JVC e-shift5 vs 4K contrast ratio - AVS Forum | Home Theater Discussions And Reviews
 9Likes
  • 4 Post By Javs
  • 1 Post By markmon1
  • 3 Post By Javs
post #1 of 12 Old 09-21-2018, 02:49 PM - Thread Starter
IrishHT's Avatar
Quoted: 55 Post(s)
Liked: 61
I'm just curious what everyone's thoughts are on the native contrast of JVC's e-shift projectors vs their new native 4K ones. The top e-shift model claims 160,000:1 whilst the new mid-range 4K is 80,000:1. I realize the new 4K does have dynamic contrast as well. Any thoughts on this? Thanks everyone!
IrishHT is offline
post #2 of 12 Old 09-21-2018, 03:38 PM
Javs's Avatar
Quoted: 6818 Post(s)
Liked: 6445
We will find out what this means soon enough.
The NX9 has a different lens and thus a different iris, which if looking at the Z1 figures tells you anything means it stops down even more than the current eshift units to a level which is too dim to even be useful, so that could explain the higher contrast ratio on that one unit vs the NX7.
The 20LTD also had an iris which stopped down more than normal, my HOPE is that they did NOT put this in the new models, because that would mean the high contrast spec is a somewhat trick. -10 for eg on the iris would not translate to a similar brightness you have on the eshift machines at -10 now. This is something I will be exploring when I do a shootout with the NX7 and X9500. I am most interest to see wide open iris contrast performance. I hope its north of 20k:1.
With the DI on the new models, if you can still get a contrast ratio into the hundreds of thousdands when enabled, that might be very worth while to give up a slight amount to get some resolution in return.
Admittedly, I am most impressed with my JVC contrast when the DI does its thing, not so much its native, which is at 160k, so I am most anxious to see the new models.
JVC X9500 (RS620) | 120" 16:9 | Marantz AV7702 MkII | Emotiva XPA-7 | DIY Modular Towers | DIY TPL-150 Surrounds | DIY Atmos | DIY 18" Subs
MadVR Settings | UHD Waveform Analysis | Arve Tool Instructions + V3 Javs Curves
Javs is online now
post #3 of 12 Old 09-21-2018, 04:06 PM
markmon1's Avatar
Quoted: 4784 Post(s)
Liked: 3068
The question of stepping down the iris was explicitly asked at CEDIA and JVC said that no, they don't step it down further than the current eshift models.
David Mathews likes this.
Video: JVC RS4500 135" screen in pure black room no light, htpc nvidia 1080ti.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, 2 sub arrays both infinite baffle: 4x15 fi audio running on behringer ep4000 + 4x12 fi audio running on 2nd ep4000.
markmon1 is online now
post #4 of 12 Old 09-21-2018, 04:46 PM
Javs's Avatar
Liked: 6445
Did they mention the 20LTD stops down more than the 'eshift' models?
Because it does
I am DEAD sure I saw lumen output measurements somewhere and the LTD was significantly less lumens at -15 than the normal models.
A nice trick to get to 200k.
Javs is online now
post #5 of 12 Old 09-21-2018, 04:52 PM
markmon1's Avatar
Liked: 3068
Because it does
No, but no one explicitly asked the question regarding the 20LTD. They did ask this regarding the new line. It was explicitly asked if this was the case because it would explain some of the improved contrast numbers over the RS4500. They were explicitly told that they do not clamp down further than the existing e-shift line.
post #6 of 12 Old 09-21-2018, 06:38 PM
Javs's Avatar
Liked: 6445
All a grain of salt until we can test it mate, which I plan on doing almost first thing when I get it... Sit tight.
Javs is online now
post #7 of 12 Old 09-21-2018, 06:41 PM
Mike Garrett's Avatar
Quoted: 11982 Post(s)
Liked: 9501
You know that it is going to be higher native contrast than the chip in the RS4500. Otherwise they would have just used the RS4500 chip.
Mike Garrett is online now
post #8 of 12 Old 09-21-2018, 06:52 PM
Javs's Avatar
Liked: 6445
Of course it do.
I am referring to how they arrive at max contrast.
Javs is online now
post #9 of 12 Old 09-21-2018, 07:01 PM
markmon1's Avatar
Liked: 3068
I'm holding off my order of the RS3000 until I hear from you and arrow's impressions. I am mainly interested in the black floor compared to current models and if additional pumping artifacts are seen to make up for the contrast being half when say the iris in in auto and aperture set to 0. I don't care about pumping on scenes like interstellar 53:30 or end credits. But I do care about it on normal scenes where folks are just talking and maybe one camera view has a bright window in the background and the other is a guy against a wall with no window or a fireplace.
Javs likes this.
post #10 of 12 Old 09-24-2018, 12:41 PM - Thread Starter
IrishHT's Avatar
Quoted: 55 Post(s)
Liked: 61
Looking forward to the testing! I'm rocking an older RS35 and have been wanting to make the jump to 4K but when I saw the native contrast number of the NX7 vs the current X790, I was a bit confused. I'm not an expert by any means, but I've just always been told to generally focus on the native contrast vs dynamic. The main example that I personally draw from is comparing my JVC to my Optoma HD8600. In one weekend I calibrated both with HCFR and an i1 Pro. The difference was very clear. Blacks: JVC. Brightness and sharpness: Optoma.
Video: JVC RS35 or Optoma HD8600 on 120". - 60" Panasonic plasma. - Darby Darblet video processor. - Panasonic BD85 Blu-ray playback.
Audio: Denon X1100W. - Speakers: Philharmonic AA+ LRC, Mirage Omnipolar Spherex surrounds. Subwoofers: - MFW-15 Turbo(amp only), Dual 12".
Misc: Sennheiser HD558 powered by Recon3d USB. HCFR with i1 Pro. PSVR for 3D Blu-ray.
IrishHT is offline
post #11 of 12 Old 09-24-2018, 04:57 PM
Liked: 9501
An Optoma HD8600 would be brighter than an RS35, but it will not be brighter than a current JVC model.
post #12 of 12 Old 11-04-2018, 05:55 PM
pottscb's Avatar
Quoted: 309 Post(s)
Liked: 124
It could appear brighter, DLP whites are disproportionately brighter than the rest of its colors...a hockey game, for example, looks fabulously bright on DLP.
pottscb is online now
