NEW JVC RS3000/NX9 RS2000/N7 RS1000/N5 Native 4K Projectors Anticipation Thread - Page 414 - AVS Forum | Home Theater Discussions And Reviews
 13017Likes
post #12391 of 13653 Old 12-27-2018, 10:46 AM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
Originally Posted by bobof View Post
Sorry, you've not followed the argument.
The N5 has 1 iris mechanism; the lens iris. This is hooked up to the DI algorithms or can be driven manually from the UI.
The N7/NX9 have 2 iris mechanisms, the lens iris and the lamp iris. The lens iris is hooked up to the DI algorithms and can be driven manually, with the lamp iris only being driven manually, being set to a level based on the "base" iris setting that you have (ie the manual setting that was displayed before enabling DI)
The N5 - if it behaves like the previous ranges - will be at around 450 lumens with the single lens iris fully closed. The N7/NX9 - again if behaves like the previous models - should be able to have light output reduced to below 250 lumens when both irises are closed.
This is important to folk who care about correct light levels for the relevant standards and have small screens and / or high gain screens. In those situations it is possible that the N5 won't be able to get dark enough for you to hit the standards, whereas on the N7/NX9 you'll almost certainly be able to make it dark enough on all but the tiniest screens.
Ah. You're right. I did not know the N7/N9 had the additional lamp iris....interesting...
stumlad is offline
post #12392 of 13653 Old 12-27-2018, 11:11 AM
aka jfinnie
Quoted: 2649 Post(s)
Liked: 1747
Originally Posted by Dominic Chan View Post
There’s a noticeable difference in native Contrast even with the iris wide open.
I'm not aware of anyone getting intimate with their X7/X9xxx light engine and removing the entire iris mech; I think it is quite possible the iris mech's presence reduces light scatter even when fully open.
Image from Cine4Home review of similar units:
http://cine4home.de/cine4home-edition-jvc-dla-x7000/
bobof is online now
post #12393 of 13653 Old 12-27-2018, 11:14 AM
aka jfinnie
Liked: 1747
It's been this way since at least the X3/X7/X9 series - 7 and 9 have always had the lamp iris.
bobof is online now
post #12394 of 13653 Old 12-27-2018, 12:22 PM
DavidHir's Avatar
Quoted: 2576 Post(s)
Liked: 2257
Originally Posted by BondDonBond View Post
I have come to the conclusion that the P3 filter is very important. I went to Marry Poppins at the theater in the Dolby Vision theater and then we watch a Hulu Marry Poppins that was hooked up to the Dolby Vision ATV and TV and the colors were not even close to what the movie was like. Sold me big time to be sure to get as high color performance as I can get.
This has been discussed a few times (and I cannot speak about the new Mary Poppins), but the filter is most important for content which reaches near 100% saturation points which is largely animation. However, comparing a DV theatrical experience to that at home introduces a lot of different variables which can impact the perception of color aside from technology differences, calibration, etc. Interestingly enough, a lot of movies (non-animation) at rec 2020 tend to have a more nuanced saturation level when compared to the rec 709 BD version which can look a little more artificially pumped up by comparison especially with a more limited dynamic range.
Craig Peer likes this.
DavidHir is online now
post #12395 of 13653 Old 12-27-2018, 12:56 PM
Wizziwig's Avatar
Quoted: 2238 Post(s)
Liked: 1522
Originally Posted by smitty View Post
Interesting point. I have a Da-Lite High Power screen, and the gain will like range from 1.8 to 2.2, depending on where I end up placing the projector.
As another owner of the High Power 2.8 screen (measured about 2.0 in my setup), I will second bobof advice to definitely go for the models with dual irises (N7/NX9). Even with dual irises, I found the RS600/R640 too bright for SDR on my small 106" screen, even with both irises clamped all the way down. I can only imagine what it would have looked like with only a single iris. Excessive brightness on these projectors is a bad thing because it exposes various flaws in the source material (such as compression artifacts) and raises your black floor. Also seems to make the grain/texture of the HP screen material more noticeable. The additional flexibility to fine tune peak brightness is more valuable to me than the higher contrast specs.
One caveat to the above advice would be for anyone sensitive to JVC brightness flicker/pulsating. If you're in that group, it will render some of the dual iris benefits moot since you can't lower the iris very far before the flicker becomes too distracting. It's still unknown if this is an issue that was improved on these new models.
smitty, Toe, Highjinx and 1 others like this.
Wizziwig is offline
post #12396 of 13653 Old 12-27-2018, 01:11 PM
Gary Lightfoot's Avatar
Quoted: 1302 Post(s)
Liked: 1054
It was still there on the N5 I saw a few weeks ago. I wasn't looking for it but there was a test pattern on screen and the pulsating caught my attention straight away.
Originally Posted by elmalloc
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is offline
post #12397 of 13653 Old 12-27-2018, 02:04 PM
Toe
Toe's Avatar
Quoted: 2725 Post(s)
Liked: 3590
Yep.
Toe is online now
post #12398 of 13653 Old 12-27-2018, 04:51 PM - Thread Starter
We're Nuts About AV
ARROW-AV's Avatar
Quoted: 4115 Post(s)
Liked: 6644
Originally Posted by Bytehoven View Post
Hello Nigel and thanks for the vote of confidence. However, because i am not in line to be an early adopter of the next series, the new owners thread would be better served by someone investing in one of the new products... Im looking forward to watching from the side lines and supporting whoever takes on the challenge.
Originally Posted by ddgdl View Post
I nominate Nigel, so he can update the first post with his test results when he has them
Originally Posted by DLCPhoto View Post
Whether it's done here, or in a new Owner's thread, I personally don't care, but I think most here trust your evaluations to be as objective and unbiased as possible, which is what AV'Science' is all about. I for one have no problem with your starting an Owner's thread... Hopefully it won't be long now!
Anyone that promises to update the first post regularly so the thread doesn't become 500 pages of people asking the same questions has my vote!
Well, OK then!
Official JVC RS3000/NX9 - JVC RS2000/NX7/N7 - JVC RS1000/NX5/N5 - Owners Thread
ARROW-AV is online now
post #12399 of 13653 Old 12-27-2018, 04:59 PM - Thread Starter
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6644
And when you do get yours delivered, I would suspect you'd want to be as thorough as possible, to base your observations on a wealth of evidence, and I think that's the way to do it.
But at the same time, many are likely waiting to get some information on production units as soon as possible, to clinch their decision to commit significant funds to any of these models. In that regard, you might consider posting some preliminary observations, on such matters as DI function, Sync times, whether or not there are any unexpected findings (either positive or negative), etc., as well as general comments on whether the production units live up to the considerable hype that is present so far, that can be used in finalizing those decisions.
You're absolutely correct that I will be wanting to be as thorough as possible; however, as you rightly say, many folks will be wanting objective feedback ASAP so I will indeed post my feedback accordingly, providing preliminary information as soon as is physically possible and then continuously adding to this as I complete the evaluation process; a bit like how I did with respect to the SONY 885/760ES, however this time, instead of posting the salient information across many posts throughout the thread what I will do is to continuously add to and thereby flesh out the initial posts in the thread such that all the information is retained right at the start of the thread. How does that sound?
post #12400 of 13653 Old 12-27-2018, 05:18 PM
Quoted: 4884 Post(s)
Liked: 1849
I know this was how it was done for all the previous models, but personally I think the models are way more similar to one another than they are different - discussions on tone mapping, custom curves, autocal etc apply equally to all three models.
Dominic Chan is online now
post #12401 of 13653 Old 12-27-2018, 05:40 PM
blee0120's Avatar
Quoted: 901 Post(s)
Liked: 614
Definitely should be just one for all three. Should have always been the case.
Jive Turkey and zombie10k like this.
blee0120 is offline
post #12402 of 13653 Old 12-27-2018, 06:21 PM - Thread Starter
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6644
Very happy to go with the majority view... What does everyone else think? One owners thread for all models or keep split into two threads as per historically?
post #12403 of 13653 Old 12-27-2018, 06:29 PM
DLCPhoto's Avatar
Quoted: 1601 Post(s)
Liked: 719
I'd lean toward a single Thread, as I think all 3 models have more in common than they have differences. There is often redundant, parallel posting dealing with the same issues with the current divisions, and given how many interesting tangents arise, it might be better contained within a single thread.
As an RS400 owner, I found myself posting much more in the RS600 thread simply because the traffic was much greater there, with more knowledge and expertise available (with some exceptions, of course). I ended up having to follow both threads to learn what I needed to.
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, powered by 2 bridged Adcom GFA-555
Center: Revel C208 powered by Cambridge Audio Azur 851W
Dolby Bed (4): Sony Core SS-CS5, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLCPhoto is online now
post #12404 of 13653 Old 12-27-2018, 06:47 PM
zombie10k's Avatar
Quoted: 5378 Post(s)
Liked: 5712
zombie10k is offline
post #12405 of 13653 Old 12-27-2018, 07:30 PM
Craig Peer's Avatar
Quoted: 6993 Post(s)
Liked: 8287
Brother, you should head up the new JVC thread !!
[email protected] JVC RS4500, Lumagen Radiance Pro, Panamorph Paladin DCR lens, Stewart Luxus Model A ElectriScreens - 128" diagonal 2.35:1 ST130 & 122" diagonal 16:9 Cima Neve, Denon X8500, Parasound A 52+ amp, Martin Logan Motion series 9.4 speakers, four SVS subs, Panasonic UB820, Oppo 203, PFP M1500 UPS
Craig Peer is online now
post #12406 of 13653 Old 12-27-2018, 07:34 PM
blee0120's Avatar
Quoted: 901 Post(s)
Liked: 614
Let's make avsforum history with one thread.
blee0120 is offline
post #12407 of 13653 Old 12-27-2018, 07:53 PM
tommarra's Avatar
Quoted: 636 Post(s)
Liked: 381
I would second one thread for all the. Even JVC manual is just one PDF
Gear: Fronts: B&W 803D3 | Center: B&W HTM2D3 | Surrounds: B&W 705S2 | Backs: B&W DM601S3 | Heights: Definitive Techonlogy ProCinema 1000 | Receiver & Amps: Anthem MRX 720 + Emotiva BasX-5 | Projector: JVC NX7 | Source: HTPC with Nvidia 2070, Kodi + External Player: MPC-HC with MadVR (for Blu-ray rips), Nvidia Shield (for streaming content)
tommarra is online now
post #12408 of 13653 Old 12-27-2018, 09:49 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6689 Post(s)
Liked: 6685
Cleveland Plasma is online now
post #12409 of 13653 Old 12-27-2018, 09:58 PM
Quoted: 229 Post(s)
Liked: 108
Single thread.
RapalloAV, ARROW-AV and wombats like this.
Colozeus is offline
post #12410 of 13653 Old 12-27-2018, 10:15 PM
Craig Peer's Avatar
Liked: 8287
The lens and 8K eshift does make the RS3000 a bit different from the RS1000 and 2000 though. For sure the RS1000 & 2000 should be in one thread.
post #12411 of 13653 Old 12-27-2018, 10:15 PM - Thread Starter
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6644
post #12412 of 13653 Old 12-27-2018, 10:18 PM
stumlad's Avatar
Quoted: 147 Post(s)
Liked: 60
I remember back in the RS1 days, people who felt the image was too bright used neutral density filters...I'm curious if this would still be an option for those going with the RS1000/NX5.
stumlad is offline
post #12413 of 13653 Old 12-27-2018, 10:25 PM
Jim Cutter's Avatar
Quoted: 193 Post(s)
Liked: 189
I'm up for a single thread too. I'd imagine that the number of RS1000/N5 owners will be few compared to the RS2000/RS3000.
Theater Room - JVC RS2000, Dalite 148" Scope, Pioneer SC-65, Panasonic UB820, Energy APS 5+2(2), Energy AC 300(1), Energy CR-3(4), PSA 15"Sub(2)
Sports Room - JVC RS4810, Dalite 106" 16:9, Onkyo TX-SR875, Oppo BDP-103, Energy C-7(2) w/Energy S8.2(2), Energy C-C3(1) w/Energy S10.2(1), Energy CR-3(3), Energy S12.3
Jim Cutter is offline
post #12414 of 13653 Old 12-27-2018, 11:56 PM
Old A/V Addict's Avatar
Quoted: 35 Post(s)
Liked: 62
One thread please. I have more than enough AVS Forum bookmarks already!
Oppo 203>Marantz 7704>JVC RS520
Old A/V Addict is offline
post #12415 of 13653 Old 12-28-2018, 02:07 AM
Quoted: 646 Post(s)
Liked: 352
Well suffice to say it's pretty unanimous... Single thread it is then!!!
I've asked a Moderator to make the necessary amendments
Onw thread
Sent from my SM-G930T using Tapatalk
jorgebetancourt is online now
post #12416 of 13653 Old 12-28-2018, 02:42 AM
mtbdudex's Avatar
Quoted: 84 Post(s)
Liked: 1534
Thx for making the thread, I’ve got the RS400 so will be closely reading it for my late 2019 or early 2020 next projector.
mtbdudex is offline
post #12417 of 13653 Old 12-28-2018, 03:50 AM
DLCPhoto's Avatar
Liked: 719
True. In a sense, the NX9 stands in its own category due to the different lens and the 8k eShift, as you point out. On the other hand, the lack of the Filter and Double Aperture put the NX5 in its own category, apart from the other 2.
But I think there is more to be gained by addressing their similarities in a single thread, in terms of overall efficiency, while discussion of the features they don't share in common can still take place within the thread with minimal disruption (or at least no more disruption than usually takes places in an AVS thread!!).
And it appears the 'ayes' have it, so one thread it is! Thanks to Nigel for heading this up.
post #12418 of 13653 Old 12-28-2018, 06:21 AM
Mike Garrett's Avatar
Quoted: 12547 Post(s)
Liked: 10167
One thread will be less work for me. Will only have to go to one thread to post corrections and updates.
Mike Garrett is online now
post #12419 of 13653 Old 12-28-2018, 06:26 AM
den110's Avatar
Quoted: 61 Post(s)
Liked: 38
You think so? I would love to go up to the 2000/3000, but that's a lot of dough....
Dedicated HT Equipment: Klipsch RF82BK L+R Speakers|Klipsch RC62BK CC Speaker|Definitive Technology B92X Surrounds|NHT Super One Rear Surrounds|4 Polk MC80 Ceiling Atmos|Velodyne VLF 1012 and Definitive Technology PF1500TL+ SWs|Marantz SR7012 Receiver|Yamaha RXV1800 Receiver for Atmos|JVC RS2000 Projector|Seymour Center Stage UF AT 140" diag 2:35 Screen on DIY frame and false front wall
den110 is online now
post #12420 of 13653 Old 12-28-2018, 07:15 AM
DennisLJacob's Avatar
Quoted: 174 Post(s)
Liked: 96
Can some of the experts in all things JVC describe and comment on the differences between the RS 3000 vs. RS2000 - on paper at least. I know the RS2000 has been absent at all the venues. That's why I'm interested in the theoretical differences. I view the 8K e shift as a non issue due to the handling of native 4K sources that are upscaled to 8K to then be E shifted. Maybe I'm wrong on that point, so correct me if I'm wrong.
DennisLJacob is offline
eshift , Jvc , native 4k , projector , uhd
