Sony VPL-VW285ES or Epson 5040UB? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 08-04-2018, 10:57 AM - Thread Starter
Liked: 0
If price was the same for both projectors, which would you choose? The reviews I have read have the Epson with the better picture, but I'd like some real world opinions. Not considering JVC at this time. Thank you.
Dark environment with no ambient light
Movies only, no gaming, maybe an occasional football game
Approximately 150" screen
-RedSectorA- is offline
post #2 of 26 Old 08-04-2018, 11:47 AM
Hawkmarket's Avatar
Quoted: 296 Post(s)
Liked: 114
I'm not sure where you have read those reviews. About the only advantage the Epson will have is that it's brighter which may matter on a 150" screen. I'll be upgrading my projector this fall and have a 150" 16:9 screen and the only reason I'm not considering the Sony 285 is it just isn't bright enough. Sony is consistent with their high quality picture, high price, low lumens. There isn't a quality reviewer on here that will give the picture advantage to the Epson.
Hawkmarket is online now
post #3 of 26 Old 08-04-2018, 12:09 PM
christoffeldg's Avatar
Quoted: 1310 Post(s)
Liked: 527
Having a good HDR picture with the Sony on a 150" screen is going to be tough. It's not bright enough for that.
Another point against the Sony is that it doesn't have a dynamic iris.
Other than that IMO the Sony is the better projector.
Video: Sony VPL-VW760ES, Elite screen Aeon 135" Cinewhite + JVC X7900, Magicscreen Reference ALR 120"
Speakers: Bowers and Wilkins 802 D3 front, JBL 580, JBL 520c, JBL 550p
Amplifiers: Lyngdorf stereo TDAI 2170, Lyngdorf SDA 2400, Denon 4300H Home Theatre
Equipment: PC/PS4/Xbox One/Switch/Synology 2415+
christoffeldg is offline
post #4 of 26 Old 08-04-2018, 12:47 PM - Thread Starter
Liked: 0
Is 135" more reasonable with the 285 Sony?
post #5 of 26 Old 08-04-2018, 12:56 PM
cemo62's Avatar
Quoted: 178 Post(s)
Liked: 49
Sony VPL-VW285ES is a lot better PQ than epson 5040.
cemo62 is offline
post #6 of 26 Old 08-04-2018, 01:32 PM
Liked: 527
Yes, that seems better.
post #7 of 26 Old 08-04-2018, 06:47 PM
Quoted: 51 Post(s)
Sony 285ES shows a much better picture than the Epson 5040UB. They are not in the same league. The 5040UB is a mid tier projector while the 285ES is a entry level high end projector. The Epson 5040 throws a good picture however the Sony 285ES shows a stunning, detailed image.
hifiheaven is offline
post #8 of 26 Old 08-04-2018, 07:47 PM
Mike Garrett's Avatar
Quoted: 12545 Post(s)
Liked: 10163
Sony throws better image, but at your screen size, the Epson is the better choice. Funny that you are not considering the JVC, since "Dark environment with no ambient light, Movies only" means the JVC would provide the best image. If you insist on 150" screen size and between the Sony and Epson, then go with Epson, but keep in mind with that size screen, HDR will not perform well.
Mike Garrett is online now
post #9 of 26 Old 08-04-2018, 08:34 PM - Thread Starter
Liked: 0
Thanks Mike. I plan to go with a 135” screen now instead of pushing for the 150”. I’m also leaning towards the 285 and hope this screen size is closer to its sweet spot for performance.
To be clear, I know the JVC provides a stunning picture, but I have specific reasons why I am looking at the Sony and Epson at this time. My choice has nothing to do with JVC. I sincerely appreciate your input.
post #10 of 26 Old 08-05-2018, 06:59 AM
coderguy's Avatar
Quoted: 2455 Post(s)
Liked: 1324
Get the Sony over the Epson if you can. Do a rough estimate of yearly usage and calculate your lamp costs as well.
The Sony could be quadruple the price or more over the Epson after you factor in lamp costs long-term for as long as you may use the projector.
**Updated Projector Calculator Released NOV 2017**
-- www.webprojectorcalculator.com --
coderguy is offline
post #11 of 26 Old 08-05-2018, 12:52 PM
Quoted: 51 Post(s)
In my opinion, you can't have a very large screen and a high contrast projector. You can pair a large screen with a high lumen, low contrast projector. Or you can pair a smaller screen with a high contrast projector.
Pairing a very large projector with a lower lumen, high contrast projector will result in a dim image. It sucks but projector technology is lagging so far behind that this is our choice until high contrast laser projectors become more affordable. JVC and Sony projectors are not bright. Most of the professional reviews list their peak lumens at 1300-1500 lumens in high lamp mode using a accurate color mode.
They try to fool potential customers using torch mode lumen numbers on the box. But the reviews tell the true tale that none of the top tier lamp based projectors from Sony or Jvc are very bright. Not to mention serious bulb dimming after the first 1000 hours. I normally change my bulb every 2000 hours to preserve adequate brightness. But that is very hard to do with $500 and up bulbs from JVC.
post #12 of 26 Old 08-05-2018, 06:03 PM
Hawkmarket's Avatar
Quoted: 296 Post(s)
Liked: 114
There seems to be some truth to this. I went from the Epson 5030 a couple years ago to the 3700 and have been very pleased with it. I realize if I did a side by side the 5030 has better contrast but that's not how I watch sports/movies and the increased lumens really makes the colors pop and the screen shine. As I said earlier on my 150" I've ruled out the Sony 285/385 because a sharp dull picture doesn't sound all that appealing. The Epson 5040 has a nice blend of increased resolution/contrast over the 3700 without giving up a ton of lumens on the screen and for watching sports (about 50% of my viewing) it has that other gear if needed. I am waiting to see if JVC does anything different at Cedia and will then be deciding between the JVC 540 and Epson 5040 assuming the Epson does add the 18Gbps HDMI. If I were just watching movies in a home theater the JVC would be the easy winner but I watch a lot of sports with the lights on as well and I'd like that other brighter mode to switch to. I'm not sure what else under 5K is the best choice for a 150" 50% sports 50% movies projector besides what I've listed.
post #13 of 26 Old 08-05-2018, 06:11 PM
DavidHir's Avatar
Quoted: 2575 Post(s)
Liked: 2257
The newer JVCs (from 2016+) do 1600-1700 calibrated in high lamp at 6500K and do not lose that many lumens after 1000 hours. They are remarkably stable lamps actually with very minimal drift and light loss compared to other lamps.
I'm getting nearly 32 ftL, around 20,000:1 native contrast with my RS440 on a 9 foot wide 1.0 gain screen. Far from dim.
DavidHir is online now
post #14 of 26 Old 08-05-2018, 06:24 PM
Hawkmarket's Avatar
Quoted: 296 Post(s)
Liked: 114
"Do not lose many lumens" means different things to different people. What % would you say they lose after 1,000 hours? 1,600-1,700 is acceptable on my 150" figuring that gives me about 25fl at peak with my screen. The question is how far does that drop off 1,000 hours later.
post #15 of 26 Old 08-06-2018, 04:38 AM
Liked: 527
Just wondering, you're saying that there's minimal lamp loss running the JVC at the full max brightness for a full 1000 hours consistently. It's not that you've run the projector at eco mode for most of the time.
post #16 of 26 Old 08-06-2018, 04:53 AM
markmon1's Avatar
Quoted: 5244 Post(s)
Liked: 3411
My RS500 was measuring 1750 lumens on high, 1270 lumens on low at 3000 hours on the bulb. JVC bulbs can be very good. I ran it on low the entire time to get to the 3000 hours, btw.
My friend currently has this installed in his theater with a 185" 1.3g screen and runs it on low lamp for all non-HDR content.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is offline
post #17 of 26 Old 08-06-2018, 04:55 AM
markmon1's Avatar
Liked: 3411
I had a 285ES on a 135" screen and it was pretty good. I'd definitely give that the thumbs up way before getting an epson. My only complaint was lack of iris so not great blacks. But it wasn't terrible either - probably better than the epson.
markmon1 is offline
post #18 of 26 Old 08-06-2018, 06:57 AM
coderguy's Avatar
Liked: 1324
That would be less lumen loss than some LASER projectors @ 3000 hours.
That would be a fluke. I wouldn't go by that for an average.
The problem is so many people that use JVC's rarely even put that many hours on them.
We don't know how good the lamps really are, we just know they are better than the old lamps.
coderguy is offline
post #19 of 26 Old 08-06-2018, 07:00 AM
coderguy's Avatar
Liked: 1324
135" is more than fine on a JVC, even the Sony as well.
150" would be pushing it a bit, but it all depends on how many times he wants to replace the lamp.
coderguy is offline
post #20 of 26 Old 08-06-2018, 07:07 AM
dcbrown88's Avatar
Liked: 6
Sony, hands down. I have a 133" and was using a 6040UB before I went to the 285 and picture quality and colors were a huge upgrade. Mine is a dedicated HT with controlled light and it's plenty bright, even on low lamp. There wasn't anything bad about the 6040 but the Sony looks so much better to me.
Theater (work in progress)
Fronts: (2) RF-7 II | Center: RC-64 II | Rears + Sides: (4) RS-62 II | Atmos: (4) CDT-5650-C II | Subs: JTR 218HT | Amps: Emotiva XPR-2 + (2) XPA-5 Gen 2 | PrePro: Marantz AV7704 | Projector: Sony VPL-285ES | 133" AT Screen | Oppo UDP-203
dcbrown88 is offline
post #21 of 26 Old 08-06-2018, 07:35 AM
Hawkmarket's Avatar
Quoted: 296 Post(s)
Liked: 114
Coder you seem to be the lumens expert. If I'm looking to stay under 5K and value the following which projector leads the pack for you.
1.) About 50% sports 50% movies and I'll watch the sports with some lighting on in the room.
2.) Its more of a sports bar / media room but for movies it can get dark. It's in a basement and I've painted all the walls and ceiling a dark grey in the viewing area. Outside light and reflection are not an issue when it's movie time.
3.) I do enjoy 3D
4.) Looking to upgrade to 4k/eshift/whatever is above 1080p.
5.) Minimal gaming. Not a priority.
6.) Screen is a 150" 16:9 Carada Brilliant White. I'll just use the latest Accucal screen report and call the gain 1.04. Close enough.
7.) The other pertinent info is "I got a guy" I can get JVC and Sony projectors from at about 25% off so that brings the JVC 540 into play in the price range. I'll also only consider the Epson 5040/6040 if they do the HDMI 18Gbps upgrade as rumored this fall.
So based on the info above what do you consider the best fit? I'm currently using an Epson 3700 and really enjoy the extra lumen pop and am making the change to finally take advantage of 4K. I realize I'm missing out on blacks with this projector but I've never ever been bothered by the current black level.
post #22 of 26 Old 08-06-2018, 07:49 AM
Liked: 10163
What projector are you suggesting the poster to use? The Epson 5040, when calibrated is not any brighter than the JVC? Around 1,600/1,700 calibrated lumens is around the max you get when looking at 5K and less HT projectors.
post #23 of 26 Old 08-06-2018, 10:21 AM
coderguy's Avatar
Liked: 1324
3.) I do enjoy 3D
I would lean towards the JVC RS-540 in your case. I would not go by pricing from just 1 dealer, also give Mike Garrett (above) a call or send him a PM and compare pricing.
Technically though, the best fit in your case would be a 2 projector solution if you can fit it, but I know some people are against 2 projectors.
Viewsonic and Benq often have sales where you can get a 1080p projector for under $500 (that's less than the cost of 1 Sony or JVC lamp).
So what I'd do is use a DLP projector for sports in ambient lighting, and use a JVC or Sony for movies.
You can run the DLP projector in High Lamp mode without feeling guilty about burning through $400 to $600 lamps.
Otherwise, if you want to just have 1 projector, that is fine as well, just keep in mind that at 150", you'll be replacing the lamp more than some do.
My personal belief is having 2 projectors is cheaper than 1 projector over the long haul, because of the cost of the JVC or Sony lamps.
coderguy is offline
post #24 of 26 Old 08-06-2018, 10:31 AM
coderguy's Avatar
Liked: 1324
Or just keep your Epson 3700 for Sports and add the JVC as a secondary projector.
You can watch sports on the JVC too if you want, but for a lot of sports you can use the Epson 3700 to save on the JVC lamps.
That's what I'd do.
coderguy is offline
post #25 of 26 Old 08-06-2018, 10:38 AM
Hawkmarket's Avatar
Quoted: 296 Post(s)
Liked: 114
That's what I'd do.
That makes a lot of sense. Because I ceiling mount my projector the logistics of that are a bit challenging but I'll see what I can come up with. I'll also wait until after CEDIA to see if JVC does a refresh of any kind on the 540.
post #26 of 26 Old 09-15-2019, 06:12 PM
Liked: 0
Has anyone had issues with ps4 4k ?
Paras Rana is offline
