NEW JVC RS3000/NX9 RS2000/N7 RS1000/N5 Native 4K Projectors Anticipation Thread - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 13017Likes
post #1291 of 13655 Old 08-30-2018, 04:13 PM
Per Johnny's Avatar
Quoted: 140 Post(s)
Liked: 89
Originally Posted by christoffeldg View Post
So the Sony vs JVC wars have already resumed
I would argue against that really. Again, the JVC doesn't have Reality Creation nor does it have a laser engine. Hence it is very much comparable to the VW760ES. It's even priced pretty much in the same range. The 870 should be considered in a different category alltogether.
That doesn't mean that it isn't a very interesting device, I'm not going to just believe that 100k contrast number until I know exactly what it means yet however. I am curious to the performance of the lens.
I'm also wondering what this 8k exactly does tho. I find eshift for upscaling not good at all, and as far as I know there's not going to be any 8k input? That's really too bad, I really see a lot of potential if we can actually utilize that 8k resolution.
What is the use of Reality Creation? It does only 'bad things' in my opinion for sources like UHD and BluRays. Studios are using millions of dollars to make 'masters' true to original source, and putting them on high-quality media, and we shall use processing that makes them overly sharpend, removing fine-detail and introducing unwanted artefacts?
J.P and llang269 like this.
Per Johnny
Per Johnny is offline
post #1292 of 13655 Old 08-30-2018, 04:13 PM
Craig Mecak's Avatar
Quoted: 315 Post(s)
Liked: 243
Do these new JVC Projectors do 3D?
Yamaha RX-A3060 7.1.4 Receiver [+Sony Power Amp for Rear Height] / Sony KD-65Z9D / JVC HD1 DILA Projector / 90" screen / OPPO UDP-203 UHD blu-ray / Apple TV 4K
Ascension Summoner 3-way Front Speakers / Ascension 3-way Centre Speaker / Peachtree D5 Surrounds / Yamaha NS-555 3-Way Rear Speakers / ERA D4 x 4 Height Speakers / Rythmik Audio F15HP Sub
Craig Mecak is online now
post #1293 of 13655 Old 08-30-2018, 04:18 PM - Thread Starter
We're Nuts About AV
ARROW-AV's Avatar
Quoted: 3829 Post(s)
Liked: 6250
Originally Posted by Manni01 View Post
I understand that you will both be attending the same private demo, so I guess there is no point in asking the same questions twice...
Well how about that... It's a small world isn't it? Therefore, your 'friend of a good friend' is Ran
Looking forward to your contrast measurements though, if they let you measure (and publish) on-off contrast measurements from a pre-production unit in a (most likely non-dedicated) showroom, that will be welcome. But please, don't post the measurements if there is any ambient light, reflected or not, in the room. We need accurate, meaningful measurements or nothing.
Do I have a track record of taking and publishing inaccurate non-meaningful measurements?
ARROW-AV is offline
post #1294 of 13655 Old 08-30-2018, 04:20 PM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 6315 Post(s)
Liked: 6320
You can only test what is in front of you which will be a prototype....... But hey with all these posts, something is better then nothing
Originally Posted by darinp View Post
Just doing other things, but this does tend to be the most exciting part of the year here. Looks like we'll have a pretty good CEDIA this year.
--Darin
From some old timers from way back when, I heard CEDIA and CES where quite the party behind closed doors, work all day, party all night Nothing like what they are today I guess, started going I think 12 years ago, that was my first year.
Originally Posted by Craig Peer View Post
There is usually no time at these shows for measurements. Anyway, better to get an actual production unit to measure, and have the time to do it right on one's own home turf !
Yep, no kidding have been to many, just responding to someone mentioning testing at shows.
Cleveland Plasma is offline
post #1295 of 13655 Old 08-30-2018, 04:21 PM
farsider3000's Avatar
Quoted: 1405 Post(s)
Liked: 792
I really want the NX9 or NX7 but without HDMI 2.1 and the fact that there are many new components, I will wait this round out as there will be quality issues that are sorted out in the second year of production.
Sent from my iPhone using Tapatalk Pro
7.4.6 system: Processors:Marantz 8805 || Xilica XP4080 Amps: Parasound A31 and ATI AT528NC & AT526NC n-core ||Speakers: Procella P8 LCR, Procella P5 for surround & ceiling
Subs: JTR Captivator S2, JTR Captivator S1, 2 Seaton Submersive (dual 15")
Screen: 2.40:1 Seymour XD Acoustically Transparent, 128" diagonal / 118" wide || Projector: JVC X570/RS420
farsider3000 is offline
post #1296 of 13655 Old 08-30-2018, 04:24 PM
LumenChip's Avatar
Quoted: 222 Post(s)
Liked: 123
Originally Posted by Highjinx View Post
Wasn't the RS4500 native 4k chip's pixel pitch of 3.8 μm as well?
Definitely, but this is in relation to how the 4K contrast got here from the previous 1080p series.
LumenChip is offline
post #1297 of 13655 Old 08-30-2018, 04:26 PM
Quoted: 122 Post(s)
I kindly ask you please, changing my past post, if the N7 has a notorious improvement over the X 950 I own, considering the known specs, adding that my projection room is pretty dark, all blacked out. I use the Oppo 205 to upscale 1080p to UHD. I'd be thankful if someone could answer me. Thanks in advance.
Walter Santos Filho is offline
post #1298 of 13655 Old 08-30-2018, 04:28 PM
HoustonHoyaFan's Avatar
Quoted: 304 Post(s)
Liked: 168
The detail is all in the source material. You cannot create detail out of thin air.
Of course you can. Motion interpolation is one current example. Image processing is full of algorithms designed to somehow "enhance" the image.
The better question is when you create detail did you you do it correctly or did you introduce enough artifacts that the result is worse than leaving the original as-is.
Sony believes that the processing algorithms in their Reality Creation suite makes displayed motion images "better". A lot of users and focus groups seem to agree.
HoustonHoyaFan is offline
post #1299 of 13655 Old 08-30-2018, 04:30 PM
Frohlich's Avatar
Quoted: 1959 Post(s)
Liked: 2128
Didn't you do the same last year with the Sony projectors (I thought I remembered you from the 385 thread)? There will always be a reason to wait but things change so quick that at some point you just have to pull the trigger....or pull the trigger every year like some of us
Toe, llang269 and bochoss like this.
Frohlich is offline
post #1300 of 13655 Old 08-30-2018, 04:33 PM
Liked: 792
I will likely buy the Trinnov Altitude 16 this year and then buy one of the new JVC this time next year..... if I can take reading all the glowing reports of these amazing new projectors.... I may snap under the pressure and put off the Trinnov!
post #1301 of 13655 Old 08-30-2018, 04:34 PM
Highjinx's Avatar
Quoted: 1219 Post(s)
Liked: 496
Got ya... reduction in aperture ratio.
May the success of a Nation be judged not by its collective wealth nor by its power, but by the contentment of its people.
Hiran J Wijeyesekera - 1985.
Highjinx is offline
post #1302 of 13655 Old 08-30-2018, 04:35 PM - Thread Starter
We're Nuts About AV
ARROW-AV's Avatar
Liked: 6250
It's a pre-production unit. We all know this. It's the final hardware, but with beta firmware. I will be taking accurate measurements. I will also soon be taking accurate measurements of the first lot of production units with the proper launch firmware. I bet you that I will not be seeing a huge difference. Would you like to take that bet?
ARROW-AV is offline
post #1303 of 13655 Old 08-30-2018, 04:36 PM
Liked: 792
Do we know if these new Projectors are using the panels from the 4500?
post #1304 of 13655 Old 08-30-2018, 04:37 PM
enricoclaudio's Avatar
Quoted: 3601 Post(s)
Liked: 4292
As soon I get mine, you are more than welcome to come to my place to check it out and help me with initials setting as this is my first JVC ever.
Mike Garrett likes this.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik F12SE(x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | 92" Stewart ST100 | Sony VW295ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #1305 of 13655 Old 08-30-2018, 04:38 PM
Liked: 792
That would be cool. Keep me updated.
enricoclaudio likes this.
post #1306 of 13655 Old 08-30-2018, 04:41 PM
christoffeldg's Avatar
Quoted: 1310 Post(s)
Liked: 526
Originally Posted by bobof View Post
Sure, let's park it; but I will just say you should probably spend a little of your time watching the two videos here (thanks to @Gary Lightfoot for the links from a while back). It >might< change your view of 2K DI content.
http://yedlin.net/ResDemo/#
If you only get though the first 10 mins of part 2 you'll see why Reality Creation making stuff sharper is probably not getting you closer to what you think should have been the sharpness of a 4K version; the 2K DI rescaled back to 4K may well be perceptually sharper than the 4K would have been if you could have got access to it...
Hey Bobof,
I've got a double impression of that video.
On the one hand it's interesting to see the minimal difference between 6k and 2k (However, I still stand by what I said in that I find most content to be subpar). On the other hand, they also show what a good upscaler can do to an image. Even though the upscaler the video used is a lot coarser than what I'm used to, the effect is the same.
Video: Sony VPL-VW760ES, Elite screen Aeon 135" Cinewhite + JVC X7900, Magicscreen Reference ALR 120"
Speakers: Bowers and Wilkins 802 D3 front, JBL 580, JBL 520c, JBL 550p
Amplifiers: Lyngdorf stereo TDAI 2170, Lyngdorf SDA 2400, Denon 4300H Home Theatre
Equipment: PC/PS4/Xbox One/Switch/Synology 2415+
christoffeldg is offline
post #1307 of 13655 Old 08-30-2018, 04:43 PM
Liked: 526
No they're not, they're not using millions of dollars at all. They're GAINING millions of dollars by selling these barely improved sources.
I use it a LOT, and I find it extremely impressive. It's the best upscaler I've ever seen.
What exactly makes you think it removes fine detail or overly sharpens? The unwanted artefacts are certainly there, but far less pronounced than what eshift does even with a 4k source.
post #1308 of 13655 Old 08-30-2018, 04:46 PM
Liked: 526
Hey Arrow, another question for you to fire if you can.
What exactly is the purpose of the 8k eshift? Are they going to provide some kind of 8k input? And if not, what type of scaling are they going to use for the output?
post #1309 of 13655 Old 08-30-2018, 04:50 PM
LumenChip's Avatar
Quoted: 222 Post(s)
Liked: 123
I recognize that your list is growing but have one question to add:
Will the N5 with the lack of lens iris measure higher calibrated lumens than the N7 & 1700 lumens in the marketing material?
post #1310 of 13655 Old 08-30-2018, 04:52 PM
Toe
Toe's Avatar
Quoted: 2661 Post(s)
Liked: 3383
Yeah, I seem to be back on the "pull the trigger every year path"!
Toe is offline
post #1311 of 13655 Old 08-30-2018, 04:52 PM
Highjinx's Avatar
Liked: 496
Highjinx is offline
post #1312 of 13655 Old 08-30-2018, 05:01 PM
alebonau's Avatar
Quoted: 1799 Post(s)
Liked: 1227
@ARROW-AV , is there a list of question for you already...dont want to overburden or ask something already asked before
but I am really keen to understand the auto HDR aspect. and HDR10 support.... are they forgoing DV in that case is HDR10 king ? and how are they supporting exactly I wonder. ...
are these jvc finally plug and play with UHD ? without needing hd furies and gamma curves and what not ?
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
post #1313 of 13655 Old 08-30-2018, 05:04 PM
Rob-Houston's Avatar
Quoted: 143 Post(s)
Liked: 95
No, but the little puppy that keeps following you around keeps messing on the thread floors with inaccurate statements!
You need to house train him!
Craig Peer likes this.
Rob-Houston is offline
post #1314 of 13655 Old 08-30-2018, 05:08 PM
Javs's Avatar
Quoted: 6779 Post(s)
Liked: 6395
Have you ever used madvr?
OzHDHT and ARROW-AV like this.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #1315 of 13655 Old 08-30-2018, 05:12 PM
Liked: 526
That's true, the Madvr screenshots you made I can't replicate.
post #1316 of 13655 Old 08-30-2018, 05:20 PM
Jmouse007's Avatar
Quoted: 214 Post(s)
Liked: 178
Yes, my Dad advised me to "never buy the first model year of a new car" because there will always be "bugs" that the manufacturer, owners and users will only discover AFTER they have purchased and used it for some time.
This advice also holds true for PJ's. I didn't follow my dad's advice, and learned my lesson the hard way. I bought the first year production model HDMI Sony Pearl (VPL-VW50).
We had to ship it back to SONY Corp SIX TIMES FOR REPAIR; SONY HAD IT FOR A TOTAL OF 18 MONTHS before they finally offered to "replace it with the next year's model Sony VPL-VW60, for a 'nominal fee''" ONLY AFTER WE CONTACTED AN ATTORNEY, GOT THE STATE'S "DEPARTMENT OF CONSUMER AFFAIRS" DIRECTLY INVOLVED AND THREATENED LEGAL ACTION!
Unsurprisingly, the replacement model Sony VPL-VW60 had rectified all of the defects that numerous Sony VPL-VW50 owners had encountered and reported.
We have put over 15,000 hours on our Sony VPL-VW60 without a hick up. Not one problem, and it has never needed repair.
Fortunately we use it nearly every day in a climate controlled environment and it is only now beginning to exhibit some panel degradation issues.
We are looking for a 4K replacement but aren't in any rush to be "early adopter" test guinea pigs. We will bide our time and wait for the "latest technology bugs" to be discovrred and worked out.
Another example are those who plopped down over $25,000 dollars for the 4K Sony 1000ES, only to discover it wasn't ready for prime time and couldn't even play native 4K without shipping it back to Sony for a "hardware update"! Hence the need for the Sony 1100ES.
Yes, the new native 4K JVC pj's, especially the 8Ke-shift look really good on paper, but we'll wait until after this year's models "shake down cruise" are over, and the "bugs" are discovered and rectified in next year's "new and improved"/updated models.
Jmouse007 is offline
post #1317 of 13655 Old 08-30-2018, 05:29 PM
Liked: 792
Totally agree.
Bytehoven and entourage2194 like this.
post #1318 of 13655 Old 08-30-2018, 05:44 PM
Toe
Toe's Avatar
Liked: 3383
They sure do! 3d is still intact.
Craig Mecak and alebonau like this.
Toe is offline
post #1319 of 13655 Old 08-30-2018, 05:58 PM
Craig Peer's Avatar
Quoted: 6564 Post(s)
Liked: 7589
When I had my VW600 and RS600 stacked so I could use either one, there was only one movie I thought looked better on the VW600 at the time - " Mad Max : Fury Road ". Everything else looked pretty close motion wise ( but they look different at times ). Motion hasn't been an issue at all on the RS4500. I'm curious to see what the motion handling looks like on the new JVC 4K machines.
Craig Peer is online now
post #1320 of 13655 Old 08-30-2018, 06:42 PM
Mike Garrett's Avatar
Quoted: 11662 Post(s)
Liked: 9222
Honestly, this is a very serious question tho. Would really like the answer to that.
Yes, but nobody is going to answer that question, before the show.
Mike Garrett is online now
eshift , Jvc , native 4k , projector , uhd
