NEW JVC RS3000/NX9 RS2000/N7 RS1000/N5 Native 4K Projectors Anticipation Thread - Page 215 - AVS Forum | Home Theater Discussions And Reviews
 13017Likes
post #6421 of 13653 Old 10-11-2018, 05:25 PM
Quoted: 4859 Post(s)
Liked: 1835
Originally Posted by lovingdvd View Post
Is it a safe assumption that all the old codes are unchanged (discrete IR codes like power, CMD off/low/high) and that the main changes are the addition of new codes such as the 10 installation memories?
Mike already mentioned that they are the same:
Originally Posted by Mike Garrett View Post
The same 10 discrete codes for the previous lens memory system are also used to control the 10 installation modes.
Dominic Chan is offline
post #6422 of 13653 Old 10-11-2018, 05:42 PM
Chris Kane's Avatar
Quoted: 37 Post(s)
To past and current JVC owners,
I would appreciate a screen recommendation for the NX7.
I've been using an older Epson 1080UB (ANSI 1600; 50,000:1) with a first-generation Stewart GrayHawk (100" diagonal and 16:9).
My first consideration was a StudioTek 100. The only two recommendations have been the StudioTek 130 and an ALR. I plan to go 120" diagonal / 16:9.
This will not be in a dedicated room but I only watch at night.
I'd appreciate any input!
Thanks in advance,
ck
Chris Kane is offline
post #6423 of 13653 Old 10-11-2018, 05:51 PM
OzHDHT's Avatar
Quoted: 1238 Post(s)
Liked: 756
I got some info through today that we be seeing the new series here in Aus till closer or even into December as opposed to November as has been stated for elsewhere. Don't know if this affects anywhere else apart from us but we historically get new models on time if even a tiny bit early.
OzHDHT is offline
post #6424 of 13653 Old 10-11-2018, 05:54 PM
Ronald Epstein's Avatar
Quoted: 242 Post(s)
Liked: 198
Are you the guy with the Carada Cinema White screen? If so, that screen retains a moderate amount of polarization. So you need to buy the 3D glasses made for the JVC. Does not have to be JVC brand, but does need to match the JVC.
I have a cheap Carada screen. I don't know how it fares with polarization.
Ronald Epstein is offline
post #6425 of 13653 Old 10-11-2018, 05:57 PM
Liked: 1835
Even if you only watch at night, the colours of the wall, ceiling and floor are still going to affect your choice of screen.
DavidHir likes this.
post #6426 of 13653 Old 10-11-2018, 06:08 PM
Quoted: 242 Post(s)
Liked: 198
Question....
Will this mount support the JVC RS2000?
https://www.projectorpeople.com/Chie...ccessory/19908
Since we have now determined that the older JVC glasses and emitter work with this new model, would you recommend this older package
https://www.amazon.com/dp/B00TJ9G8AO...v_ov_lig_dp_it
Or since I bought the xPand emitter, should I just buy these glasses
https://www.hi-shock.de/en/detail/in...number/SW10052
It seems like the first link, on Amazon, are for glasses that compensate for brightness issues. Perhaps the second linked set of glasses do as well.
Would appreciate help on both questions.
post #6427 of 13653 Old 10-11-2018, 06:15 PM
Chris Kane's Avatar
Quoted: 37 Post(s)
I'm aware of that. However, I haven't noticed any color corruption or it's too infinitesimal for my eyes. I do plan to go with a neutral color paint in the room.
ck
jorgebetancourt likes this.
post #6428 of 13653 Old 10-11-2018, 06:35 PM
Liked: 1835
ck
I wasn’t thinking of colour corruption, but the degradation of the contrast due the the black being washed out by the reflection.
post #6429 of 13653 Old 10-11-2018, 06:56 PM
Mike Garrett's Avatar
Quoted: 12498 Post(s)
Liked: 10117
There is a preview from Germany that links were posted here about a week or so ago. The author has looked at the N5 and NX9 and had great things to say about the N5 lens, and said the lens in the NX9 is even better (as expected).
That's a great sign that we are moving closer to manufacturing/production. Is it a safe assumption that all the old codes are unchanged (discrete IR codes like power, CMD off/low/high) and that the main changes are the addition of new codes such as the 10 installation memories?
The installation codes stayed the same also.
Mike Garrett is offline
post #6430 of 13653 Old 10-11-2018, 07:02 PM
Liked: 10117
Carada had three screens. A gray screen, Cinema White and Brilliant White. Cinema White has moderate polarization and would need to use the correct glasses. Brilliant White has a little polization, so probably does not matter and I do not know if the gray screen retained any polarization.
post #6431 of 13653 Old 10-11-2018, 07:04 PM
Liked: 10117
Question....
Wrong mount. The universal does not fit. You need the custom plate for the JVC.
post #6432 of 13653 Old 10-11-2018, 07:05 PM
Quoted: 242 Post(s)
Liked: 198
Mike or anyone,
Can you recommend a plate and mount please?
This will be a drop ceiling mount so I will need the pole extension and anything else for drop ceiling installation.
Appreciate the help.
post #6433 of 13653 Old 10-11-2018, 07:15 PM
DavidHir's Avatar
Quoted: 2571 Post(s)
Liked: 2252
Thanks in advance,
ck
I would probably only go with the ST100 in a true black room (black carpet, black walls, black ceilings, etc.).
DavidHir is offline
post #6434 of 13653 Old 10-11-2018, 07:24 PM
Quoted: 242 Post(s)
Liked: 198
Mike or anyone,
Per Post #6431
Do I need just a new mounting plate or a new drop ceiling assembly?
I already have the Universal mount linked in the indicated post.
Is it just the plate I need to attach to the mount? And if so, what specific plate so I can order it?
Thanks all
post #6435 of 13653 Old 10-11-2018, 07:29 PM
Frohlich's Avatar
Quoted: 2053 Post(s)
Liked: 2258
Per Post #6431
Thanks all
If its a universal mount then you just need the JVC plate. For example I currently have a Sony projector but have the RS 2000 on order. I have a slightly different chief universal mount but maybe they use the same plate. I need the Chief Smaller Projector Models Hardware Mount Black (SLB281).
For example you can get what I need off Amazon:
https://www.amazon.com/dp/B004SU2LH8...v_ov_lig_dp_it
Frohlich is online now
post #6436 of 13653 Old 10-11-2018, 07:38 PM
Quoted: 242 Post(s)
Liked: 198
Appreciate the help but your Amazon link goes nowhere, unfortunately.
Just for clarification from anyone that wants to answer...
I own this mounting kit for my current Sony projector:
It includes a drop ceiling install and extension pole.
Are you or anyone else saying that all I need to add to this existing mount is the JVC plate?
Which specific plate should I order? I'd rather go larger plate if I need to since this thing seems to be a monstrosity.
Thank You
post #6437 of 13653 Old 10-11-2018, 07:42 PM
markmon1's Avatar
Quoted: 5212 Post(s)
Liked: 3381
Originally Posted by mutiger View Post
It's not the wrong thread, but you'll get a very partial response out of this crew. I'm still leaning Sony 295 myself, but Markmon does present compelling testimony. There are plenty other people happy with Sony projectors however, including yourself. I saw the N5/N9/295/995 at CEDIA and came away wanting the Sony. I'm no expert and have no experience with either Sony or JVC projectors. Without viewing each side by side, I doubt most people without laser vision could tell much difference. I'm amazed that people on these forums have so much passion for JVC, although there are some haters as well, but the sheer number of posts in this thread versus the Sony certainly says something. That said, the purchase needle for me is still pointing Sony but I'd like to see some real-world reviews of production units. I wouldn't get the 385 because of the chipset limitation among other things. The 695 is overpriced compared to the JVC's. The N5/N7 are first gen which scares me. I really like the changes Sony made to the 295 and how quickly they responded to the outcry over their issues with the 285/385. The 3d emitter is built-in if I'm not mistaken on the 295. I don't really think you can go wrong with any of these, it's just a matter of how much you want to squander.
The JVC is not first generation. It's actually JVC's 3rd generation 4K panel and JVC has been making projectors since early 2000's maybe before that. Their firmware is mature, they are using the same lamps as before. This is very familiar ground.
But yea I've already stated all my opinions. I just can't see anyone that would prefer anything Sony has over the lowest JVC N5. Tell me why you'd consider a 295ES? I think a very strong case can be made that the $6000 N5 is *far better* than the $10000 695ES. Sony is just way far outclassed this round.
WOLVERNOLE likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #6438 of 13653 Old 10-11-2018, 07:50 PM
markmon1's Avatar
Liked: 3381
Honestly guys buy with what you feel comfortable with. At the end of the day its in your home whatever you choose and your the one that is going to be enjoying it. I know a number of people that are going with Sony and with JVC. You decide what suits you best. Go and view one before you buy and if your happy go for it. Ive had a Jvc X5900 and have seen a sony vpl 385es in one retailer is was demonstrated horribly but then I saw another in another retailer it blew me away, PQ looked awesome. Regarding these new JVC I bet there going to awesome as well.
I actually think anyone that ends up with say a 295ES or 695ES this round has done so based on mis-information rather than educated selection.
post #6439 of 13653 Old 10-11-2018, 07:50 PM
Quoted: 242 Post(s)
Liked: 198
Thank You
Just did a little more research...
Is this the plate I need?
https://www.bhphotovideo.com/c/produ...tor_Mount.html
If so, will it mount to the Chief ceiling mount I have referenced in the quote or do I need to buy a whole new kit?
If not, what plate will I need?
Again, thanks for the help
post #6440 of 13653 Old 10-11-2018, 07:54 PM
Franin's Avatar
Quoted: 3280 Post(s)
Liked: 2129
My point was get whatever makes you happy who cares whatever you me or anybody thinks.
Gary Lightfoot likes this.
_________________________
God Bless!
Equipment: Bose Soundbar; 1951 Philco Model 50-T701 Black and White tabletop TV;Projection :HANIMEX ZOOM 8 MM PROJECTOR
Franin is online now
post #6441 of 13653 Old 10-11-2018, 07:55 PM
Killroy's Avatar
Quoted: 528 Post(s)
Liked: 412
This is one of them: https://www.legrandav.com/Products/C...ing/RPA/RPA281
Killroy is offline
post #6442 of 13653 Old 10-11-2018, 07:56 PM
Quoted: 242 Post(s)
Liked: 198
Originally Posted by Killroy View Post
This is all I need, huh?
Does it attach to the existing mount I have in place?
post #6443 of 13653 Old 10-11-2018, 07:56 PM
markmon1's Avatar
Liked: 3381
Originally Posted by Bytehoven View Post
There is nothing wrong with holding onto the 640 for awhile. I agree, why upgrade until we see a replacement which exceeds the 640/990 in all areas?
Once you see the nx9, you may change your mind, so i look forward to your report.
Yes, lets hope so. I keep saying if the black levels dont basically match the RS640 that the RS3000 is gone. I suppose it could come in here and be so remarkable that I just don't care. If so, that'll say quite a bit.
David Mathews likes this.
post #6444 of 13653 Old 10-11-2018, 08:00 PM
Killroy's Avatar
Quoted: 528 Post(s)
Liked: 412
This is the other (the one I have been using for almost 15-years)... https://www.legrandav.com/Products/C...ets/SLB/SLB281
Killroy is offline
post #6445 of 13653 Old 10-11-2018, 08:00 PM
Quoted: 242 Post(s)
Liked: 198
Found it here:
Just need to know if compatible with this or I need a whole new drop ceiling mount
post #6446 of 13653 Old 10-11-2018, 08:02 PM
Killroy's Avatar
Quoted: 528 Post(s)
Liked: 412
From the looks of it, you loosen those 6 screws, remove that universal bottom, attach the plate and you're golden.
Killroy is offline
post #6447 of 13653 Old 10-11-2018, 08:02 PM
markmon1's Avatar
Liked: 3381
Originally Posted by ack_bk View Post
I am trying to understand the advantage of the Sony vs the JVC (MSRP maybe?).. JVC will be better contrast, lens memory, more brightness. We won't know which projector will have better tone mapping but contrast and lumens and lens shift/memory alone are pretty big advantages for JVC.
EDIT unless maybe I am not sure which models you are comparing.
The sony's have no tone mapping. They have an HDR curve. So we do know which has the better tone mapping. The only one with tone mapping is the JVC.
The comments above about wanting the 295ES seems to be all about price. He even mentions wanting an Epson 4k. No one in here would want that unless they think that they want to pay even less. Epson is not synonymous with high quality. And as mutiger said, he doesn't care about jet black vs grey black. I doubt anyone else in this thread feels that way.
post #6448 of 13653 Old 10-11-2018, 08:03 PM
Killroy's Avatar
Quoted: 528 Post(s)
Liked: 412
Found it here:
If you look at the one you posted earlier (the one you said you already had): https://www.projectorpeople.com/Chie...ccessory/19908
The actual mount to the pipe is the same....just replace the bottom portion with that plate.
Killroy is offline
post #6449 of 13653 Old 10-11-2018, 08:04 PM
Quoted: 242 Post(s)
Liked: 198
BEAUTIFUL!
I will order this plate:
Feel free to check that link for the accuracy of what I am ordering.
THANK YOU for all your help
post #6450 of 13653 Old 10-11-2018, 08:06 PM
Killroy's Avatar
Quoted: 528 Post(s)
Liked: 412
BEAUTIFUL!
That's the mount...not the plate....this is the plate.
https://www.bhphotovideo.com/c/produ...Interface.html
Killroy is offline
eshift , Jvc , native 4k , projector , uhd
