Improving Madvr HDR to SDR mapping for projector - Page 314 - AVS Forum | Home Theater Discussions And Reviews
 8869Likes
post #9391 of 9401 Old 06-29-2020, 06:10 AM
Neo-XP's Avatar
Quoted: 928 Post(s)
Liked: 1323
Of course, I totally agree, but I guess it is not possible to know what the important information of a scene is to adapt the tone mapping for it and ignore all the other elements.
The sky detection can help to ignore bright flat areas, because they can be "detected" on the histogram and are, most likely, not part of the most important information of a scene.
But when you have a very bright background which is not flat (like the example of Rogue One you posted) and a darker foreground which is the main focus of a scene, this last will appear too dark if you don't use shadow boost to limit the compression of that dark area.
I do not think there is another solution for these situations at the moment, but maybe madshi has some new ideas
Neo-XP is offline
post #9392 of 9401 Old 06-29-2020, 03:13 PM
Ian_Currie's Avatar
Quoted: 339 Post(s)
Liked: 104
I thought the Shadow Recovery option was part of HSTM and required HSTM to be enabled...?
JVC-RS4500 4k projector, Lumagen Pro, 138" 2.35:1 ST130
Panasonic DMP-UB820 & i7 PC w/1080ti running Win10/Kodi DSPlayer/madVR
Classe SSP-800, Bryston amplification, Wilson Audio speakers (7.2) + Buttkickers.
Ian_Currie is offline
post #9393 of 9401 Old 06-29-2020, 04:08 PM
Neo-XP's Avatar
Quoted: 928 Post(s)
Liked: 1323
Not at all, you can use them independently.
Neo-XP is offline
post #9394 of 9401 Old 07-03-2020, 06:06 PM
DigitalAV's Avatar
Quoted: 190 Post(s)
Liked: 102
Question
Hi, folks. I just started using madVR and right off the bat I'm not understanding why my madVR settings > hdr page isn't letting me set my target peak nits (it's just stuck on 200) and doesn't show all of the advanced settings like in others' screenshots (dynamic target nits, etc.)?
I'm using MPC-HC.1.9.6.7.x64 and latest MadVR (see screenshot).
(apologies if this is covered somewhere, I've been trying to pour through all the different guides)
**EDIT** Nevermind, I needed to install the latest beta madVR 113 from here https://www.avsforum.com/forum/24-di...l#post59127786
BL4DE likes this.
DigitalAV is offline
post #9395 of 9401 Old 07-06-2020, 02:43 PM
DigitalAV's Avatar
Quoted: 190 Post(s)
Liked: 102
Lightbulb
I have to say, madVR is f**king amazing. I just went through trying to calibrate, custom curve static tone map, you name it, could get things looking "good" but knew it just wasn't right. madVR instantly made my Epson 3800 look amazing and put all my previous work to absolute shame. It ain't even the same sport. Mad props to @madshi
stevenjw and Salty01 like this.
post #9396 of 9401 Old 07-07-2020, 08:37 PM
MidnightWatcher's Avatar
Quoted: 287 Post(s)
Liked: 283
Originally Posted by stevenjw View Post
@madshi , where do I post issues with v112b? (I haven't upgraded to v113 yet). Not sure if support forums are correct place since the problem seems to be with one of the test files. The following is from the JRiver MC26 bugreport. There's a lot more data, but it's greek to me. JRiver's solution is to turn off MadVR rendering, but obviously, the files in question are not what's delivered in their product. Not sure where to go from here to resolve. Guess I could update to v113, but don't see why v112b is causing an issue. Any help is appreciated. Thanks!
exception message : Access violation at address $4a403623 in module 'madVR64.ax'. Read of address $0.
EDIT: I went ahead and installed v113 and will continue the movie from where it lest off. Hoping that fixes the issue...
EDIT 2: Crashed again with nearly identical error msg. Going to need help with debug / fix.
exception message : Access violation at address $4a403653 in module 'madVR64.ax'. Read of address $0.
Hi stevenjw, did you ever figure out the cause of this crash or how to fix it? I'm now having the same issue myself.
MidnightWatcher is offline
post #9397 of 9401 Old 07-08-2020, 03:47 AM
Quoted: 35 Post(s)
Liked: 36
Ahhhhh, sh.t
I was really happy to open up this tread because i thought Madshi was here with a new build. Now i see you guys posting in the wrong topic..
Not funny.
neo_2009 and noob00224 like this.
Reezepees is offline
post #9398 of 9401 Old 07-08-2020, 08:57 AM
stevenjw's Avatar
Quoted: 680 Post(s)
Liked: 902
Yes, it's been fixed for a while. I seem to recall that I was also having issues with Windows 10 crashing and had to resolve that first. I found some file that was part of TMT5 that Windows didn't like. I removed TMT5 and then Windows stopped crashing and madVR was fine. Good luck.
...Steve
"Opinions are like orgasms… mine matters most and I really don’t care if you have one or not." ;)
My HT gear
stevenjw is offline
post #9399 of 9401 Old 07-08-2020, 09:54 AM
Bumper's Avatar
Quoted: 191 Post(s)
Liked: 60
Originally Posted by Reezepees View Post
Ahhhhh, sh.t
I was really happy to open up this tread because i thought Madshi was here with a new build. Now ik see you guys posting in the wrong topic..
Not funny.
Are you aware that out of the few replies you have posted in this topic, a lot of them are complaints about others being off topic. Simply let it go we have forum moderators for that...
DigitalAV likes this.
Bumper is offline
post #9400 of 9401 Old 07-08-2020, 01:10 PM
Quoted: 35 Post(s)
Liked: 36
Ahhhhh, sh.t
Not funny.
But as you can see, there is no intervention..
And still people are posting all kind of stuff that doesn't belong here. The most of us are waiting what Madshi is going to release, soonish..
post #9401 of 9401 Old 07-09-2020, 05:43 PM
Quoted: 37 Post(s)
Liked: 39
We can't stop people from posting messages unrelated to madVR tone mapping development in this thread because they just search for madVR support online, find this thread and starting to post here. Stop answering to those posts is the best way to stop posting.
Manni01 and cableffm like this.
alps006 is offline
dynamic tone mapping , hdr , madvr , sdr , ton mapping
