How would a 3 chip DLP compare to a new model JVC RS540 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By stanger89
post #1 of 12 Old 04-09-2018, 08:18 PM - Thread Starter
scottyb's Avatar
Quoted: 47 Post(s)
Liked: 30
Title says most of it, but it’s a Sim2 C3X. I know the Sim has “pop” especially in brighter films.
How bad would the contrast be compared to the JVC?
Any other things better or worse?
Thx in advance!!
scottyb is offline
post #2 of 12 Old 04-09-2018, 08:20 PM
torii's Avatar
Quoted: 4377 Post(s)
Liked: 2540
when i had the opportunity to buy stuff for work..the screen usually made the most difference within certain low price ranges I had to deal with.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is online now
post #3 of 12 Old 04-10-2018, 04:37 AM
stanger89's Avatar
Quoted: 4156 Post(s)
Liked: 2390
Thx in advance!!
It might be a bit brighter, but contrast won't even be close. It doesn't have WCG, 4K support, no lens memory, and "pop" is largely calibration related.
I can't see going for the Sim2 unless it's a lot cheaper.
stanger89 is offline
post #4 of 12 Old 04-10-2018, 05:28 AM
Mike Garrett's Avatar
Quoted: 13792 Post(s)
Liked: 11435
I agree.
Mike Garrett is online now
post #5 of 12 Old 04-10-2018, 10:50 AM
DavidHir's Avatar
Quoted: 2655 Post(s)
Liked: 2370
"How would a 3 chip DLP compare to a new model JVC RS540?"
It wouldn't.
DavidHir is online now
post #6 of 12 Old 04-10-2018, 11:34 AM
Aztar35's Avatar
Quoted: 2964 Post(s)
Liked: 1696
Thx in advance!!
Are you referencing the Sim2 C3X or the C3X1080P?
The Sim2 C3X1080P will have excellent optics. Don't forget these lens assemblies are coming from a $20,000 plus projector. The Sim2 will also have slightly better motion, and virtually no dark scene dithering.
It will be very bright and have better ANSI contrast than the 540. It will have strong performing overall/sequential contrast with the Dark chip 4, but expect blacks will not look as good as, especially in low APL scenes, as on the 540.
And the 540 can shift to display UHD images and has a filter to substantially display DCI P3 color. And..yes...of course it has reference black levels for a projector and is pretty bright. But I agree with others who posted here...if you can get the Sim2 for a good price, then it's worth considering.
I would demo both the 540 and the Sim2 first. Lastly, something to consider is warranty. A newer projector will have coverage, but I'm not sure about what types of protection plans there are on the Sim2 C3X1080P as an older model.
Aztar35 is offline
post #7 of 12 Old 04-10-2018, 12:28 PM
Craig Peer's Avatar
Quoted: 7956 Post(s)
Liked: 10338
Thx in advance!!
Price will determine whether it's worth getting. I loved my Sim Lumis Host, but it's no match for my current projector.
Craig Peer is online now
post #8 of 12 Old 04-10-2018, 01:54 PM - Thread Starter
scottyb's Avatar
Quoted: 47 Post(s)
Liked: 30
The Sim is around $3000 and it’s a C3X
Thx for the opinions so far!
I used to have DLP and they were so sharp.
scottyb is offline
post #9 of 12 Old 04-10-2018, 04:41 PM
Aztar35's Avatar
Liked: 1696
Scotty, single chip DLPs have a sharpness advantage over three chippers due to lack of convergence errors, but the C3X1080, although a three-chip display, typically has great convergence and outstanding optics.
That being said, the 4K compatible JVC has a lens that's no slouch.
Again, demo both and then decide.
Aztar35 is offline
post #10 of 12 Old 04-10-2018, 04:48 PM
Aztar35's Avatar
Liked: 1696
...what is...Laser, Lens, Longevity, 4K...need I say more? But unfortunately it's also ten times the price of where Scotty is looking now.
Aztar35 is offline
post #11 of 12 Old 04-10-2018, 06:04 PM
Liked: 11435
Thx in advance!!
Keep in mind, you need to find out which lens is in the Sim2, to make sure it will work in your room. Because if it doesn't you will have a lot of money tied up in a lens swap.
post #12 of 12 Old 04-11-2018, 04:33 AM
stanger89's Avatar
Liked: 2390
That seems like way too much IMO. If it were a Lumis, maybe, at least that has the DI to help with contrast/black levels in dark scenes, but the C3X doesn't. On top of that the C3X is a 720p machine, the C3X1080 is the 1080p model.
I've got a Planar 8150 and an RS600 hanging in my HT, the only reason I still have Planar is because of the high lag on the RS600 (which has been resolved in the x20 and x40 lines). The JVC is brighter, contrast is in a different league, it's really no contest. There's really no sharpness advantage to the Planar, and the ANSI contrast advantage never shows itself, but the native/sequential contrast definitely does.
