JVC DLA-X990RB vs. DLA-X790RB - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-25-2018, 06:33 PM - Thread Starter
Quoted: 29 Post(s)
So I'm looking to see of any feedback on these on one vs the other. The main difference that I see is with the lumens being 2000 vs 1900 and the contrast with 160,000 vs 130,000 respectively. I can get the 990 for about 1k more than the 790...just trying to figure out if its worth that added cost. I have to be honest and say I am not very educated or informed on what some of these specs mean in detail...although I have a basic idea.
This will be for a dedicated, sealed room with light control. About 17' from lens to screen, roughly...on a 137.7" screen of which I have not entirely decided on yet either. But was leaning towards a Seymour XD right now.
Any input is appreciated!
Pluggz is offline
post #2 of 10 Old 04-25-2018, 09:40 PM
Purple X's Avatar
Quoted: 173 Post(s)
Liked: 197
They are the same projector, but the 990 uses higher-binned parts.
Basically the top tested parts get put in the 990 the remainder goes in the 790.
Purple X is offline
post #3 of 10 Old 04-26-2018, 03:52 AM - Thread Starter
Quoted: 29 Post(s)
So that sounds like I just go with the 790 because only marginal improvement with the 990
Pluggz is offline
post #4 of 10 Old 04-28-2018, 09:55 AM
timmyotule's Avatar
Quoted: 48 Post(s)
You definitely get more bang for your buck going that route. That's what most people that are considering these projectors do.
timmyotule is offline
post #5 of 10 Old 04-28-2018, 10:11 AM - Thread Starter
Quoted: 29 Post(s)
Hmmm...yeah I can grab the 990 for $900 more bucks. Which I thought wasn't so bad...but maybe not worth it.
Pluggz is offline
post #6 of 10 Old 05-01-2018, 05:48 PM
0100010's Avatar
Quoted: 54 Post(s)
Liked: 50
In a light controlled room, I would no question spend the $900 more for the 990 over the 790.
0100010 is offline
post #7 of 10 Old 05-01-2018, 05:57 PM - Thread Starter
Quoted: 29 Post(s)
Funny you say that...after reading more last few days I'm thinking the same thing. I found that recent shootout with the jvcs and Sonys...so what's another 900 in the grand scheme of things...
Pluggz is offline
post #8 of 10 Old 05-01-2018, 08:55 PM
Bytehoven's Avatar
Quoted: 1612 Post(s)
Liked: 1275
The x990/9900 has had issues as far as being built from select parts. I was eventually able to have a poorly built x990 replaced with an acceptable unit, but jvc did not make it easy. The process took 2 months, but i did end up with a good unit.
JVC DLA-X990 - 128" 2.35 1.3 Gain Screen - Vertex2 - X800M2 - UB820 - ATV4K64 - ROKU Ultra - PS4 - XBone
7.1.4 Atmos - Denon X4300H + Denon 3806(LCR) - JBL Control 5 - BIC Sub - Dayton
Bytehoven is offline
post #9 of 10 Old 05-03-2018, 07:14 PM
scottyb's Avatar
Quoted: 47 Post(s)
Liked: 30
So which is it, $900 or a Grand?
Scott
scottyb is offline
post #10 of 10 Old 05-03-2018, 07:18 PM - Thread Starter
Quoted: 29 Post(s)
So which is it, $900 or a Grand? [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG] [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Scott
Ha I did get a couple quotes! 😉
Pluggz is offline
