Improving Madvr HDR to SDR mapping for projector - Page 309 - AVS Forum | Home Theater Discussions And Reviews
 8721Likes
post #9241 of 9283 Old 05-18-2020, 06:56 PM
catav's Avatar
Quoted: 415 Post(s)
Liked: 241
Originally Posted by Balbolito View Post
At the moment i am running madVR on my desktop and it has a 4K 32'' LED Samsung monitor(SDR, no HDR support)
When i run a 4K HDR movie i know it's doing tone mapping cause i can clearly see movies in HDR (colors) playing fine . The movie is playing in it's native resolution which is 4k.
1.Is there any benefit if i downscale it to 1080p and let it do tone mapping? or since my monitor is 4k should i just keep it that way? i am noticing most people scale the movie from 4k HDR to 1080p.
If it's better to downscale the movie from 4k to 1080p is there a profile rule i could add ? or how could i apply the scaling?
PC has a crappy 1030 GPU just learning most of the basics before i apply them to my HTPC (which has a 2060 Super 8GB GPU)
On the other hand, my HTPC is connected to my PJ which has HDR . so should i stick with movies also at 4k or let it downscale them?
Sorry if this has been asked but i am honestly reading for more than a week about madVR and trying to learn most of the features myself. Thank you in advance.
PS:using madVR 113
I would just be working with the HTPC (which has a 2060 Super 8GB GPU) for setup. Your desktop PC can get you started, but you need to dial in the processing, scaling algos, and rendering for the HTPC, not the desktop PC, eventually. The two PC's could need totally different settings. Your HTPC GPU should work just fine for medium level madVR settings. Just follow some of the postings here, especially for HDR tab options and you should be good to go.
Just stay with 4K HDR processing. On HDR tab, use "tone map HDR using pixel shaders", set your min target /real display nits to around 100 or less and don't check "output video in HDR format". Set your PJ to BT2020, SDR mode and you're about done. Everything else is personal preference and depends on the GPU power for best picture. Good luck.
Balbolito likes this.
catav is online now
post #9242 of 9283 Old 05-18-2020, 08:49 PM
Balbolito's Avatar
Quoted: 477 Post(s)
Liked: 861
@catav Thanks appreciate the reply. yes for sure that is what i am gonna do. at the moment i am just trying to learn some basic rules, difference between all the settings and creating profiles. its a bit more practical to start on the desktop just to experiment.
Would you recommend two color profiles in madVR if i run HDR movies to let it switch to BT2020? and SDR movies to be in 709?
Or should i just keep my PJ always at BT2020 SDR mode? and let it to the switch to HDR if needed.
Thanks again
catav likes this.
Processors Marantz AV8805 & miniDSP 2x4 HD Amps Crown DCI/N x2 CT8150 x1 Speakers JBL PRO M2 x3 708i x4 328c x6 Subs SVS SB16 x4 Screen SI 160 Slate AT 1.2 Projector Optoma UHZ65 4K Media HTPC w/madVR Cables Wireworld,Hosa & Belden
Balbolito is online now
post #9243 of 9283 Old 05-18-2020, 10:02 PM
catav's Avatar
Quoted: 415 Post(s)
Liked: 241
Thanks again
I just use one color profile (BT2020) for both SDR (Rec709) and HDR 4K. I have not had any problems with Rec709 vs BT2020 source. For me, Rec709 is not overly saturated. Some members will setup two profiles, but I just don't see the need. You should feel free to test which works best for you.
catav is online now
post #9244 of 9283 Old 05-19-2020, 12:42 AM
Quoted: 1710 Post(s)
Liked: 507
PS:using madVR 113
Just because you see colors it does not mean it's doing tone mapping.
There is no benefit to downscaling to 1080p. The reason people do that is because they don't have 4K displays. It also takes GPU resources to downscale.
The UHZ65 covers ~87% of DCI P3 so 2020 should be used.
The color gamut issue has been discussed on this thread as well as here:
https://www.avsforum.com/forum/26-ho...l#post59603520
noob00224 is online now
post #9245 of 9283 Old 05-19-2020, 06:12 AM
DocCharky's Avatar
Quoted: 22 Post(s)
Honestly, using madvr with 2 different displays (and different settings) can be a real pain.
After countless hours trying to use profile rules and custom timings to make everything work as intended on both my TV (LG C8) and Sony HW40ES (PJ), including custom timings, I just created a dual boot on my HTPC with two entirely different (and separated) Windows 10 installs. It took me half an hour and it works like a charm...
It solved Windows problems too, since the OS often tried to send a 4K signal to my 1080p projector, which resulted in a blank picture, reboot, etc.
DocCharky is offline
post #9246 of 9283 Old 05-19-2020, 08:07 AM
Vern Dias's Avatar
Quoted: 26 Post(s)
Liked: 29
That's a good plan.
Taking that to the next logical step, I have 3 HTPCs in my HT:
1 optimized for HD media including Blu ray (Outputs 1920x1080 23.976 Hz)
1 optimized for 3D Blue ray media (Outputs 1920x2205 23.976 Hz Frame Packed)
1 optimized for UHD media (Outputs 3840x2160 23.976 Hz)
all running Windows 8.1 (although I run Windows 10 on a couple of laptops, I simply don't trust MS to deliver a stable HTPC environment.)
Primary media player is JRiver Media Center 26 running red October HQ
additional media players: MPC-HC (LAV Filters, MadVR) , VLC Media player, Zoom Player (LAV Filters, MadVR)
Denon AVR-X4500h receiver
JVC DLA-RS57 Projector with an ISCO 1.5X anamorphic lens (Primary)
JVC DLA-RS35 Projector with an ISCO 1.5X anamorphic lens (Backup)
52"x 142" 2.76:1 Curved screen
Vern Dias is online now
post #9247 of 9283 Old 05-19-2020, 10:39 AM
claw's Avatar
Quoted: 2845 Post(s)
Liked: 2714
I notice that this thread is updated with new posts, then disappointed when the new posts belong elsewhere.
Guide to Building a MadVR HTPC thread:
https://www.avsforum.com/forum/26-ho...tpc-madvr.html
MadVR Player Support thread:
https://www.avsforum.com/forum/26-ho...rt-thread.html
stevenjw, woofer, Manni01 and 5 others like this.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H (7.2.4) | X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | Amazon Fire TV Stick 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #9248 of 9283 Old 05-19-2020, 01:08 PM
Balbolito's Avatar
Quoted: 477 Post(s)
Liked: 861
Thanks appreciate the help.
So would you recommend i set it to 2020 in madVR for Everything? SDR 1080 > 4K and 4K HDR content? and no need for two color profiles.
How about in my PJ?
Sorry if i am asking a lot this is new to me and it's overwhelming.
Thanks again
post #9249 of 9283 Old 05-19-2020, 05:37 PM
Quoted: 272 Post(s)
Liked: 26
Hi there.
I’ve been trying to get my Madvr 112b config right. The colors look great and all, but it seems very dark.
I’m using the pixel shader option. I really like it, but to me it shadows seem very dark, even at 20 nits.
I tried shadow recovery, but still very dark. Bright scenes look great.
Any advice, or settings I should try?
I tried v113, but I need smooth motion, which isn’t working in this version.
cowbodude99 is offline
post #9250 of 9283 Old 05-19-2020, 06:03 PM
Javs's Avatar
Quoted: 7078 Post(s)
Liked: 6827
Everyone.
If you need tech support, this is NOT the thread for it.
We discuss the development of MadVR tone mapping here, we test scenes and settings specifically for issues with the TONE MAPPING.
Please take your tech support questions elsewhere.
This thread assumes you know how to setup MadVR. If your 'shadows' are too dark even nits 20 nits, you have something seriously wrong with your setup and you should ask in the relevant thread.
Defer to the links posted by CLAW above for where to ask tech support questions.
Manni01, neo_2009, mkohman and 1 others like this.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #9251 of 9283 Old 05-21-2020, 02:33 AM
perioms's Avatar
Quoted: 14 Post(s)
Does it make any sense to use more than one HDR profile in madvr for example for movies with very extreme different HDR video peaks?
perioms is offline
post #9252 of 9283 Old 05-21-2020, 03:40 AM
Quoted: 29 Post(s)
Liked: 32
Ask this in another topic.
Reezepees is offline
post #9253 of 9283 Old 05-21-2020, 04:26 AM
perioms's Avatar
Quoted: 14 Post(s)
Maybe my question is a little misleading. But I don't think it's off topic. We are talking about improving HDR to SDR mapping.
In this context, it could be advantageous to use film-based HDR-SDR mapping profiles that take into account, for example, the different basic brightness levels, such as in the movie "The Meg".
perioms is offline
post #9254 of 9283 Old 05-21-2020, 06:18 AM
Quoted: 29 Post(s)
Liked: 32
If you know how madVR works you already have your answer...
And also known, it has nothing to do with this topic. I am sorry if my answer is a little harsh but there are so much questions and other pulotion in this topic, its sometimes hard to read "between the lines" and see what really matters in this topic.
*Mori*, neo_2009 and ((( atom ))) like this.
post #9255 of 9283 Old 05-21-2020, 08:56 AM
Neo-XP's Avatar
Quoted: 926 Post(s)
Liked: 1323
I hope everyone is well and that we can resume testing "soon", it has been a long time now...
In the meantime, I watched a lot of movies with 112b and I have found a bad tone mapping jump with the movie Marrowbone.
Here is the sample: https://www.mediafire.com/file/3m3du7ly7254cm9/tonemap_jump.mkv/file
It happens from frame 232 to 233 of this sample, very noticeable on the forehead of the actor:
Marrowbone - Frames 232-233
Tone map goes from 251 to 306 nits in 1 frame.
On a whole different subject, shadow boost is becoming more and more important to me and I am not far from switching to "insane".
A little comparison while waiting for the next build: https://slow.pics/c/aDNqFxs2
Neo-XP is offline
post #9256 of 9283 Old 05-21-2020, 12:53 PM
DocCharky's Avatar
Quoted: 22 Post(s)
Is HSTM supposed to be unticked/disabled in your settings?
post #9257 of 9283 Old 05-22-2020, 03:41 AM
*Mori*'s Avatar
Quoted: 363 Post(s)
Liked: 547
[QUOTE=Neo-XP;59684184]
On a whole different subject, shadow boost is becoming more and more important to me and I am not far from switching to "insane"./QUOTE]
I had a look at this and I did not notice an obvious brightness jump during playback with my setttings. When I looked at the info data it says in my case that frame 232 measues 239 nits and is then tonemapped to 239 nits. Frame 233 is 409 nits and tonemapped to 257 nits. So the jump is in my case from 239 nits to 257 nits which I think is quite moderate and probably the reason that this scene seems not to be a problem in my case.
I had been using shadow boost for while but I stopped to use it. Obviously it helps to get the details near black but in my case I had always found that shadow boost costs all in all some contrast. The effect in my case was IMO going too far into the the midtones. I modified the gamma of my Sony VW760 at the very low end only in order to improve shadow details. First by following BT1886 up to about 10% of the greyscale I could improve shadow details. But this was too much as well. At about 3 IRE my gamma is at 2.05 and at about 4.5 IRE it is 2.10. The rest is all 2.2. This way I think I can avoid loosing contrast and still have the shadow details that I want. Last but not least I keep my dynamic target nit value the same as my real nit value. IMO this way there is more contrast / pop and HDR effect by doing so. This also worked with my Nero 3 plus from Sim2 that has only half the brightness of the Sony: here I measure 75 real nits and set the DT at 75 as well. Only by this it gave me a nice contrast. Beeing a DLP details near black are fine and not a problem (the black floor is of course still poor and there is no way to change that).
Name:	232 vs 233.PNG
“Details make perfection, and perfection is not a detail.” Leonardo Da Vinci, Italian inventor, architect, artist, mathematician, scientist
*Mori* is offline
post #9258 of 9283 Old 05-22-2020, 04:32 AM
Neo-XP's Avatar
Quoted: 926 Post(s)
Liked: 1323
Yes, absolutely. I got the right balance for me by increasing DT and shadow boost.
Now using the settings in attachment after some more tests.
It is actually worse than what I posted before, I can see it during normal playback without any difficulty.
When going frame by frame after the first cut:
- frame 232 measures 251 nits and is tonemapped to 267 nits
- frame 233 measures 404 nits and is tonemapped to 360 nits
I can reproduce it every time with those same values.
KoKlusz and DocCharky like this.
Neo-XP is offline
post #9259 of 9283 Old 05-22-2020, 04:54 AM
*Mori*'s Avatar
Quoted: 363 Post(s)
Liked: 547
In the pictures the difference between the 2 frames is very obvious. From 267 nits to 360 nits is equivalent to an increase of about 35%. In my case it is about 7.5% which is far less obvious and like I said not really a problem.
The question of course is how often cases like this do occur ...
*Mori* is offline
post #9260 of 9283 Old 05-22-2020, 03:44 PM
Neo-XP's Avatar
Quoted: 926 Post(s)
Liked: 1323
Not very often fortunately
However, I did report similar issues with the tone mapping algo and fade ins more than one year ago: https://www.avsforum.com/forum/24-di...l#post58513588
And another fade in fail here: https://www.avsforum.com/forum/24-di...l#post58517502
I can now add this latest find to the list: https://www.avsforum.com/forum/24-di...l#post59684184
I guess madshi would want to try to fix those small issues before the release of the Envy. Being able to look a few frames ahead would also help to perfect it
stevenjw likes this.
Neo-XP is offline
post #9261 of 9283 Old 05-23-2020, 10:00 AM
DocCharky's Avatar
Quoted: 22 Post(s)
So in the end, all these months playing with curves... for nothing ?
post #9262 of 9283 Old 05-23-2020, 12:13 PM
Neo-XP's Avatar
Quoted: 926 Post(s)
Liked: 1323
Of course not, I am sure this option will be useful to a lot of users, and it was fun to test
Neo-XP is offline
post #9263 of 9283 Old 05-23-2020, 01:33 PM
woofer's Avatar
Quoted: 1787 Post(s)
Liked: 2747
Interesting.... @Javs actually came to that conclusion in a matter of hours ..
aerodynamics likes this.
woofer is online now
post #9264 of 9283 Old 05-23-2020, 02:40 PM
Neo-XP's Avatar
Quoted: 926 Post(s)
Liked: 1323
Another good shadow boost comparison IMO, from Robin Hood: https://slow.pics/c/iQHELgEy
Full settings in attachment.
Name:	madVR settings.png
lovingdvd, Manni01 and KoKlusz like this.
Neo-XP is offline
post #9265 of 9283 Old 05-23-2020, 05:03 PM
Javs's Avatar
Liked: 6827
I would say the UHD of that film is probably just overall bad.
The Bluray is not only far brighter there, is actually much sharper too than the UHD.
Bluray
chros73 likes this.
Javs is online now
post #9266 of 9283 Old 05-23-2020, 05:23 PM
stevenjw's Avatar
Quoted: 679 Post(s)
Liked: 902
WOW! In just a few months, Neo switched back to v112 and is not using HTSM anymore and I'm pretty sure that Javs is using some different settings and older version too. What's the world coming to? And here I was just concerned about a Pandemic. Maybe the sky is falling....
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one or not." ;)
My HT gear
stevenjw is offline
post #9267 of 9283 Old 05-23-2020, 05:30 PM
Javs's Avatar
Liked: 6827
No, I am using 113, just with Compromise ON.
I am hoping that Madshi will bring back the Hue 100% correction ONLY from version 10 and 'separate' it from the other bells and whistles he has added since as it only costs 2ms of rendering for hue perfect gamut mapping in version 10 vs Comp On compared to the over 20ms of rendering from today for almost the same thing! This is HUGE difference in rendering power required.
Javs is online now
post #9268 of 9283 Old 05-23-2020, 11:01 PM
DocCharky's Avatar
Quoted: 22 Post(s)
AFAIK he claims that DTM introduced a hue shift (which is still disputed...) not that HSTM is useless.
Are you a fan or something ?
post #9269 of 9283 Old 05-23-2020, 11:02 PM
DocCharky's Avatar
Quoted: 22 Post(s)
AFAIK he claims that newer madvr builds introduced a hue shift (which is still disputed...) not that HSTM itself is useless.
post #9270 of 9283 Old Yesterday, 02:22 AM
Javs's Avatar
Liked: 6827
So far nobody has provided evidence to the contrary, so it's rather undisputed I think. And it's not a hue shift it's an over saturation. And I traced the cause back to 'saturation correction' in build 10.
And no, I don't like hstm at all I don't think it's necessary and personally I think it's detrimental, but that doesn't mean others don't have the right to enjoy it.
Sent from my SM-T720 using Tapatalk
Javs is online now
dynamic tone mapping , hdr , madvr , sdr , ton mapping
