NEW JVC RS3000/NX9 RS2000/N7 RS1000/N5 Native 4K Projectors Anticipation Thread - Page 293 - AVS Forum | Home Theater Discussions And Reviews
 13017Likes
post #8761 of 13653 Old 11-11-2018, 09:06 AM
jbarteli's Avatar
Quoted: 213 Post(s)
Liked: 52
Saw the NX9 today .....wow.....
Also saw the N5 next to the Sony VW570, the N5 is imho the better unit. More light, sharper and more depth. Only the motion was better on the Sony.
jbarteli is offline
post #8762 of 13653 Old 11-11-2018, 09:12 AM
zombie10k's Avatar
Quoted: 5419 Post(s)
Liked: 5778
Originally Posted by Ribeye1 View Post
Hi, I'm new to the forum, but have been keeping up with the thread from the beginning...
I purchased the i1Display Pro (not the i1Display Pro 2), back when I pre-ordered my RS2000, not realizing I needed the Pro 2 to work with JVC's calibration software. Now I am past the return period. I am a novice with projector calibration and expect to only use JVC's calibration software. I'd rather not invest the $$ for the i1Display Pro 2, and am debating between the Spyder 5 Pro and Spyder 5 Elite. Is there any benefit to going with the Elite?
hi you can use the less expensive Spyder5 express with the JVC software, you don't need the pro or elite version.
I would keep the Display Pro, you can use it with the open source calibration software HCFR, there is a discussion on it below.
https://www.avsforum.com/forum/139-d...-software.html
The Spyder is mainly used to fix what is call 'gamma droop' which happens to the majority of the current JVC e-shift projectors. it happens over a period of time and the image can lose it's 'pop' since the gamma isn't correct. This is an extreme example below that can be corrected with the Spyder and the free JVC autocal software. That line should be flat across 2.3 and you can see how it dips down to 1.8 gamma which will cause issues with the overall PQ.
you would check the gamma with the Display Pro and if it's off, correct it with the Spyder / Autocal. The Display Pro can then be use to check and adjust greyscale and also color gamut.
I don't recall hearing about the gamma droop on the current JVC 4K laser models so we'll have to wait and see if it's still an issue on the new JVC 4K lamp models.
Ribeye1 likes this.
zombie10k is online now
post #8763 of 13653 Old 11-11-2018, 09:13 AM
Aztar35's Avatar
Quoted: 2638 Post(s)
Liked: 1432
Also saw the N5 next to the Sony VW570, the N5 is imho the better unit. More light, sharper and more depth. Only the motion was beter in the Sony.
Awesome. But now you're going to get questions from everyone.
Of course, motion is a huge part, unless you plan on only watching stills. Was the Sony 570's motion better than the NX9's too? Did you view in controlled room? Was the 570's contrast on par with the NX5's?
Also, what stood out most with the NX9? Thanks in advance.
Aztar35 is offline
post #8764 of 13653 Old 11-11-2018, 09:17 AM
Aztar35's Avatar
Liked: 1432
There was a report that after about 800 hours, a laser projector drooped even more than the lamp-based of the last series. Someone care to post that link. I don't have the time or the energy to go back and look for the post. Thanks.
Aztar35 is offline
post #8765 of 13653 Old 11-11-2018, 09:22 AM
jbarteli's Avatar
Quoted: 213 Post(s)
Liked: 52
Oh crap.....haha
No motion looked really good on the NX9, it was a batcave with some light coming in from the curtens entrance.
There wasn't much difference in contrast with the sony but the picture of the N5 was more dynamic.
What stood out on the NX9 was the amount of licht, the colors and sharpness.....the whole package.
jbarteli is offline
post #8766 of 13653 Old 11-11-2018, 09:26 AM
Frohlich's Avatar
Quoted: 2061 Post(s)
Liked: 2275
The Sony 570 is equal to the Sony 695 in U.S. model..right? So its JVC's $6k projector versus a Sony's $10K projector. Pretty nice review/comments that the JVC is still superior in many aspects.
ARROW-AV likes this.
Frohlich is online now
post #8767 of 13653 Old 11-11-2018, 09:33 AM
Aztar35's Avatar
Liked: 1432
Frohlich, as more reports are coming in, this NX9 is beginning to sound like a monster!
Jbarteli, two more for you, :do you know if the dynamic iris was operating on the NX9? Was it turned on?
Aztar35 is offline
post #8768 of 13653 Old 11-11-2018, 09:36 AM
jbarteli's Avatar
Quoted: 213 Post(s)
Liked: 52
The 570 is €8k and the N5 €6k here.
jbarteli is offline
post #8769 of 13653 Old 11-11-2018, 09:37 AM
jbarteli's Avatar
Quoted: 213 Post(s)
Liked: 52
No I do not, I do know on the other projectors it was off.
Aztar35 likes this.
jbarteli is offline
post #8770 of 13653 Old 11-11-2018, 09:37 AM
zombie10k's Avatar
Liked: 5778
from this forum? I just checked the 4500 thread and only 1 comment about gamma droop shows up from a fellow with an e-shift model.
post #8771 of 13653 Old 11-11-2018, 09:44 AM
Quoted: 572 Post(s)
Liked: 574
Ya, I would say that if you don't need better motion or lower input lag then the N5/N7 is hard to beat in the US for sure.
kaotikr1 is offline
post #8772 of 13653 Old 11-11-2018, 09:57 AM
Aztar35's Avatar
Liked: 1432
Yeah..someone here posted a statement with a reference that a laser projector, don't recall which brand, showed gamma droop after about 800 hours that was worse than the droop of lamp projectors. I can't find the post now. so until the poster or someone helps with linking to the credible reference and post, I'll withdraw my statement.
Aztar35 is offline
post #8773 of 13653 Old 11-11-2018, 09:58 AM
Aztar35's Avatar
Liked: 1432
Was it an e-shift laser?
Aztar35 is offline
post #8774 of 13653 Old 11-11-2018, 10:11 AM
zombie10k's Avatar
Liked: 5778
It was an X990 that drooped down to ~2.0. The 4500 has been out for a while, I would think there would have been some conversation if it was still an issue.
I'm glad they are continuing with the autocal + meter support just in case.
Aztar35 likes this.
post #8775 of 13653 Old 11-11-2018, 10:14 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6788 Post(s)
Liked: 6791
I'm hoping that I'll have my NX9 next month.
I hope you are right
Where did you have an honor of seeing the unit?
Cleveland Plasma is offline
post #8776 of 13653 Old 11-11-2018, 10:31 AM
jbarteli's Avatar
Quoted: 213 Post(s)
Liked: 52
In Belgium at het home cinema happening 2018.
jbarteli is offline
post #8777 of 13653 Old 11-11-2018, 10:44 AM
circumstances's Avatar
Quoted: 85 Post(s)
Liked: 36
Awesome. Congrats. Looking forward to hearing all about it.
Aztar35 and ARROW-AV like this.
circumstances is offline
post #8778 of 13653 Old 11-11-2018, 10:48 AM
tigerhonaker's Avatar
Quoted: 694 Post(s)
Liked: 677
Thumbs up
Originally Posted by enricoclaudio View Post
Ferrari porn From my last trip to my hometown of Maranello
Enrico,
Terry
tigerhonaker is offline
post #8779 of 13653 Old 11-11-2018, 10:48 AM
grendelrt's Avatar
Quoted: 578 Post(s)
Liked: 310
Curious on the comments above about the motion being better on Sony, what about the motion is better? Ghosting/response on pixels or something? I have a sony now. Moving to rs2000 so curious about that one.
Sent from my SM-G920V using Tapatalk
grendelrt is offline
post #8780 of 13653 Old 11-11-2018, 10:49 AM
Toe
Toe's Avatar
Quoted: 2738 Post(s)
Liked: 3615
Originally Posted by docrog View Post
OK, thanks for that info. The DI isn't active in my RS500 and I hadn't been keeping up with the subsequent models until now. Has the consensus been that this feature has improved HDR viewing?
Depends on who you ask, what their manual iris is set at and if they find the DI distracting at that point. I turn the DI off for my scope HDR because I run the iris wide open and the DI is distracting at that point and not worth using for me. This is just something you'll have to view and decide for yourself though.
Toe is online now
post #8781 of 13653 Old 11-11-2018, 10:53 AM
enricoclaudio's Avatar
Quoted: 3870 Post(s)
Liked: 4758
Originally Posted by tigerhonaker View Post
Enrico,
Terry
Hi Terry, yes Sr. that's me 8 years younger
tigerhonaker likes this.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #8782 of 13653 Old 11-11-2018, 10:59 AM
Aztar35's Avatar
Liked: 1432
Thanks. That's good to know, Zombie, 'cause if there are significant delays with the NX9, I may have to revisit my options.
Okay, so I just went back and looked in this forum with search words 800 and 1800 hours, as I couldn't recall if he said it was after 800 or 1800, and found nothing on point. The poster may have deleted that post, meaning it might have contained error but I don't think it pertained to the RS4500/Z1 anyway. So, we'll leave it that the JVC RS4500/Z1 does not show evidence of gamma droop.
Agreed on having the autocal just in case.
Aztar35 is offline
post #8783 of 13653 Old 11-11-2018, 10:59 AM
Toe
Toe's Avatar
Liked: 3615
Originally Posted by Manni01 View Post
It's only because some of the regulars have better things to do.
Frankly, a couple of off-topic posts is fine, but it's getting annoying. Now that you guys know you share the same interest in toys and have done your bit of self-promotion, please take your cars discussion in a chit-chat thread and don't bother those who are happy not having to read anything until there is actual information. I am not subscribed to this thread to read off-topic bragging posts on cars, sorry. If you post a link here, those who enjoy that can subscribe to that thread and they won't miss any of the fun. That's the way it works...
I have put a lot of posters on my ignore list because they never, ever post anything useful, but I can't put you (and a few other of the cars offenders) on my ignore list, so please guys, show some mercy
The thread is already full of on-topic garbage, no need to add to that!
Agreed! I couldn't possibly care less about cars, but I am interested in hearing about the new JVCs. If there is nothing new to report, let the thread rest until there is vs PAGES of car talk. I drive two POS cars that get me to and from work and I'm fine with that right now. Hopefully the car talk can be taken to the appropriate forum which isn't here.
Toe is online now
post #8784 of 13653 Old 11-11-2018, 11:13 AM
Quoted: 694 Post(s)
Liked: 677
Post
Originally Posted by woofer View Post
All you lot with your toys.....
I've got you covered spec wise though.....
60 Tonne vehicle weight..
700HP V12 ..
9-12 gallons per mile..
Top Speed 35mph..
Parking....Anywhere i want!!
Woofer,
I can actually relate to the Tank things buddy for a fact.
1965-1966 CuChi, Vietnam ………..
Terry
woofer, Frohlich and ARROW-AV like this.
post #8785 of 13653 Old 11-11-2018, 11:26 AM
Quoted: 694 Post(s)
Liked: 677
Thumbs up
Originally Posted by ARROW-AV View Post
Yes, technically it's an Audi Huracán Performante
Yes indeed I am. I'm relocating to the United States just as soon as I finish my latest project, which is about 7-8 months away from completion. So I am hoping to be making moves around this time next year
Nigel,
A warm "Welcome" buddy to the USA when your ready to make the change of address.
Terry
post #8786 of 13653 Old 11-11-2018, 11:58 AM
Aztar35's Avatar
Liked: 1432
Woofer,
Terry
I didn't know you were a veteran, Terry. Have a great Veteran's Day.
Aztar35 is offline
post #8787 of 13653 Old 11-11-2018, 12:04 PM
blee0120's Avatar
Quoted: 921 Post(s)
Liked: 636
Since no more car topics, do we have any update on projector availability? Are we looking at December?
blee0120 is offline
post #8788 of 13653 Old 11-11-2018, 12:14 PM
Frohlich's Avatar
Liked: 2275
I believe the latest is late November arrival at customs and early to mid December to customer's hands.
Mike Garrett likes this.
post #8789 of 13653 Old 11-11-2018, 12:23 PM
console's Avatar
Quoted: 202 Post(s)
Liked: 62
Originally Posted by slots1 View Post
Hmmmmm. A medical site
Just to join in on the fun, I ruptured my Achilles’ tendon on 10/31 - my birthday! Trick or treat? I’m still getting an N7.
console is offline
post #8790 of 13653 Old 11-11-2018, 12:47 PM
Quoted: 694 Post(s)
Liked: 677
Post
Yes I am buddy and Thank-You … Sir.
eshift , Jvc , native 4k , projector , uhd
