Official Sony VPL-VW295ES Owners Thread - Page 32 - AVS Forum | Home Theater Discussions And Reviews
 280Likes
post #931 of 956 Old 01-24-2020, 04:07 AM
Archibald1's Avatar
Quoted: 2398 Post(s)
Liked: 1298
Originally Posted by Scurly View Post
Decided on the JVC - RS2000 today. Cait wait. Thx for everyone’s input.
Good choice. Did you find one below your $4500 ceiling or have you decided to just stump up the extra for the 7/2000?
Let us know your thoughts on the JVC thread once you have it.
“Remember to look up at the stars and not down at your feet. Be curious. And however difficult life may seem, there is always something you can do and succeed at. It matters that you don’t just give up."
Stephen Hawking.
Archibald1 is offline
post #932 of 956 Old 01-26-2020, 10:54 AM
Industry Insider
Cleveland Plasma's Avatar
Quoted: 7134 Post(s)
Liked: 7175
You said it...only Sony or JVC for native 4K , so I am going to stick with 1 of those 2 for my next projector. mount sounds like a new plate will be needed. Hopefully an easy fix.
It will be very interesting to see what Sony does at CEDIA 2020.
Brian Hampton and Archibald1 like this.
Cleveland Plasma is online now
post #933 of 956 Old 01-27-2020, 10:24 AM
cdelena's Avatar
Quoted: 108 Post(s)
Liked: 68
I am happy with my new 295 but have a couple of questions I could use help with...
- I used a feature on my Denon receiver to pop up a status of sound mode and chose an alternative but these pop-ups which worked well on my previous Epson do not work on the Sony. Ideas?
- I find the level of detail in the picture exceptionally good with 4K and high quality sources but less impressive than my previous Epson 5040 with lower quality input. Am I observing a feature of my old projector or a lack of tuning with my new?
UPDATE - the pop-up issue appears to be a user problem and I have corrected it (remote and AVR settings).
cdelena is offline
post #934 of 956 Old 01-27-2020, 11:43 AM
mnieto's Avatar
Quoted: 28 Post(s)
Anyone care to weigh in?
After agonizing over which projector to buy and lurking on this thread since its inception, I've finally bought the 295. Now I need to find a suitable screen that doesn't destroy my budget. My room is in the basement with three windows facing north and is under a deck (so shaded), and I have black-out shades so ambient light won't really be a problem. The long wall is 16' 11". According to the Projector Central calculator, I need a throw distance of 15'3" for a 108" diag screen. The projector is 18.25" long. This means that the pj will be 1.75" away from the back wall, which should be fine since it doesn't appear there are any vents in the back.I'll be hanging it from the ceiling.
I think I've settled on the EluneVision 108" [16:9] Reference Studio 4k fixed with a 1.0 gain. https://www.projectorscreen.com/stor...or-Screen.html
It seems like good value for money. I would appreciate any input anyone might have, especially if you've had a EluneVision screen. BTW, we will be watching 3D from time to time. I wish I could afford a Stewart screen like I used to have.
Lastly, it'll be a couple of months before the room is ready. I think I should take the 295 out of the box and make sure it's working properly. Any tips on what I should do?
Thank you all for the many insights you've provided me through your discussions here.
mnieto is offline
post #935 of 956 Old 01-30-2020, 09:46 PM
Haacksta's Avatar
Hey everyone, it’s been a long time since I have been here. I am in need of everyone’s wisdom once again. From what I can tell, this projector is a great choice if I am looking to be able to play games(Xbox, PlayStation) in true 4K and 60fps without spending a fortune(I wouldn’t want to go higher than 5K). If I am in the wrong there, please let me know. Here is my current setup:
Pioneer Elite SC-35 Receiver
Sony VPL-HW40ES Projector
Definitive Technology BP-8040 Front Towers
Definitive Technology Mythos Three Center
Definitive Technology Gem XL Surrounds and Rear Surrounds
Klipsch Reference Sub
Here’s the problem. That super-expensive SC-35 is useless if I want to do the 4K/60fps gaming. So if I am going to go with the 295, I need some suggestions on a new receiver to get. I learned my lesson with the SC-35, I am NOT going to spend another 1.5K on a receiver for it to be way out of date a couple years down the line. I would rather get something cheaper and expect to have to upgrade it every once in a while. Anyway, suggestions are welcome. Thanks all.
Haacksta is offline
post #936 of 956 Old 01-31-2020, 04:27 AM
Liked: 0
Haacksta
Marantz SR5014
https://www.us.marantz.com/us/Produc...oductId=SR5014
Have you considered this receiver?
Perhaps it will suit you
Zel41 is offline
post #937 of 956 Old 01-31-2020, 04:33 AM
Brian Hampton's Avatar
Quoted: 1563 Post(s)
Liked: 997
. I would appreciate any input anyone might have, especially if you've had a EluneVision screen. .
Hi,... I just have 1 bit to consider. I have a 285 and always ran a 16/9 screen until someone on this forum one day was getting rid of a 2.40/1 screen.
I started using it and then put some curtains so it's very easy to make it into a 16/9 screen so my kids don't have to think about Aspect Ratios and stuff to watch things.
When I want to watch a movie shaped movie like Jaws, all I do is open curtains and zoom to fit and it's so worth it.
When I had 16/9 I tried several masking systems but having just some simple Walmart black curtains to slide back is by far the easiest.
All this doesn't matter if you are width limited but if not I personally would consider a 2.40/1 screen. The 285 doesn't have lens memory and I don't think the 295 does either but it's still easy and worth it. (my opinion )
-Brian
mnieto and Archibald1 like this.
Brian Hampton is online now
post #938 of 956 Old 02-01-2020, 06:46 PM
mnieto's Avatar
Quoted: 28 Post(s)
-Brian
Thank you Brian! That's great advise. Anyone else want to help a dude out and chime in?
mnieto is offline
post #939 of 956 Old 02-02-2020, 09:56 AM
Haacksta's Avatar
Originally Posted by Zel41 View Post
Haacksta
Marantz SR5014
I ended up finding an amazing open box deal at Best Buy Magnolia on an RX-A1080 Yamaha for $600.
Haacksta is offline
post #940 of 956 Old 02-02-2020, 12:01 PM
ragged's Avatar
Quoted: 68 Post(s)
Liked: 39
Anyone using this PJ with YouTubeTV? Trying to get a calibration setting that works with sports. Been messing around with the settings but not having any luck, it's still blurry on games.
ragged is offline
post #941 of 956 Old 02-03-2020, 06:44 PM
mylopr's Avatar
Quoted: 17 Post(s)
Hi Team.
Just wondering if that bottom left portion on the pic is because of the 295ES not properly mounted or is it a convergence issue. The entire TOP portion of the screen looks good is just that bottom part.
-JJ
mylopr is offline
post #942 of 956 Old 02-03-2020, 06:52 PM
m0j0's Avatar
Quoted: 1019 Post(s)
Liked: 1344
I have a Stewart Cima Neve 115” 2.35:1 screen and absolutely love it!
Mod edit: Per forum rules, please leave street pricing out of posts in the tech forum
m0j0 is online now
post #943 of 956 Old 02-05-2020, 09:57 PM
Matt Helander's Avatar
Quoted: 95 Post(s)
Liked: 61
Hey Guys - Just got my 295es! Really loving it.
One quick question on setup - when using the lens shift and zoom to fill the screen, there are several lines available, which I understand corresponds to the aspect ratio of the screen.
ANYWAYS - my screen is 16x9 so I lined it up correctly, but there are lines overhanging the screen. I haven't noticed this in a movie, but if you look at the 2nd image of my PC - it uses the entire screen even outside of the 16x9 area. Is is there setting to tell the projector I have a 16x9 screen?
Matt Helander is offline
post #944 of 956 Old 02-06-2020, 03:34 AM
Archibald1's Avatar
Liked: 1298
The lamp based Sony's exhaust from the front left and right and intake from around the lens and the rear, so there are vents there, yes.
Stephen Hawking.
post #945 of 956 Old 02-06-2020, 03:42 AM
Archibald1's Avatar
Liked: 1298
Hi.
Line the image up as per the attached picture for your 16:9 screen and set your PC to 3840x2160.
If you use 4096x2160 for the PC you will always get that overspill unless using a 17:9 screen.
Also, FYI, 3840x2160 gives all motionflow options etc, whereas 4096x2160 only gives impulse.
Name:	picture alignment pattern 16_9.jpg
Stephen Hawking.
post #946 of 956 Old 02-06-2020, 07:43 AM
badchad65's Avatar
I'm also considering aspect ratios and have concluded it's mostly a toss up. I watch entirely mixed content ranging from standard 16:9 to 2.35 movies and the odd 1.85-2.0ish formats that seem to be getting popular on streaming services. It's really a matter of where you prefer your letterboxing. I think I'm going to go with a 2.35 because much of the 16:9 content I watch is TV, so the "smaller" letterboxed 16:9 image may be a bit more crisp. In addition, it seems likely I'll watch most of my 16:9 TV on an adjacent upstairs set reserving the 295 for "movies."
Polk Fronts: RTi A7's
Polk Center: CSi A6
Polk Surrounds: FXi A6's
Polk Rear Surround: RTi4
Sub: HSU VTF-3 (MK1)
AVR: Yamaha RX-A2010
B&K Reference 200.7
TV: Sharp LC-70LE847U
badchad65 is offline
post #947 of 956 Old 02-06-2020, 07:48 AM
badchad65's Avatar
Anyone have a preferred mount?
I was all set to go with the universal Chief Mount, but then I found this mount on Amazon: http://www.amazon.com/PCMD-LLC-Projector-Compatible-VPL-VW270ES/dp/B07H7PT633
I don't really care that it's cheaper (though that is nice), it just looks WAY simpler than the chief. I'm a projector noob so simplicity is appreciated. I called Sony and they no longer have a "recommended" mount. Any thoughts?
Polk Center: CSi A6
B&K Reference 200.7
post #948 of 956 Old 02-06-2020, 07:56 AM
Mike Garrett's Avatar
Quoted: 13152 Post(s)
Liked: 10790
You do not need 15'-3" of throw for a 108" diagonal 16:9 screen. The throw range for that size screen is 11'-5" to 23'-4". What is your viewing distance? As for checking the projector. Set on a table or bench 8' to 15' from a wall. Connect a source to the projector. Turn on projector and adjust image size and focus. Watch some content and see if you see any issues.
Mike Garrett is online now
post #949 of 956 Old 02-06-2020, 09:56 AM
Quoted: 95 Post(s)
Liked: 61
Originally Posted by Archibald1 View Post
Hi.
Perfect.
As far as for movies. Last night I noticed when the projector was on but not displaying anything - i still see a bit of light both left and right of the screen, as in the other photos. Is there just no way to completely eliminate that overspill without a larger screen border?
It's not dramatic and i'm probably the only one to notice it - but i do notice it. Never really had that issue with my UHD65, and this is only my 2nd projector so i'm still quite new to this.
THanks!
post #950 of 956 Old 02-06-2020, 11:01 AM
Archibald1's Avatar
Liked: 1298
Perfect.
THanks!
The panels on these are 17:9 and when no video signal is being received the light inside it still comes out of the lens a little. It is coming from the full panel width and thus without bigger borders there really is nothing to be done about it.
It is totally normal.
As to the UHD65, that isn't native UHD, let alone 4K DCI like the Sony and thus you wouldn't get this effect, as it was jiggle 4k on a 16:9 panel.
Stephen Hawking.
post #951 of 956 Old 02-06-2020, 12:37 PM
Quoted: 95 Post(s)
Liked: 61
The panels on these are 17:9 and when no video signal is being received the light inside it still comes out of the lens a little. It is coming from the full panel width and thus without bigger borders there really is nothing to be fine about it.
Ok - Makes sense - So that's just the way it is. Thank you!
Archibald1 likes this.
post #952 of 956 Old 02-06-2020, 12:44 PM
m0j0's Avatar
Liked: 1344
You can turn blanking on and then adjust the blanking for top, bottom, left and right independently to get everything to fit on screen perfectly.
m0j0 is online now
post #953 of 956 Old 02-06-2020, 03:07 PM
Archibald1's Avatar
Liked: 1298
One more thing I have noticed is that your image does not seem in any way square on your screen.
Make sure your PJ lens is parallel to the screen and it is level on both axes to start.
Then line up the upper line of the zoom pattern with the top inner edge of your screen border and then zoom so the left and right sides are about 1cm equally inside the border of your screen and then take your time to get all sides square to the border.
Once done, use the PJ controls to zoom the pattern to the point shown on my last diagram (16:9) and then use the lens shift to fine tune the top and bottom of the pattern.
Hope that makes sense.
Cheers.
Stephen Hawking.
post #954 of 956 Old 02-10-2020, 02:43 PM
Quoted: 95 Post(s)
Liked: 61
Thanks guys - I got it straightened out and some how totally missed the blanking in the manual.
m0j0 and Archibald1 like this.
post #955 of 956 Old 02-10-2020, 04:51 PM
Quoted: 579 Post(s)
Liked: 588
https://www.amazon.com/Projector-Cei...1378542&sr=8-2
This is also a solid choice.
kaotikr1 is offline
post #956 of 956 Old 02-13-2020, 08:43 AM
Schurter's Avatar
Quoted: 56 Post(s)
Screen recommendation 140inch
Probably 16/9
Might goto 150'
Space will be dark
Light control.
Open to ideas on placement of the projector.
White
Grey
Alr
What gain.
Schurter is offline
