NEW JVC RS3000/NX9 RS2000/N7 RS1000/N5 Native 4K Projectors Anticipation Thread - Page 456 - AVS Forum | Home Theater Discussions And Reviews
 13021Likes
post #13651 of 13664 Old 03-01-2019, 10:38 AM
smitty's Avatar
Quoted: 764 Post(s)
Liked: 1020
Originally Posted by Dr.Tom 2001 View Post
Hello Gents - my son just received his NX-7...how many hours will it need on it before it can be calibrated?
Please advise.
This is the anticipation thread. You probably want to post this in the owners' thread. But I believe that the usual recommendation is 200 hours.
P.S. I also don't think it's kosher to post stuff for sale outside of the for sale forum. I'm not positive, but I think I recall that.
smitty is offline
post #13652 of 13664 Old 03-01-2019, 01:08 PM
Quoted: 44 Post(s)
Thank you Smitty...
[QUOTE=smitty;57678526]This is the anticipation thread. You probably want to post this in the owners' thread. But I believe that the usual recommendation is 200 hours.
I checked with Michael Lang - he said it is OK to post it at the footer as long as you don't discuss it in the thread...
Dr.Tom 2001 is offline
post #13653 of 13664 Old 03-02-2019, 06:20 PM
Quoted: 44 Post(s)
[quote=Dr.Tom 2001;57679370]Thank you Smitty...
Thank you for your concern...I appreciate it.
Paladin DCR w/ M2 Kit For Sale - $5995 - Located in the "Front Projector section of the Classified"
Lumagen Pro 4242 for sale - Located in the "This and That Section of the Classified"
smitty likes this.
post #13654 of 13664 Old 02-10-2020, 07:47 AM
puntloos's Avatar
Quoted: 70 Post(s)
(sorry, thread is really too long to search at this point..)
As far as I can tell these JVCs don't support Dolby Vision. Should I be sad about this? Any chance JVC might firmware update? Wait until the N6, N8 and NX10? Thoughts?
Kodi Streamer -> Denon X4500 -> Nord 500DMUP -> Quad 2912
puntloos is offline
post #13655 of 13664 Old 02-10-2020, 07:51 AM
Quoted: 6131 Post(s)
Liked: 2543
https://www.avsforum.com/forum/465-h...rojectors.html
Dominic Chan is offline
post #13656 of 13664 Old 02-10-2020, 07:57 AM
ScottSFA's Avatar
Quoted: 283 Post(s)
Liked: 100
Zero projectors do Dolby vision.
65" Sony A9F
Arcam SR250
Bowers & Wilkins 702s
REL T7i
ScottSFA is offline
post #13657 of 13664 Old 02-10-2020, 10:12 AM
blee0120's Avatar
Quoted: 1081 Post(s)
Liked: 782
Is there a reason you think it will be Dolby Vision is needed?
blee0120 is offline
post #13658 of 13664 Old 02-10-2020, 11:56 AM
Mike Garrett's Avatar
Quoted: 13760 Post(s)
Liked: 11409
None of these projectors support Dolby Vision and if waiting for that, it might never come.
Mike_WI likes this.
Mike Garrett is offline
post #13659 of 13664 Old 02-10-2020, 07:00 PM
puntloos's Avatar
Quoted: 70 Post(s)
Thanks everyone, indeed waiting for new features is often a bad idea. Dolby Vision was touted as a more intelligent way to do HDR, but eh, I think HDR10 might be sufficient regardless....
puntloos is offline
post #13660 of 13664 Old 02-11-2020, 04:04 AM
markmon1's Avatar
Quoted: 6525 Post(s)
Liked: 4662
These projectors do frame by frame tone mapping without dolby vision and it supports all HDR10 sources. Dolby vision works similar in that the mastering engineer can store off in the video meta the frame light level. JVC projector ignores the meta and measures the frame light level on the fly. The result is great.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #13661 of 13664 Old 04-26-2020, 09:13 AM
westmd's Avatar
Quoted: 1009 Post(s)
Liked: 437
I am a bit puzzled. I had a X7000 and a Paladin DCR. Was really happy with the lens optimising picture quality significantly. Now updated to the NX9 and reinstalled the DCR lens after using the projector without the lens for the first week. Now without the lens picture quality is super sharp with great contrast. With the lens I somehow have the feeling to loosen both contrast and sharpness significantly. I presumably can still optimise the positioning of the lens but it wasn't too far off? Any ideas?
westmd is online now
post #13662 of 13664 Old 04-26-2020, 09:23 AM
Craig Peer's Avatar
Quoted: 7938 Post(s)
Liked: 10296
It has to be the position of the lens in relation to your NX9.I didn't lose any sharpness or contrast using it with my RS4500. But it took quite a bit of fine tuning to get the lens positioned just right.
Azekecse likes this.
Craig Peer is offline
post #13663 of 13664 Old 04-26-2020, 10:57 AM
Liked: 11409
Place a piece of white paper between your A-lens and the projector lens. Have the paper against the back of the A-lens. Is the image centered on the A-lens? Next place the paper on the exit side of the A-lens. Is the image centered there? Note, you posted in the anticipation thread, not the owners thread.
post #13664 of 13664 Old 04-27-2020, 08:32 AM
Azekecse's Avatar
Quoted: 247 Post(s)
Liked: 239
This certainly helped me to ensure my DCR lens was properly centered/aligned, thx MG...Because the lens is larger than your previous JVC you may have to move the lens further out to compensate for the ~1/3 increase in lens size and/or move the projector further back to increase the TD. Just my quick thoughts, hope this helps.
Peace and blessings,
Azeke
Marantz SR7011: 7.4.4 Martin Logan Edges (4: FR/FL/SR/SL) Martin Logan Axis (2: SBL/SBR) Martin Logan Stage X (Center) Martin Logan 1500X Sub (2) Martin Logan 1100X Sub (2) Sonance VP86R SST/SUR (4: Dolby Atmos) JVC NX-7/DaLite 125" 2:35:1 Scope Screen; Paladin DCR
Azekecse is offline
eshift , Jvc , native 4k , projector , uhd
