Official Sony VPL-VW295ES Owners Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 269Likes
post #901 of 918 Old 01-05-2020, 02:35 PM
Quoted: 25 Post(s)
Liked: 3
Originally Posted by anderde View Post
Interesting, the old cable which was actually only 35’ long not 40’ like I thought was passing 4K and HDR when looking at the menu when streaming from Netflix and Amazon Prime. It just wouldn’t pass it using my Home Theater PC using Windows 10. Just wouldn’t lock in. It would also pass 4K and HDR from my Sony UB800 Blu-Ray player. Although HDR was an overly dark image. I play MKV 4K HDR movies on my HTPC that the UB800 won’t play the audio on. For some reason the Sony won’t play the audio on Dolby Atmos encoded 4K movies on its 4K player that are an MKV file.
Sorry, meant to ask this question before. I saw an image on this forum showing the software version of 2.1. Mine is 2.0. I couldn’t find any info with a search about the update. What’ does the update do, where to get it, (I’ve searched Sony’s site but couldn’t locate it).
anderde is offline
post #902 of 918 Old 01-06-2020, 10:58 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7015 Post(s)
Liked: 7028
The RUIPRO Fiber Optic HDMI cable (50’) took care of my problem with Win 10 HDR on my HTPC not locking in with my 295es projector. My original HDMI cable is 40’ long. The Optical cable is 10’ longer (Which I’ll be running today) but works very well with faster hand shakes, better color, and a sharper image. Very happy.
Optical Cable upside: Better Image than my 40’ standard cable, very light and thin and flexible for its length. Downside, Very expensive, at least the the the cable I purchased.
Its kind of amazing thru all the years since HDMI was released, people saying you had to update cables when you did not. Now-a-days that is just not the case, cables do matter.... Glad she is fixed !
rwestley and Archibald1 like this.
Cleveland Plasma is offline
post #903 of 918 Old 01-06-2020, 02:58 PM
Quoted: 25 Post(s)
Liked: 3
This is what I was trying to get to lock-in. With the New Fiber Optic cable, success.
Well that didn’t work, couldn’t get my picture to upload from my iPad. Sorry.
anderde is offline
post #904 of 918 Old 01-07-2020, 08:10 AM
Quoted: 25 Post(s)
Liked: 3
Can anyone help me with this?
anderde is offline
post #905 of 918 Old 01-07-2020, 08:17 AM
Mike Garrett's Avatar
Quoted: 12996 Post(s)
Liked: 10632
Often times projectors will come with a newer firmware that may not be released yet to the public. Sometimes it is never released. So if Sony does not have a public release, then you will not get it. But if your projector does not have any problem, then why would you even want it? In other words, don't try and fix something that is not broken.
Archibald1 likes this.
Mike Garrett is offline
post #906 of 918 Old 01-07-2020, 06:37 PM
Senator's Avatar
Hi, is this cable likely to work with the 295es?
https://www.amazon.com/gp/product/B0...WXRNV7N7FN1NAM
Feeding from an Apple TV 4k via Integra RX5.3?
No more training do you require, already know you that which you need.
Senator is offline
post #907 of 918 Old 01-08-2020, 08:34 AM
Liked: 10632
Get this one in the length you need.
https://www.amazon.com/RUIPRO-Suppor...NrPXRydWU&th=1
rwestley likes this.
post #908 of 918 Old 01-08-2020, 04:27 PM
Quoted: 428 Post(s)
Liked: 46
The only issue I have is that the 295ES is dim compared to my previous epson. I have gotten use to 2500 lumens
Asgard1an is offline
post #909 of 918 Old 01-08-2020, 09:48 PM
serff's Avatar
Hi all, if I should start a new thread, let me know. I have a brand new 295es and when watching certain content, we see weird pink halos around bright objects. Usually in the sky. It was very apparent when watching episode 7 of the Mandolorian with the sky. Is there a way to fix this? It is a problem of content, screen, hardware?? What should I do? We are usually watching on an Apple TV and it’s in HDR mode.
serff is offline
post #910 of 918 Old 01-09-2020, 05:13 AM
Archibald1's Avatar
Quoted: 2290 Post(s)
Liked: 1236
I have read the Mandalorian is a dark master in HDR terms and the compression may have some affect as well.
Are your HDMI ports on the PJ set to enhanced format? This needs to be done to enable full 18Gbps HDMI bandwidth.
Also, try match frame rate on the apple tv.
Smooth gradation is something to try after the above options if necessary.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is offline
post #911 of 918 Old 01-09-2020, 10:44 AM
Liked: 10632
Do you ever see any of this when playing a 4K UHD? If not, then I doubt it is the projector.
post #912 of 918 Old 01-09-2020, 01:19 PM
Senator's Avatar
Thanks for the help on the HDMI run.
I am planning on ceiling mounting this, ceiling is 8ft high, projector will be mounted as far back in my room as I can, but likely to be directly above our seats. Is the chief mount (https://www.amazon.com/Chief-RPAU-Un...4QRXQMHFT&th=1) the right mount for the job and will I need anything else?
Builders are putting fixings at the projector location so I'll be able to mount it securely to the ceiling joists.
Senator is offline
post #913 of 918 Old 01-10-2020, 08:59 AM
serff's Avatar
Is the chief mount ... the right mount for the job and will I need anything else?
I used these:
Chief CMA101
Chief RPA020
They fit the 295ES Perfectly. I was told those were made for this projector and I don't disagree!
serff is offline
post #914 of 918 Old 01-11-2020, 08:16 AM
Quoted: 25 Post(s)
Liked: 3
Try the setting on this link. A lot to read but worked for me especially in Cinema Film 2 settings for 4K with HDR. I also came from an EPSON. It won’t match the Epsons light output but works quite well. I set up the TV for SDR material, the Cinema Film 1 for HD and the Cinema 2 for 4K. Be sure to set color correction to ON and adjust the colors also. Make sure you have associated material playing while in each mode. Regular cable (in my case Dish Network) for TV, HD source at 1080P for Cinema 1 and 4K/HDR source for Cinema 2. I’m sure other people have other settings they’ve used but these worked well for me.
https://www.projectorreviews.com/son...tion-settings/
anderde is offline
post #915 of 918 Old 01-12-2020, 04:30 PM
Liked: 0
To perfectly fit the boundaries of my screen, I'm about an inch short at max zoom on the top and bottom (zooming out to watch 2:35) To get it to fit, would I need to move the PJ forward or back a few inches? I have it ceiling mounted, but I have a little flexibility with moving my mount.
orby2000 is offline
post #916 of 918 Old 01-13-2020, 06:20 PM
Liked: 10632
Move it back a few inches.
orby2000 likes this.
post #917 of 918 Old 01-13-2020, 08:32 PM
pidge's Avatar
Quoted: 27 Post(s)
Liked: 41
Can you show me where you saw it? I'd like to reach out to Sony and see if they are willing to provide it.
pidge is offline
post #918 of 918 Old 01-14-2020, 07:45 AM
Quoted: 25 Post(s)
Liked: 3
Post 888 of this forum.
anderde is offline
