BenQ HT9050 - how does it compare to more popular projectors under $5K? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 32Likes
post #31 of 123 Old 06-07-2019, 07:36 PM
Aztar35's Avatar
Quoted: 3108 Post(s)
Liked: 1808
@Solarium , I know it's off topic, but you might also want to look at the Sonys too. Another forum member just recently showed me some charts of how well the Sony 4K projectors handle contrast across the ADL spectrum and how high they are over 1% ADL.
Aztar35 is offline
post #32 of 123 Old 06-08-2019, 05:41 AM
Ruined's Avatar
Quoted: 2643 Post(s)
Liked: 1273
Originally Posted by Daddyduke View Post
Hi guys haven't read every page on topic yet but I would like to know if the ht5550 would be in the same ball park as the ht9050 saw a lot of bad reviews on the ht9050 while the ht5550 has better reviews than the ht9050 so I'm just confused completely can someone share any thoughts about this thanks
I would pass on both the ht9050&ht5550 and instead try to get a ht9060 refurb by calling BenQ direct.
Ruined is offline
post #33 of 123 Old 08-11-2019, 09:59 PM
blee0120's Avatar
Quoted: 1096 Post(s)
Liked: 788
I have a few questions about the ht9050 compared to the ht9060. Do both have the same lens? And how do they differ in contrast? I'm thinking about picking up a ht9050 or HT5550. I will be using MadVR for my 4k HDR material and the ht9050 not having HDR will not be a problem.
blee0120 is offline
post #34 of 123 Old 08-12-2019, 06:08 AM
Mike Garrett's Avatar
Quoted: 14030 Post(s)
Liked: 11694
Same lens and native contrast should be the same. I would avoid the 9050 like the plague.
Mike Garrett is online now
post #35 of 123 Old 08-12-2019, 10:36 AM
blee0120's Avatar
Liked: 788
You think I should look at the benq ht5550 or move toward the ht9060?
blee0120 is offline
post #36 of 123 Old 08-12-2019, 10:43 AM
Liked: 11694
The 9060 is obviously the better projector, but what are you planning on using the projector for and what is the room going to be like?
post #37 of 123 Old 08-12-2019, 11:12 AM
blee0120's Avatar
Liked: 788
A second projector to go along with my RS2000. The room is a black velvet room. I will be using it for my every day use to not out too many hours on my rs2000.
blee0120 is offline
post #38 of 123 Old 08-12-2019, 11:50 AM
evanft's Avatar
Quoted: 96 Post(s)
Liked: 43
Why wouldn't you just use the JVC? Bulb cost?
JVC RS-520, Elite Screens 16x9 100", XY Screen 2.4:1 115"
Klipsch RP-8000F, RP-450C, 2xRP-240S, 2xRP-402S, 2xSVS PB-1000
Denon AVR-X3200W/HDFury Linker/MiniDSP 2x4 HD
Panasonic UB820/PC/PS3/PS4 Pro/Switch/WiiU/Xbox One X/Original Xbox
Logitech Harmony Hub
evanft is offline
post #39 of 123 Old 08-12-2019, 12:13 PM
Liked: 11694
you can buy a lot of lamps for the cost of the 9050.
post #40 of 123 Old 08-12-2019, 12:31 PM
blee0120's Avatar
Liked: 788
Bulb coat is a nonfactor. Pairing a DLP is a great combination. Already use a Digital Projection M-Vision projector with my RS2000. Always use a dual setup with a LCOS and DLP. I use my JVC for strictly uhd bds. I've been using it more frequently but looking for a 4k led/laser projector for family, friends, and sports
blee0120 is offline
post #41 of 123 Old 08-12-2019, 12:39 PM
blee0120's Avatar
Liked: 788
Bulb cost is not an issue. Just needed a second projector that going to be used daily that is preferable 4k led/laser.
blee0120 is offline
post #42 of 123 Old 08-12-2019, 01:26 PM
Liked: 11694
I can understand having a second projector for sports and TV viewing. That is what I use my RS640 for.
post #43 of 123 Old 08-13-2019, 08:33 AM
Ruined's Avatar
Liked: 1273
The HT9060 is the best overall 4K DLP LED/Laser under $20k IMO. Ht9050 I would pass on though
Ruined is offline
post #44 of 123 Old 08-13-2019, 09:15 AM
Quoted: 830 Post(s)
Liked: 441
I do the same thing.. I have a 1080 projector for the kids below my 640 and thats all they use for gaming.. Sometimes if is a 1080 movie ill just watch it on my kids projector to not use mines.. lol Call it weird but i love it this way.. Mines is strickly for uhd and 3D.. Not even the wife can touch my projector..
I
jorgebetancourt is offline
post #45 of 123 Old 08-13-2019, 10:40 AM
blee0120's Avatar
Liked: 788
I haven't really got a good reason to why I should pass on the ht9050. Then lens and contrast is the same. Both are LED and the same brightness. I know the ht9060 is superior, but can someone outline it for me?
blee0120 is offline
post #46 of 123 Old 08-13-2019, 11:16 AM
Liked: 11694
Read this: https://www.soundandvision.com/conte...ector-review-0
post #47 of 123 Old 08-13-2019, 11:37 AM
SirMaster's Avatar
Quoted: 1366 Post(s)
Liked: 1026
But what if your only source is madVR, so you are always doing HDR -> SDR tone-mapping before the projector and you can map all your content to DCI-P3 for the native LED lamp gamut?
SirMaster is offline
post #48 of 123 Old 08-13-2019, 11:37 AM
blee0120's Avatar
Liked: 788
I need to see what changed with the ht9060, because that review was terrible
blee0120 is offline
post #49 of 123 Old 08-13-2019, 11:40 AM
blee0120's Avatar
Liked: 788
That's true and in my case, would not be an issue since I was Madvr. It looked like the lens, light source, brightness, and contrast is the same.
blee0120 is offline
post #50 of 123 Old 08-13-2019, 11:48 AM
Liked: 11694
https://www.soundandvision.com/conte...ojector-review
post #51 of 123 Old 08-13-2019, 11:54 AM
Liked: 11694
With the 9060, you can't use MadVR and the wider color space for HDR. I can't remember if the 9050 has that same restriction. I do believe that if you can get it to work with MadVR, that you will run into problems, since the 9050 does not have support for BT2020.
post #52 of 123 Old 08-13-2019, 11:54 AM
Quoted: 1522 Post(s)
Liked: 812
This review is a lot more sanguine and seems to match the impressions of HT9060 owners:
https://hometheaterhifi.com/reviews/...jector-review/
and another video review:
with a side by side with a Sony 4K LCOS.
Text version of the above:
https://www.tvspecialists.com/sony-v...ht9060-part-ii
DunMunro is offline
post #53 of 123 Old 08-13-2019, 12:01 PM
SirMaster's Avatar
Liked: 1026
When you have madVR you don't use HDR on the projector, you use madVR to convert HDR to SDR. But even though it's SDR, you can still output the video in the wider color gamut, and of course you get to control the tone-mapping of the nits to your own screen brightness.
You get the wider color gamut when you put the HT9060 in normal or vivid color profile modes, it uses the LED native gamut then which is really close to P3, possibly even beyond P3 in some colors. You can then use a 3DLUT in madVR to trim that down to a very nice P3 gamut and get all the saturations to track nicely too.
I don't see why this would be any different with the HT9050 as well to be honest.
SOWK and rjmcinnis like this.
post #54 of 123 Old 08-13-2019, 12:15 PM
Home Theater Enthusiast
SOWK's Avatar
Quoted: 1741 Post(s)
Liked: 1349
SirMaster, you are so smart!
Wisconsin Home Theater Enthusiasts Meet
SOWK Home Theater
SOWK is offline
post #55 of 123 Old 08-13-2019, 12:46 PM
ultra 150 pilot's Avatar
Quoted: 291 Post(s)
Liked: 266
I tried the 9050 for about a month through Benq direct, Ben Q is a great company to deal with and excellent customer service. The projector itself was plenty bright and sharp contrast was not that great. The worst part of all was the way it handled sports and other material. There was a Judder effect watching basketball or football or anything for that matter. I tried running it through the dvdo edge video processor it helped a little bit but it was still unwatchable. I’m thinking it was all the processing it had to do to make 4K The projector made an annoying buzzing noise all the time too.
Btw at the time I had my infocus 777 3 chip DLP projector, The motion On the infocus is far superior to the 9050
I now have the jvc nx5 and enjoy it for everything...
If you’re insistent on having a second DLP projector than I would stick with 1080p
Just my two cents
ultra 150 pilot is offline
post #56 of 123 Old 08-13-2019, 12:54 PM
Liked: 11694
I seemed to recall Kris saying if not using the HDR mode, the projector mapped to Rec709? I did find the post of kris's regarding the 9050:
"The 9050 did have a proper 2020 color gamut, it uses actual P3. So you would need to ensure that your calibration takes that into account and that the device you're using converts 2020 to P3 (both the Lumagen and MadVR can do this). Performance for the dynamic contrast may be different as others have reported, I did not have a chance to compare the projectors directly for this."
So it looks like the 9050 used with MadVR would not be a problem.
post #57 of 123 Old 08-13-2019, 01:10 PM
Kris Deering's Avatar
Quoted: 4409 Post(s)
Liked: 8049
Correct. All the color modes are what appear to be native gamut, which is a bit all over the place TBH. You could try and correct with a 3D LUT if you have a device capable, but YMMV. But really only applies to those with something like MadVR or a Radiance and the calibration software/hardware to make it work.
SOWK and SirMaster like this.
My Home Theater UPDATED JUNE 2020
Deep Dive AV - Calibration, Consulting and Education
Kris Deering is offline
post #58 of 123 Old 08-13-2019, 01:14 PM
Liked: 8049
You could use MadVR or the Radiance if you have the hardware/software to do LUT calibrations. The native gamut would get you in the ballpark, but because it is so unbalanced, you may have some artifacts associated with the LUT. You would also probably want to convert input signals to P3 unless using Lightspace's LUT options.
post #59 of 123 Old 08-13-2019, 01:54 PM
Liked: 11694
Thanks for the explanation.
post #60 of 123 Old 08-13-2019, 03:31 PM
Ruined's Avatar
Liked: 1273
One big change is the dynamic dimming on the ht9060 actually works while it does barely anything with real content on the ht9050.
Ht9050 also had some weird hardware issue that some people experienced with white flashing (see art feierman's review of ht9050,.also someone on forum had same issue). Ht9060 added 3d and HDR modes as well.
Ht9050 was basically unfinished projector, ht9060 final product.
Ruined is offline
