)
Liked: 5922
OK, I thought LAV could pass it over to MadVR. Maybe worth asking Nev, to reduce MadVR support posts re failing measurements with some files? I have converted the problem files with another tool, they are processed correctly now, so not an issue for me, I know what to do if I get the issue now.
I did ask for as much metadata as possible :
No, I mean the first line that says "metadata", the one where you report the disc metadata. These have nothing to do with your calculations/measurements (2nd line), so you could always output the disc/content metadata and only output the "measurements" line if/when the measurements are complete, and still display the same warning when they aren't. Does that make sense?
It's just very handy when doing tests to have the metadata quickly available in the log wherever each file is, and the more metadata, the better (especially MinMDL would be useful). Not critical of course
I guess I should have been more specific about gamut and white point, as there were the only two metadata points not mentioned. Don't worry if it takes too much time to add it, I didn't realise it was so time-consuming.
It's just that since these earlier posts six weeks ago, quite a few BT2020 titles have been released, so it's become more relevant. Still not critical.
Will remeasure with the new build.
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
JVC Macro feature on Vertex/Vertex2/Integral2/Maestro
Manni01 is offline
post #4656 of 7922 Old 12-27-2018, 02:05 PM
Quoted: 71 Post(s)
"So please trash all the measurements you made with build 37 once more, and re-measure with this new test build:"
Do we have to delete the measurement file or is it enough to just remeasure and let the original measurement file be overwritten by the new measurement?
I understand that "HtpcControl.exe" do overwrite but if I only want to use "madMeasureHDR.exe" do i have to delete the original measurement file first?
The word "trash" in Madshi post got me wondering?
arcspin is offline
post #4657 of 7922 Old 12-27-2018, 02:48 PM
Quoted: 71 Post(s)
Originally Posted by BerndFfm View Post
Hi,
I'm trying out the latest htpccontrol.exe and the program is kind of stuck and just idle after measuring the first UHD HDR movie.
I have updated Madvr to the latest version38 and the "madMeasureHDR.exe" works just fine.
The program finds 33 movie files in my directory and starts measuring the first file to the end without any problem.
But after that nothing more happens, the program does not continue to the next movie file.
Anyone else having this problem and what am I doing wrong here?
//Peter
arcspin is offline
post #4658 of 7922 Old 12-27-2018, 09:09 PM
JBauer0024's Avatar
Not a question on projectors, but the same issue I imagine...
Can someone point me to a bit of a primer on this subject? 156 pages is a bit much to digest to find my answer. Point me in the right direction?
HDR content on a non-HDR 10-bit UHD monitor. Very dark blacks on some movies.
I'd appreciate any nudges I can get... Been doing searching, and well - it's complicated
Thanks...
JBauer0024 is offline
post #4659 of 7922 Old 12-27-2018, 11:45 PM
Quoted: 45 Post(s)
Liked: 67
Quick Update of MadMeasurementAnalyzer tool.
For someone who may still need this simple tool : madMeasurementAnalyzer, ability to read version 4-6 measurement files.
It also includes a simple tool that automatically measures the UHD directories and creates hard links to the measurement files : madMeasurementMakeHardLink.
Hints of madMeasurementMakeHardLink:
1. create madMeasurement files for UHD Driver. (each directory contains a single UHD movie). The UHD Driver can be local or network mapped driver.
2. If madMeasureHDR is running > 45 minutes. consider madMeasureHDR hangs, automatically terminate it , and create a .failure file(skip this directory on the next run), then proceeds to the next directory.
3. Skip the multi-segments(the size of main stream < total size / 2), created(madmeasurement file existed), and previous failure(.failure file existed) UHD movies.
4. create hard links (index.bdmv.measurements and .mpls.measurements) for madmeasurement files. (Does not consume extra disk space). Kodi DSPlayer uses index.bdmv as main file on playing UHD directory. MPC-BE uses ?????.mpls as main file on playing UHD directory.
5. Because the hard link cannot be created for network files, the UHD driver only lists the local drivers.
6. You need to manually select the main playlist file for the new UHD movie.
7. Recreate the hard links after you apply SoulNight's madMeasureDynamicClipping.
ID:	2501682   Click image for larger version
ID:	2501684   Click image for larger version
pandm1967 is offline
post #4660 of 7922 Old 12-28-2018, 03:36 AM
BerndFfm's Avatar
Quoted: 94 Post(s)
Liked: 104
Sorry Peter, I think I used too much memory for scanning the directories.
Update : http://download.seven-c.de/files/madvr/htpccontrol.zip
- Much faster and much less memory use when measuring HDR files.
- The program maybe hangs up, I hope that is fixed.
- The files with the extensions .9900, .9950 etc. are deleted, they are no longer needed.
Bernd
arcspin likes this.
Home Cinema with : Onkyo 1009, Nubert, JVC RS-500, madVR
BerndFfm is offline
post #4661 of 7922 Old 12-28-2018, 05:52 AM
chros73's Avatar
Quoted: 360 Post(s)
Liked: 171
Thank You for the quick update, I use it frequently!
Ryzen 5 2600,Asus Prime b450-Plus,16GB,MSI GTX 1060 Gaming X 6GB(v385.28),Win10 LTSB 1607,MPC-BEx64+LAV+MadVR,Yamaha RX-A870,LG OLED65B8(04.10.25+PC4:4:[email protected]/24/25/29/30/50/59/60Hz)
chros73 is offline
post #4662 of 7922 Old 12-28-2018, 06:14 AM
Ian_Currie's Avatar
Quoted: 325 Post(s)
Liked: 99
Can someone briefly explain the purpose of measuring our MKV files when madVR does it live? I've tried the measurement on one file and can see any difference in performance (visually or rendering time).
JVC-RS4500 4k projector, Lumagen Pro, 138" 2.35:1 ST130
Panasonic DMP-UB820 & i7 PC w/1080ti running Win10/Kodi DSPlayer/madVR
Classe SSP-800, Bryston amplification, Wilson Audio speakers (7.2) + Buttkickers.
Ian_Currie is offline
post #4663 of 7922 Old 12-28-2018, 10:01 AM
VerGreeneyes's Avatar
Quoted: 21 Post(s)
Simply put, the live version can't see into the future, so if a scene change happens it can't know what the average lighting for that scene will be. It can still adjust to changes pretty quickly so most of the time the difference won't be very noticeable, but some changes are so sudden and erratic that there will be a noticeable adjustment period.
BlueChris likes this.
VerGreeneyes is offline
post #4664 of 7922 Old 12-28-2018, 10:15 AM
Ian_Currie's Avatar
Quoted: 325 Post(s)
Liked: 99
Perfect explanation, thank you!
post #4665 of 7922 Old 12-28-2018, 02:41 PM
BerndFfm's Avatar
Quoted: 94 Post(s)
Liked: 104
Every time I get incomplete. The process arrives at 100% but the final file is incomplete.
I measured Pacific Rim and Pacific Rim 2 from mkv (makemkv) with the newest build. Worked well.
Bernd
PS.: For a new HTPC a 1080TI or a 2080 is better ?
BerndFfm is offline
post #4666 of 7922 Old 12-28-2018, 03:05 PM
Manni01's Avatar
Liked: 5922
They have about the same performance as of now but Madshi recommends buying RTX (so 2080 in your case) rather than GTX (1080ti) for new builds.
The tensor cores in the new RTX models might be put to good use in MadVR in the future (my words, not his).
By the way Bernd, have you checked that you have allowed MakeMKV to update its system files in MakeMKV's configuration (View/Preferences/General/Allowing Contacting Web Server for Updates)? I can't understand why you don't get updates and still have to update files manually.
Manni01 is offline
post #4667 of 7922 Old 12-28-2018, 03:09 PM
Quoted: 71 Post(s)
Bernd
Hi,
I'm sorry to inform you that I have had no luck with this update.
The first .mkv is scanned without any problem and with the summery information showing up last.
Nothing more happens and the GPU returns to basically zero again.
arcspin is offline
post #4668 of 7922 Old 12-28-2018, 06:11 PM
Neo-XP's Avatar
Quoted: 860 Post(s)
Liked: 1188
@madshi Bright halos are clearly visible here with the last build (everything under "trade quality..." unchecked):
madVRhdrMeasure36 (300-0.010-3) / madVRhdrMeasure38
Samsung Wonderland Two HDR UHD 4K Demo - Frame 1127
The "repair repair blur strength" is probably too low.
300-0.010-disabled / 300-0.010-noblur / 300-0.010-2 / 300-0.010-3 / 300-0.010-5 / 300-0.010-7 / 300-0.010-10
I would suggest 3 as the absolute minimum (and my preferred value), but maybe 5 if you want to be "safe".
Edit:
I had to double-check this one to be sure, but it also looks worse on the last build (all "trade quality..." settings disabled):
BvS - Frame 213230
Neo-XP is offline
post #4669 of 7922 Old 12-29-2018, 02:06 AM
Manni01's Avatar
Liked: 5922
I've updated my algo(link in my sig) following the new measurements. Here is the explanation:
[EDIT 29-12-18: from test build 38, the black bars are not taken into account anymore. I have updated my algo and for now I've decided to experiment with something very close to @Dexter Kane 's values, apart from a few tuned thresholds. The profiles are often higher than with my older algo as his curve for AVGFMLL is less linear than mine, but it might be a good thing so I'm going to try and see how it is. As I'm going to get close to 140nits in low lamp with my new PJ, I might be happy with this. I'm going to set my lamp to high with the rs500 to get 145nits and see what I like and don't like. Unless I'm very unhappy with a few selections, I'm unlikely to finetune this until I get my new PJ anyway. For now I've taken out all the exceptions/special cases. I haven't had the time to update the list of films attached below, I'll do this when I find the time].
Dexter, thanks for the starting point. I think we had arrived at something very similar, the main difference being the black bars. I thought it would make sense to start with your values now that we have the same measurements as the black bars are not taken into account anymore. I slightly changed a few thresholds to catch a few exceptions, but it's mostly your last values, as linked in the post describing my algo. Let us know if you've changed it since. I plan to watch my usual test files over the next few days (I haven't done any visual testing yet). Can you remind me what your actual peak brightness is?
Manni01 is offline
post #4670 of 7922 Old 12-29-2018, 03:16 AM
Quoted: 111 Post(s)
Liked: 98
The last one I posted is quite different to what I'm currently using, the avgFMLL values that I'm currently using are completely linear, so if avgFMLL < 300 activate 300 nits profile and so on. I've also changed the avgFALL curve but that seems like it's a lot more to do with taste or at least based on the measured brightness of the display.
Here are my current rules, my measured brightness was 212nits, I've added rules up to 800nits because I found a couple of very bright titles (The Meg and Lego Batman) but obviously just end it at whatever maximum and minimum you want.
if (hdrVideoPeak <= 210) "200nits"
else if (hdrVideoPeak <=220) "212nits"
else if (AvgFMLL = 0) "250nits"
else if (AvgFALL <= 6) "200nits"
else if (AvgFMLL <= 100) "200nits"
else if (AvgFALL <= 9) "212nits"
else if (AvgFALL <= 11) "225nits"
else if (AvgFMLL <= 225) "225nits"
else if (avgFall <= 12) "250nits"
else if (AvgFMLL <= 250) "250nits"
else if (AvgFall <= 14) "275nits"
else if (AvgFMLL <= 275) "275nits"
else if (AvgFALL <= 16) "300nits"
else if (AvgFMLL <= 300) "300nits"
else if (AvgFALL <= 18) "325nits"
else if (AvgFMLL <= 325) "325nits"
else if (AvgFALL <= 22) "350nits"
else if (AvgFMLL <= 350) "350nits"
else if (AvgFALL <= 26) "375nits"
else if (AvgFMLL <= 375) "375nits"
else if (AvgFALL <= 30) "400nits"
else if (AvgFMLL <= 400) "400nits"
else if (AvgFALL <= 34) "425nits"
else if (AvgFMLL <= 425) "425nits"
else if (AvgFALL <= 38) "450nits"
else if (AvgFMLL <= 450) "450nits"
else if (AvgFALL <= 42) "475nits"
else if (AvgFMLL <= 475) "475nits"
else if (AvgFALL <= 48) "500nits"
else if (AvgFMLL <= 500) "500nits"
else if (AvgFALL <= 54) "525nits"
else if (AvgFMLL <= 525) "525nits"
else if (AvgFALL <= 62) "550nits"
else if (AvgFMLL <= 550) "550nits"
else if (AvgFALL <= 72) "575nits"
else if (AvgFMLL <= 575) "575nits"
else if (AvgFALL <= 82) "600nits"
else if (AvgFMLL <= 600) "600nits"
else if (AvgFALL <= 92) "625nits"
else if (AvgFMLL <= 625) "625nits"
else if (AvgFALL <= 102) "650nits"
else if (AvgFMLL <= 650) "650nits"
else if (AvgFALL <= 112) "675nits"
else if (AvgFMLL <= 675) "675nits"
else if (AvgFALL <= 122) "700nits"
else if (AvgFMLL <= 700) "700nits"
else if (AvgFALL <= 132) "725nits"
else if (AvgFMLL <= 725) "725nits"
else if (AvgFALL <= 142) "750nits"
else if (AvgFMLL <= 750) "750nits"
else if (AvgFALL <= 152) "775nits"
else if (AvgFMLL <= 775) "775nits"
else if (AvgFMLL > 775) "800nits"
Manni01 likes this.
Dexter Kane is offline
post #4671 of 7922 Old 12-29-2018, 03:30 AM
Manni01's Avatar
Liked: 5922
Thanks, it makes sense for 212nits peak brightness. That won't work for me at 100nits or even 145nits but I'll link to it in my post for users with 200nits or more. It might work if I switch to high lamp on my new PJ but I'm reluctant to do this (fan noise, heat, power use).
Sure profiles are hopefully going to be obsolete soon for HDR, but until a revised utility offers an algo I'm happy with to populate the new target nits field, I'm not going to stop watching films, so I needed something to deal with the new build measurements, because my old algo wasn't going to work, unlike yours as you've never taken the black bars into account thanks to your cropping...
I'm unlikely to spend much time on this until I get my new PJ hopefully in January and @Soulnight gives us an updated tool. Then we'll see...
Dexter Kane likes this.
Manni01 is offline
post #4672 of 7922 Old 12-29-2018, 04:35 AM
Manni01's Avatar
Liked: 5922
@madshi
I've posted the measurements for my HDR example titles in my algo post (link in sig).
I've left the previous measurements, so we can compare the measurements taken with black bars (older builds) and without (latest build).
As expected, MaxFALL, AvgFALL and AvgFMLL values go up as the aspect ratio gets wider.
It looks like you might have slightly changed the calculations for MaxCLL, as it usually goes up but occasionally goes down.
I haven't spotted anything weird, but I thought the data might be useful if you (and others) wanted to check for these 25 titles or so.
I'm hoping to be able to do some watching over the next few days...
Manni01 is offline
post #4673 of 7922 Old 12-29-2018, 04:39 AM
hasta666's Avatar
Quoted: 515 Post(s)
Liked: 182
I have the feeling that Htpc is remeasuring files that were already measured with the latest madVR build. How can I check what version of MadVR was used on a particular file? There is no information in the txt file and measurement files cannot be opened with Notepad++. Or should I change the encoding in Notepad++?
hasta666 is online now
post #4674 of 7922 Old 12-29-2018, 04:49 AM
Manni01's Avatar
Liked: 5922
Use @pandm1967 's updated tool linked above (simply drop the measurement file on the program window). In the upper left corner, it displays the file version. Latest one is 6, so a V6 file shouldn't be remeasured, but a V5 will (that's the difference between build 37 and build 38).
Manni01 is offline
post #4675 of 7922 Old 12-29-2018, 05:17 AM
the_jaguar's Avatar
Quoted: 166 Post(s)
Liked: 52
Thanks much for this tool. Pardon my ignorance, but I want to confirm if this tool will work for me - I have BDMV folders ripped from my UHD's and stored on my NAS. Will I be able to use this tool to create measurement files that can be used by madvr later while playback?
I would hate to convert all these files to MKV's...
the_jaguar is offline
post #4676 of 7922 Old 12-29-2018, 05:39 AM
chros73's Avatar
Quoted: 360 Post(s)
Liked: 171
These files are binary files, you can't open them in a text editor but in a hex editor. But just use pandm's tool as @Manni suggested.
I noticed that it also read the Target field, but we can't set it (as MaxCLL). Can you also add this to it?
@Soulnight ,Anna: I tried to open a v6 file in v2.4 but it says that the histogram columns are wrong. Can you update your tool to be compatible with v6? (No further improvements are needed for now.) Thanks
chros73 is offline
post #4677 of 7922 Old 12-29-2018, 06:00 AM - Thread Starter
Soulnight's Avatar
Quoted: 1110 Post(s)
Liked: 1797
@chros73 @Manni01
New version of our tool coming today with a few new updates/features ;-)
CoryW, SamuriHL, Mevlock and 9 others like this.
Soulnight is offline
post #4678 of 7922 Old 12-29-2018, 06:30 AM
Quoted: 45 Post(s)
Liked: 67
Yes,This is what I did. I use "Run Measure" of madMeasurementMakeHardLink to measure the main stream of UHDs, because Kodi DSPlayer use index.bdmv and MPC use ?????.mpls as main media file, so I use "Make Hard Link" to create hard links of these measurement files.
Yes, the target nits field can be edited, just input your desire value, the field turns yellow, and the Save button is visible.
post #4679 of 7922 Old 12-29-2018, 06:50 AM
hasta666's Avatar
Quoted: 515 Post(s)
Liked: 182
It actually does remeasure v6 files. Don’t know what’s wrong on my side. The detection feature might be broken. I’m not gonna worry to much at this point though, I’m expecting some v7 to appear at some point ;-)
post #4680 of 7922 Old 12-29-2018, 07:22 AM
BerndFfm's Avatar
Quoted: 94 Post(s)
Liked: 104
Hi, I'm sorry to inform you that I have had no luck with this update.
Sorry for this. Here its working, I will test it again.
Manni : Now my makemkv loads the newest keys automatically. Thanks for the information.
Bernd
Manni01 likes this.
BerndFfm is offline
dynamic tone mapping , hdr , madvr , sdr , ton mapping
