Improving Madvr HDR to SDR mapping for projector - Page 208 - AVS Forum | Home Theater Discussions And Reviews
 4926Likes
post #6211 of 6249 Old 09-10-2019, 05:11 AM
Icaro's Avatar
Quoted: 109 Post(s)
Liked: 41
Could someone post the settings with the new build for projectors with 50/60 Nits?
I continue to have the best compromise with the penultimate build (the 86), the 87 remains too dark or with high lights shot.
Thank you
Sorry for my bad English
Epson LS10500 - AMD RX580 - LightSpace CMS
Icaro is online now
post #6212 of 6249 Old 09-10-2019, 06:44 AM
Quoted: 250 Post(s)
Liked: 84
Thank you
Haven't tried v.87, but what settings are you using with v.86?
noob00224 is online now
post #6213 of 6249 Old 09-12-2019, 06:54 AM
Icaro's Avatar
Quoted: 109 Post(s)
Liked: 41
I've always used Neo-XP settings (Thank you so much Neo ),
but now with build 87, I made a mix between the settings of builds 86 and 87 used by Neo-XP,
with the 87 in fact I don't use the "FALL Knee algo" (I think Neo-XP uses it on a brighter TV), with the projector with only 61 nits, the image is too dark,
instead with these settings and build 87, I am fine with both the projector and the old TV with only 74 nits
noob00224 likes this.
Icaro is online now
post #6214 of 6249 Old 09-12-2019, 10:11 AM
Neo-XP's Avatar
Quoted: 594 Post(s)
Liked: 715
@Icaro
I still use the settings you posted for watching new HDR titles. The only difference is my real display peak nits of course.
Oddly, the Red Sparrow scene at 00:26:46 is not producing any visible brightness adaptation anymore with these brightness speeds (even at 50 real nits and 100 dynamic tuning), madshi must have fixed something without telling us (or without being aware of it ).
Neo-XP is offline
post #6215 of 6249 Old 09-12-2019, 10:35 AM
Icaro's Avatar
Quoted: 109 Post(s)
Liked: 41
@Neo-XP
Sorry Neo,
but I had seen that in your only settings post of build 87, you used the "Fall Knee algo" with 75 dynamic tuning and 0 recovery strength
I thought they were your current settings
Originally Posted by Neo-XP View Post
For now, I find the targets with the alternative FALL Knee algo better (more "ideal" per scene) than with the default FALL algo.
With low FALL they stay low (not producing a too dark image), but with high FALL the targets are much higher (more balanced image, less compression in highlights, without being too dark).
Obviously, this can cause even more brightness difference between two scenes of the same "chapter", it is yet another compromise to make...
The "FALL threshold" option is only harmful for me.
Icaro is online now
post #6216 of 6249 Old 09-18-2019, 10:07 AM
Quoted: 69 Post(s)
Liked: 45
Has anyone else noticed this issue in build 87? In my setup, the colors are off in build 87, this particular scene is very red in build 87, I’m not sure if the phone captures the image very well, but on the screen this scene doesn’t look right, the first image is build 86 and the second image is build 87. There are no other changes in the settings and I can switch between the builds with consistent results.
ID:	2617208   Click image for larger version
azkino is offline
post #6217 of 6249 Old 09-18-2019, 10:39 AM - Thread Starter
Soulnight's Avatar
Quoted: 1001 Post(s)
Liked: 1509
I can confirm that this Blade Runner 2049 scene is rended much more saturated with build 87 that it used to be with the older build 78 I was still using.
I was using mapping to DCI-P3 for the comparison if it matters.
Since I love saturation, I will not complain... but would be good to know which one is correct.
Soulnight is online now
post #6218 of 6249 Old 09-18-2019, 10:43 AM
Neo-XP's Avatar
Quoted: 594 Post(s)
Liked: 715
@azkino
The only difference I see by switching between build 86 and 87 is the OSD showing "movie" on build 86 and "video" on build 87:
Build 86 / Build 87
What settings are you using, especially for color gamut? Do you see any difference on the OSD between the two builds?
Neo-XP is offline
post #6219 of 6249 Old 09-18-2019, 10:50 AM
Neo-XP's Avatar
Quoted: 594 Post(s)
Liked: 715
I think I have found the issue: the "this display is already calibrated" option is broken on build 87.
There is no difference for me between all color gamut.
SamuriHL and Manni01 like this.
Neo-XP is offline
post #6220 of 6249 Old 09-18-2019, 10:51 AM - Thread Starter
Soulnight's Avatar
Liked: 1509
Well actually, I think I found the issue. No matter what you select in colorspace, the new build always give the same results.
I guess it's akways tone mapping to REC709 in the new build.
So people who used to tone map to 709 will see zero difference.
People who used to tone map to dci-p3 will see everything slightly oversaturated. And the one who tone mapped to rec2020 will see it massively oversaturated.
@madshi could it be? :-)
Manni01 and wombats like this.
post #6221 of 6249 Old 09-18-2019, 11:59 AM
Quoted: 69 Post(s)
Liked: 45
Yeah, I’m using “this display is already calculated” with BT.2020 option and it’s really oversaturated.
azkino is offline
post #6222 of 6249 Old 09-18-2019, 01:27 PM
Icaro's Avatar
Quoted: 109 Post(s)
Liked: 41
Still in build 87,
also in device properties,
nothing changes between "TV Levels" and "PC Levels"
Icaro is online now
post #6223 of 6249 Old 09-18-2019, 02:52 PM
Manni01's Avatar
Quoted: 5411 Post(s)
Liked: 5579
...unless (s)he uses a 3D LUT
Soulnight likes this.
JVC Autocal Software V11 Calibration for 2019 Models (Google)
Batch Utility V4.02 May 16 2019 to automate measurements files for madVR with support for BD Folders
Manni01 is online now
post #6224 of 6249 Old 09-18-2019, 10:55 PM
blackbird's Avatar
Quoted: 40 Post(s)
I thought it was a feature and not a bug
Does that mean the users who are using 2020 should switch back to build 86 or will there be a build 88 soon?
blackbird is online now
post #6225 of 6249 Old 09-19-2019, 09:38 AM
Quoted: 69 Post(s)
Liked: 45
I just switched back to build 86 for now.
azkino is offline
post #6226 of 6249 Old 09-19-2019, 11:59 AM
Icaro's Avatar
Quoted: 109 Post(s)
Liked: 41
Same here
Icaro is online now
post #6227 of 6249 Old 09-20-2019, 10:16 AM
stef2's Avatar
Quoted: 487 Post(s)
Liked: 286
I currently use the zooming method (constant height) with my setup and I get 110 nits when watching 16.9 content. For scope content, I get 70 nits. Therefore, I must change that setting (real nits value) in madvr according to the movie I watch. The result is stunning!
Is there a way for madvr (using profiles?) to know whether the movie is 16:1 vs 2.35:1? I would like to make two profiles, one for each zoom preset, and have madvr automatically chose the correct one (70 vs 110 nits).
Can this be done?
stef2 is offline
post #6228 of 6249 Old 09-20-2019, 10:58 AM
Quoted: 27 Post(s)
the AR variable is what you need
and rule for profile :
if (AR >=2.40) "ratio2.40"
elseif (AR >= 2.385) "ratio2.39"
elseif (AR >= 2.375) "ratio2.38"
elseif (AR >= 2.345) "ratio2.35" .....
else "ratio4:3"
stef2, neo_2009 and Neo-XP like this.
xxxx5 is online now
post #6229 of 6249 Old 09-21-2019, 02:29 AM
Liked: 1
I use the mode and it is really different. The HDR mode is very dark and almost invisible.
markmon1 likes this.
[email protected] is offline
post #6230 of 6249 Old 09-21-2019, 02:42 AM
markmon1's Avatar
Quoted: 5066 Post(s)
Liked: 3290
Can this be done?
why do you get lower nits on scope content? In CIH dont you just get black bars on 16x9 content on the sides?
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #6231 of 6249 Old 09-21-2019, 03:50 AM
tingtong5's Avatar
I would like to try the neo-xp settings for build 86 but can't seem to find them in this quite long thread. Anyone a link to a screenshot?
tingtong5 is offline
post #6232 of 6249 Old 09-21-2019, 04:14 AM
Neo-XP's Avatar
Quoted: 594 Post(s)
Liked: 715
@tingtong5
For build 86:
For build 86, with adapted (better) brightness speeds:
For build 87:
Don't use build 87 unless your display is calibrated to BT.709 and with PC levels (0-255).
And increase dynamic tuning as you wish if you find it too bright
Neo-XP is offline
post #6233 of 6249 Old 09-21-2019, 04:41 AM
stef2's Avatar
Quoted: 487 Post(s)
Liked: 286
When zooming for CH, you have to light up a much bigger surface for the scope image to be as high as the 16.9 one.
xxxx5, Thank you for the tip, I will try it tonight (AR variable).
stef2 is offline
post #6234 of 6249 Old 09-21-2019, 07:50 AM
tingtong5's Avatar
@tingtong5
For build 86:
For build 87:
Thanks a lot Neo-XP!! Will try it tonight :-)
post #6235 of 6249 Old 09-21-2019, 07:50 AM
tingtong5's Avatar
@tingtong5
For build 86:
For build 87:
post #6236 of 6249 Old 09-21-2019, 11:00 AM
danbez's Avatar
Quoted: 64 Post(s)
Liked: 24
For those of us using Soulnight measurements customization tool, would a newer beta build give any benefits quality wise? I am probably at build 40 or something close to it.
AmigoHD likes this.
danbez is offline
post #6237 of 6249 Old 09-21-2019, 11:31 AM
AmigoHD's Avatar
Quoted: 67 Post(s)
Liked: 44
I'd say no. There were no changes in madMeasureHDR.exe.
Epson EH-LS10000, madVR on GTX 1080, Oppo UDP-203, Oppo BDP-EU93, Toshiba HD E1, Dreambox 900 ultraHD, Xodiac masked, AT, 3m scope (2.40:1), Marantz SR7011
3x Klipsch PRO-7800-L-THX, 6x Klipsch PRO-7800-S-THX (Dolby Atmos setup, 5.2.4)
2x Velodyne SC-600IW, Velodyne SC-602
Middle Atlantic Rack, RTI XP-6 control processor, RTI T2x remote, LUTRON Graphics Eye QS
AmigoHD is online now
post #6238 of 6249 Old 09-21-2019, 12:29 PM
Quoted: 315 Post(s)
Liked: 188
I noticed that last night. Being new-ish to MadVR in general I wasn't sure if it was something new or something I had never noticed before. Thanks! Rolling back to 86 for now, but I actually kinda like the FALL Knee algo.
wombats is offline
post #6239 of 6249 Old Yesterday, 08:39 AM
Sittler27's Avatar
Quoted: 1242 Post(s)
Liked: 112
Been using madvr with my x970R for a while, and now have an NX9 and a DCR lens coming for it.
I estimate I should have up to ~44ftL available for HDR from my 1.18 actual gain screen. I only had about 25ftL available from my x970R with 1800 hrs on the bulb.
With this additional brightness, I'm wondering if I should be doing something else in how I output from madvr?
Currently tone mapping HDR but outputting SDR to the projector. Should this change now with the increased brightness?
Also, is the proper way to determine the nits value to put in the newest version of madvr to read ftL on 100IRE pattern off screen when in HDR mode/high lamp using Mascior's HDR patterns, and then convert to nits?
Finally, about madmeasureHDR given my details above - what would be the recommended settings to generate that measure file for my setup?
Sittler27 is offline
post #6240 of 6249 Old Yesterday, 05:16 PM
Quoted: 99 Post(s)
Liked: 117
I have an RS1000/NX5 (115" screen/1.2gain at almost min throw) so I'm ~50ftL in high lamp give or take. With the dtm from MadVR I ended up leaving it on low lamp except when I'm watching 3D. I noticed a slight increase in brightness, but ended up deciding it wasn't worth the lamp wear. I have the projector tucked away in a closet with a port hole so noise isn't an issue. The tone mapping by MadVR is so good I just didn't think it was worth going to high lamp. I'd set it up how you want, calibrate, etc and then just flip back and forth and see how you like it. I run mine right now low lamp 0 iris and no DI. For SDR I ended up doing low lamp, -10, and auto 2(the yellowing isn't noticeable for me below -8 or so).
dgrizzard is offline
dynamic tone mapping , hdr , madvr , sdr , ton mapping
